Some bare wires and bad connectors in poor conditions
  • Sponsor
Some photos of the normal arrangement here SKODA FABIA 04 FUSE BOX 6Q0937550F | eBay
Thick red wire connects battery positive clamp to underside of fusebox , black wire coming off same clamp goes to starter motor.
As long as the connections at your battery positive clamp are OK, (they still look a bit 'rough') and don't get hot. it's probably not worth changing it again.
That fuse panel is normally hinged onto the battery box, and has a cover over the top. You seem to be missing most of these parts, so be careful! Check that the downwards-pointing stud where the red (green now on yours) cable normally connects cannot touch battery negative post or any other metal if that fuse tray moved around.
  • Replies 78
  • Views 10k
  • Happens a lot here !!
  • yes yes it does make sense, i got it, and yes i found 1 2 3 in the other side too, i wil make sure it hass good contact with some contact cleaner and some adjustment, thank you!
  • Massive current drain sounds like the PAS pump might be running when it shouldn't. That would affect the idle and the voltage.
excellent.
i will use that for referece, ill see if i get that box to complete the job  later.
Regarding the cut wire, yes i will fix that in another round, probably in January.
one thing to do, the problem is almost gone, i say almost, because in some moments the problem is back, but only for 20-40 seconds, for example, yesterday i was all l the day out, and wen parking the car at home i did notice the issue, but it feels like if something was causing that big draw of current.
The problem is back, like if i woul have done nothing, a little bit less severe
  • 2 months later...
the problem is there yet, any suggestion?
