1.4 mpi 8v timing chain....help!
Ok mate no worries thanks 😁
  • Replies 54
  • Views 9.7k
  • It's impossible to get the cam timing wrong (doesn't matter if it's been turned 360 degrees) as long as there are 12 chain pins between the dots on the sprockets as it shows here...   https:
  • No probs at all   Yeah, the sumps are stuck on with sealant. As you say, it should be fine as the sealant should fill any slight unevenness.
  • Sounds like you want to put something like this on your Christmas wishlist: https://www.amazon.co.uk/Sealey-AK7301-450mm-Breaker-Silver/dp/B000WZABDO/ref=sr_1_6?dchild=1&keywords=breaker+bar&q
I've been through the whole procedure so just ask if you need help/advice :)
Edited by TMB
Great many thanks 😁
Oops, posted on wrong thread. I mean for the head gasket.
I was just reading that actually. Funnily enough was reading through the procedure in the Haynes manual last night in case it ever needs doing. It doesn't have the Temac gasket on it so will probably go at some stage. Doesn't look as difficult as the timing chain from reading the manual.
