Thermostat & Thermo-switch
27 minutes ago, D.FYLAKTOS said:
What is the colour of the ring of your thermostat sensor now?
:cool:
i think yellow
  • Replies 83
  • Views 6.9k
  • D.FYLAKTOS
    D.FYLAKTOS
    Who said that? Here in Greece we have hot cliamate too and the Skoda mechanics which had Felicia some years ego suggest 80-85C and even 75-80C thermo-switch I have use all the scales from 70
  • @Agalalh You mentioned you don't want the radiator fun to run almost all the time. A lower temperature thermo-switch will keep the fan working often. It is not economical to use the rad
  • D.FYLAKTOS
    D.FYLAKTOS
    The temperature radiator fan switches have scales at 5 °C Which thermo switch says on that is for 88C only? Take a look some Mahle:   https://www.euspares.co.uk/manufacturer/mahle-
Yellow again
10 hours ago, Thefeliciahacker said:
Yellow again
What u want to say i can't understand ur opinion
If you replace go with the same color you had
Look the arrow, it points the Yellow ring that your thermostat sensor has.
The horseshoe clip is a good indication if the sensor has ever been changed because people will fit it the other way round
Last update
Changed Rad
Thermostat 88
Switch 82
Fan work and stop and the temperature between 88~ 92 under 100k/h
After 100k/h fan working a lot of time now im looking for a new thermostat 80c it's available in egypt I'll try to buy it from on-line store
before any more money is spent try no thermostat and see what the fan does if its ok then procced with 80c replacement if its not we need to investigate further
Without thermostat the fan  will never stop with switch 82
Edited by Agalalh
Well then 80c thermostat is not going to cut it. Given that you have new rad and all I would look into a tiny head gasket failure
sorry
without thermostat fan will not stop
but if found thermostat 80 it'll be good
I wonder what's going to happen on Winter, you will have no heat in the beginning.
NO if no thermostat causes the fan to run all the time a 80c thermostat is going to make it worse
hello, as I said before, I installed the 80'c thermostat.
but i need an opinion
Does this 10'c difference cause problems with the engine? (fan switch 85-80)
I'm thinking of installing an 80-75c fan switch if I can find it.
what are your thoughts
Let it be don't burn your fan out
Hi all
Have a nice day
Last updated
I installed thermostat 80c buy which is the best switch 75-70 or 82-68 in hot County
Thank you
Well IMO there's no point in running the fan if the thermostat hasn't opened.
You are going way too aggressive with the fan
Why i just ask which it's better switch with thermostat 80
The fan won't run if thermostat is closed - the switch is at output side of the radiator, which is at ambient temperature when the thermostat is closed. But with 70° switch, it might run even at higher speeds in high-load situations. I wouldn't go beyond 5° difference.
Having tried 70-75 switch it caused the fan to run wayyyyy too much. I reverted back to my 80-85c.
Edited by Thefeliciahacker
I heavy traffic at summer actually works all the time.
For me last only one day, i could stand it and the next day at morning i was in the repair-shop with the demand ''change it now''.
Some say ''this will save your gasket@ but i don't agree.
I also dont agree, head gasket goes from using water, anything below 100c is actually pretty ok
So
Where is Wright answer to my question tell now nobody tell witch is better
