No RS Theme on Virtual Cockpit
As mentioned elsewhere I've recently retrofitted a virtual cockpit, all coded up and working with maps.
I've tried to activate the RS theme with no success. Using both the obdeleven app and setting the adaption manually (tube and display depiction set to version 3).
Anyone any clue (from searching I'm definitely aiming this towards @SashaGrace
26 minutes ago, SashaGrace said:
The SportLine has the RS theme as well. What is the full part number? Do you have the speedo end set to 160 or 180 mph?
Speedo end (called tachometer end value in obdeleven??) was set to version 0 (260kmph) but I just changed it to version 2 (280kmph)
