MY17 Superb Retrofitted with Direct TPMS
Is the control unit still responding via diagnostics? If not, buy an OEM part.
  • Replies 151
  • Views 39.6k
  • It depends what system your wife's car has. Indirect systems don't have physical pressure sensors, instead they rely on rotational differences between the wheels (via the ABS sensors) so would just ne
  • We can now, thank feck
  • I'll post up the exact VCDS/OBDEleven coding steps shortly. I'll also post up the link that allows u to create the RDX parameter file, to b loaded via VCP/ODIS.
Check your sensors. If you can connect normaly to 55 module, your sensors died. Aswell had problems with faulty module and sensors from ali since get one which works
