Tyre advice needed ASAP
Hi guys, noticed a split in my front driverside tyre this afternoon. It goes up the tyre wall and not in to the tyre. Very weird. The tyres currently fitted are Continental 215/35 ZR18 84Y XL ContiSportContact 5's.  Would it be advisable to stick to these Contis? or could I fit a different brand on the driverside? Needing to buy a new tyre has just come at the wrong time. Thanks guys.
img%5D
You could fit what you want but I'm personally a sucker for matching tyres. I've found the Continentals on my Octy really comfortable but on the, now-former, Fabia (and Mx5 before it) I had Kumho tyres all round and found them excellent.
The issue with different tyres is that some cars are pretty sensitive to different tread patterns etc. I'd imagine for a small, FWD car that it wouldn't make any huge issues.
Before rushing off to get fresh tyres, I would consult an expert as that small split may not be illegal/dangerous. Furthermore I would concur with Benz re the Kumho tyres as Continentals are very expensive these days. There is a tyre review site which I have used in the past which is quite informative, here it is:- https://www.tyrereviews.co.uk/
To add to the above, that crack is on the edge of the rim protection area, and might just be due to that tyre having "kissed" a vertical surface quite firmly - but only you could judge that from its appearance close up.
Edit:-as always, if you are in doubt, use common sense and default to replacing.
Edited by rum4mo
15 hours ago, onedaymyfriend said:
noticed a split in my front driver side tyre
Impact damage normally.
The Conti has an extra rubber kerb rim protector bump strip. ( which might have done its job )
Can you see any white cords showing inside the split?
215/35 ZR18 84Y XL
I would guess that this is a tyre from the OP's Superb and not the Fabia.
Thanks AG Falco
Thanks AG Falco
No cord showing, these tyres came with the Fabia MC from new not the Superb. 🤔
Tyres getting bigger again then. Was that a standard or optional size wheel/tyre?
How deep does it go?
Any bulges?
Thanks AG Falco
I’m gonna check this, but I believe any crack over 25mm Long is an MOT failure regardless of cords showing or not..... will update this once my Mac has updated and I can access the material
I was always going to replace the tyre, was just considering putting a cheaper tyre on the driverside.
I believe the wheels were an optional extra.
Some people might want to use some vulcanising glue in the split.
It need to be glue that stays flexible when it dries - tyre puncture repair glue.
It helps if the wound is compressed when the glue is drying.
Thanks AG Falco
I did that to a very small impact damage on a tyre on my daughter's previous car, there had been a comment in the MOT - so I glued it back down before it git ripped off, in that case there was nothing but rubber at the "base" of that crack/tear so after checking and cleaning it properly I glued it with a suitable rubber glue, I've forgotten which type/brand - and applied pressure "somehow" for a few hours, again forgotten how.  Next MOT, no comment.
Thanks guys, replaced the tyre like for like and managed to save £40 only (Ha! Only!) paid £146 all in.
It would appear that the tyre place have replaced the TPMS sensor for a standard one. Fml, what next. 😩
Scrap that, I'm almost 100% sure that the Fabia has an indirect system. That could've been embarrassing.lol
  • Sponsor
Yes, indirect.
