AC charging
So just to confirm. If you have a 3P charging cable ( rasy to check with a multimeter, are all the big pins wired through) and you plug in an AC 22Kw charging point, you'll charge st 12Kw because it's limited by the charger in the car. Always make me smile as even a Zoe has a 22Kw charger and is supplied with a 3p cable. I have a Zoe and 3p + a 23Kw charger at home. So plenty of time to fully charge 2 Eva at home overnight.
classic - The cable that was supplied with my Enyaq is a three phase cable. Look at the Label.
GIBSONMB - Yes 11 Kw/h limit.
Edited by Perchede
Had a look at the label, and indeed it is 3 phase, 32A. Will test it out at some point.
Therefore no need for @Cotswold to be looking at buying a separate 3 phase cable.
However, these are the specs from ev database, which suggest it won’t charge faster on 3 phase…..
https://ev-database.uk/car/1279/Skoda-Enyaq-iV-60#charge-table
Type 2 (Mennekes - IEC 62196)
Charging Point Max. Power Power Time Rate
Wall Plug (2.3 kW) 230V / 1x10A 2.3 kW 29h45m 7 mph
1-phase 16A (3.7 kW) 230V / 1x16A 3.7 kW 18h30m 11 mph
1-phase 32A (7.4 kW) 230V / 1x31A 7.2 kW † 9h30m 22 mph
3-phase 16A (11 kW) 230V / 2x16A 7.2 kW † 9h30m 22 mph
3-phase 32A (22 kW) 230V / 2x16A 7.2 kW † 9h30m 22 mph
† = Limited by on-board charger, vehicle cannot charge faster.
Edited by classic
It's wrong - here is another TP site that says different and agrees with Skoda that it's AC charges is Max 11 Kw/h.
Skoda Enyaq iV 80 home chargers | From just £34 a month | Smart Home Charge
