Superb sat nav positional accuracy issues
4 hours ago, Gyp said:
Whereas who I've got a Skoda workshop manager. Would he do?
Unlikely. Geodysy is a specialist discipline in itself. Lots of coders more or less understand it when they see it; lots of geographers and mathematicians may be capable of coding it as well as doing it; I'd be surprised if a workshop manager has any of those skill sets.
Post your system information to check what software/hardware you have.
If it is a conversion issue, then it should be present on all units with the same SW/HW. Given nobody else seems to be having the same issue it seems unlikely :)
I'm not super familiar with the MIB2.5 Columbus but I think there is 1440 for that headunit.
@pab567 - can you confirm is that's correct?
Then it's up to you @Gyp, you can either update it yourself or ask the dealer to :)
Probably GPS antenna is faulty - try any other, e.g. the cheap Chinese internal GPS antenna. If this doesn't help then I recommend to reset navigation calibration data - it can be done only with diagnostics interface, e.g. VCDS. Then you should drive a straight road approx. 1 km.
Unfortuntely message with sw download link cannot be sent - probably @Gyp has mailbox size exceeded.
Edited by pab567
There wasn't much in my inbox but it's clear now.
Dealer replaced the antenna with no difference - whilst they are still dealing with it as a warranty issue, I'm not overly keen to start fiddling as I don't want to give them a reason to cut me adrift
1440?
3 minutes ago, Gyp said:
1440?
Yup, it's currently on SW:1382 as shown in your screenshot.
I believe the latest version is SW:1440 but now your inbox is clear, hopefully Pab will send you a link to download it :)
Just now, Gyp said:
I've surprised the dealer didn't do this as part of the service
They won't do any software updates unless you complain... But yes, I agree it really should be done during a service, especially given you've got issues with the headunit!
As an aside, I naively thought that paying for Skoda connect services would include firmware updates but no. Seems like it has the map updates but not firmware.
I've not subscribed btw.
  • 5 months later...
Did this issue get fixed? I have a MIB 3 unit with an identical issue.
Sometimes it works fine.
Sometimes it takes 10 minutes of driving before it works out where you are.
Other times it'll work perfectly for a while then drop out and starts to suggest I'm driving off road
Android Auto and car play are always accurate, whether wired or wireless
I have the kodiaq L&K on a 21 plate, ex managers cars apparently and I'm having exactly the same issue, have been to two dealers a total of five times, had all the software updated a brand new head unit fitted and I'm still driving in the sea at times. Finally the manager has now got involved and is supposed to be ordering a new GPS antenna.
Also having issues with the Bluetooth when making a call the Bluetooth will for no reason disconnect from the phone while the call is still active?? Can happen up to seven times in a five minute call and not once in a twenty min call?? Any advice would he helpfull. Using a Samsung A52 which is compatible also connected a Samsung A21 which isn't and had the same issue. Also the cars location when using the app I miles off as well.20220112_172739.thumb.jpg.29bd953134df7543fca5d73f03235339.jpgScreenshot_20220112-200244_MyKODA.thumb.jpg.a03023ece08d11b300916a7d50d08fbc.jpg
