Xenons
How many turns did you try?
3 hours ago, Andrea11 said:
if that is with ur headlights on - something is wrong as it appears there is no light beam hitting the wall at all!!!
below is a video of mine starting up - i'm about 7 to 10 meters from the wall, but u can clearly see the light.
https://youtu.be/cqCnOi2dDnc
What do u guys suggest I do
Take it to a friendly mechanic with the right tools to check and correctly align your headlights...? If you can, watch them while they do the adjustments and you'll know how it works in the future :)
It should be pretty obvious when the adjuster moves the light:
- cover up one light
- find and mark the cut off on the floor/wall with tape (5-10m away)
- put a couple of turns on one adjuster
- see where the cut off has moved
There are plenty of tutorials on youtube showing how to roughly set the lights up.
