1.2 htp 2008 misfire possibly? Help.
  • Sponsor
Looks like that cylinder has had a loose spark plug in at some point, judging by the debris on the thread.
What do the other two look like?
5 minutes ago, yaz0811 said:
So I've replaced the spark plugs with new ones, just took this one out of cylinder 3, is that how they are supposed to be?  After 1 day?
No, that's running really rich, if the other two look the same then replace the ECT sensor and if that doesn't help replace the precat lambda probe.
Could it be a faulty TB?
All three are similar
  • Sponsor
Possible but very rare thing to have trouble with.
Can you do a compression test?
Any idea what sensor is this?
  • Sponsor
Oil pressure switch.
If I disconnected that shouldn't the oil light come on the dash?
  • Sponsor
Only if the engine is run at >1500rpm for a while. (Possibly with bonnet closed too).
Edited by Wino
Thanks, I don't that's the issue, is the ect sensor in the thermostat?
  • Sponsor
Yep, sticks out towards battery.
Could be timing related as my mum had the 1.2 htp and the timing chain jumped a tooth twice on two separate chains eventually killing the engine
