Upgraded Clutch GB (PD130)
Right chaps,
I've been speaking to Jabba Sport and they would like to sort us out with a GB on the above.
There are a following options which are as follows.
(1) Sinter Friction Paddle and pressure plate rated upto 510nm (374lb/ft):
Supplied £363.00
Fitted £574.50 @ 4 hours labour*
Fitted £627.50 @ 5 hours labour*
(2) Organic Friction Disc and pressure plate rated to 350lb/ft (will confirm this shortyly):
Supplied £465.00
Fitted £676.50 @ 4 hours labour*
Fitted £729.50 @ 5 hours labour*
*Labour charge varies due to age and mileage of vehicle.
Now this is the even better bit, Jabba will tweak their customers current remap free of charge to take advantage of the new clutch. There should be an extra 25lbft torque between 1.8k to 3k rpm.
Not to mention the main advantage that this clutch will allow you to make the most of what you already have!
If you choose to have the clutch fitted without a current re-map Jabba will give you a 10% discount on a custom remap £382.50 (instead of the £425)
I'm working with Jabba to get you Octavia vRS boys n girls a deal on a upgraded clutch will update you asap.
The usual retail price is:
(1) £427.99 inc VAT plus fitting
(2) £557.19 inc VAT plus fitting
The target on this is 10 people.
This is for any FWD PD130 with a 6 speed box (i.e. Seat Ibiza 130TDi, skoda Octavia 130TDi) if in doubt if it will fit your car then please PM me.
  • Replies 72
  • Views 6.6k
Right chaps' date='
There are a few options which are as follows.
(1) Pressure Spring Plate and Paddle which will cope with 376lb/ft easy and
possible upto 400lb/ft
(2) Pressure Spring Plate and Organic which will cope upto 350lb/ft.
Price are to be confirmed but the usual retail price is:
At the moment it's looking like a 10% but this could change depending on interest.
Fitting will be about £211-£264
More details to follow, for the moment this is just to gauage any interest from you guys.
Start a list as usual or PM me if you have any questions.[/quote']
Mike,
see if Nick can included clutch upgrades for Octy RS/PD130 as well...might pull in a bit more interest as well.
Who manufactures the clutches??
The clutch is made by sach.
The 130PD octavia with 6 speedbox will be the same as the fabia's. The Octavia RS can be catered for if anyone is interested in this (prices and specs to follow).
I've got just the basic details at the moment but should have some confirmed prices and specs very soon.
If in any doubt if your car is/isn't cover then just drop me a PM.
Sorry to be pedantic, but is option 1 guaranteed to 376lb/ft ? I know they had issues before but that was some time ago and there may have been developments since then. I am certainly interested if that is the case.
Derek
derek,
That is what sach have rated them to (well 510nm which works out to about 376lb/ft). The paddle plate isn't too harsh (i.e. it's not on/off like some).
Just to add the clutch it's self will not give you 376lb/ft but allow with further mods to possibly reach that amount of torque.
For the fabby owners out there wanting to gain big power, this would be an ideal starting point, even though it will not add any power to your car it will allow a re-mapper to get the most out of your re-map.
Yeah baby!!!!
Count me in. Not sure which one to go for as yet, but pushing out around 310lb ft at the moment & definately need an upgrade.
1. Jon TDI
Organic Friction Disc.
Is it correct that, although the sintered clutch can handle more torque than the organic one, it does not last as long??
Jon,
I will try and find out for you. nick did say that even though it's a paddle type it's not on/off like most on the market it's very progressive (I think that was the word :o )
Been informed it will last just as long as the organic one, the main difference is the organic one has more of an OME feel to it.
Would this fit onto a 110TDi or are there different fittings?
Ta
which gearbox has it got 5 or 6 speed?
can anybody explain why the organic i.e. normal material clutch plate is more expensive than the sintered paddle type clutch plate ?
this late in the evening I'm guessing it's down to the fact that the organic one gives the nearest feel to the standard clutch.
Would have thought there would be more interest than this!! :rolleyes:
Right I've just got back from Jabba Sport.
I've tested the paddle clutch on it's very good indeed. Slightly heavier than the standard one but it more a makes up for it in feeling and responce.
You have even more feel than the standard one, gone is the spongy feel.
If you've got a remapped fabia then you will want this!
Pictures of the paddle clutch
Sounds good.
I think I'll go for the sintered paddle clutch & pressure plate then. :) And free tweak! :thumbup:
Don't mind it being slighty heavier, as I'm the only one that drives my car anyway!
Jon, it does feel very good indeed if my car wasn't standard then it's what my money would be on ;)
This GB is open to other PD VAG cars, if in any doubt please PM me and I will find out for you.
Ibiza TDi 130
Polo (9n) TDi 130
Leon Tdi 130
Golf Tdi 130
Octavia TDi 130
Jon' date=' it does feel very good indeed if my car wasn't standard then it's what my money would be on ;)
Ibiza TDi 130
Polo (9n) TDi 130
Leon Tdi 130
Golf Tdi 130
Octavia TDi 130[/quote']
Does that mean you already have one fitted?
Might have friend with an Ibiza TDI Sport who'd be interested.
I think you'll find that Mike's car is as it left the factory ;):D
Mike,
open this up to CupraSi for the SE guys...I'm sure a few of them will be interested.
Did Nick give you any details regarding upgrade clutch for Octavia vRS?
Ah yes, I misunderstood Mikes' post! :o
Friend with Ibiza TDI Sport ain't interested, as his clutch ain't slipping now.:(
I have the organic one, Very recommended, onces its run in it feels very OEM. I have hybrid turbo etc and not a hint of slip.
spot on matey ;)
Mike' date='
Did Nick give you any details regarding upgrade clutch for Octavia vRS?[/quote']
Good idea will contact him about it.
Nick is still working on it, but in the mean time if anyone that has an octavia that might be interested in one, then please PM me.
Guest
