Will a 16 inch spare fit in place of a 17 inch wheel ?
Hello
I am looking at buying a 2020 skoda superb 1.5 tsi se technology 17 inch wheels.
It does not come with a spare wheel.
I currently have a 16 inch spare from a 2018 skoda octavia mk3 and wonder if the studs are the same so i could use it as a temp spare wheel.
Any comments appreciated.
I'm not sure if Gizmo is correct, most tyre inflation kits where some kind of latex is put into the tyre to seal it before inflating requires the wheel to be removed.
Usually  the kit includes a bottle of latex, a valve core remover,  and a compressor.
My old honda had the same junk, never used it bought a second hand full size wheel and tyre second hand for £20, no brainer.
Anyway back to the procedure, you get a puncture that hasn't wrecked the tyre, the car is jacked up and the wheel removed, the valve core is removed and the latex is  squezzed through the valve stem, the wheel is then rolled about to distribute the latex, the valve core is then replaced, and the tyre inflated to it's normal pressure.
It is only a get you home fix with speed limited to approx 40mph and a limited distance, can't remember how far.
There are instructions in the owners manual under "Puncture repair kit" slightly different procedure but basically the same.
Yes you do need a jack and a compressor.
Hope this helps
Thanks for the info. I will keep the 16 inch spare from my octavia (the car originally had a repair kit) and leave the original repair kit alone. If it sounds like the new car does not come with a jack i will keep this also from the octavia.
Thanks Again
Edited by Donald1
Hi, Donald1 it's me again, Yes Gizmo is right, I have just took delivery of a 2020 Superb SE and it came with an emergency spare wheel,  it's not one of those skinny narrow tyres, it's almost full size.
But what is puzzling me is that the Superb as standard comes with 215/55R17 wheels and tyres but the spare is a 205/55R16, with  different diameters, I queired this on Monday afternoon with Skoda Sheffield, and they confirmed it was the correct wheel and tyre.
I'm not saying it won't get you home, but there is a difference of 36mm in the diameter of the tyres, which is why it is limited to 50mph, not sure of any distance restriction.
If it was on an Octavia fitted with the standard 205/55r16's it would be classed as a full spare with no restrictions. obviously a cost cutting exercise as the two tyres have a rough price difference of £40, I'm hoping never to have to use it, especially on the front axle, I'd rather have a 17 inch steel wheel with a cheap 215/55r17 tyre on it.
But yea, save your money and fit the Octavia wheel just remember the 50mph limit because of the different diameter and tread patch size, you'll see why if you ever have use one on the front.
Cheers Terry
Hi Terry
That is interesting to know. I must admit i would prefer a 17 inch spare wheel for my 2020 superb but as i already have a 16 inch i dont see the point in spending the money on a 17 for all the times (if ever) i need to use it.
I double checked the size of the spare i have in my octavia that i am going to keep and it is indeed also a 205/55R16.
Thanks again
Donald
Dead right mate, as a Yorkshire man, we are second in line to the Scots for being tight fisted and wanting value for money.
I'm sure you've seen the Plusnet adverts, eh up.
BTW the 1.5tsi is a revelation after having driven a diesel for the last 13 years, thought I'd gone deaf so quiet pulling up at lights, (I'd switch off the stop/start)
and the Adaptive Cruise is great, I'm sure you'll love the car.
Cheers Terry
For the record, I bought a standard 6.5x16" steel rim and fitted a 215/60/16 tyre as on the base model cars.
Fits in the spare wheel recess well and does lift the carpet up ever so slightly (non-variable boot floor) but I'd rather have a decent spare as was intending to go aboard in it.
I was go to line the boot floor with say a layer of 10mm thick insulation around the spare wheel to lift the carpet up slightly but I got a boot liner and never bothered me.
Angelo
Hi Angelo, that's another good alternative, only 4mm smaller diameter than the standard 215/55r17.  a new tyre
Only the same as running a old worn tyre with a set of newish ones.
The online wheel and tyre calculators are great for comparing different sizes.
https://www.rotawheelsuk.com/tyre-size-calculator/width/6.5"/rr-offset/et30/rr-diameter/16".html
By the way Donald, if the Superb came with an inflator kit, I think the latex has a shelf life of 3 yrs, then they advise throwing it and buying another bottle,
My wifes car also had a latex bottle of gunk (out of date) and it was cheaper to buy one of the aerosol repair cans at around £7-£8, but did eventually get a second hand full size for her.
Cheers Terry
why everyone focusing on inches of disk?
while more important is what size of tire is mounted on it.
16" can be used even on 280/272, which have bigger brakes,
just install spare wheel on the right place - rear axle
yes, double procedure if damaged front, but it's lot safer to leave normal tire on the front axle
On 14/04/2018 at 08:09, MartiniB said:
replaced stock 205/55r16 by full diameter 205/65r16
weren't easy put it in cause back side plastic
diameter comparison to 215/55r17 and 225/55r17:
205/55r16 _ -5.3% _ -6.7%, this huge size difference cancels usage of cruise control
205/65r16 _ +0.8% _ -0.7%, not tested yet
Angelo
If you had fitted the 215/60R16 tyre to a 6Jx16 rim, your lifted carpet would have been about 6mm lower. That's because the width of a 215/60R16 tyre fitted to a 6.5J rim is 221mm wide, but fitted to a 0.5" narrower 6J rim it's only about 215mm wide.
215/60 R16 16 99V XL 8.7 664 221 6.0-6.5-7.5 C B   70 dB
195/65R16, 205/60R16, or 205/65R16 fitted to a 6J rim (or maybe even a 6.5J rim) and the carpet may have been completely flush.
Alcar 6665 6Jx16 ET43 5/112 57.1 Steel Rim (from the Karoq)
https://www.oponeo.pl/felga-stalowa/alcar-kfz-6665#21298241
6665
A 205/60R16 fitted to a 6.5J rim is about the same width as a 215/60R16 fitted to a 6J rim, ie. both about 215mm wide.
Notice is the chart below that a 205/55R16 is 214mm wide when fitted to a 6.5J rim (the size that Skoda sell as a spare for the Superb MK3...although it's actually an Octavia MK3 spare wheel...at 6.5Jx16 ET46).
Maybe a 215/60R16 fitted to a 6J rim would fit with the carpet flush ???
logo.svg
Tire Size Rim Diameter Load Speed Index Tread Depth (mm) Overall Diameter (mm) Overall Width (mm) Approved Rim Width Range (inch) icon-rrc.png icon-wet.png   icon-db.png
185/60 R16 16 86H 7.9 628 189 5.0-5.5-6.5 C B   70 dB
185/55 R16 16 87H XL 8.3 610 194 5.0-6-6.5 C B   70 dB
185/50 R16 16 81H 7.5 592 194 5,0-6-6,5 C B   70 dB
195/60 R16 16 89H 8.7 640 201 5.5-6-7.0 C B   70 dB
195/55 R16 16 91V XL 8.4 620 201 5.5-6-7.0 C B   70 dB
195/55 R16 16 87V 8.4 620 201 5.5-6-7.0 C B   70 dB
195/55 R16 16 87H 8.4 620 201 5.5-6-7.0 C B   70 dB
195/50 R16 16 88V XL 8.3 602 201 5.5-6-7.0 C B   70 dB
195/45 R16 16 84V XL 7.7 582 195 6.0-6.5-7.5 C B   70 dB
205/65 R16 16 95V 8.6 672 209 5.5-6-7.5 C B   70 dB
205/60 R16 16 92V 8.6 652 209 5.5-6-7.5 C B   70 dB
205/60 R16 16 92H 8.6 652 209 5.5-6-7.5 C B   70 dB
205/60 R16 16 96V XL 8.6 652 209 5.5-6-7.5 C B   70 dB
205/55 R16 16 91V 8.5 632 214 5.5-6.5-7.5 C B   70 dB
205/55 R16 16 91H 8.5 632 214 5.5-6.5-7.5 C B   70 dB
205/55 R16 16 94V XL 8.5 632 214 5.5-6.5-7.5 C B   70 dB
205/55 R16 16 94H XL 8.5 632 214 5.5-6.5-7.5 C B   70 dB
205/50 R16 16 87V 8.4 612 214 5.5-6.5-7.5 C B   70 dB
205/45 R16 16 83H 8.2 590 206 6,5-7-7,5 E B   70 dB
215/65 R16 16 98H 8.7 686 221 6.0-6.5-7.5 C B   70 dB
215/60 R16 16 99H XL 8.7 664 221 6.0-6.5-7.5 C B   70 dB
215/60 R16 16 95H 8.7 664 221 6.0-6.5-7.5 C B   70 dB
215/55 R16 16 93W 8.6 642 226 6.0-7-7.5 C B   70 dB
215/55 R16 16 97V XL 8.6 642 226 6.0-7-7.5 C B   70 dB
215/45 R16 16 90V XL 7.9 600 213 7.0-7-8.0 C B   70 dB
215/45 R16 16 86V 7.9 600 213 7.0-7-8.0 C B   70 dB
225/60 R16 16 98W 7.9 676 228 6.0-6.5-8.0 C B   70 dB
225/55 R16 16 95V 8.7 654 233 6.0-7-8.0 C B   70 dB
https://www.toyo.co.uk/tire/pattern/proxes-cf2
Edited by Carlston
