Skoda Superb AFS problem
Both a dealer and VCDS can disable travel mode, it's just an adaption channel in the AFS master/range controller.
If travel mode is enabled, you'll have an obvious fault code stored.
  • 1 year later...
On 08/07/2020 at 06:56, Phil-E said:
It's probably easier to code it show that it shows up in Maxidot and you can just change it from there. I'm not sure how to do that I'm afraid. But most likely under instruments.
I have fault code of 02988 which is left right switchover active. I tried to dissble tourist mode via vcds but it wont let me because in the area of parametres it shows security access required even if I enter security code. My friend told me that coding could be done only via VAS 5054 diagnostic and I visited official skoda dealer and they told me they have this one.
