Fabia 1.4 tdi exhaust fumes in car when stationary
Got a 2010 Skoda fabia 1.4 tdi. I've noticed the past couple of days after starting the car there's a faint smell of exhaust fumes. The exhaust seems to be ok & not blowing.
The car passed an mot last Thursday.
I know I need to change the pollen filter but I don't think that  would prevent the fumes?
Is there anything else I can check? Any particular weak spots?
car seems to drive as normal with no apparent noises
I know before the mot I checked the oil. Is there supposed to be an O ring on the orange handle of the dipstick to seal inside the guide  tube? There doesn't seem to be fumes eminating from here,  but I'm just trying to rule it out
Thanks!
You say the exhaust isn't leaking but you obviously have an exhaust leak, you need to look at the manifold, turbo and EGR for leaks under the bonnet rather than from the exhaust system itself.
Thanks for the replies
Ill get my mechanic to put it up on a ramp to investigate the EGR & manifold etc
Theres no apparent exhaust leak sounds that I can hear in the engine bay & no obvious splits in hoses etc
I was just checking with the dipstick as I wasnt sure if I saw an O ring on the handle, but it does seem to seal snugly & isnt loose
Is it possible that you spilt some oil and what you can smell is this spillage gradually burning off?
I think the dipstick does have a little O-ring, mounted near the top end.
