lack of pikey mods
on the recent C+F run i had a look round most of the Fabia VRS ,13 or 14 cars iirc, and quite a few were remapped i think , but i didn't notice any of them had pikey mods 1+2 , surely its a very cheap and easy job to do ,which in the coming summer months will make a difference to the performance when its warm , just wondering why nobody had done it thats all:confused:
Maybe they've got a FMIC :D
Seriously though, I can imagine reasons against it being it's a fair bit of work, and it may cause road crud to get into the SMIC I suppose if you don't quite get it right.
That said IMHO *disclaiming whatever here :o * it should be fine if you fit the louvre in the correct way, and I was going to go for it myself (then the GB on the Forge FMIC came along, etc ).
I would imagine the biggest difference will be for those who have a custom remap rather than the generic ones (as the custom one will probably have significantly higher boost => temperature)
You done yours then?
I've done both mine, differences in performance are negligable. maybe a little better up top and 3-4 degrees C cooler under full throttle acceleration. my SMIC is stone chip free after 25,000 miles however it is dirty now and in need of a clean.
Mine has both mods, and was at the C&F. Not convinced they make a vast difference, to be honest (when you're looking at an intake air temperature increase of (say) 30
I have the pikey arch mod, although its useless now. :rolleyes:
Yashicamat (sp?) :D has reserved it for a clean, no cost swap over at the blackpool meet.... He knows he's going, he just refuses to acknowledge it publically :D
Forgive me for being ignorant, but, what are these mods.??
If mine has these I will remove them immediately to return my car to standard, as it should be.....Bah!
And you didnt notice my "ultimate" mod :rofl:
Who needs pikey mods??? :D
Forgive me for being ignorant' date=' but, what are these mods.??
If mine has these I will remove them immediately to return my car to standard, as it should be.....Bah![/quote']
Basically its cheap mods that are good for performance. hence the cheap venting of the arch liner trick is called a pikey mod as it vents the very well tucked away :rolleyes: side mounted intercooler, allowing better performance in warmer weather, :) It worked well on mine until I opted to move the IC itself.
There a 2 pikey mods, venting at the front (pikey mod 2) and the TT arch liner mod (pikey mod 1).
please tell me what your ultimate mod is ?:confused:
A FMIC ;) - Neo_VR has the prototype Forge FMIC which IIRC is a tad bigger :)
or to be more precise...
extra 10mm deeper giving about another 30% capacity over "normal" fmics :D
why did you not show it off ?:( i'm always interested in other peoples mods especially a bigger FMIC :thumbup:
