Rear coil spring (1 blue 1 yellow) part number needed to replace on a 1Z5 2010 Mk2 Octavia Vrs Estate
Hi everyone and happy new year.
I bought 2xkyb rear coil springs to replace mine but they are not correct giving a massive wheel arch ride height .
Going around in circles on the net so thought I’d ask you all with the knowledge
btw it’s a 2.0 Tfsi Petrol if that helps
OEM number: 1K0511115BR
Build code: PR-1JC+0YD
http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2010/drive_standart/663/hg_ug/511/subcategory/511021/part_id/2561497/lang/e
What part number are the KYB rear springs?
Edited by Carlston
Ahhhh legend!! I had every other last 2 letters on that part number but the one you have just shown me!!
Thank you very very much-can get this suspension overhaul finished and 4 wheel aligned at last!
Sorry Carlson ,just seen the bottom of your message
the kyb rear coil spring parts I had delivered and have fitted just one of so far are :-
RH7021
confusing as that’s where I was lead via previous  part number catalogue but they are huge in ride height
 the kyb rear coil spring parts I had delivered and have fitted just one of so far are RH7021
KYB RH7021 are supposed to match 1K0511115BT which are very similar to 1K511115BR.
Your coloured dots shows that you have 1K511115BR but some online catalogues suggest 1K511115BS or 1K511115BT.
Can you measure the KYB RH7021 that you haven't fitted to see if it is even close to the specification that these OEM numbers should have? Sometimes sellers put the wrong spring in the box, so maybe that is the case and it's not actually 1K0511115BT.
Order OEM 1K0 511 115 BS SPIDAN 86744 Coil Spring in top conditionCoil Spring 86744 — current discounts on top quality OE 1K0511115BS spare parts
Product info:
  • Fitting Position:Rear Axle
  • Spring Design:Coil spring with constant wire diameter
  • Length [mm]:330
  • Thickness [mm]:11,75
  • Diameter [mm]:112
  • Weight [kg]:1,85
  • Item number86744
Reference number OEM:1K0511115BS
Show OEM numbers of the product
Edited by Carlston
Yep I’ll pop out to the garage now.... still going round in circles here on the net anyway!!
Back in a mo
thank you
Back in a mo
thank you
1K0511115BS and 1K0511115BT rear springs should be similar to these specifications.
Length 330mm
Thickness 11.75mm
Diameter 112mm
Weight 1.85kg
KYB RH7021 is sold to replace OEM number 1K0511115BT.
However, In the KYB range I would have chosen KYB RA7102 because it is sold to replace OEM numbers 1K0511115BR and 1K0511115BS.
There seems to be a problem though, because you should notice very little difference between these OEM part numbers.
Edited by Carlston
Right.Old spring(blue/yellow) is 32.5ishcm
new kyb 7021 is 33.3ishcm
Only reason I bought new rear springs was mechanic fitted new Bilstein B4’s front struts and a white line rear arb for me,since then the front passenger side is higher...
so I bought new rear springs and Bilstein B4’s rear shocks of which I have fitted one of each on the rear drivers side today and it looks ridiculous
measured the springs this morning before fitting and didn’t think there was much in it...
really appreciate your help here sir
In the past hour I’ve been looking at KYB 7201 as you have just suggested, looking up the specs etc there is nothing in it unless its the diameter of the actual spring ??
other option was Bilstein b3 coil springs or Kilen but I was sure I got the right parts in the 1st place and don’t fancy forking out another £85 ish either
Kyb 7201i meant
Sachs claim 326mm for their 1K0511115BR replacement, so your old spring measurement of approximately 325mm is near enough spot on.
New KYB RH7021 at 333mm is only 3mm more than Spidan/Suplex give for their 1K0511115BS and 1K0511115BT replacement, so again almost spot on.
It doesn't look like the new springs are the problem, if the KYB that you have fitted is the same as the one you have measured.
Edited by Carlston
Kyb 7201i meant
I think you mean KYB RA7102 which is sold to replace OEM numbers 1K0511115BR and 1K0511115BS.
The problem won't be the diameter of the spring.
Edited by Carlston
That.Is great news.I think I may have to go back to the drawing board and strip out/start again and fit both tomorrow
on hindsight I should take a proper gander at the mechanics front strut fitting and high passenger side......
as my rear original rear springs look fine-
just thought to rule it out and I was fitting new rear shocks myself anyway
really appreciate all of your help tonight
a happy new year to you
Just measured ride height all around
( I’ve a new baby so have to do car stuff when I choose to ignore the wife)
mid wheel cap to too middle of wheel arch ...
Front passenger side new b4 strut over 40cm,
front drivers side new b4 strut about 40cm
rear passenger side with old spring and shock still fitted- about 40cm
Rear passenger side new kyb spring and new b4 shock almost 43cm!
The whole car looks like a 4x4 !!
something is very wrong ....
Fit the other rear side, take it out for a short drive, and measure again!
Ok sir I will deffo do that- I can stop looking at bloody springs thanks to you!
Tho I understand it should be a stock ride height of 370mm front and 365mm ish back so it has a lot  to drop to do for a vrs estate mk2 from my 400mm + ......
Thanks again Carlston.
So I have taken your advice and went ahead and fitted the other new rear kyb 7021 coil spring (although the originals looked fine) when fitting the new rear Bilstein B4’s.
The car now sits very solidly and the ride height has evened out.Still a little high but not Tractor high!
I have taken the car for a 50 mile mostly motorway drive today.It feels planted, no squeaks or groans at all.
I have read it good to leave new suspension to settle for approx 300 miles/1 week until getting it 4 wheel aligned so looking forward to that with the Whiteline rear Arb also fitted and car is remapped to a modest 220 bhp.
Many many Thanks for your knowledge and replies to me and I wish all on here a Happy New Year.
On 03/01/2021 at 23:03, Nexus21 said:
Apart from just getting a 4 wheel alignment and STILL sitting high after myself fitting the new rear Kyb springs and Bilstein B3 shocks.
The front passenger spring is 3 pink and 1 red dot and front drivers side is 3 red dots.
I cannot find the correct part numbers/ dot colours in catalogues/eBay etc needed to finally sit my mk2 facelift 2.0 tfsi estate the way it is supposed to.
In the Skoda online parts catalogue, I can't see any front springs with either 3 pink dots and 1 red dot, or 3 red dots.
Are these two front springs what was on the car when you bought it? eg. they're not KYB springs.
Do you mean Bilstein B3 or Bilstein B4 shocks? I didn't think Bilstein did B3 shocks only B3 springs.
Edited by Carlston
Yes sir, that’s what came on the car.I am baffled too!
Been looking for hours.Just seen your post reference part number for petrol manual estate vrs mk2 200bhp (1z5) but I am still confused as when I input that part number,says not compatible for my car!
Front Passenger side....
And front drivers side is 3 red dots.....
gknautomotive lists OEM part number 1K0411105DA as being suitable for the Skoda Octavia MK2 RS 200HP
gknautomotive 1K0411105DA front spring
https://web.tecalliance.net/gkn/en/parts/1/56843/detail?targetType=cars&targetId=19459&typeNumber=19459&groups=188#@brc/brands:Car;targetType:cars;mandator:gkn/assem:SKODA%20OCTAVIA%20II%20Combi%20(1Z5)%202.0%20RS;targetType:cars;mandator:gkn;targetId:19459;typeNumber:19459/lnkparts:Coil%20Springs;targetType:cars;mandator:gkn;assemblyGroupId:100113;targetId:19459;typeNumber:19459;groups:188;brands:1;pf:2;page:0/detail:56843;brandId:1;articleNo:56843;mandator:gkn;targetType:cars;targetId:19459;typeNumber:19459;groups:188
Spring Design Coil spring with constant wire diameter
Fitting Position Front Axle
Thickness 12,25 mm
Length 315 mm
Outer diameter 137 mm
Weight 1,75 kg
Suspension for vehicles with sports suspension
Transmission Type Manual Transmission
1K0411105DB front coil spring Is for an automatic estate as heavier front end
1K0411105DA is for a manual estate
As I say I’ve just found your info but I am baffled as of the correct dot colours on there and what I actually need ......
Also 1K0411105DA is saying incorrect/won’t fit my vrs estate
Very weird indeed
Bloody gutted the new mechanic I paid £365 for labour only to fit my new front Bilstein B3 struts and top mount/bearing kit plus Whiteline Rarb didn’t point this out,before I myself fitted the rear B3’s and new springs then a 4 wheel alignment and it STILL looking like a tractor!!
Just hoping this helps some other folk in the future
Sorry just seen end of your post Carlston,I meant B4 struts and shocks I’ve been looking at suspension part numbers for way too long!!
Thank you very much indeed for your help again Carlston
