Virtual Cockpit Retrofit with Columbus and Canton
7 hours ago, deepshegde said:
Did you manage to get this working? I bought a connector with 1 male and 2 females and my audio isnt working at all...not sure if the splitter itself is faulty..i can see optic light and no issues with that but audio isnt working.
You probably have two arrows pointing each other rather than a continuous loop.
  • Replies 53
  • Views 19.3k
  • this should be the display config adaptations 5F ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps,OFF ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,On
  • I believe 3fh is for FL sportline,  Pre-FL spoline should be NY5: https://www.oemvwshop.com/3v0857053a-ny5-cover-for-instrument-housing-maze-black-skoda-superb-3v-p2263506/   I bou
  • The correct part is 3v0857053A  ( to use with virtual cockpit) the last letter A is very important , the next letters has to do with the color mine is NF8 (silver)
Ok it was exactly same issue ..fixed. thank you but i am unable to enable 5F adaptations for displaying maps...ODIS-E is giving "function not available" errors for some adaptations...
Have the same problem - no maps on vc
My vc no maps
My vc no maps
mib2 columbus 8”
