Citygo 1.0 automatic not starting.
Hi.  My citygo just will not start.  No previous issues.  All lights turn on. Tried second key. Just jump leads. It's fuel tank is full.  Just doesn't crank. Any suggestions as to what could be causing this?
  • Sponsor
Check earth connections, I think there's one near the offside engine mount that causes trouble on these when it corrodes/breaks.
If that seems OK, look for a broken wire going to the starter motor solenoid (thinnest wire going to starter motor).
Do these cars use a "neutral position switch" on the selector lever like other automatics? It's a common failure point...
My manual only starts if I press the clutch pedal, but do you have to press the brake pedal on your automatic car (some autos require this)? If so, check the brake lights come on and off and if not, check the switch on the pedal.
They have d n and r. Thats it.  Its in n and has to be started in n with foot on break.  Just doesn't seem to react when you go to crank it.
If you just turn on the headlights are they dim, and just go dimmer.
Dead Battery.
Jump leads not strong enough from the vehicle providing power to the dead battery.
Dead Battery.
I will check this thanks.  The car providing power had a new battery itself.  I don't think its battery related.
If not Battery related, and not Key / Battery / Immobiliser related then likely the 'N' switch immobiliser.
Is the car out of Warranty & Skoda Assist cover and do you have no Breakdown / recovery cover?
Is just under 3 years old. It's second hand. What is the n switch immobiliser? Thanks
Is there Skoda Assist available then if just Under 3 years old ?
Like on an Automatic that can only be started in P or N, or with the brake pedal pressed, there will be an inhibitor that requires the stick to be in N with the ASG.
It's in n. When I turn key with foot in brake everything comes on except the engine.  Not a sound from it.
Which might mean a fault at the inhibitor switch not recognising that it is in N.
Thanks. I'll check this out.
A faulty neutral position switch (if these have them) will just stop the engine from starting. Everything else would work...
They are normally found under the main body that contains the selector lever, so you may need to pull a few bits off to find it. It's just a small microswitch that indicates to the ECU that you are in neutral and thus safe to start. Sometimes the NPS is under the car body if the selector lever exits the underbody, and if so, they tend to fail more often for obvious reasons (external = possible damp ingress).
As I said before, if you normally have to hold the brake pedal to start, check your brake lights work - this will prove that the microswicth on the brake pedal is working. Or not.
Edited by freemansteve
Thanks. I'll check this.
By process of elimination it would seem to be the nps. I'm taking it to a garage.  Any of you know roughly what it would cost to repair this?
@Godfrey
Is that the neutral position switch?
The car is under warranty if under 3 years old, it could possibly cost you nothing if a premature failure due to a design, materials, or manufacturing fault.
Do not be too keen to go paying for a diagnosis and then the part and labour/VAT.
Yes, the NPS is a possibility, but I wouldn't jump to firm conclusions just yet!
In any case, the VAG ASG is a very unusual design compared with most automatics, and the NPS idea is just a theory as most of us have manuals, and many like me have never even seen an ASG (but I have had plenty of automatics).
I echo the above in that if the car is "just under three years old", don't waste time and get to a dealer before the warranty runs out! (I think it is 3 years, and being second hand is probably irrelevant)
Thanks.  I'll update you all with the final diagnosis
By the way they call it robotic gears and they are not the vw standard tsg
Yes the ASG is a single clutch Automated Manual so the Automated-Shift Gearbox,
rather than a twin clutch DSG.   Direct-Shift Gearbox.
Exactly. That's what makes it unusual. Loads of DSG twin-clutch variants, and loads of slush boxes out there!
  • 2 years later...
Hi everyone my mums automatic citygo is doing the exact same thing as godreys automatic.
Did anyone resolve this issue thanks
Dunno. People don't always do more than ask questions, so once fixed, they are often silent....
Make sure the battery is tip-top, as the first thing.
>5 years old, change it, but if not disconnect and reconnect to power-reset all systems.
Then check switches in gear selector.
Then consider solenoid actuators.
Thanks mum mums car has been in the skoda main dealers for 2 weeks and so far the battery and starter motor have been changed also checked to see if its a bad earth but still will not start.
Before we took it to the garage sometimes I would use jump leads and another car and sometimes it would start and be ok for a few days then other times it wouldn't start.
Her car is the same to start you have to put it in neutral and put your foot on the brake.
Skoda called me today and said they think it might be the gearbox but I don't think it can be that cause when it does start it drives fine.
It is the ASG sort of if it is the Inhibitor switch.
Have they actually tested that?
