Skoda Superb Interior Background Lighting
Hi,
I've search all through this forum, the VCDS posts, rosstech Forums, Vag forums but had no luck.
Can anyone please give me the procedure to increase the brightness of the ambient light strips on the doors and dash of the Superb 3.
I know it can be increased as when you open the door at night you can see all the strips get brighter as you leave and dim back when you close the door.
I have the max brightness set in the infotainment but cannot find anything anywhere or in Obd11.
Cheers.
You don’t need VCDS etc. It’s done through the infotainment screen
Vehicle > Settings > Background Lighting > Brightness Button (bottom R.H. Corner of screen) > select area "ALL" > Slider appears at bottom of screen
Hey, I mean like even outside of that. Even set at its brightest in the infotainment it's not really bright. It just looks pale.
And when the doors open you can see the strips swell in brightness and dim back to the infotainment setting once closed
