Scan Results Help please
Hi guys kept getting traction control light coming on but it did not today infect I had no warning lights on but thought I would do a scan anyways and come up with some faults, had a lot of faults come up to do with the comfort module l got some contact cleaners and cleaned all the fuses relays and all the warning lights went out and it then started up fine again.
anyways still seem to have faults even though no warning lights on the dash.
scan below if anyone can help please, car is running great at the moment so dont understand the faults
Monday,05,April,2021,15:45:33:35642
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0 (x64)  HEX-V2 CB: 0.4543.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: TMBKE21Z788009343   License Plate:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 55 56 62 72 76
VIN: TMBKE21Z788009343   Mileage: 311870km-193787miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-021-BMM.clb
   Part No SW: 03G 906 021 SS    HW: 03G 906 021 AB
   Component: R4 2,0L EDC G000SG  1302
   Revision: --H07---    Serial number: SKZ7Z0G4311023
   Coding: 0000172
   Shop #: WSC 66565 257 00032
   VCID: 025C73D48807A2BB997-8056
4 Faults Found:
005658 - Glowplug for Cylinder 1 (Q10)
               P161A - 000 - Open Circuit
             Freeze Frame:
                    Fault Status: 01110000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 311829 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:11:10
             Freeze Frame:
                    RPM: 819 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.52 V
                    Bin. Bits: 00101100
                    Temperature: 5.4°C
                    Bin. Bits: 10110000
005659 - Glowplug for Cylinder 2 (Q11)
               P161B - 000 - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 311829 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:11:10
             Freeze Frame:
                    RPM: 819 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.52 V
                    Bin. Bits: 00101100
                    Temperature: 5.4°C
                    Bin. Bits: 10110000
005660 - Glowplug for Cylinder 3 (Q12)
               P161C - 000 - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 311829 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:11:10
             Freeze Frame:
                    RPM: 819 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.52 V
                    Bin. Bits: 00101100
                    Temperature: 5.4°C
                    Bin. Bits: 10110000
005661 - Glowplug for Cylinder 4 (Q13)
               P161D - 000 - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 311829 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:11:10
             Freeze Frame:
                    RPM: 819 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.52 V
                    Bin. Bits: 00101100
                    Temperature: 5.4°C
                    Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels:. 1K0-614-517-MK60AT.clb
   Part No SW: 1K0 614 517 AD    HW: 1K0 614 517 AD
   Component: ESP 4MOTION MK60-AT 0102
   Revision: 00H14001
   Coding: 0023170
   Shop #: WSC 73430 790 00000
   VCID: 698E4478957151E338D-803C
1 Fault Found:
01324 - Control Module for All Wheel Drive (J492)
            013 - Check DTC Memory - Intermittent
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1Z0 907 044 R    HW: 1Z0 907 044 R
   Component: ClimatronicPQ35 110 0402
   Revision: 00110021    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 45D6A8C8D9A95583FC5-8010
No fault code found.
Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-H.lbl
   Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
   Component: Bordnetz-SG     H54 2202
   Revision: 00H54000    Serial number: 00000005018991
   Coding: E18A0F130004100000110D000000000000087F065C000000000000000000
   Shop #: WSC 07894 067 57207
   VCID: 71BE2C18BDA1A92370D-8024
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 060607 022  0601
   Coding: 00055223
   Shop #: WSC 07894
   Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
   Component: RLS     250607 046  0204
   Coding: 00471077
   Shop #: WSC 07894
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1A3RTX
   Coding: 0020788
   VCID: 3D26C028B1791D43A45-8068
   Subsystem 1 - Serial number: 6332MSME184A620EG
   Subsystem 2 - Serial number: 6342MSME1C044D46G
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Component: J0527           036 0070
   Coding: 0002042
   VCID: 015E7CD88D01B9A380D-8054
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           002 0010
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1Z0 920 942 D    HW: 1Z0 920 942 D
   Component: KOMBIINSTRUMENT VD1 1612
   Revision: V1612036    Serial number: SKZ7Z0G4311023
   Coding: 0007402
   Shop #: WSC 11111 067 57207
   VCID: 392ED438A551216388D-806C
Address 19: CAN Gateway        Labels:. 1K0-907-530-V3.clb
   Part No SW: 1K0 907 530 L    HW: 1K0 907 951
   Component: J533  Gateway   H07 0052
   Revision:   H07 01    Serial number: 160607F2000472
   Coding: E9837F0E0002022303
   VCID: 3038E91C762BE02B3F3-8064
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554 L
   Component: Haldex 4Motion      0116
   Coding: 0000001
   VCID: 3634DF04944FCE1B65F-8062
2 Faults Found:
00003 - Control Module
            014 - Defective - Intermittent
02248 - Valve for Controlling Clutch Operating Angle (N373)
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VD1 1612
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MIN3.clb
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         006 1204
   Coding: 0000758
   VCID: 3828D13C9E5B386B773-806C
Address 44: Steering Assist        Labels: 1Kx-909-144-G2V2.clb
   Part No: 1K2 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   VCID: 3430E50C8233DC0B5BB-8060
Address 46: Central Conv.        Labels:. 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0204
   Revision: 00020000    Serial number: 00000000000000
   Coding: 81801A085283007F3F02050FC0085F96907C00
   VCID: 035276D0971DABB3921-8056
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008 4801
   Coding: 00000000
   Shop #: WSC 73430
   Subsystem 6 - Part No: 1K0 951 605 D
   Component: LIN BACKUP HORN H07 9001
   Subsystem 7 - Component:       NGS n.mounted
1 Fault Found:
01134 - Alarm Horn (H12)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 4
                    Fault Frequency: 20
                    Reset counter: 209
                    Mileage: 311813 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:00:10
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Coding: 0000758
1 Fault Found:
00121 - Outside Warning Light/Door exit Light Passenger Side
            012 - Electrical Fault in Circuit
Address 55: Headlight Range        Labels: 1T0-907-357.lbl
   Part No: 1T0 907 357
   Component: Dynamische LWR      0003
   Coding: 0000008
   VCID: 74B0250CC2B39C0B9BB-8020
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 1Z0 035 161 C    HW: 1Z0 035 161 C
   Component: Radio FO3       019 0040
   Revision: 00019000    Serial number: SKZ7Z3G0019189
   Coding: 0000402
   VCID: 2E04F7646C1FF6DB2DF-807A
Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
   Part No SW: 1K0 959 703 J    HW: 1K0 959 703 J
   Component: Tuer-SG         006 1201
   Coding: 0000144
   Shop #: WSC 73430 790 1012544
   VCID: 372AD200934537137E9-8062
Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
   Part No SW: 1K0 959 704 J    HW: 1K0 959 704 J
   Coding: 0000144
Address 76: Park Assist        Labels: 1Z0-919-283.lbl
   Part No SW: 1Z0 919 283 B    HW: 1Z0 919 283 B
   Component: Parkhilfe 4-Kan H04 0020
   Coding: 0000001
End----------(Elapsed Time: 01:20, VBatt start/end: 12.8V/12.6V)-----------
You can forget about the defective glow plug warning, save yourself a few seconds and just turn the key as you would a petrol engined car.  The preheat isn't doing anything and the car starts just fine.
If you wish to test each plug, remove the plug caps and test continuity between each plug and ground, you should see <2 Ohms for a good plug.
You can also check for power to the plugs by measuring voltage between the plug caps and ground.  You should see battery voltage when the preheat lamp is lit and probably for a short while after it extinguishes.
Since all 4 are showing a fault and they didn't before I suspect you have a broken connection somewhere in the preheat circuit (as a result of recent electrical disturbances) rather than dud plugs.
Assuming all the relays are good I can only suggest a painstaking continuity check between each end of the affected system's wiring especially as some show as intermittent possibly indicating connectivity issues rather than faulty components.
cheers MicMac do you know where the relay for them are maybe a good spray of contact cleaner might help
My manual doesn't cover your model but indicates 2 relays in the engine fusebox for the 1.9 & 2.0 PD/CR.
It shows an on-board power supply unit/Vehicle Voltage Control Unit (CCM?).
I believe that is what you previously disturbed and should probably look at again, clear all DTCs and rescan.
having read up a bit I think they may be a relay module under the battery
You didn't disturb that recently so don't go looking for problems, as I said non functioning glow plugs don't affect starting, at least not on my car down to at least -8C.
true but in a bit the traction control light will show up as well it was coming on before it cut out then all of a sudden after not doing anything and leaving it the car broke down with the same fault  numbers 0010 i,m just worried about it breaking down again
You need to consult your VCDS documentation to find out the meaning of Malfunction 0010.
I suspect it has something to do with the frequency/severity of the fault e.g. 0010 may mean intermittent and 0001 may mean permanent etc, I'm just speculating.
The traction control light is almost certainly due to the fault in the ABS module:
1 Fault Found:
Which in turn is caused by the AWD module:
2 Faults Found:
So at a guess, I'd try checking the fuse for the AWD module and possibly also replace the fluid/clean the filter. If it's not been done for a while it could be causing issues?
Rosstech's wiki for the 02248 error: http://wiki.ross-tech.com/wiki/index.php/02248
Hi guys thanks for the Info sorry for the late replay I have some disabilities and been pretty much bed ridden for a while but up and kicking again.
when I cleaned all the fuses and relays as in my last thread I never cleared all the faults so maybe start there?
Langers2k do you know where the  AWD module or the ABS module is and fuse number? I will go clean all of it as it does seem to help, I think my car has lots of bad connections cuz as I clean them things do seem to work better
apologies I have fibromyalgia and brain fog can be a pain at times
ABS module is probably below the battery tray somewhere. I believe the AWD module will be part of the haldex around the rear diff.
TBH, I'd be looking at the AWD module (it's more exposed) rather than the ABS module. Fuse number should be in the owners manual but I haven't got a WD for your car to confirm I'm afraid :)
thanks mate, yea I know there is a module below the battery tray somewhere, I will get to it  soon as I'm feeling with it a bit more, haldex? never heard of that before, it sure is a learning curve owning a skoda Octavia but its nice when you get it right and fix something yourself, if I had to pay a garage for every job I dont think I'd be able to have a car or my bike
Haldex are the company who make the coupling to transfer power to the rear axle :)
Useful picture of it here:
Has your haldex ever been serviced? It should have fresh fluid every 40k miles if I remember correctly.
If it hasn't, it could just be full of gunk which is stopping the valve working properly...
Edited by langers2k
I will have to check the service history, it had a full service history when I bought it and I dont do a lot of miles and had it nearly 2 years
There is a very good chance the PCB has got corrosion on it as the faults match this thread:
been looking it all up and found these photos and the vid on how to change the haldex oil and filter, nothing in the service book to say if it has been done or not, I could maybe let a few drops out and see how clean or dark it is?
No Ideal what Gen my Haldex would be
also take a look at this for corrosion
https://www.audi-sport.net/xf/threads/haldex-not-working-no-communication-etc-look-inside.142194/
Edited by sealover1
Apologies not been in touch guys I had more ill-health and been in and out of hospital, due to go back into hospital Thursday 20th may, Deep Joy.
my car problems all of a sudden stopped and so I got a new MOT and carried on driving but I think I knew it would not be for to long,
glow plugs light and Traction control light came back on again, but think some other faults are there as well, think 1 is the Rain and Light Recognition Sensor of which I had no idea it had one.
done a scan and these came up so as like I did last time I deleted them all and put the battery back on charge, a lot of it is due to I dont drive much and the car could be parked up for a while are I only drive it for a mile or so, what with covid and everything I have had nowhere to go apart from the hospital appointments. got two more this week I hope the car makes it.
could you take a look please see what you think? says all the glow plugs are faulty just seems strange they would all go at once maybe I should just change them there not that expensive are they?
Monday,17,May,2021,14:56:07:35642
www.Ross-Tech.com
VIN: TMBKE21Z788009343   License Plate: NX57GHB
Mileage: 312250km-194023mi   Repair Order: 1
VIN: TMBKE21Z788009343   Mileage: 312250km-194023miles
09-Cent. Elect. -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
   Coding: 0000172
5 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 311829 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:11:10
             Freeze Frame:
                    RPM: 819 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.52 V
                    Bin. Bits: 00101100
                    Temperature: 5.4°C
                    Bin. Bits: 10110000
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 311829 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:11:10
             Freeze Frame:
                    RPM: 819 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.52 V
                    Bin. Bits: 00101100
                    Temperature: 5.4°C
                    Bin. Bits: 10110000
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 311829 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:11:10
             Freeze Frame:
                    RPM: 819 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.52 V
                    Bin. Bits: 00101100
                    Temperature: 5.4°C
                    Bin. Bits: 10110000
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 311829 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:11:10
             Freeze Frame:
                    RPM: 819 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.52 V
                    Bin. Bits: 00101100
                    Temperature: 5.4°C
                    Bin. Bits: 10110000
000801 - Engine Speed Sensor (G28)
               P0321 - 000 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00110000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 312251 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 02:08:39
             Freeze Frame:
                    RPM: 1764 /min
                    Speed: 41.0 km/h
                    Load: 26.3 %
                    Voltage: 14.52 V
                    Bin. Bits: 00101000
                    Idle Stabilization: 0.0°KW
                    RPM: 882 /min
   Revision: 00H14001
   Coding: 0023170
1 Fault Found:
01314 - Engine Control Module
   Coding: 00055223
   Shop #: WSC 07894
   Coding: 00471077
   Shop #: WSC 07894
1 Fault Found:
01520 - Rain and Light Recognition Sensor (G397)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 215
                    Mileage: 311954 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        OFF
                    Voltage: 12.70 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
   Coding: 0020788
   Coding: 0002042
   Coding: 0007402
   Coding: 0000001
   Coding: 0000758
1 Fault Found:
00943 - Heated Exterior Mirror; Driver Side (Z4)
   Coding: 00000000
   Shop #: WSC 73430
   Subsystem 6 - Component:   Sounder No Answer
1 Fault Found:
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 4
                    Fault Frequency: 32
                    Reset counter: 181
                    Mileage: 311813 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:00:10
   Coding: 0000758
2 Faults Found:
00944 - Heated Exterior Mirror; Passenger Side (Z5)
   Coding: 0000008
   Coding: 0000402
   Coding: 0000144
   Coding: 0000144
   Coding: 0000001
End----------(Elapsed Time: 01:21, VBatt start/end: 12.4V/12.4V)-----------
VCDS Release 21.3.0:  SRI Reset
Control Module Part Number: 1Z0 920 942 D       Labels:  1K0-920-xxx-17.lbl
Component:KOMBIINSTRUMENT VD1 1612, Coding:0007402
Operation: Please select an operation
Channel      Description                                           Unit          Current val.      New val.
02           Service Reminder Status                                             1                 ---
40           Distance since Service                                miles x100    14                ---
41           Time since Service                                    Days          355               ---
42           Minimum Distance to Service                           ---           ---               ---
43           Maximum Distance to Service                           ---           ---               ---
44           Maximum Time to Service                               ---           ---               ---
45           Oil Quality                                                         1                 ---
47           Soot Quantity                                         km x100       64                ---
48           Thermal Load                                          km x100       22                ---
49           Minimum Time to Service                               ---           ---               ---
50           Basic Distance Value for Oil Change                   miles x100    93                ---
51           Basic Time Value for Oil Change                       Days          372               ---
Operation: General Service Reset
02           Service Reminder Status                                             1                 0
Address 17,1Z0 920 942 D,channel 2,adapted from,1,to,00000,
You can physically disconnect them and it'll not make any difference to things so forget about them.
With your luck you'll probably get a seized plug and shear it off so why play with fire.
I suspect you have an electrical fault upstream of the plugs, have you tested for voltage at the plug connection?
No I haven't not sure where the plug connection is or are you talking 1 at a time?
you right had no luck what so ever with this car, its a shame as I really enjoy the drive and have spent loads getting it back up together it just seems to be the electrics but I tried to take it to a car sparky he gave me a £380 bill and its all still happening, I just dont know anyone good with the wiring side of things, I have the tools but this is really my 1st time doing anything like this never knew a car had so many modules and sensors.
The car starts and runs great its just all these false warning lights making the car cut out, many a RAC guy have plugged into it and got it wrong, just hope it gets me to these 2 hospital appointments as there important, think I might take my laptop with me so I can plug in if something goes wrong
The glow plugs are a red herring.
Again you've got an abs fault guiding you to a a fault in another module, this time guiding you back to the engine control module.
As we can pretty much rule out glow plugs. That leaves your other code in engine, the G28 Which is the crankshaft position sensor. This playing up will cause cutting out and issues as its the main sensor for the engine module to know what position the engine is at at all times.
I agree Daz glow plugs are ok
abs is the 1 that keeps coming up
the abs seems to light up when something else is wrong like this time the light sensor and wiper sensor and the horn, well its only got 1 horn not 2 the wipers do go funny now and then and the lights dont always switch on when you put the switch on auto, they work fine apart from the auto light
do you think the crankshaft position sensor may be gone?.
Thing is I done the same thing this time, I put the battery on charge over night and deleted all the faults and drove to my 1st hospital appointment 30 miles away and no problems what so ever drove like a dream with no fault lights on.
am really at a loss what to do next as I got a feeling a lot of these faults are red herrings, its just past its MOT 3 days ago with no faults or advisers
Edited by sealover1
