SKODA ROOMSTER 5J ABS LIGHT INTERMITENT
hi i am looking for help regarding the problem i am facing .. ABS  light with parking break light come with all electronics is like droping voltages ON/OFF also power steering stop working after this error . but if switch off and start again some time it goes i have searched briskoda for the possible solution but could not sort it out yet... fuses on battery all ok.. break fine
video clip for fault
It needs a code reader to identify the fault(s).
i try with vcds found these 2 codes attaching pic
some time the error not come i checked last time when i start error once came and after 5 minutes of driving gone and not came again, even i drove about 60km with no error.
ABS Module? A Skoda dealer would know
Edited by edbostan
I would start by checking the alternator, it could be an unstable and electrically noisy output.
how can i check noisy output .... i have check output with multimeter 14.4 stable output
i would try asking them. i am in spain dont know if they do this free of cost :))
My son has a Ford Fiesta which had the ABS light on with handbrake light and traction control all light up at the same time.  He called the breakdown service who read the codes as the pump on the ABS Module for the rear nearside wheel was not working. He carefully drove to a Ford dealer who confirmed the fault.
Edited by edbostan
thanks for all your help... finally problem solved...
battery was the problem. replaced battery and all ok
badluck again same problem.. means battery was ok.
any one please help how diagnose this problem
although battery main negative cable look good. just in case i disconnect and clean well and connected again. fault not apeared again. i wait a week to confirm. so finally solved.
thnks for all to help me.
