Is this the correct coding for xenon Europe Iceland
06 DA 00 00 3F 01 00 00
help would be nice
It might be better to post a full autoscan to give that coding some context :)
How do I do that with OBDeleven
'Please' is the magic word ....
Please how do I do that with OBDeleven because my lights were amazing 1 year ago now I can hardly see and I have messed with the coding
No idea, I've never used it.
I think there is a history function which might show the original coding?
Because my headlights are dull is there something in central electronics can I take a backup of it and send it here
Edited by Andrea11
I am going to send a backup of every module in the car because I am just out of ideas I’d anyone could point me out that would be amazing and my vin if that could be any help
And sometimes my seat and mirrors have a kind of their own kessy air con and much more issues
OBDeleven vehicle history log
Date: 2021-08-01 19:32:18
    VIN: TMBAH7NP2H7009796
    Car: nvm20
    Year: 2017
    Body type: Saloon
    Engine: CRLB  kW ( hp) l
    Mileage: 372624 km
    Backup
        01 Engine
        System description: R4 2.0l TDI
        Software number: 04L906026ET
        Software version: 1990
        Hardware number: 04L907309R
        Hardware version: H23
        Backup name: Engine
        Long coding
            011D0012032405087000
        Adaptations
            Injector 1 correction value
                    8IZH817
            Injector 3 correction value
                    888GAEA
            Injector 4 correction value
                    BAIAFEB
            Injector 2 correction value
                    8RZEBI7
            Adaptation of ash mass
                    0.00 g
            Service regeneration of particulate filter while driving
                    0
            Initialization of NOx catalyst accumulator
                    0 s
            Blocking of particle filter regeneration
                    not active
            Individually adjustable maximum speed limit
                    300.0 km/h
            Idle RPM correction
                    0.0 1/min
            Activation of start-stop function
                    active
            Bleeding of coolant circuit
                    not active
            Production mode
                    000000
            Deactivate production mode
                    000000
            Protective function
                    Enabled
            Roller test bench mode, functional
                    Not activated
            Engine run-in oil pressure
                    not active
        Advanced identification
            Vehicle history data
                    eAiAfFaBnBmHcAiLnNhEcHnFaBkBcDnJpJhDkEbDnFoBeDnNgHjFbBgIjAaGdBpImAnBjOpGfPdBoCfFdEpPpJnEaOlFnFgNfLmDcBjHhPhIdPmLeKmAjAnEgNkDlMmBeNoDlBlMcPeGcKpNlNcDlAbBiDmAcJcGfNhLpNcFiDaKgHkLoHmJeEpDeCeMfGnIcGbGbHeGkPbBkNcAbKeDjLiLlNoPlEeGfGoJkNcKhCkFmFdGbIhCdChCgNjOlEoNaBcC
            Number of programming attempts
                Bootloader
                    2
                Application
                    2
                Application 2
                    2
                Application 3
                    2
                Data record
                    2
            Maximum number of possible update programming
                Bootloader
                    100
                Application
                    100
                Application 2
                    100
                Application 3
                    100
                Data record
                    100
            ISO TP block size in bootloader
                    0
            Coding length
                    10
            Workshop code and date of last update programming of SW module
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
                Programming status
                    Correct result
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
                Programming status
                    Correct result
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
                Programming status
                    Correct result
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
                Programming status
                    Correct result
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
                Programming status
                    Correct result
            FAZIT-identification
                Manufacture location index
                    RB8-658
                Day of manufacture
                    27.05.16
                Manufacturer- test stand number
                    1409
                Running manufacturer number
                    0121
            Manufacturer modification status
                Control module family
                    B
                Decoration variant
                    5
                Construction version
                    H23
                Manufacture version
            Diagnostic mode
                    VW - diagnostic mode
            VW/Audi part number
                    04L906026ET
            SoftwareVersion
                    1990
            Vehicle Identification Number (VIN)
                    TMBAH7NP2H7009796
            Hardware part number
                    04L907309R
            System description
                    R4 2.0l TDI
            ASAM/ODX file identification
                    EV ECM20TDI01104L906026ET
            ASAM/ODX file version
                    002002
            HardwareVersion
                    H23
            Coding workshop code
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
            System abbreviation
                    J623
            Versions of software module
                Bootloader
                    0002
                Application
                    0003
                Application 2
                    0003
                Application 3
                    0003
                Data record
                    0006
            Engine code
                    CRLB
            Programmability status
                Programmability
                    programmable
                Program consistency
                    Program present
        Mileage: 372624 km
        Date: 2021-08-01 19:31:57
    Backup
        02 Transmission
        System description: DQ250-6F MQB
        Software number: 0D9300041H
        Software version: 4905
        Hardware number: 02E927770AQ
        Hardware version: H53
        Serial number: TFK01604240015
        Backup name: Transmission
        Long coding
            0014
        Adaptations
                    Not activated
                Bootloader
                    1
                Application
                    2
                Data record
                    3
                Bootloader
                    1
                Application
                    1000
                Data record
                    1000
                Year
                    0
                Month
                    1
                Day
                    1
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    16
                Month
                    5
                Day
                    31
                Device number
                    10
                Importer number
                    2
                Dealership number
                    4864
                Programming status
                    Correct result
                Year
                    16
                Month
                    6
                Day
                    7
                Device number
                    20
                Importer number
                    770
                Dealership number
                    73216
                Programming status
                    Correct result
                    TFK-053
                Day of manufacture
                    24.04.16
                    80A5
                    0015
                    0
                Decoration variant
                    6
                    253
                Manufacture version
                    104
            Diagnostic mode
            VW/Audi part number
                    0D9300041H
            SoftwareVersion
                    4905
                    02E927770AQ
            System description
                    DQ250-6F MQB
                    EV TCMDQ250021
                    001001
            HardwareVersion
                    H53
                Device number
                    31
                Importer number
                    770
                Dealership number
                    33281
            System abbreviation
                    J743
                Bootloader
                    0008
                Application
                    0049
                Data record
                    4905
                Programmability
                    programmable
                Program consistency
                    Program present
                    TMBAH7NP2H7009796
            Serial number
                    TFK01604240015
            Vehicle equipment code
                    FFFFFFFFFFFFFFFFFFFFFFFF
                    F
            Adaptation workshop code
                Device number
                    20
                Importer number
                    770
                Dealership number
                    73216
            Number of possible access authorizations
                Number Of Logins
                    1
        Mileage: 372624 km
    Backup
        03 Brakes
        System description: ESC
        Software number: 5Q0614517BJ
        Software version: 0636
        Hardware number: 5Q0614517AG
        Hardware version: H62
        Serial number: 61546000001673
        Backup name: Brakes
        Long coding
            1D076A9C34200B75477E060941C949B8562CD0E2608292751061F078C20202
        Adaptations
            Tire pressure monitoring display
                Warning thresholds, tire pressure monitoring system
                    2
                    Manual activation, possible
                Status
                    activated
            Engine drag torque control
                    activated
            Activating and deactivating all development messages
                    0
            OFFROAD
                Offroad portion electronic differential lock
                    0
            Brake system vacuum pump
                Offset
                    5
            Hydraulic brake booster
                Offset
                    8
            Brake prefill
                Brake prefill
                    activated
            Braking torque boost for distance regulation
                    3
            Brake booster
                Brake booster
                    4
            Hydraulic brake assistant
                    normal
            Electronic Stability Program
                Speed-dependent activation
                    Not activated
            Brake disk drying
                Brake disk drying
                    medium
            Hill-start assistant
                    normal
            Straight ahead brake stabilization
                    activated
            Brake pedal evaluation
                    activated
            Seat belt buckle scan
                    activated
            Dynamic starting assist
                    normal
            Driver door status
                Driver door status
                    activated
            Automatic application during engine stalling
                    activated
            Starting vibration reduction
                    Strong
                Torque limitation
                    Deactivated
            AUTO HOLD functionality
                    Not activated
            AUTO HOLD increase threshold, reduced tensioning force
                    0 %
            AUTO HOLD increase threshold, full tensioning force
                    10 %
            Developer_Function_108
                Fall-back level
                    0
                Developer Function 1
                    0
            Developer_Function_2
                Developer Function 2
                    activated
            Monitoring of functional lights
                Indicator light in the button for electromech. parking brake
                    7
                Indicator light in AUTO HOLD button
                    7
            Vehicle and trailer stabilization
                Trailer information evaluation
                    Not activated
                    Not activated
            AUTO HOLD slippage recognition
                    activated
            Overboost in brake system
                    activated
            Electromechanical parking brake
                Driver presence recognition via brake pedal
                    Not activated
            AUTO HOLD functional status
                Personalized settings
                    Last setting
            Tire pressure monitoring display, tire selection
                    1
            Developer_Function_3
                Developer Function 3
                    Not activated
            ABS in lower speed range
                    activated
            Developer_Function_4
                Developer Function 4
                    5
            Thresholds for brake performance
                    activated
            XCP calibration protocol
                    Not activated
            Monitoring infotainment control unit
                    Not activated
            Developer_Function_100
                Monitoring VIN
                    activated
            Developer_Function_101
                Anti-slip regulation (ASR)
                    activated
            Developer_Function_102
                ASR and ESP function deactivation
                    activated
            Developer_Function_104
                Delay interface for adaptive cruise control
                    activated
            Plausibility check
                Reverse gear
                    activated
                Neutral gear sensor
                    activated
                Clutch movement
                    activated
            Developer_Function_110
                AutoHold minimum pressure threshold
                    4
            Expanded electronic differential lock
                Electronic Differential Lock
                    Standard
            Production mode
                    not active
            Electromechanical parking brake, emergency braking
                    activated
            Developer_Function_5
                Developer Function 5
                    Not activated
            dimming_characteristic_1
                X1
                    0
                Y1
                    6
                X2
                    10
                Y2
                    6
                X3
                    50
                Y3
                    8
                X4
                    100
                Y4
                    12
                X5
                    220
                Y5
                    80
                X6
                    253
                Y6
                    100
            dimming_characteristic_2
                X1
                    0
                Y1
                    6
                X2
                    10
                Y2
                    6
                X3
                    50
                Y3
                    8
                X4
                    100
                Y4
                    12
                X5
                    220
                Y5
                    80
                X6
                    253
                Y6
                    100
            Dimming
                dimming
                    activated
                    Deactivating
            Developer_Function_121
                Tyre pressure control monitoring tour mode
                    Not activated
            Electromechanical parking brake, delay level
                    6
            Developer_Function_105
                Delay interface for electro-mechanical parking brake
                    activated
            Rough road optimization
                    activated
            Brake pre-filling
                    not completed successfully
                Bootloader
                    0
                Application
                    0
                Bootloader
                    100
                Application
                    1000
            Identification of connected components
                ID number
                    3
                subsystem name
                    Brakes 1
                Bus message/node address
                    13
                Year
                    0
                Month
                    1
                Day
                    1
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    1
                Day
                    1
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
            Subassembly and series number
                    1673
            Date of last coding
                Year
                    0
                Month
                    0
                Day
                    0
                    TT1-0CB
                Day of manufacture
                    02.06.16
                    0302
                    0689
            Manufacturer's test stand number
                    0302
            Manufacturer code
                    TT1
            Diagnostic mode
            VW/Audi part number
                    5Q0614517BJ
            SoftwareVersion
                    0636
            Supplier identification
                    436F6E74696E656E74616C2054657665732C204775657269636B657374722E20372C203630343838204672616E6B66757274
            Date of manufacture
                Year
                    16
                Month
                    6
                Day
                    2
            Serial number
                    61546000001673
                    5Q0614517AG
            System description
                    ESC
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
            Date of last adaptation
                Year
                    0
                Month
                    0
                Day
                    0
                    EV Brake1UDSContiMK100IPB
            Parameter set part number
            Parameter set version
                    035019
            HardwareVersion
                    H62
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
            System abbreviation
                    J104
                Bootloader
                    0005
                Application
                    0636
                    1
                Programmability
                    programmable
                Program consistency
                    Program present
            Coding
                    F
        Mileage: 372624 km
    Backup
        08 Air Conditioning
        System description: AC Automat
        Software number: 3V0907044BC
        Software version: 4001
        Hardware number: 3V0907044BC
        Hardware version: H34
        Serial number: 00000B00119216
        Backup name: Air Conditioning
        Long coding
            11010104002110011005100000101102
        Adaptations
            Runtime for compressor run-in basic setting
                    60 s
            Duration of compressor run in
                    60 s
            Retention of driver's seat heater level
                    active for 10 minutes
            Retention of frt.pass. seat heater level
                    not active
            Deactivation of start-stop function
                    not active
            Stop release for start-stop function
                    According to function requirements
            Window condensation exterior reduction at high humidity
                    Matching coding
            Blower logic for manual adjustment
                    Matching coding
            Ignore compressor switch-off by Engine Control Module
                    Do not ignore
            Blower voltage for voice operation
                    Not activated
            Post-heating of parking heater
                    0 min
            Retrofitting of parking heater without CAN
                    not installed
            Air quality sensor sensitivity
                    Maximum
            Reset all counters
                    Not activated
            Production mode
                    Deactivating
                    Deactivating
                X1
                    0
                Y1
                    0 %
                X2
                    6
                Y2
                    6 %
                X3
                    40
                Y3
                    40 %
                X4
                    60
                Y4
                    60 %
                X5
                    80
                Y5
                    80 %
                X6
                    100
                Y6
                    100 %
                X1
                    0
                Y1
                    2 %
                X2
                    10
                Y2
                    2 %
                X3
                    50
                Y3
                    10 %
                X4
                    100
                Y4
                    21 %
                X5
                    220
                Y5
                    85 %
                X6
                    253
                Y6
                    100 %
            dimming_characteristic_3
                X1
                    0
                Y1
                    2 %
                X2
                    10
                Y2
                    2 %
                X3
                    50
                Y3
                    5 %
                X4
                    100
                Y4
                    10 %
                X5
                    220
                Y5
                    85 %
                X6
                    253
                Y6
                    100 %
            dimming_characteristic_4
                X1
                    0
                Y1
                    2 %
                X2
                    10
                Y2
                    2 %
                X3
                    50
                Y3
                    5 %
                X4
                    100
                Y4
                    10 %
                X5
                    220
                Y5
                    85 %
                X6
                    253
                Y6
                    100 %
            dimming_characteristic_5
                X1
                    0
                Y1
                    2 %
                X2
                    10
                Y2
                    2 %
                X3
                    50
                Y3
                    5 %
                X4
                    100
                Y4
                    10 %
                X5
                    220
                Y5
                    85 %
                X6
                    253
                Y6
                    100 %
            Automatic Activation of front windshield heater at MAX-Defrost
                    not active
            Control module switch-off, switch-off time
                Control module
                    20 min
                Data bus
                    30 min
            Climate modes
                    Matching coding
            Remote start function, activation of seat ventilation
                    activated
            Rem. start funct., activat.temper. of seat heating
                    15 °C
            Rem. start funct., activat.temper. of seat ventilation
                    30 °C
            Remote start function, activation stage of seat heating
            Remote start function, activation stage of seat ventilation
            Rem.start funct.,activ.temper. of windshield defrost.heat.
                    4
            Remote start function, interior climate control status
                    Remote start function with last set value active
            Target temperature of A/C - heater function via remote control
                    22.0 °C
            Filtering of interior air, store
                    Service life-dependent store
                Bootloader
                    1
                Application
                    0
                Data record
                    0
                    F
                Bootloader
                    1
                Application
                    0
                Data record
                    0
            Known subsystems
                Subsystem designation
                    Reserved
                segment number
                    1
                subsystem present
                    No
                subsystem coded
                    No
                reserved (VW 80127 3.0)
                    1
                Subsystem number
                    0
                    Rear Climatronic Operating And Display Unit
                segment number
                    1
                subsystem present
                    Yes
                subsystem coded
                    Yes
                    1
                Subsystem number
                    101
            Table of Class 0 subsystems
                LIN Product - ID
                    9600010101
                LIN Segment Number
                    LIN Segment 1
                LIN node- address
                    1A
                LIN Product - ID
                    2500002144
                LIN Segment Number
                    LIN Segment 1
                LIN node- address
                    60
            Identification of bus master/sub bus master
                ECU ID
                    8
                ECU Name
                    Air Conditioning
                LOGICAL-LINK SHORT-NAME
                    Air Conditioning
                ID number
                    8
                subsystem name
                    Air Conditioning
                    46
                Year
                    0
                Month
                    1
                Day
                    1
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    1
                Day
                    1
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    1
                Day
                    1
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                    0295
            Date of last coding
                Year
                    0
                Month
                    0
                Day
                    0
                    PR6-044
                Day of manufacture
                    07.05.16
                    0003
                    0295
                    0003
                    2
                Decoration variant
                    0
                    K05
                Manufacture version
                    000
            Manufacturer code
                    PR6
            Diagnostic mode
            VW/Audi part number
                    3V0907044BC
            SoftwareVersion
                    4001
                    Preh GmbH, Schweinfurter Str. 5 - 9, D-97616 Bad Neustadt a. d. Saale
            Date of manufacture
                Year
                    16
                Month
                    5
                Day
                    7
            Serial number
                    00000B00119216
                    3V0907044BC
            Hardware part number for suppliers
                    80626-371
            Hardware version for suppliers
                    0000
            Software version of suppliers
                    05553-274
            Software version for suppliers
                    0014
            System description
                    AC Automat
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
                Year
                    21
                Month
                    7
                Day
                    1
                    EV ACClimaPrehVW37X
                    0000
                    002014
            HardwareVersion
                    H34
                    000000000000000000000000
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
            System abbreviation
                    E87
                Bootloader
                    X408
                Application
                    4001
                Data record
                    4001
                Number Of Logins
                    1
            AUTOSAR Standard application software identification
                Standard software module
                    BAP
                Software manufacturer ID
                Primary version number
                    1
                Secondary version number
                    6
                Revision number
                    8
                    UDS - protocol
                    In2Soft GmbH
                    2
                    1
                Revision number
                    16
                    Diagnostics - Event - Handler
                    IAV GmbH
                    4
                    1
                Revision number
                    21
                    CAN - driver
                    Vector Informatik GmbH
                    1
                    45
                Revision number
                    0
                    ISO15765-2
                    In2Soft GmbH
                    2
                    0
                Revision number
                    6
                    OSEK - operating system
                    Elektrobit Automotive GmbH (3SOFT GmbH)
                    4
                    5
                Revision number
                    0
                    High Speed - Network management
                    2
                    3
                Revision number
                    0
                    LIN 2.0
                    2
                    0
                Revision number
                    11
                    Standard diagnostic services for UDS
                    In2Soft GmbH
                    2
                    2
                Revision number
                    8
                    Flash EEPROM emulation
                    1
                    1
                Revision number
                    2
                    Bootloader/flasher (TP2.0/ISO TP)
                    3
                    4
                Revision number
                    5
                    Unknown
                    0
                    0
                Revision number
                    0
                    SPI driver
                    Fujitsu Ltd.
                    2
                    3
                Revision number
                    3
                    Flash driver
                    Fujitsu Ltd.
                    2
                    3
                Revision number
                    2
                    GPT driver
                    Fujitsu Ltd.
                    2
                    3
                Revision number
                    2
                    MCU driver
                    Fujitsu Ltd.
                    2
                    3
                Revision number
                    3
                    DIO driver
                    Fujitsu Ltd.
                    2
                    3
                Revision number
                    2
                    PWM driver
                    Fujitsu Ltd.
                    2
                    3
                Revision number
                    2
                    ICU driver
                    Fujitsu Ltd.
                    2
                    3
                Revision number
                    2
                    ADC driver
                    Fujitsu Ltd.
                    2
                    3
                Revision number
                    3
                    Port driver
                    Fujitsu Ltd.
                    2
                    3
                Revision number
                    3
                Programmability
                    programmable
                Program consistency
                    Program present
        Mileage: 372624 km
    Backup
        09 Central Electrics
        System description: BCM MQBAB M+
        Software number: 5Q0937084CF
        Software version: 0236
        Hardware number: 5Q0937084CF
        Serial number: 02001614101021
        Backup name: Central Electrics
        Long coding
            000000000000000000000000000000000000000000000000000000000000
        Adaptations
            Leuchte 0 BLK VL B36
                Lasttyp 0
                    33 - LED-Modul Blinkleuchten
                Lampendefektbit Position 0
                    34
                Fehlerort mittleres Byte DTC-DFCC 0
                    14
                Lichtfunktion A 0
                    Blinken links Hellphase
                Lichtfunktion B 0
                    nicht aktiv
                Dimmwert AB 0
                    127
                Lichtansteuerung HD AB 0
                    always
                Lichtfunktion C 0
                    nicht aktiv
                Lichtfunktion D 0
                    nicht aktiv
                Dimmwert CD 0
                    0
                Dimming Direction CD 0
                    maximize
                Lichtfunktion E 0
                    nicht aktiv
                Lichtfunktion F 0
                    nicht aktiv
                Dimmwert EF 0
                    0
                Dimming Direction EF 0
                    maximize
                Lichtfunktion H 0
                    nicht aktiv
                Dimmwert GH 0
                    0
                Dimming Direction GH 0
                    maximize
                Lichtfunktion G 0
                    nicht aktiv
            Leuchte1BLK VRB20
                Lasttyp 1
                Lampendefektbitposition 1
                    3E
                Fehlerort mittleres Byte DTC-DFCC 1
                    15
                Lichtfunktion A 1
                    Blinken rechts Hellphase
                Lichtfunktion B 1
                    nicht aktiv
                Dimmwert AB 1
                    127
                Lichtansteuerung HD AB 1
                    always
                Lichtfunktion C 1
                    nicht aktiv
                Lichtfunktion D 1
                    nicht aktiv
                Dimmwert CD 1
                    0
                Dimming Direction CD 1
                    maximize
                Lichtfunktion E 1
                    nicht aktiv
                Lichtfunktion F 1
                    nicht aktiv
                Dimmwert EF 1
                    0
                Dimming Direction EF 1
                    maximize
                Lichtfunktion G 1
                    nicht aktiv
                Lichtfunktion H 1
                    nicht aktiv
                Dimmwert GH 1
                    0
                Dimming Direction GH 1
                    maximize
            Leuchte2SL VLB10
                Lasttyp 2
                    4 - LED Tagfahrlichtmodul Signal
                Lampendefektbitposition 2
                    48
                Fehlerort mittleres Byte DTC-DFCC 2
                    4A
                Lichtfunktion A 2
                    Standlicht allgemein (Schlusslicht, Positionslicht, Begrenzungslicht)
                Lichtfunktion B 2
                    Parklicht links (beidseitiges Parklicht aktiviert li & re)
                Dimmwert AB 2
                    27
                Lichtansteuerung HD AB 2
                    always
                Lichtfunktion C 2
                    Tagfahrlicht
                Lichtfunktion D 2
                    nicht aktiv
                Dimmwert CD 2
                    100
                Dimming Direction CD 2
                    maximize
                Lichtfunktion E 2
                    Blinken links aktiv (beide Phasen)
                Lichtfunktion F 2
                    nicht aktiv
                Dimmwert EF 2
                    0
                Dimming Direction EF 2
                    minimize
                Lichtfunktion G 2
                    nicht aktiv
                Lichtfunktion H 2
                    nicht aktiv
                Dimmwert GH 2
                    0
                Dimming Direction GH 2
                    maximize
            Leuchte3SL VRB21
                Lasttyp 3
                Lampendefektbitposition 3
                    4C
                Fehlerort mittleres Byte DTC-DFCC 3
                    4C
                Lichtfunktion A 3
                Lichtfunktion B 3
                    Parklicht rechts
                Dimmwert AB 3
                    27
                Lichtansteuerung HD AB 3
                    always
                Lichtfunktion C 3
                    Tagfahrlicht
                Lichtfunktion D 3
                    nicht aktiv
                Dimmwert CD 3
                    100
                Dimming Direction CD 3
                    maximize
                Lichtfunktion E 3
                    Blinken rechts aktiv (beide Phasen)
                Lichtfunktion F 3
                    nicht aktiv
                Dimmwert EF 3
                    0
                Dimming Direction EF 3
                    minimize
                Lichtfunktion G 3
                    nicht aktiv
                Lichtfunktion H 3
                    nicht aktiv
                Dimmwert GH 3
                    0
                Dimming Direction GH 3
                    maximize
            Leuchte4TFL LB4
                Lasttyp 4
                    1 - LED Tagfahrlichtmodul Versorgung
                Lampendefektbitposition 4
                    48
                Fehlerort mittleres Byte DTC-DFCC 4
                    49
                Lichtfunktion A 4
                    Tagfahrlicht
                Lichtfunktion B 4
                    nicht aktiv
                Dimmwert AB 4
                    127
                Lichtansteuerung HD AB 4
                    always
                Lichtfunktion C 4
                Lichtfunktion D 4
                Dimmwert CD 4
                    127
                Dimming Direction CD 4
                    maximize
                Lichtfunktion E 4
                Lichtfunktion F 4
                    nicht aktiv
                Dimmwert EF 4
                    0
                Dimming Direction EF 4
                    minimize
                Lichtfunktion G 4
                    nicht aktiv
                Lichtfunktion H 4
                    nicht aktiv
                Dimmwert GH 4
                    0
                Dimming Direction GH 4
                    maximize
            Leuchte5 TFL RB32
                Lasttyp 5
                Lampendefektbitposition 5
                    4C
                Fehlerort mittleres Byte DTC-DFCC 5
                    4B
                Lichtfunktion A 5
                    Tagfahrlicht
                Lichtfunktion B 5
                    nicht aktiv
                Dimmwert AB 5
                    127
                Lichtansteuerung HD AB 5
                    always
                Lichtfunktion C 5
                Lichtfunktion D 5
                    Parklicht rechts
                Dimmwert CD 5
                    127
                Dimming Direction CD 5
                    maximize
                Lichtfunktion E 5
                Lichtfunktion F 5
                    nicht aktiv
                Dimmwert EF 5
                    0
                Dimming Direction EF 5
                    minimize
                Lichtfunktion G 5
                    nicht aktiv
                Lichtfunktion H 5
                    nicht aktiv
                Dimmwert GH 5
                    0
                Dimming Direction GH 5
                    maximize
            Leuchte6ABL LC5
                Lasttyp 6
                    3 - Xenon Abblendlicht
                Lampendefektbitposition 6
                    36
                Fehlerort mittleres Byte DTC-DFCC 6
                    1A
                Lichtfunktion A 6
                    Abblendlicht links
                Lichtfunktion B 6
                    Lichthupe generell
                Dimmwert AB 6
                    127
                Lichtansteuerung HD AB 6
                    always
                Lichtfunktion C 6
                    nicht aktiv
                Lichtfunktion D 6
                    nicht aktiv
                Dimmwert CD 6
                    0
                Dimming Direction CD 6
                    maximize
                Lichtfunktion E 6
                    nicht aktiv
                Lichtfunktion F 6
                    nicht aktiv
                Dimmwert EF 6
                    0
                Dimming Direction EF 6
                    maximize
                Lichtfunktion G 6
                    nicht aktiv
                Lichtfunktion H 6
                    nicht aktiv
                Dimmwert GH 6
                    0
                Dimming Direction GH 6
                    maximize
            Leuchte7ABL RB1
                Lasttyp 7
                Lampendefektbitposition 7
                    40
                Fehlerort mittleres Byte DTC-DFCC 7
                    1B
                Lichtfunktion A 7
                    Abblendlicht rechts
                Lichtfunktion B 7
                    Lichthupe generell
                Dimmwert AB 7
                    127
                Lichtansteuerung HD AB 7
                    always
                Lichtfunktion C 7
                    nicht aktiv
                Lichtfunktion D 7
                    nicht aktiv
                Dimmwert CD 7
                    0
                Dimming Direction CD 7
                    maximize
                Lichtfunktion E 7
                    nicht aktiv
                Lichtfunktion F 7
                    nicht aktiv
                Dimmwert EF 7
                    0
                Dimming Direction EF 7
                    maximize
                Lichtfunktion G 7
                    nicht aktiv
                Lichtfunktion H 7
                    nicht aktiv
                Dimmwert GH 7
                    0
                Dimming Direction GH 7
                    maximize
            Leuchte8FL LB39
                Lasttyp 8
                    not active
                Lampendefektbitposition 8
                    0
                Fehlerort mittleres Byte DTC-DFCC 8
                    0
                Lichtfunktion A 8
                    nicht aktiv
                Lichtfunktion B 8
                    nicht aktiv
                Dimmwert AB 8
                    0
                Lichtansteuerung HD AB 8
                    always
                Lichtfunktion C 8
                    nicht aktiv
                Lichtfunktion D 8
                    nicht aktiv
                Dimmwert CD 8
                    0
                Dimming Direction CD 8
                    maximize
                Lichtfunktion E 8
                    nicht aktiv
                Lichtfunktion F 8
                    nicht aktiv
                Dimmwert EF 8
                    0
                Dimming Direction EF 8
                    maximize
                Lichtfunktion G 8
                    nicht aktiv
                Lichtfunktion H 8
                    nicht aktiv
                Dimmwert GH 8
                    0
                Dimming Direction GH 8
                    maximize
            Leuchte9FL RB2
                Lasttyp 9
                    not active
                Lampendefektbitposition 9
                    0
                Fehlerort mittleres Byte DTC-DFCC 9
                    0
                Lichtfunktion A 9
                    nicht aktiv
                Lichtfunktion B 9
                    nicht aktiv
                Dimmwert AB 9
                    0
                Lichtansteuerung HD AB 9
                    always
                Lichtfunktion C 9
                    nicht aktiv
                Lichtfunktion D 9
                    nicht aktiv
                Dimmwert CD 9
                    0
                Dimming Direction CD 9
                    maximize
                Lichtfunktion E 9
                    nicht aktiv
                Lichtfunktion F 9
                    nicht aktiv
                Dimmwert EF 9
                    0
                Dimming Direction EF 9
                    maximize
                Lichtfunktion G 9
                    nicht aktiv
                Lichtfunktion H 9
                    nicht aktiv
                Dimmwert GH 9
                    0
                Dimming Direction GH 9
                    maximize
            Leuchte10SHUTTER LB23
                Lasttyp 10
                    2 - Shutter, Diagnosesensierung für 'LED low'
                Lampendefektbitposition 10
                    37
                Fehlerort mittleres Byte DTC-DFCC 10
                    1E
                Lichtfunktion A 10
                    Fernlicht links
                Lichtfunktion B 10
                    Lichthupe generell
                Dimmwert AB 10
                    127
                Lichtansteuerung HD AB 10
                    always
                Lichtfunktion C 10
                    nicht aktiv
                Lichtfunktion D 10
                    nicht aktiv
                Dimmwert CD 10
                    0
                Dimming Direction CD 10
                    maximize
                Lichtfunktion E 10
                    nicht aktiv
                Lichtfunktion F 10
                    nicht aktiv
                Dimmwert EF 10
                    0
                Dimming Direction EF 10
                    maximize
                Lichtfunktion G 10
                    nicht aktiv
                Lichtfunktion H 10
                    nicht aktiv
                Dimmwert GH 10
                    0
                Dimming Direction GH 10
                    maximize
            Leuchte11SHUTTER RB22
                Lasttyp 11
                Lampendefektbitposition 11
                    41
                Fehlerort mittleres Byte DTC-DFCC 11
                    1F
                Lichtfunktion A 11
                    Fernlicht rechts
                Lichtfunktion B 11
                    Lichthupe generell
                Dimmwert AB 11
                    127
                Lichtansteuerung HD AB 11
                    always
                Lichtfunktion C 11
                    nicht aktiv
                Lichtfunktion D 11
                    nicht aktiv
                Dimmwert CD 11
                    0
                Dimming Direction CD 11
                    maximize
                Lichtfunktion E 11
                    nicht aktiv
                Lichtfunktion F 11
                    nicht aktiv
                Dimmwert EF 11
                    0
                Dimming Direction EF 11
                    maximize
                Lichtfunktion G 11
                    nicht aktiv
                Lichtfunktion H 11
                    nicht aktiv
                Dimmwert GH 11
                    0
                Dimming Direction GH 11
                    maximize
            Leuchte12NL LB45
                Lasttyp 12
                    10 - allgemeine Scheinwerfer
                Lampendefektbitposition 12
                    38
                Fehlerort mittleres Byte DTC-DFCC 12
                    22
                Lichtfunktion A 12
                    Nebellicht links
                Lichtfunktion B 12
                    Abbiegelicht links
                Dimmwert AB 12
                    100
                Lichtansteuerung HD AB 12
                    always
                Lichtfunktion C 12
                    nicht aktiv
                Lichtfunktion D 12
                    nicht aktiv
                Dimmwert CD 12
                    0
                Dimming Direction CD 12
                    maximize
                Lichtfunktion E 12
                    nicht aktiv
                Lichtfunktion F 12
                    nicht aktiv
                Dimmwert EF 12
                    0
                Dimming Direction EF 12
                    maximize
                Lichtfunktion G 12
                    nicht aktiv
                Lichtfunktion H 12
                    nicht aktiv
                Dimmwert GH 12
                    0
                Dimming Direction GH 12
                    maximize
            Leuchte13NL RB5
                Lasttyp 13
                Lampendefektbitposition 13
                    42
                Fehlerort mittleres Byte DTC-DFCC 13
                    23
                Lichtfunktion A 13
                    Nebellicht rechts
                Lichtfunktion B 13
                    Abbiegelicht rechts
                Dimmwert AB 13
                    100
                Lichtansteuerung HD AB 13
                    always
                Lichtfunktion C 13
                    nicht aktiv
                Lichtfunktion D 13
                    nicht aktiv
                Dimmwert CD 13
                    0
                Dimming Direction CD 13
                    maximize
                Lichtfunktion E 13
                    nicht aktiv
                Lichtfunktion F 13
                    nicht aktiv
                Dimmwert EF 13
                    0
                Dimming Direction EF 13
                    maximize
                Lichtfunktion G 13
                    nicht aktiv
                Lichtfunktion H 13
                    nicht aktiv
                Dimmwert GH 13
                    0
                Dimming Direction GH 13
                    maximize
            Leuchte 35 LED Warnblinktaster C48
                Lasttyp 15
                    36 - LED Kleinleistung
                Lampendefektbitposition 15
                    0
                Fehlerort mittleres Byte DTC-DFCC 15
                    0
                Lichtfunktion A 15
                    nicht definiert 4C
                Lichtfunktion B 15
                    nicht aktiv
                Dimmwert AB 15
                    100
                Lichtansteuerung HD AB 15
                    always
                Lichtfunktion C 15
                    nicht aktiv
                Lichtfunktion D 15
                    nicht aktiv
                Dimmwert CD 15
                    0
                Dimming Direction CD 15
                    maximize
                Lichtfunktion E 15
                    nicht aktiv
                Lichtfunktion F 15
                    nicht aktiv
                Dimmwert EF 15
                    0
                Dimming Direction EF 15
                    maximize
                Lichtfunktion G 15
                    nicht aktiv
                Lichtfunktion H 15
                    nicht aktiv
                Dimmwert GH 15
                    0
                Dimming Direction GH 15
                    maximize
            Leuchte16BLK SLB35BLK SL KC9
                Lasttyp 16
                    not active
                Lampendefektbitposition 16
                    0
                Fehlerort mittleres Byte DTC-DFCC 16
                    0
                Lichtfunktion A 16
                    nicht aktiv
                Lichtfunktion B 16
                    nicht aktiv
                Dimmwert AB 16
                    0
                Lichtansteuerung HD AB 16
                    always
                Lichtfunktion C 16
                    nicht aktiv
                Lichtfunktion D 16
                    nicht aktiv
                Dimmwert CD 16
                    0
                Dimming Direction CD 16
                    maximize
                Lichtfunktion E 16
                    nicht aktiv
                Lichtfunktion F 16
                    nicht aktiv
                Dimmwert EF 16
                    0
                Dimming Direction EF 16
                    maximize
                Lichtfunktion G 16
                    nicht aktiv
                Lichtfunktion H 16
                    nicht aktiv
                Dimmwert GH 16
                    0
                Dimming Direction GH 16
                    maximize
            Leuchte17TFL R BLK SRB3TFL R BLK SR KC3
                Lasttyp 17
                    not active
                Lampendefektbitposition 17
                    0
                Fehlerort mittleres Byte DTC-DFCC 17
                    0
                Lichtfunktion A 17
                    nicht aktiv
                Lichtfunktion B 17
                    nicht aktiv
                Dimmwert AB 17
                    0
                Lichtansteuerung HD AB 17
                    always
                Lichtfunktion C 17
                    nicht aktiv
                Lichtfunktion D 17
                    nicht aktiv
                Dimmwert CD 17
                    0
                Dimming Direction CD 17
                    maximize
                Lichtfunktion E 17
                    nicht aktiv
                Lichtfunktion F 17
                    nicht aktiv
                Dimmwert EF 17
                    0
                Dimming Direction EF 17
                    maximize
                Lichtfunktion G 17
                    nicht aktiv
                Lichtfunktion H 17
                    nicht aktiv
                Dimmwert GH 17
                    0
                Dimming Direction GH 17
                    maximize
            Leuchte18BLK HLA60
                Lasttyp 18
                    12 - Blinkleuchten
                Lampendefektbitposition 18
                    8
                Fehlerort mittleres Byte DTC-DFCC 18
                    16
                Lichtfunktion A 18
                Lichtfunktion B 18
                    nicht aktiv
                Dimmwert AB 18
                    100
                Lichtansteuerung HD AB 18
                    always
                Lichtfunktion C 18
                    nicht aktiv
                Lichtfunktion D 18
                    nicht aktiv
                Dimmwert CD 18
                    0
                Dimming Direction CD 18
                    maximize
                Lichtfunktion E 18
                    nicht aktiv
                Lichtfunktion F 18
                    nicht aktiv
                Dimmwert EF 18
                    0
                Dimming Direction EF 18
                    maximize
                Lichtfunktion G 18
                    nicht aktiv
                Lichtfunktion H 18
                    nicht aktiv
                Dimmwert GH 18
                    0
                Dimming Direction GH 18
                    maximize
            Leuchte19BLK HRC31
                Lasttyp 19
                    12 - Blinkleuchten
                Lampendefektbitposition 19
                    18
                Fehlerort mittleres Byte DTC-DFCC 19
                    18
                Lichtfunktion A 19
                Lichtfunktion B 19
                    nicht aktiv
                Dimmwert AB 19
                    100
                Lichtansteuerung HD AB 19
                    always
                Lichtfunktion C 19
                    nicht aktiv
                Lichtfunktion D 19
                    nicht aktiv
                Dimmwert CD 19
                    0
                Dimming Direction CD 19
                    maximize
                Lichtfunktion E 19
                    nicht aktiv
                Lichtfunktion F 19
                    nicht aktiv
                Dimmwert EF 19
                    0
                Dimming Direction EF 19
                    maximize
                Lichtfunktion G 19
                    nicht aktiv
                Lichtfunktion H 19
                    nicht aktiv
                Dimmwert GH 19
                    0
                Dimming Direction GH 19
                    maximize
            Leuchte20BR LA71
                Lasttyp 20
                    34 - LED Bremsleuchten
                Lampendefektbitposition 20
                    9
                Fehlerort mittleres Byte DTC-DFCC 20
                    2B
                Lichtfunktion A 20
                    Bremslicht
                Lichtfunktion B 20
                    nicht aktiv
                Dimmwert AB 20
                    100
                Lichtansteuerung HD AB 20
                    always
                Lichtfunktion C 20
                    nicht aktiv
                Lichtfunktion D 20
                    nicht aktiv
                Dimmwert CD 20
                    0
                Dimming Direction CD 20
                    maximize
                Lichtfunktion E 20
                    nicht aktiv
                Lichtfunktion F 20
                    nicht aktiv
                Dimmwert EF 20
                    0
                Dimming Direction EF 20
                    maximize
                Lichtfunktion G 20
                    nicht aktiv
                Lichtfunktion H 20
                    nicht aktiv
                Dimmwert GH 20
                    0
                Dimming Direction GH 20
                    maximize
            Leuchte21BR RC8
                Lasttyp 21
                Lampendefektbitposition 21
                    19
                Fehlerort mittleres Byte DTC-DFCC 21
                    2D
                Lichtfunktion A 21
                    Bremslicht
                Lichtfunktion B 21
                    nicht aktiv
                Dimmwert AB 21
                    100
                Lichtansteuerung HD AB 21
                    always
                Lichtfunktion C 21
                    nicht aktiv
                Lichtfunktion D 21
                    nicht aktiv
                Dimmwert CD 21
                    0
                Dimming Direction CD 21
                    maximize
                Lichtfunktion E 21
                    nicht aktiv
                Lichtfunktion F 21
                    nicht aktiv
                Dimmwert EF 21
                    0
                Dimming Direction EF 21
                    maximize
                Lichtfunktion G 21
                    nicht aktiv
                Lichtfunktion H 21
                    nicht aktiv
                Dimmwert GH 21
                    0
                Dimming Direction GH 21
                    maximize
            Leuchte22BR MA57
                Lasttyp 22
                Lampendefektbitposition 22
                    29
                Fehlerort mittleres Byte DTC-DFCC 22
                    2C
                Lichtfunktion A 22
                    Bremslicht
                Lichtfunktion B 22
                    nicht aktiv
                Dimmwert AB 22
                    100
                Lichtansteuerung HD AB 22
                    always
                Lichtfunktion C 22
                    Quittierungsfunktion 1
                Lichtfunktion D 22
                    nicht aktiv
                Dimmwert CD 22
                    32
                Dimming Direction CD 22
                    maximize
                Lichtfunktion E 22
                    nicht aktiv
                Lichtfunktion F 22
                    nicht aktiv
                Dimmwert EF 22
                    0
                Dimming Direction EF 22
                    maximize
                Lichtfunktion G 22
                    nicht aktiv
                Lichtfunktion H 22
                    nicht aktiv
                Dimmwert GH 22
                    0
                Dimming Direction GH 22
                    maximize
            Leuchte23SL HLC10
                Lasttyp 23
                    32 - allgemeine LED bis 12W
                Lampendefektbitposition 23
                    A
                Fehlerort mittleres Byte DTC-DFCC 23
                    29
                Lichtfunktion A 23
                Lichtfunktion B 23
                Dimmwert AB 23
                    100
                Lichtansteuerung HD AB 23
                    always
                Lichtfunktion C 23
                    nicht aktiv
                Lichtfunktion D 23
                    nicht aktiv
                Dimmwert CD 23
                    0
                Dimming Direction CD 23
                    maximize
                Lichtfunktion E 23
                    nicht aktiv
                Lichtfunktion F 23
                    nicht aktiv
                Dimmwert EF 23
                    0
                Dimming Direction EF 23
                    maximize
                Lichtfunktion G 23
                    nicht aktiv
                Lichtfunktion H 23
                    nicht aktiv
                Dimmwert GH 23
                    0
                Dimming Direction GH 23
                    maximize
            Leuchte24SL HRA65
                Lasttyp 24
                Lampendefektbitposition 24
                    1A
                Fehlerort mittleres Byte DTC-DFCC 24
                    2A
                Lichtfunktion A 24
                Lichtfunktion B 24
                    Parklicht rechts
                Dimmwert AB 24
                    100
                Lichtansteuerung HD AB 24
                    always
                Lichtfunktion C 24
                    nicht aktiv
                Lichtfunktion D 24
                    nicht aktiv
                Dimmwert CD 24
                    0
                Dimming Direction CD 24
                    maximize
                Lichtfunktion E 24
                    nicht aktiv
                Lichtfunktion F 24
                    nicht aktiv
                Dimmwert EF 24
                    0
                Dimming Direction EF 24
                    maximize
                Lichtfunktion G 24
                    nicht aktiv
                Lichtfunktion H 24
                    nicht aktiv
                Dimmwert GH 24
                    0
                Dimming Direction GH 24
                    maximize
            Leuchte25KZL HA59
                Lasttyp 25
                    43 - allgemeine LED
                Lampendefektbitposition 25
                    28
                Fehlerort mittleres Byte DTC-DFCC 25
                    30
                Lichtfunktion A 25
                Lichtfunktion B 25
                    nicht aktiv
                Dimmwert AB 25
                    127
                Lichtansteuerung HD AB 25
                    always
                Lichtfunktion C 25
                    nicht aktiv
                Lichtfunktion D 25
                    nicht aktiv
                Dimmwert CD 25
                    0
                Dimming Direction CD 25
                    maximize
                Lichtfunktion E 25
                    nicht aktiv
                Lichtfunktion F 25
                    nicht aktiv
                Dimmwert EF 25
                    0
                Dimming Direction EF 25
                    maximize
                Lichtfunktion G 25
                    nicht aktiv
                Lichtfunktion H 25
                    nicht aktiv
                Dimmwert GH 25
                    0
                Dimming Direction GH 25
                    maximize
            Leuchte26NSL LA72
                Lasttyp 26
                    9 - allgemeine Glühlampe 27W, auch H15
                Lampendefektbitposition 26
                    C
                Fehlerort mittleres Byte DTC-DFCC 26
                    2E
                Lichtfunktion A 26
                    Nebelschlusslicht wenn kein Anhaenger gesteckt
                Lichtfunktion B 26
                    nicht aktiv
                Dimmwert AB 26
                    100
                Lichtansteuerung HD AB 26
                    only if closed
                Lichtfunktion C 26
                    nicht aktiv
                Lichtfunktion D 26
                    nicht aktiv
                Dimmwert CD 26
                    0
                Dimming Direction CD 26
                    maximize
                Lichtfunktion E 26
                    nicht aktiv
                Lichtfunktion F 26
                    nicht aktiv
                Dimmwert EF 26
                    0
                Dimming Direction EF 26
                    maximize
                Lichtfunktion G 26
                    nicht aktiv
                Lichtfunktion H 26
                    nicht aktiv
                Dimmwert GH 26
                    0
                Dimming Direction GH 26
                    maximize
            Leuchte27NSL RC6
                Lasttyp 27
                    not active
                Lampendefektbitposition 27
                    0
                Fehlerort mittleres Byte DTC-DFCC 27
                    0
                Lichtfunktion A 27
                    nicht aktiv
                Lichtfunktion B 27
                    nicht aktiv
                Dimmwert AB 27
                    0
                Lichtansteuerung HD AB 27
                    always
                Lichtfunktion C 27
                    nicht aktiv
                Lichtfunktion D 27
                    nicht aktiv
                Dimmwert CD 27
                    0
                Dimming Direction CD 27
                    maximize
                Lichtfunktion E 27
                    nicht aktiv
                Lichtfunktion F 27
                    nicht aktiv
                Dimmwert EF 27
                    0
                Dimming Direction EF 27
                    maximize
                Lichtfunktion G 27
                    nicht aktiv
                Lichtfunktion H 27
                    nicht aktiv
                Dimmwert GH 27
                    0
                Dimming Direction GH 27
                    maximize
            Leuchte28RFL LC11
                Lasttyp 28
                Lampendefektbitposition 28
                    B
                Fehlerort mittleres Byte DTC-DFCC 28
                    31
                Lichtfunktion A 28
                    Rueckfahrlicht
                Lichtfunktion B 28
                    nicht aktiv
                Dimmwert AB 28
                    100
                Lichtansteuerung HD AB 28
                    always
                Lichtfunktion C 28
                    nicht aktiv
                Lichtfunktion D 28
                    nicht aktiv
                Dimmwert CD 28
                    0
                Dimming Direction CD 28
                    maximize
                Lichtfunktion E 28
                    nicht aktiv
                Lichtfunktion F 28
                    nicht aktiv
                Dimmwert EF 28
                    0
                Dimming Direction EF 28
                    maximize
                Lichtfunktion G 28
                    nicht aktiv
                Lichtfunktion H 28
                    nicht aktiv
                Dimmwert GH 28
                    0
                Dimming Direction GH 28
                    maximize
            Leuchte29RFL RA64
                Lasttyp 29
                Lampendefektbitposition 29
                    1B
                Fehlerort mittleres Byte DTC-DFCC 29
                    32
                Lichtfunktion A 29
                    Rueckfahrlicht
                Lichtfunktion B 29
                    nicht aktiv
                Dimmwert AB 29
                    100
                Lichtansteuerung HD AB 29
                    always
                Lichtfunktion C 29
                    nicht aktiv
                Lichtfunktion D 29
                    nicht aktiv
                Dimmwert CD 29
                    0
                Dimming Direction CD 29
                    maximize
                Lichtfunktion E 29
                    nicht aktiv
                Lichtfunktion F 29
                    nicht aktiv
                Dimmwert EF 29
                    0
                Dimming Direction EF 29
                    maximize
                Lichtfunktion G 29
                    nicht aktiv
                Lichtfunktion H 29
                    nicht aktiv
                Dimmwert GH 29
                    0
                Dimming Direction GH 29
                    maximize
            Leuchte30FR LC72
                Lasttyp 30
                Lampendefektbitposition 30
                    0
                Fehlerort mittleres Byte DTC-DFCC 30
                    2
                Lichtfunktion A 30
                    Fussraumlicht
                Lichtfunktion B 30
                    nicht aktiv
                Dimmwert AB 30
                    100
                Lichtansteuerung HD AB 30
                    always
                Lichtfunktion C 30
                    nicht aktiv
                Lichtfunktion D 30
                    nicht aktiv
                Dimmwert CD 30
                    0
                Dimming Direction CD 30
                    maximize
                Lichtfunktion E 30
                    nicht aktiv
                Lichtfunktion F 30
                    nicht aktiv
                Dimmwert EF 30
                    0
                Dimming Direction EF 30
                    maximize
                Lichtfunktion G 30
                    nicht aktiv
                Lichtfunktion H 30
                    nicht aktiv
                Dimmwert GH 30
                    0
                Dimming Direction GH 30
                    maximize
            Leuchte31AMBL 1C61
                Lasttyp 31
                    not active
                Lampendefektbitposition 31
                    0
                Fehlerort mittleres Byte DTC-DFCC 31
                    3
                Lichtfunktion A 31
                    Ambientelicht 1
                Lichtfunktion B 31
                    nicht aktiv
                Dimmwert AB 31
                    0
                Lichtansteuerung HD AB 31
                    always
                Lichtfunktion C 31
                    nicht aktiv
                Lichtfunktion D 31
                    nicht aktiv
                Dimmwert CD 31
                    0
                Dimming Direction CD 31
                    maximize
                Lichtfunktion E 31
                    nicht aktiv
                Lichtfunktion F 31
                    nicht aktiv
                Dimmwert EF 31
                    0
                Dimming Direction EF 31
                    maximize
                Lichtfunktion G 31
                    nicht aktiv
                Lichtfunktion H 31
                    nicht aktiv
                Dimmwert GH 31
                    0
                Dimming Direction GH 31
                    maximize
            Leuchte32AMBL 2C35
                Lasttyp 32
                    not active
                Lampendefektbitposition 32
                    0
                Fehlerort mittleres Byte DTC-DFCC 32
                    4
                Lichtfunktion A 32
                    Ambientelicht 2
                Lichtfunktion B 32
                    nicht aktiv
                Dimmwert AB 32
                    0
                Lichtansteuerung HD AB 32
                    always
                Lichtfunktion C 32
                    nicht aktiv
                Lichtfunktion D 32
                    nicht aktiv
                Dimmwert CD 32
                    0
                Dimming Direction CD 32
                    maximize
                Lichtfunktion E 32
                    nicht aktiv
                Lichtfunktion F 32
                    nicht aktiv
                Dimmwert EF 32
                    0
                Dimming Direction EF 32
                    maximize
                Lichtfunktion G 32
                    nicht aktiv
                Lichtfunktion H 32
                    nicht aktiv
                Dimmwert GH 32
                    0
                Dimming Direction GH 32
                    maximize
            Leuchte33AMBL 3C36
                Lasttyp 33
                    not active
                Lampendefektbitposition 33
                    0
                Fehlerort mittleres Byte DTC-DFCC 33
                    5
                Lichtfunktion A 33
                    Ambientelicht 3
                Lichtfunktion B 33
                    nicht aktiv
                Dimmwert AB 33
                    0
                Lichtansteuerung HD AB 33
                    always
                Lichtfunktion C 33
                    nicht aktiv
                Lichtfunktion D 33
                    nicht aktiv
                Dimmwert CD 33
                    0
                Dimming Direction CD 33
                    maximize
                Lichtfunktion E 33
                    nicht aktiv
                Lichtfunktion F 33
                    nicht aktiv
                Dimmwert EF 33
                    0
                Dimming Direction EF 33
                    maximize
                Lichtfunktion G 33
                    nicht aktiv
                Lichtfunktion H 33
                    nicht aktiv
                Dimmwert GH 33
                    0
                Dimming Direction GH 33
                    maximize
            Leuchte34AMBL 4C37
                Lasttyp 34
                    not active
                Lampendefektbitposition 34
                    0
                Fehlerort mittleres Byte DTC-DFCC 34
                    6
                Lichtfunktion A 34
                    Ambientelicht 4
                Lichtfunktion B 34
                    nicht aktiv
                Dimmwert AB 34
                    0
                Lichtansteuerung HD AB 34
                    always
                Lichtfunktion C 34
                    nicht aktiv
                Lichtfunktion D 34
                    nicht aktiv
                Dimmwert CD 34
                    0
                Dimming Direction CD 34
                    maximize
                Lichtfunktion E 34
                    nicht aktiv
                Lichtfunktion F 34
                    nicht aktiv
                Dimmwert EF 34
                    0
                Dimming Direction EF 34
                    maximize
                Lichtfunktion G 34
                    nicht aktiv
                Lichtfunktion H 34
                    nicht aktiv
                Dimmwert GH 34
                    0
                Dimming Direction GH 34
                    maximize
            Vernetzung
                Klimaelektronik
                    installed
                Anhaengeranschlussgeraet
                    not installed
                Bremsen Steuergeraet
                    installed
                Getriebesteuergeraet
                    installed
                Kunden spezifisches Funktions SG
                    not installed
                Kopfraumheizung
                    not installed
                UGDO
                    not installed
            HW_Verbau
                Aussentemperatursensor
                    installed
                Brake pad wear
                    installed
                PTC Zuheizer
                    not installed
                Insufficient brake fluid
                    installed
                Insufficient coolant
                    installed
                Insufficient washer fluid
                    installed
                Kontaktschalter fuer Motorhaube
                    installed
                Status Tankdeckelverriegelung
                    not active
                Druckklappe
                    not installed
                Ladesteckerverriegelung
                    not installed
                Signalhorn ohne KL15
                    active
                Elektrische Laderaumabdeckung
                    not installed
                Elektrische Laderaumabdeckung aktiv
                    not active
            Querschnitts_funktionen
                Lenkungsanordnung
                    Left
                Verkehrsseite
                    Right
                Brand
                    Skoda
                Personalisierungsuebernahme
                    not installed
                Bedien und Anzeigeprotokoll
                    active
                Schnittstelle TrackingSystem
                    not active
                Codierungsabsicherung
                    not active
                CAN Wecken bei Softtouchbetaetigung
                    active
                Hardware Eingang Drucktankklappenstatus
                    Pin 31
                Klemmenfehler auf CAN ausgeben
                    active
                Fahrgeschwindigkeit aus ESP 21
                    not active
            Aussenlicht_uebergreifend
                Light Control Module
                    not installed
                Kontrollleuchte fuer Begrenzungslicht
                    integriert in Suchbeleuchtung
                Standlicht aus
                    active
                Parklicht ueber LSS aktiviert
                    One-sided
                Standlichtreduzierung mit beidseitigem Parklicht
                    active
                Menueeinstellung CHO LHO
                    Menuesteuerung Zeit aktivieren
                Faktor fuer Verfügbarkeitstimer
                    Faktor fuer x5 Minuten
                Umfeldleuchte als Manoevrierleuchte
                    not active
                Fahrlichtwarnung Hinweis Konfig
                    kein Hinweis
                Fahrlicht Hinweis mehrfach
                    not active
                Bedingungen zur Standlichtbegrenzung
                    abschaltbar über Energiemanagement
                Standlicht-Verfügbarkeit
                    24 s
                bewusstes Standlicht
                    Aktive Begrenzung
                Bedingungen zur Parklichtbegrenzung
                Lichtwarnungsverhalten
                    klemmenabhaengig
                Coming Home Verbaustatus
                    automatic
                Menuesteuerung Coming Home Werkseinstellung
                    active
                Coming home Leuchten
                    Low beam
                Menueeinstellung Cominghome
                    10 seconds
                Coming-home Einschaltereignis
                    driver door
                Helligkeitsschwelle Infrarot-Messung
                    12 lx
                Leaving-Home Verbausstatus
                    Enabled
                Menuesteuerung Leaving-home Freischaltung per BAP
                    active
                LDS mit Nebellicht
                    Yes
                Lichtdrehschalter (LDS)
                    discrete
                Menueeinstellung Leaving-home Zeit per BAP
                    10 seconds
                Helligkeitsschwelle Forward-Messung
                    46400 lx
                LDS mit Nebel Schlusslicht
                    Yes
                LDS mit AFL
                    Yes
                LDS mit Standlichtstellung
                    Yes
                HVLM Ladezustandsanzeige
                    No
                LCM blinker
                    FALSE
                Allwetterlicht
                    not installed
            Aussenlicht_Front
                Abblendlicht Leuchtentyp
                    GDL
                Zahl der aktiven Scheinwerfer auf 2 limitieren
                    in Betrieb lassen
                Lichthupe bei Zuendung aus moeglich
                    active
                Allwetterlicht Einschaltgrenze
                    50 km/h
                Allwetterlicht Ausschaltgrenze
                    50 km/h
                Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht
                    not active
                Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich
                    not active
                Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge
                    active
                Standlicht aktiviert zusaetzlich Tagfahrlicht
                    active
                Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten
                    not active
                Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht
                    not active
                Tagfahrlichtkontrollleuchte
                    not active
                Fahrlicht bei Tag
                    Daytime running lights
                Tagfahrlicht nur in Schalterstellung AUTO
                    not active
                Signaturlicht verbaut
                    not installed
                Signaturlicht HMI-default Anzeige im Kombiinstrument
                    not active
                TFL Abschaltung ueber Geschwindigkeit
                    not active
                Geschwindigkeitsabhaengiges TFL
                    5 km/h
            Aussenlicht_Heck
                Bremslicht ist auch Blinklicht
                    No
                Schlusslicht mit Bremslichtfunktion
                    not active
                Notbremsanzeige NBA
                    active
                Umgreifende Heckklappe
                    not installed
                Nebelschlusslicht Warngeschwindigkeit
                    0 km/h
            Aussenlicht_Blinker
                Warnblinken durch Fahrerassistenz
                    not active
                Komfortblinken Blinkzyklen
                    3
                Abbruch Komfortblinken
                    active
                Komfortblinken
                    active
                Blinkkontrolleuchte fuer Anhaenger
                    separte
                Schluessel Anlern Blinken
                    not active
                UGDO  Anlern Blinken
                    not active
                ZV Blinken zu
                    not active
                ZV Blinken auf
                    not active
                Telematikblinken1 STS Blinken Telematikblinken2 OCU Blinken
                    not active
                DWA Schaerfungsquittung
                    not active
                DWA Alarm Blinken
                    not active
                Taxialarmblinken
                    not active
                Panikblinken
                    not active
                Multi kollisions Blinken
                    not active
                Emergency alert blinken
                    not active
                Notwarn blinken NBA Phase 2
                    not active
                dynamisch blinken 10
                    not active
                Richtungs blinken rechts
                    not active
                Richtungs blinken links
                    not active
                ABBA Blinken
                    not active
                Crashblinken
                    not active
                Warnblinken Zuendung EIN
                    not active
                Warnblinken Zuendung AUS
                    not active
                Dynamische Blink Delay
                    50 ms
            Static AFS light
                bei Rueckwaertsfahrt
                    both sides
                Zeitwert Einschaltzeit Abbiegelicht
                    15 min
                Vorschrift
                    ECE R119
                Untere Geschwindigkeitsschwelle
                    0.0 km/h
                Obere Geschwindigkeitsschwelle
                    40.0 km/h
                Steering wheel angle, offset
                    -0.2 °
                Unterer Lenkradwinkel
                    30 °
                Oberer Lenkradwinkel
                    90 °
                Abdimmgeschwindigkeit
                    50.0 %/s
                Maximaltemperatur
                    100.0 °C
                obere Grenztemperatur
                    95.0 °C
                untere Grenztemperatur
                    80.0 °C
            Sonderfunktionen
                Sonderfunktionen 1
                    not installed
                Sonderfunktionen
                    not enabled
                Signalprioritaet fuer Blinker
                    SMLS
            Fernlicht_assistent
                Erweiterte Fernlichtsteuerung
                    AFS, BCM-Fernlicht
                Menuesteuerung Fernlichtassistent
                    Not present
                Fernlichtassistent Reset
                    active
                Menuesteuerung Fernlichtassistent Werkseinstellung
                    Not present
                Will Beam assistant, responsivity adjustable via BAP
                    Present
            Leuchtweitenregulierung
                sensor headlight range control installed
                    not installed
                sLWR verbaut
                    not installed
                1 Sensor LWR
                    1-Sensor LWR
                Fahrwerk Variante
                    Verbundlenkerhinterachse
                sLWR bei Abblendlicht
                    active
                Quelle Hoehenwerte
                    BCM
                Aktivierung LWR Fehlerlampe
                    not active
                Logik PWM Signal
                    Negative
                sLWR nach Motorstart
                    not active
                Entprellung Fehlerlampe
                    10.0 s
                Fail Safe sLWR
                    62.0 %
                Zyklus sLWR
                    0.00 s
                sLWR Touristenlicht
                    0.0 %
                sLWR SW Grad
                    1000.0 %/s
                sLWR Hysterese
                    0.0 %
                diagnose soll toleranz
                    15 %
                Ansteuerung untere grenze
                    0.0 %
                Ansteuerung obere grenze
                    100.0 %
                Lineare Abbildung
                    0
                fac Pwm Zu Hoehe V 1
                    3.00 mm/%
                fac Pwm Zu Hoehe H 1
                    5.00 mm/%
                fac Pwm Zu Hoehe V 2
                    3.00 mm/%
                fac Pwm Zu Hoehe H 2
                    5.00 mm/%
                Achssensor PWM Wert Einfederung Sensor vorn
                    3.00 mm/%
                Achssensor PWM Wert Einfederung Sensor H4
                    5.00 mm/%
                Achsabstand des Fahrzeuges
                    2700 mm
                lwr lFzg Sw Abstand
                    550 mm
                lwr lFzg Sw Hoehe
                    680 mm
                pa fDynFiltStatLwr
                    100 Hz
                fFiltEinf
                    0.03 Hz
                pa fFiltSwNeigung
                    0.03 Hz
                lwr pwm untere schwelle
                    5.0 %
                lwr pwm obere schwelle
                    95.0 %
                max v slwr
                    255 km/h
                lwr lEinfOffsHFahrw 1
                    0 mm
                lwr lEinfOffsHFahrw 2
                    0 mm
                lwr lEinfOffsHFahrw 3
                    0 mm
                lwr lEinfOffsHFahrw 4
                    0 mm
            lwr_ofs_RSw_Ah1S
                x0
                    -3.71 %
                x1
                    -2.96 %
                x2
                    -2.04 %
                x3
                    -1.48 %
                x4
                    -0.37 %
                y0
                    -0.20
                y1
                    -0.10
                y2
                    -0.05
                y3
                    -0.01
                y4
                    0.00
            Kennlinie_sLWR_Soll
                x0
                    -100.00 %
                x1
                    -83.00 %
                x2
                    -67.00 %
                x3
                    -50.00 %
                x4
                    -33.00 %
                x5
                    -17.00 %
                x6
                    0.00 %
                x7
                    0.00
                x8
                    0.00 %
                x9
                    0.00 %
                y0
                    20.0 %
                y1
                    30.0 %
                y2
                    41.0 %
                y3
                    48.0 %
                y4
                    55.0 %
                y5
                    58.0 %
                y6
                    62.0 %
                y7
                    62.0 %
                y8
                    62.0 %
                y9
                    62.0 %
            Activate left/right hand drive switch-over
                    not active
            Assistance light functions
                Regen Lichtsensor
                    LIN Regen Licht Sensor
                Feuchtesensor
                    installed
                Assistenzfahrlicht bei Regen
                    active
                Sonnensensor
                    not installed
                LS Error Ausgabe
                    not active
                Maskierung Regenfunktion
                    not active
                Lichtsensorempfindlichkeit
                    normal
            Light sensor
                Einschaltgrenze CHO LHO
                    600 lx
                Daemmerungsgrenze, Hysterese obergrenze
                    1200 lx
                Daemmerungsgrenze Hysterese untergrenze
                    2200 lx
                Helligkeitsgrenze sehr hell
                    2000 lx
                Helligkeitsgrenze Licht  einschalten
                    1200 lx
                Helligkeitsgrenze Licht ausschalten
                    2200 lx
                Minimale Beleuchtungsstaerke
                    0 lx
                Maximale Beleuchtungsstaerke
                    225300 lx
                Minimale Ausgangsspannung
                    53255 mV
                Maximale Ausgangsspannung
                    37905 mV
                Tunnel einschalt verzoegerung
                    2
                ECE Lichteinschaltschwelle
                    59395 lx
                Helligkeitsgrenze Licht ausschalten red
                    5000
                HMI Wiper Comfort Rain Sensor OFF
                    not active
                HMI Exterior light on highway
                    not active
                HMI Exterior light on rain
                    not active
                LS Error Ausgabe
                    not active
                HMI exterior light sensitivity
                    frueh
            LuB Lichtrouter Kennlinie 1
                x0
                    0.0 %
                x1
                    5.0 %
                x2
                    50.0 %
                x3
                    75.0 %
                x4
                    110.0
                x5
                    126.5
                y0
                    0.0 %
                y1
                    6.0 %
                y2
                    16.0 %
                y3
                    30.0 %
                y4
                    60.0 %
                y5
                    100.0 %
            Light configuration
                    2134001402007F000000000000000000213E001504007F0000000000000000000448004A08091B140064060080000000044C004C080A1B1400640700800000000148004914007F08097F060080000000014C004B14007F080A7F0700800000000336001A0B0F7F0000000000000000000340001B0C0F7F00000000000000000000000000000000000000000000000000000000000000000000000000000000000237001E0D0F7F0000000000000000000241001F0E0F7F0000000000000000000A3800221216640000000000000000000A420023131764000000000000000000
            Leuchtenkonfiguration_Aussenlich_Heck
                    0C0800160200640000000000000000000C1800180400640000000000000000002209002B1800640000000000000000002219002D1800640000000000000000002229002C180064240020000000000000200A0029080964000000000000000000201A002A080A640000000000000000002B28003008007F000000000000000000090C002E1A00E400000000000000000000000000000000000000000000000000090B0031190064000000000000000000091B0032190064000000000000000000
            Leuchtenkonfiguration_Sonstiges
                    0000000000000000000000000000000000000000000000000000000000000000240000022B0064000000000000000000000000032D0000000000000000000000000000042E0000000000000000000000000000052F000000000000000000000000000006300000000000000000000000240000004C0064000000000000000000
            debug_light_function
                Adresse
                    0
                Bitmask
                    0
                Offset
                    0
                Divisor
                    0
                Polaritaet
                    0
                Aktivierung
                    0
            Int. light, 2nd generation
                Aufloesung Dimmzeit
                    0.25 s
                weicher Farbwechsel
                    not active
                Tuertafelbeleuchtung mehrfarbig
                    active
                Instrumententafelbeleuchtung mehrfarbig
                    not active
                Cockpitbeleuchtung mehrfarbig
                    not active
                Lautsprecherbeleuchtung mehrfarbig
                    not active
                Mittelkonsolenbeleuchtung mehrfarbig
                    not active
                Dachbeleuchtung mehrfarbig
                    not active
                Panoramaschiebedachbeleuchtung mehrfarbig
                    not active
                Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren
                    not active
                BAP Farbwert Farbe 1
                    2
                BAP Farbwert Farbe 2
                    3
                BAP Farbwert Farbe 3
                    1
                Defaultwert Ambienteprofil Mittelkonsole
                    80 %
                Defaultwert Ambienteprofil Dach
                    80 %
                Defaultwert Ambienteprofil Farbe
                    2
                Defaultwert Ambienteprofil Fussraum
                    20 %
                Defaultwert Ambienteprofil Tuer
                    0 %
                Defaultwert Ambienteprofil Vorn
                    0 %
                Helligkeit Tuertafelbeleuchtung nicht berechnen
                    active
                Helligkeit Instrumententafelbeleuchtung nicht berechnen
                    active
                Helligkeit Cockpitbeleuchtung nicht berechnen
                    active
                Helligkeit Lautsprecherbeleuchtung nicht berechnen
                    active
                Helligkeit Mittelkonsolenbeleuchtung nicht berechnen
                    active
                Helligkeit Dachbeleuchtung nicht berechnen
                    active
                Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen
                    active
                Farbausgabe Tuertafelbeleuchtung nicht berechnen
                    active
                Farbausgabe Instrumententafelbeleuchtung nicht berechnen
                    active
                Farbausgabe Cockpitbeleuchtung nicht berechnen
                    active
                Farbausgabe Lautsprecherbeleuchtung nicht berechnen
                    active
                Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen
                    active
                Farbausgabe Dachbeleuchtung nicht berechnen
                    active
                Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen
                    active
                Innenlicht bei offenem Heckdeckel einschalten
                    active
                KL30G ohne PWM
                    not active
                Weckfaehigkeit klemme 30G
                    not installed
                LIN-Dachkonsole mit Flaechenlicht
                    not installed
                Tuerinnengriffbeleuchtung mit I-Tafel
                    not installed
                Tuerinnengriff mit Tuertafel
                    not installed
            Interior light, light configuration
                Ambiente Applikationsleisten in Tuertafel
                    not installed
                Ambiente Lautsprecher
                    not installed
                Ambiente Applikationsleisten in Instrumententafel
                    not installed
                Cockpitbeleuchtung
                    not installed
                    not installed
                Dachbeleuchtung
                    not installed
                    not installed
                Fussraumbeleuchtung
                    installed
                Farbwahl ueber HMI
                    not installed
                Farbwahl ueber Fahrprofil
                    not installed
                LIN-Dachkonsole lokal aktivierbar
                    not active
                Ambientemenue mit globalem aus
                    not active
                Ambientemenue mit alle Zonen
                    not active
                Ambient Farbliste HMI
                    not active
                Frei Farbwahl ueber HMI
                    not active
            Interior lighting, parameter
                p t verzoegerung einstieg innenlicht
                    0.0 s
                p t verzoegerung ausstieg innenlicht
                    0.0 s
                p t verzoegerung oeffnen innenlicht
                    0.0 s
                p t verzoegerung entriegelt innenlicht
                    0.0 s
                p t verzoegerung schliessen innenlicht
                    0.0 s
                p t verzoegerung schluessel ab innenlicht
                    0.0 s
                p t verzoegerung verriegelt innenlicht
                    0.0 s
                p t verzoegerung einstieg tueren
                    0.0 s
                p t verzoegerung ausstieg tueren
                    0.0 s
                p t verzoegerung oeffnen tueren
                    0.0 s
                p t verzoegerung entriegelt tueren
                    0.0 s
                p t verzoegerung schliessen tueren
                    0.0 s
                p t verzoegerung schluessel ab tueren
                    0.0 s
                p t verzoegerung verriegelt tueren
                    0.0 s
                p t verzoegerung einstieg fussraum
                    1.0 s
                p t verzoegerung ausstieg fussraum
                    0.0 s
                p t verzoegerung oeffnen fussraum
                    0.0 s
                p t verzoegerung entriegelt fussraum
                    0.0 s
                p t verzoegerung schliessen fussraum
                    0.0 s
                p t verzoegerung schluessel ab fussraum
                    0.0 s
                p t verzoegerung verriegelt fussraum
                    0.0 s
                p t verzoegerung einstieg cockpit
                    0.0 s
                p t verzoegerung ausstieg cockpit
                    0.0 s
                p t verzoegerung oeffnen cockpit
                    0.0 s
                p t verzoegerung entriegelt cockpit
                    0.0 s
                p t verzoegerung schliessen cockpit
                    0.0 s
                p t verzoegerung schluessel ab cockpit
                    0.0 s
                p t verzoegerung verriegelt cockpit
                    0.0 s
                p t verzoegerung einstieg miko
                    0.0 s
                p t verzoegerung ausstieg miko
                    0.0 s
                p t verzoegerung oeffnen miko
                    0.0 s
                p t verzoegerung entriegelt miko
                    0.0 s
                p t verzoegerung schliessen miko
                    0.0 s
                p t verzoegerung schluessel ab miko
                    0.0 s
                p t verzoegerung verriegelt miko
                    0.0 s
                p t verzoegerung einstieg dach
                    0.0 s
                p t verzoegerung ausstieg dach
                    0.0 s
                p t verzoegerung oeffnen dach
                    0.0 s
                p t verzoegerung entriegelt dach
                    0.0 s
                p t verzoegerung schliessen dach
                    0.0 s
                p t verzoegerung schluessel ab dach
                    0.0 s
                p t verzoegerung verriegelt dach
                    0.0 s
                p helligkeit entriegelt innenlicht
                    100 %
                p helligkeit max innenlicht
                    100 %
                p helligkeit HD auf zuendung ein innenlicht
                    100 %
                p helligkeit HD auf zuendung aus innenlicht
                    100 %
                p helligkeit dieseTuer auf zuendung ein innenlicht
                    100 %
                p helligkeit andereTuer auf zuendung ein innenlicht
                    100 %
                p helligkeit Fzg geschlossen zuendung ein innenlicht
                    0 %
                p helligkeit dieseTuer auf zuendung aus innenlicht
                    100 %
                p helligkeit andereTuer auf zuendung aus innenlicht
                    100 %
                p helligkeit einausstieg innenlicht
                    100 %
                p helligkeit Fzg geschlossen zuendung aus innenlicht
                    100 %
                p helligkeit Tueren geschlossen HD auf zuendung aus innenlicht
                    100 %
                p helligkeit Tueren geschlossen HD zu zuendung aus innenlicht
                    100 %
                p helligkeit Tueren geschlossen schluessel ab innenlicht
                    100 %
                p helligkeit Fzg geschlossen schluessel ab innenlicht
                    100 %
                p adaption kundenwunsch tuer
                    0.00
                p helligkeit entriegelt tueren
                    0 %
                p helligkeit max tueren
                    100 %
                p helligkeit HD auf zuendung ein tueren
                    126 %
                p helligkeit HD auf zuendung aus tueren
                    127 %
                p helligkeit dieseTuer auf zuendung ein tueren
                    100 %
                p helligkeit andereTuer auf zuendung ein tueren
                    100 %
                p helligkeit Fzg geschlossen zuendung ein tueren
                    126 %
                p helligkeit dieseTuer auf zuendung aus tueren
                    100 %
                p helligkeit andereTuer auf zuendung aus tueren
                    100 %
                p helligkeit einausstieg tueren
                    100 %
                p helligkeit Fzg geschlossen zuendung aus tueren
                    127 %
                p helligkeit Tueren geschlossen HD auf zuendung aus tueren
                    100 %
                p helligkeit Tueren geschlossen HD zu zuendung aus tueren
                    100 %
                p helligkeit Tueren geschlossen schluessel ab tueren
                    100 %
                p helligkeit Fzg geschlossen schluessel ab tueren
                    100 %
                p adaption kundenwunsch fussraum
                    1.00
                p helligkeit entriegelt fussraum
                    100 %
                p helligkeit max fussraum
                    100 %
                p helligkeit HD auf zuendung ein fussraum
                    126 %
                p helligkeit HD auf zuendung aus fussraum
                    127 %
                p helligkeit dieseTuer auf zuendung ein fussraum
                    100 %
                p helligkeit andereTuer auf zuendung ein fussraum
                    100 %
                p helligkeit Fzg geschlossen zuendung ein fussraum
                    126 %
                p helligkeit dieseTuer auf zuendung aus fussraum
                    100 %
                p helligkeit andereTuer auf zuendung aus fussraum
                    100 %
                p helligkeit einausstieg fussraum
                    100 %
                p helligkeit Fzg geschlossen zuendung aus fussraum
                    127 %
                p helligkeit Tueren geschlossen HD auf zuendung aus fussraum
                    127 %
                p helligkeit Tueren geschlossen HD zu zuendung aus fussraum
                    127 %
                p helligkeit Tueren geschlossen schluessel ab fussraum
                    100 %
                p helligkeit Fzg geschlossen schluessel ab fussraum
                    100 %
                p adaption kundenwunsch lautsprecher
                    1.00
                p helligkeit entriegelt lautsprecher
                    100 %
                p helligkeit max lautsprecher
                    100 %
                p helligkeit HD auf zuendung ein lautsprecher
                    100 %
                p helligkeit HD auf zuendung aus lautsprecher
                    100 %
                p helligkeit dieseTuer auf zuendung ein lautsprecher
                    100 %
                p helligkeit andereTuer auf zuendung ein lautsprecher
                    100 %
                p helligkeit Fzg geschlossen zuendung ein lautsprecher
                    126 %
                p helligkeit dieseTuer auf zuendung aus lautsprecher
                    100 %
                p helligkeit andereTuer auf zuendung aus lautsprecher
                    100 %
                p helligkeit einausstieg lautsprecher
                    100 %
                p helligkeit Fzg geschlossen zuendung aus lautsprecher
                    100 %
                p helligkeit Tueren geschlossen HD auf zuendung aus lautsprecher
                    100 %
                p helligkeit Tueren geschlossen HD zu zuendung aus lautsprecher
                    100 %
                p helligkeit Tueren geschlossen schluessel ab lautsprecher
                    100 %
                p helligkeit Fzg geschlossen schluessel ab lautsprecher
                    100 %
                p adaption kundenwunsch itafel
                    1.00
                p helligkeit entriegelt itafel
                    100 %
                p helligkeit max itafel
                    100 %
                p helligkeit HD auf zuendung ein itafel
                    100 %
                p helligkeit HD auf zuendung aus itafel
                    100 %
                p helligkeit dieseTuer auf zuendung ein itafel
                    100 %
                p helligkeit andereTuer auf zuendung ein itafel
                    100 %
                p helligkeit Fzg geschlossen zuendung ein itafel
                    126 %
                p helligkeit dieseTuer auf zuendung aus itafel
                    100 %
                p helligkeit andereTuer auf zuendung aus itafel
                    100 %
                p helligkeit einausstieg itafel
                    100 %
                p helligkeit Fzg geschlossen zuendung aus itafel
                    100 %
                p helligkeit Tueren geschlossen HD auf zuendung aus itafel
                    100 %
                p helligkeit Tueren geschlossen HD zu zuendung aus itafel
                    100 %
                p helligkeit Tueren geschlossen schluessel ab itafel
                    100 %
                p helligkeit Fzg geschlossen schluessel ab itafel
                    100 %
                p adaption kundenwunsch cockpit
                    1.00
                p helligkeit entriegelt cockpit
                    100 %
                p helligkeit max cockpit
                    100 %
                p helligkeit HD auf zuendung ein cockpit
                    100 %
                p helligkeit HD auf zuendung aus cockpit
                    100 %
                p helligkeit dieseTuer auf zuendung ein cockpit
                    100 %
                p helligkeit andereTuer auf zuendung ein cockpit
                    100 %
                p helligkeit Fzg geschlossen zuendung ein cockpit
                    126 %
                p helligkeit dieseTuer auf zuendung aus cockpit
                    100 %
                p helligkeit andereTuer auf zuendung aus cockpit
                    100 %
                p helligkeit einausstieg cockpit
                    100 %
                p helligkeit Fzg geschlossen zuendung aus cockpit
                    100 %
                p helligkeit Tueren geschlossen HD auf zuendung aus cockpit
                    100 %
                p helligkeit Tueren geschlossen HD zu zuendung aus cockpit
                    100 %
                p helligkeit Tueren geschlossen schluessel ab cockpit
                    100 %
                p helligkeit Fzg geschlossen schluessel ab cockpit
                    100 %
                p adaption kundenwunsch miko
                    1.00
                p helligkeit entriegelt miko
                    100 %
                p helligkeit max miko
                    100 %
                p helligkeit HD auf zuendung ein miko
                    100 %
                p helligkeit HD auf zuendung aus miko
                    100 %
                p helligkeit dieseTuer auf zuendung ein miko
                    100 %
                p helligkeit andereTuer auf zuendung ein miko
                    100 %
                p helligkeit Fzg geschlossen zuendung ein miko
                    126 %
                p helligkeit dieseTuer auf zuendung aus miko
                    100 %
                p helligkeit andereTuer auf zuendung aus miko
                    100 %
                p helligkeit einausstieg miko
                    100 %
                p helligkeit Fzg geschlossen zuendung aus miko
                    100 %
                p helligkeit Tueren geschlossen HD auf zuendung aus miko
                    100 %
                p helligkeit Tueren geschlossen HD zu zuendung aus miko
                    100 %
                p helligkeit Tueren geschlossen schluessel ab miko
                    100 %
                p helligkeit Fzg geschlossen schluessel ab miko
                    100 %
                p adaption kundenwunsch dach
                    0.00
                p helligkeit entriegelt dach
                    0 %
                p helligkeit max dach
                    0 %
                p helligkeit HD auf zuendung ein dach
                    0 %
                p helligkeit HD auf zuendung aus dach
                    0 %
                p helligkeit dieseTuer auf zuendung ein dach
                    0 %
                p helligkeit andereTuer auf zuendung ein dach
                    0 %
                p helligkeit Fzg geschlossen zuendung ein dach
                    0 %
                p helligkeit dieseTuer auf zuendung aus dach
                    0 %
                p helligkeit andereTuer auf zuendung aus dach
                    0 %
                p helligkeit einausstieg dach
                    0 %
                p helligkeit Fzg geschlossen zuendung aus dach
                    0 %
                p helligkeit Tueren geschlossen HD auf zuendung aus dach
                    0 %
                p helligkeit Tueren geschlossen HD zu zuendung aus dach
                    0 %
                p helligkeit Tueren geschlossen schluessel ab dach
                    0 %
                p helligkeit Fzg geschlossen schluessel ab dach
                    0 %
                p adaption kundenwunsch psd
                    1.00
                p helligkeit entriegelt psd
                    100 %
                p helligkeit max psd
                    100 %
                p helligkeit HD auf zuendung ein psd
                    100 %
                p helligkeit HD auf zuendung aus psd
                    100 %
                p helligkeit dieseTuer auf zuendung ein psd
                    100 %
                p helligkeit andereTuer auf zuendung ein psd
                    100 %
                p helligkeit Fzg geschlossen zuendung ein psd
                    126 %
                p helligkeit dieseTuer auf zuendung aus psd
                    100 %
                p helligkeit andereTuer auf zuendung aus psd
                    100 %
                p helligkeit einausstieg psd
                    100 %
                p helligkeit Fzg geschlossen zuendung aus psd
                    100 %
                p helligkeit Tueren geschlossen HD auf zuendung aus psd
                    100 %
                p helligkeit Tueren geschlossen HD zu zuendung aus psd
                    100 %
                p helligkeit Tueren geschlossen schluessel ab psd
                    100 %
                p helligkeit Fzg geschlossen schluessel ab psd
                    100 %
                p dimmfaktor farbwechsel auf
                    1
                p dimmfaktor farbwechsel ab
                    1
                p farbwechsel delay
                    0
                p farbauswahl HMI
                    0
                p ambienteumfang mehrfarbig HMI
                    0
                p ambienteumfang mehrfarbig HMI 2
                    0
                p ambienteumfang mehrfarbig HMI 3
                    0
                p ambienteumfang mehrfarbig HMI 4
                    0
                p ambientelicht verbauinformation HMI
                    0
                p ambientelicht verbauinformation HMI 2
                    0
                p ambientelicht verbauinformation HMI 3
                    0
                p ambientelicht verbauinformation HMI 4
                    0
                p verzoegerung berechnen
                    0
                p t HMI verzoegerung helligkeitswerte
                    200 ms
            Ambient light color list
                Rotwert Farbe 1
                    1
                Gruenwert Farbe 1
                    0
                Blauwert Farbe 1
                    0
                Rotwert Farbe 2
                    0
                Gruenwert Farbe 2
                    0
                Blauwert Farbe 2
                    0
                Rotwert Farbe 3
                    0
                Gruenwert Farbe 3
                    0
                Blauwert Farbe 3
                    0
                Rotwert Farbe 4
                    0
                Gruenwert Farbe 4
                    0
                Blauwert Farbe 4
                    0
                Rotwert Farbe 5
                    0
                Gruenwert Farbe 5
                    0
                Blauwert Farbe 5
                    0
                Rotwert Farbe 6
                    0
                Gruenwert Farbe 6
                    0
                Blauwert Farbe 6
                    0
                Rotwert Farbe 7
                    0
                Gruenwert Farbe 7
                    0
                Blauwert Farbe 7
                    0
                Rotwert Farbe 8
                    0
                Gruenwert Farbe 8
                    0
                Blauwert Farbe 8
                    0
                Rotwert Farbe 9
                    0
                Gruenwert Farbe 9
                    0
                Blauwert Farbe 9
                    0
                Rotwert Farbe 10
                    0
                Gruenwert Farbe 10
                    0
                Blauwert Farbe 10
                    0
            ambient_lighting_lin_slaves_modules
                pa einzeladresse slave 1
                    0
                pa verbauinfo slave 1
                    not installed
                pa fehlerort slave 1
                    0
                pa einzeladresse slave 2
                    0
                pa verbauinfo slave 2
                    not installed
                pa fehlerort slave 2
                    0
                pa einzeladresse slave 3
                    0
                pa verbauinfo slave 3
                    not installed
                pa fehlerort slave 3
                    0
                pa einzeladresse slave 4
                    0
                pa verbauinfo slave 4
                    not installed
                pa fehlerort slave 4
                    0
                pa einzeladresse slave 5
                    0
                pa verbauinfo slave 5
                    not installed
                pa fehlerort slave 5
                    0
                pa einzeladresse slave 6
                    0
                pa verbauinfo slave 6
                    not installed
                pa fehlerort slave 6
                    0
                pa einzeladresse slave 7
                    0
                pa verbauinfo slave 7
                    not installed
                pa fehlerort slave 7
                    0
                pa einzeladresse slave 8
                    0
                pa verbauinfo slave8
                    not installed
                pa fehlerort slave8
                    0
                pa einzeladresse slave 9
                    0
                pa verbauinfo slave 9
                    not installed
                pa fehlerort slave 9
                    0
                pa einzeladresse slave 10
                    0
                pa verbauinfo slave 10
                    not installed
                pa fehlerort slave 10
                    0
                pa einzeladresse slave 11
                    0
                pa verbauinfo slave 11
                    not installed
                pa fehlerort slave 11
                    0
                pa einzeladresse slave :12
                    0
                pa verbauinfo slave 12
                    not installed
                pa fehlerort slave 12
                    0
                pa einzeladresse slave 13
                    0
                pa verbauinfo slave 13
                    not installed
                pa fehlerort slave 13
                    0
                pa einzeladresse slave 14
                    0
                pa verbauinfo slave 14
                    not installed
                pa fehlerort slave 14
                    0
                pa einzeladresse slave 15
                    0
                pa verbauinfo slave 15
                    not installed
                pa fehlerort slave 15
                    0
                pa einzeladresse slave 16
                    0
                pa verbauinfo slave 16
                    not installed
                pa fehlerort slave 16
                    0
                pa einzeladresse slave 17
                    0
                pa verbauinfo slave 17
                    not installed
                pa fehlerort slave 17
                    0
                pa einzeladresse slave 18
                    0
                pa verbauinfo slave 18
                    not installed
                pa fehlerort slave 18
                    0
                pa einzeladresse slave 19
                    0
                pa verbauinfo slave 19
                    not installed
                pa fehlerort slave 19
                    0
                pa einzeladresse slave 20
                    0
                pa verbauinfo slave 20
                    not installed
                pa fehlerort slave 20
                    0
            ambient_lighting_lin_slaves_groups
                pa verbauinfo gruppe 1
                    not installed
                pa lichtfunktion gruppe 1
                    Door
                pa korrekturfaktor gruppe 1
                    1.00
                pa verbauinfo gruppe 2
                    not installed
                pa lichtfunktion gruppe 2
                    Door
                pa korrekturfaktor gruppe 2
                    1.00
                pa verbauinfo gruppe 3
                    not installed
                pa lichtfunktion gruppe 3
                    Door
                pa korrekturfaktor gruppe 3
                    1.00
                pa verbauinfo gruppe 4
                    not installed
                pa lichtfunktion gruppe 4
                    Door
                pa korrekturfaktor gruppe 4
                    1.00
                pa verbauinfo gruppe 5
                    not installed
                pa lichtfunktion gruppe 5
                    Door
                pa korrekturfaktor gruppe 5
                    1.00
                pa verbauinfo gruppe 6
                    not installed
                pa lichtfunktion gruppe 6
                    Door
                pa korrekturfaktor gruppe 6
                    1.00
                pa verbauinfo gruppe 7
                    not installed
                pa lichtfunktion gruppe 7
                    Door
                pa korrekturfaktor gruppe 7
                    1.00
                pa verbauinfo gruppe 8
                    not installed
                pa lichtfunktion gruppe 8
                    Door
                pa korrekturfaktor gruppe 8
                    1.00
                pa verbauinfo gruppe 9
                    not installed
                pa lichtfunktion gruppe 9
                    Door
                pa korrekturfaktor gruppe 9
                    1.00
                pa verbauinfo gruppe 10
                    not installed
                pa lichtfunktion gruppe 10
                    Door
                pa korrekturfaktor gruppe 10
                    1.00
                pa verbauinfo gruppe 11
                    not installed
                pa lichtfunktion gruppe 11
                    Door
                pa korrekturfaktor gruppe 11
                    1.00
                pa verbauinfo gruppe 12
                    not installed
                pa lichtfunktion gruppe 12
                    Door
                pa korrekturfaktor gruppe 12
                    1.00
                pa verbauinfo gruppe 13
                    not installed
                pa lichtfunktion gruppe 13
                    Door
                pa korrekturfaktor gruppe 13
                    1.00
                pa verbauinfo gruppe 14
                    not installed
                pa lichtfunktion gruppe 14
                    Door
                pa korrekturfaktor gruppe 14
                    1.00
                pa verbauinfo gruppe 15
                    not installed
                pa lichtfunktion gruppe 15
                    Door
                pa korrekturfaktor gruppe 15
                    1.00
            Suchbeleuchtung_allgemein
                Warnblinktastersuchbeleuchtung Aktivierung
                    always active
                Eingabemedium Suchbeleuchtung
                    HMI
                Umgebungs helligkeit auswahl
                    Fotosensor Kombi
                Warnblinktastersuchbeleuchtung Grundwert
                    20.0 %
                Warnblinktastersuchbeleuchtung Faktor
                    0.100
                KL58 Einschalten mit Rampe
                    not active
                KL58 Verriegelungsausschalten
                    not active
                Lichtsensor wirkt auf Suchbeleuchtung
                    active
                Suchbeleuchtung Festwert
                    100 %
                PWM Daempfung Aufdimmen KL58xs PWM
                    0.00 s
                Daempfung Abdimmen KL 58xs PWM
                    0.00 s
                Daempfung Aufdimmen KL 58xt PWM
                    0.00 s
                Daempfung Abdimmen KL 58xt PWM
                    0.00 s
                Daempfung Aufdimmen KL 58xd PWM
                    0.00 s
                Daempfung Abdimmen KL 58xd PWM
                    0.00 s
                Helligkeit RLS Daempfung Aufdimmen
                    0.0 s
                Helligkeit RLS Daempfung Abdimmen
                    0.0 s
                pa Hysterese RLS
                    0
            Suchbeleuchtung_Tasterdimmung
                tasterdimmung x0
                    0 ms
                tasterdimmung x1
                    2000 ms
                tasterdimmung x2
                    3000 ms
                tasterdimmung x3
                    4000 ms
                tasterdimmung x4
                    5100 ms
                tasterdimmung y0
                    1.0 %
                tasterdimmung y1
                    5.0
                tasterdimmung y2
                    15.0
                tasterdimmung y3
                    40.0
                tasterdimmung y4
                    100.0
            Suchbeleuchtung_Hochdimmen
                x0
                    0 ms
                x1
                    100 ms
                x2
                    200 ms
                x3
                    300 ms
                x4
                    400 ms
                x5
                    500 ms
                x6
                    600 ms
                x7
                    700 ms
                x8
                    800 ms
                x9
                    900 ms
                x10
                    1000 ms
                y0
                    0.0 %
                y1
                    3.0 %
                y2
                    7.0 %
                y3
                    12.0 %
                y4
                    17.0 %
                y5
                    24.0 %
                y6
                    33.0 %
                y7
                    44.0 %
                y8
                    59.0 %
                y9
                    78.0 %
                y10
                    100.0 %
            Suchbeleuchtung_Abdimmen
                x0
                    0 ms
                x1
                    100 ms
                x2
                    200 ms
                x3
                    300 ms
                x4
                    400 ms
                x5
                    500 ms
                x6
                    600 ms
                x7
                    700 ms
                x8
                    800 ms
                x9
                    900 ms
                x10
                    1000 ms
                y0
                    100.0 %
                y1
                    78.0 %
                y2
                    59.0 %
                y3
                    44.0 %
                y4
                    33.0 %
                y5
                    24.0 %
                y6
                    17.0 %
                y7
                    12.0 %
                y8
                    7.0 %
                y9
                    3.0 %
                y10
                    0.0 %
            Suchbeleuchtung_Fotosensor
                x0
                    0
                x1
                    50
                x2
                    100
                x3
                    200
                x4
                    253
                x5
                    0
                x6
                    0
                x7
                    0
                x8
                    0
                x9
                    0
                x10
                    0
                y0
                    0 lx
                y1
                    50 lx
                y2
                    100 lx
                y3
                    200
                y4
                    500
                y5
                    0
                y6
                    0 lx
                y7
                    0 lx
                y8
                    0 lx
                y9
                    0 lx
                y10
                    0 lx
            Suchbeleuchtung_KL 58xs min
                x0
                    0 lx
                x1
                    8 lx
                x2
                    50 lx
                x3
                    510 lx
                y0
                    6.0
                y1
                    6.0
                y2
                    100.0
                y3
                    100.0
            Suchbeleuchtung_KL 58xs max
                x0
                    0 lx
                x1
                    8 lx
                x2
                    50 lx
                x3
                    500 lx
                y0
                    100.0
                y1
                    100.0
                y2
                    100.0
                y3
                    100.0
            Suchbeleuchtung_KL_58xt min
                x0
                    0 lx
                x1
                    8 lx
                x2
                    50 lx
                x3
                    500 lx
                y0
                    6.0
                y1
                    6.0
                y2
                    100.0
                y3
                    100.0
            Suchbeleuchtung_KL_58xt_max
                x0
                    0 lx
                x1
                    8 lx
                x2
                    50 lx
                x3
                    500 lx
                y0
                    100.0
                y1
                    100.0
                y2
                    100.0
                y3
                    100.0
            Suchbeleuchtung_KL_58xd_min
                x0
                    0 lx
                x1
                    8 lx
                x2
                    220 lx
                x3
                    300 lx
                x4
                    500 lx
                y0
                    6.0
                y1
                    6.0
                y2
                    100.0
                y3
                    100.0
                y4
                    100.0
            Suchbeleuchtung_KL_58xd_max
                x0
                    0 lx
                x1
                    8 lx
                x2
                    200 lx
                x3
                    300 lx
                x4
                    500 lx
                y0
                    16.0
                y1
                    16.0
                y2
                    100.0
                y3
                    100.0
                y4
                    100.0
            Suchbeleuchtung_KL_58xd_log_Bus
                x0
                    0.0 %
                x1
                    6.0 %
                x2
                    16.0 %
                x3
                    30.0 %
                x4
                    60.0 %
                x5
                    100.0 %
                y0
                    10
                y1
                    10
                y2
                    100
                y3
                    150
                y4
                    220
                y5
                    253
            Dimmunt_KL_58xs_PWM
                x0
                    0.0 %
                x1
                    50.0 %
                x2
                    100.0 %
                y0
                    0.0 %
                y1
                    50.0 %
                y2
                    100.0 %
            Suchbeleuchtung_KL_58xt_PWM
                x0
                    0.0 %
                x1
                    50.0 %
                x2
                    100.0 %
                y0
                    0.0 %
                y1
                    50.0 %
                y2
                    100.0 %
            Suchbeleuchtung_KL_58xd_PWM
                x0
                    0
                x1
                    10
                x2
                    50
                x3
                    100
                x4
                    220
                x5
                    253
                y0
                    2.0 %
                y1
                    2.0 %
                y2
                    6.0 %
                y3
                    10.0 %
                y4
                    80.0 %
                y5
                    100.0 %
            Suchbeleuchtung_58_xs_Bus_Kennlinie
                x0
                    0.0 lx
                x1
                    8.0 lx
                x2
                    50.0 lx
                x3
                    80.0 lx
                x4
                    100.0 lx
                y0
                    6.0
                y1
                    6.0
                y2
                    20.0
                y3
                    50.0
                y4
                    100.0
            Suchbeleuchtung_58xt_Bus_Kennlinie
                x0
                    0.0 lx
                x1
                    8.0 lx
                x2
                    50.0 lx
                x3
                    80.0 lx
                x4
                    100.0 lx
                y0
                    6.0
                y1
                    6.0
                y2
                    20.0
                y3
                    50.0
                y4
                    100.0
            Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie
                x0
                    0 lx
                x1
                    200 lx
                x2
                    400 lx
                x3
                    600 lx
                x4
                    800 lx
                x5
                    1020 lx
                y0
                    0
                y1
                    84
                y2
                    166
                y3
                    250
                y4
                    370
                y5
                    500
            ZV allgemein
                Notschliessfunktion
                    active
                Funkfrequenz
                    434,42MHz
                Funk bei Klemme 15 ein
                    not active
                ZV ohne Safe Funktion
                    installed
                Deaktivierung SAFE ueber DWA Deaktivierungstaster
                    active
                Entsafen mit autorisierte Klemme 15 Ein
                    not active
                Bewusstes Safe mit 2. Betaetigung der FFB
                    not active
                Lock Unlock Taster direkt
                    installed
                Lock Unlock Toggle Taster
                    installed
                ZV Tuerentriegelung
                    Globale Entriegelung
                Menuesteuerung Tuerentriegelung
                    active
                LS Taster Togglefunktion
                    not active
                Deaktivierung Laderaumschliessung extern
                    not active
                Nutzfahrzeug Schliessung
                    not active
                Wiederverriegelung Laderaum
                    Freigabe Softtouch
                Tankschloss
                    bidirectional
            ZV Türkonfiguration
                Viertuerer
                    Yes
                Fond Schloss
                    2-Motorenschloesser
                Schlosstyp NAR
                    Yes
                Schiebetueren Crafter
                    not installed
                Schiebetuerschloss direkt BCM
                    Driver side
                Schiebetuer Kontaktmodul Fahrerseite
                    not installed
                Schiebetuer Kontaktmodul Beifahrerseite
                    not installed
                Schiebetuer links
                    No
                Schiebetuer rechts
                    No
                Schliessung der Schiebetuer bei geoeffneter Tankklappe
                    not active
                HFT Invertierung Drehfallensignal
                    nicht invertiert
            ZV Heck
                Tausch Tank Hecktreiberausgang
                    No
                ZV Heck Schlosstyp
                    1- oder 2-Rasten-Hecksteller
                Heckschloss mit Vorraste
                    Yes
                Heckschloss Steuerung
                    Kontaktsteuerung mit Mindestansteuerzeit
                Entriegelungwunsch verzoegert waehrend Zuziehvorgang
                    not active
                Heckdeckelentriegelung HDF Innentaster
                    via pin
                ZV entriegelt auch Heckdeckel
                    active
                Direkter Auswurf des Heckdeckels
                    active
                Heckfreigabe Ohne Verzoegerung
                    not active
                ZV Heck nur direkt auswerfen
                    not active
                Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster
                    not active
                Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt
                    not active
                Mindestbetaetigung HDF Innentaster
                    0.6 s
                Heckoeffnung ueber 2 Bedienhandlungen
                    not active
            Acknowledgement signals
                Optical feedback during locking
                    Decelerate
                Optische Rueckmeldung Komfortschliessen
                    not active
                Optische Rueckmeldung 3.Bremsleuchte
                    not active
                Akustische Rueckmeldung global
                    not active
                Akustische Rueckmeldung entriegeln
                    not active
                Quittierton bei zweitem ZV-AUF-Befehl
                    not active
                Akustische Rueckmeldung verriegeln
                    not active
                Quittierton bei zweitem ZV-ZU-Befehl
                    not active
                Menuesteuerung akustische Rueckmeldung
                    not active
                Dauer der Akustischen Rueckmeldung vom Einfachhorn
                    normal
                Akustische Rueckmeldung Signalhorn
                    not active
                ZV-Blinken Hellzeit
                    200 ms
                ZV-Blinken Dunkelzeit
                    200 ms
                ZV-Blinken Abschluss Dunkelzeit
                    200 ms
            ZV Komfort
                Freigabenachlauf FH bei Kl 15 aus
                    active
                Freigabenachlauf FH bei Tueroeffnen abbrechen
                    active
                Komfortbedienung global
                    active
                Comfort opening
                    active
                Komfortoeffnen nur FH Fahrertuer
                    not active
                Schliesszylinder Komfort oeffnen
                    active
                Funk Komfort oeffnen
                    active
                Fahrertuerbedienung Fensterheber oeffnen
                    active
                FH SAD Kl15Aus Freigabezeit
                    600 s
                Comfort closing
                    active
                Schliesszylinder Komfort schliessen
                    active
                Funk Komfort schliessen
                    active
                Fahrertuerbedienung Fensterheber schliessen
                    active
                Menuesteuerung Komfortbedienung einstellbar
                    adjustable
                Regenschliessen ein aus
                    not active
                Regenschliessen art
                    once
                Menuesteuerung Regenschliessen
                    not active
                elektrischer Fensterheber hinten
                    Yes
            ZV Autolock
                Automatisches Verriegeln bei Geschwindigkeit
                    active
                automatisches Entriegeln
                    active
                Autounlock NAR
                    not active
                Autolock Autounlock wirkt auf Heck
                    active
                Geschwindigkeitsabhaengige Tankdeckelverriegelung
                    not active
                Menuesteuerung ZV Autolock-Unlock
                    adjustable
            Schiebedach
                SAD Richtung Komfortoeffnen
                    tilting
                SAD Komfort schliessen
                    not active
                SAD Komfort oeffnen
                    not active
                Schiebedachmodul MD 1
                    not installed
                Schiebedachmodul MD 3
                    not installed
                Schiebedachmodul MD Rollo
                    not installed
                Verortung Schiebedachmodule
                    LIN
            Spiegelverstellung
                Spiegelabsenkung bei Rueckwaertsfahrt
                    active
                Spiegelverstellung Synchron
                    active
                Menuesteuerung Spiegelabsenkung
                    active
                Funk Spiegelanklappen
                    active
                Funk Spiegelanklappung Modus
                    by look command via remote control key
                Menuesteuerung synchrone Spiegelverstellung
                    active
                Menuesteuerung Funk Spiegel anklappen
                    active
                Profilfunktion fuer Anklappung der Aussenspiegel
                    not active
                Signalisierung Spiegelanklappung
                    active
                Spiegelanklappen bei Wiederverriegelung
                    active
            ZV Crash
                Heckdeckel-Bedienstellen nachCrash temporaer sperren
                    active
                ZV-Entriegelung nach Seitencrash
                    not active
                SAD PreCrash Konturschliessen
                    not active
            Anti-theft device
                Alarmsignal
                    frequency modulated
                Verzoegerung Panikalarm
                    2 sekunden verzoegerung
                DWA Alarmverzoegerung
                    not active
                DWA Camper Modus
                    not active
                Ueberwachung Innenentriegelungshebel
                    not active
                Sirenen Alarmzahl
                    10 Alarme
                Akustischer Alarm Signalhorn
                    not active
                IRUE NGS Deaktivierungstaster direkt am BCM verdrahtet
                    No
                Diebstahlwarnanlage
                    not active
                Heckscheibenbruchsensor
                    not installed
                DWA Einfachhorn oder Sounder
                    not installed
                tilt sensor
                    No
                Schliesszylinder in Richtung Oeffnen aktiv (Thatcham inaktiv)
                    No
                Sensor fuer Innenraumueberwachung
                    No
                Parking heater
                    not installed
                OBD Alarm
                    activ
            After-run for park light
                Bedingungen zur Beendigung des Standlichtnachlaufs
                    abschalten nach der Nachlaufzeit
                ZV verriegeln bei Klemme 15 Ein
                    active
                Standlicht-Nachlaufzeit
                    30 min
            Front_wiper
                Frontwischertyp
                    LIN
                Frontwischer Referenzlauf
                    active
                Variable Regensensoraktivierung
                    active
                Wischer stop bei KL15 aus
                    active
                Wischer abparken bei Oeffnen der Motorhaube
                    not active
                Regensensor aktivieren
                    Deactivating
                Menuesteuerung Frontwischer
                    not active
                Frontwischer Notlaufprogramm
                    active
                Tippwischen mit erhoehter Wischfrequenz
                    active
                Geschwindigkeitsabhaengige Wischstufenrueckschaltung
                    active
                Traenenwischen Front Status
                    not active
                Washer Tipwiping Variant
                    not active
                Adaptives Nachwischen bei SRA
                    not active
                Wischer Stopp bei Oeffnen der Motorhaube
                    not active
                Frontwischer Abtauposition
                    not active
                Anfahrzeit servicestellung
                    800 ms
                Mindestwaschzeit Frontwischer
                    0 ms
                Timer DWP SRA delay
                    0 ms
            Rear Window Wiper
                Heckwischer
                    not installed
                Komfortwischen Heck
                    not active
                Menuesteuerung Komfortwischen HW
                    not active
                Automatisches Heckwischen
                    not active
                Traenenwischen Heck
                    not active
                Heckwischer Weiterlauf
                    not active
                Komofortwischen Heck Intervallpausenzeit Stufe Intervall
                    7 s
                Komofortwischen Heck Intervallpausenzeit Stufe Automatik
                    7 s
                Komofortwischen Heck Intervallpausenzeit Stufe 1
                    5 s
                Komofortwischen Heck Intervallpausenzeit Stufe 2
                    3 s
                Einzelansteuerung Heckintervallwischen Zeitintervall 1
                    8 s
                Einzelansteuerung Heckintervallwischen Zeitintervall 2
                    16 s
                    not active
                Zeit wasch min heck
                    0 ms
            Scheinwerferreinigung
                Scheinwerferreinigungsanlage
                    installed
                SRA bei Waschwassermangel
                    active
                Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung
                    10
                SRA Verzoegerungszeit
                    0 ms
                SRA Waschzeit
                    800 ms
                SRA Einweichpausenzeit
                    1000 ms
                SRA Nachwaschzeit
                    1000 ms
                SRA Pausenzeit
                    0 ms
            Button in center console
                Function of button 1
                    Start-stop
                Function of button 2
                    not coded/not installed
                Function of button 3
                    0 not defined
                Function of button 4
                Zusatzcodierung Fahrprofiltaster hat keine LED
                    LED installed
            Seat heater level current consumption allocation
                Sitzheizung Filterkonstante fuer Waermefluss
                    1 s
                Sitzheizung Regeltemperaturkorrektur bei Waermefluss
                    0.00 °C
                Sitzheizung Stufe 1 untere Schaltschwelle
                    22.00 °C
                Sitzheizung Stufe 1 obere Schaltschwelle
                    23.00 °C
                Sitzheizung Stufe 2 untere Schaltschwelle
                    22.00 °C
                Sitzheizung Stufe 2 obere Schaltschwelle
                    23.00 °C
                Sitzheizung Stufe 3 untere Schaltschwelle
                    35.50 °C
                Sitzheizung Stufe 3 obere Schaltschwelle
                    36.00 °C
                Sitzheizung Stufe 4 untere Schaltschwelle
                    35.50 °C
                Sitzheizung Stufe 4 obere Schaltschwelle
                    36.00 °C
                Sitzheizung Stufe 5 untere Schaltschwelle
                    40.00 °C
                Sitzheizung Stufe 5 obere Schaltschwelle
                    41.00 °C
                Sitzheizung Stufe 6 untere Schaltschwelle
                    40.00 °C
                Sitzheizung Stufe 6 obere Schaltschwelle
                    41.00 °C
                Sitzheitzung CAN
                    Heizmatten am BCM
                Sitzheizungsfreigabe
                    not installed
            Seat fan charac. curve
                Level 1 Sitz
                    40 %
                Level 1 Lehne
                    40 %
                Level 2 Sitz
                    40 %
                Level 2 Lehne
                    40 %
                Level 3 Sitz
                    40 %
                Level 3 Lehne
                    40 %
                Level 4 Sitz
                    70 %
                Level 4 Lehne
                    70 %
                Level 5 Sitz
                    40 %
                Level 5 Lehne
                    40 %
                Level 6 Sitz
                    100 %
                Level 6 Lehne
                    100 %
                Sitzlueftung
                    not installed
                Sitzlueftung reduzierbar
                    installed
                Sitzpneumatik
                    not installed
            Window heater
                Heizbare Frontscheibe
                    not installed
                Heizbare Heckscheibe
                    installed
                Waschduesenheizung
                    not installed
                Frontscheibenheizung LED direkt
                    not installed
                Frontscheibenheizungsansteuerung direkt von externem Algorithmus
                    not installed
                Temperaturabhaengige Einschaltzeit HSH
                    not active
                Temperaturabhaengige Einschaltzeit FSH
                    not active
                FSH Automatik
                    active
                Heckscheibenheizung Zeitwert
                    600 s
                Running time of heated front window
                    600 s
                Abschalttemperatur fuer Heckscheibenheizung
                    35.0 °C
                Abschalttemperatur fuer Frontscheibenheizung
                    35.0 °C
                Frontscheibenheizung  maximale Dauer
                    0 s
                window heating front activation time pause
                    240 s
            A/C heater function via remote control
                Remotestart
                    not installed
                Rueckmeldung bei Aktivierung
                    not active
                Kombi Fahrerhinweis m Uebernahme RSt
                    not active
                Abbruch Hupen RSt
                    not active
                Abbruch d Warnblinker moeglich
                    not active
                Kombi Fahrerhinweis m Akustik
                    not active
                Aktivierung Drehzahlanzeige
                    not active
            Characteristics in production mode
                Headlamp washer system
                    2000 ms
            Roller test bench mode, functional
                    not active
            Transport mode
                    active
            Production mode
                    not active
                Heckwischer
                    not active
                Innenbeleuchtung
                    not active
                Aussenbeleuchtung
                    not active
                Zugangskontrolle
                    not active
                Virtuel pedal
                    not active
            Deactivate production mode
                    not active
            Keyless access and start authorization
                Kessy
                    installed
                Elektische Lenkradverriegelung
                    installed
                Kessy Komfort oeffnen
                    active
                Kessy Komfort schliessen
                    active
                Oeffnung Heckdeckel bei Wiederentriegelung
                    active
                Kessy Komfortbedienung Reichweitenbegrenzung
                    active
            Read parameter address
                Parameter address
                    0
            Vernetzungs- Diagnosefunktionen
                can msg 1
                    0
                can msg 2
                    0
                can msg 3
                    0
                can msg 4
                    0
                lin msg 1
                    0
                lin msg 2
                    0
                lin msg 3
                    0
                lin msg 4
                    0
                lin msg 5
                    0
                lin msg 6
                    0
            LIN-Mirrormode
                mirror mode typ
                    not active
                Data bus LIN 1
                    not active
                Data bus LIN 2
                    not active
                Data bus LIN 3
                    not active
                Data bus LIN 4
                    not active
                Data bus LIN 5
                    not active
                Data bus LIN 6
                    not active
            Activating and deactivating all development messages
                    not active
            Energy management
                Hybridfahrzeug
                    No
                Recuperation
                    active
                Energiemanagement Abschaltung
                    active
                Zweitbatterie
                    not installed
                Energy Management Adaptation
                    Energy management active
                Praediktives Energiemanagement
                    not active
                Hochvoltfahrzeug
                    not installed
            Personalisierung
                Personalisierung Profilfunkion
                    profiles inactive
                Profil Variante
                    Schluessel
                Personalisierung aktiv
                    not active
                Aktivierungsoption im HMI-Menue sichtbar
                    not active
                Benutzerkontenverwaltung in HMI-Menue sichtbar
                    not active
                Personalisierungsfunktionen in HMI-Menue sichtbar
                    not active
                Anzahl Benutzerkonten
                    4
                Automatische  Schluesselzuordnung
                    not active
                PSO FSG Setup2 Bit 1
                    not active
                PSO FSG Setup2 Bit 2
                    not active
                PSO FSG Setup2 Bit 3
                    active
                PSO FSG Setup2 Bit 4
                    not active
            Verdecksteuergeraet
                Nachsaven nach Verdecklauf
                    not active
                Komfortbedienung Verdeck global
                    active
                Komfortbedienung Verdeck oeffnen
                    active
                Komfortbedienung Verdeck schliessen
                    active
                Verdeck oeffnen via Schliesszylinder
                    active
                Verdeck schliessen via Schliesszylinder
                    active
                Verdeck oeffnen via Funkfernbedienung
                    active
                Verdeck schliessen via Funkfernbedienung
                    active
                Verdeck oeffnen via Kessy
                    active
                Verdeck schliessen via Kessy
                    active
                Doppelpuls nur Verdeck
                    active
                Verdeck mit Schiebedach
                    not active
                Heckdeckel sperren bei Verdeckbetrieb
                    not active
                Softtouch-Betaetigung senden
                    immer
                Servoheck Schlossansteuerung
                    nur wenn mind. 1 Raste zu
                Reichweitenbegrenzung fuer Servoheck schliessen
                    active
                Cabrio Verdeck
                    not installed
                trunk lid conrol unit
                    installed
                Virtuelles Pedal Verbau
                    not installed
                Virtuelles Pedal
                    not active
                Virtuelles Pedal HMI einstellba
                    not active
                easycloselight aktiv
                    not active
                Kick and close
                    not installed
            OCU
                OCU
                    not installed
                DWA push
                    not active
                Remote Unlock Lock
                    not active
                Honk DWA Ausgabe Fanfare
                    not active
                Remote Lock Unlock Timer s3
                    20.0 ms
                Remote Lock Unlock Timer s1
                    80 s
                Remote HuF Abbruch
                    20 km/h
                Remote HuF Hupfrequenz
                    3
            Allwetterlicht_Spoiler
                tt spoiler
                    not installed
                Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT
                    active
                Spoiler Einfahrunterdrueckung nach manuellem Ausfahren
                    active
            Slave_systems_identification
                Control Unit For Wiper Motor
                    Not available
                Rain Light Recognition Sensor
                    Not available
                Light Switch
                    Not available
                Garage Door Opener Control Module
                    Not available
                Garage Door Opener Operating Unit
                    Not available
                Sensor For Anti Theft Alarm System
                    Not available
                Alarm Horn
                    Not available
                Sun Roof
                    Not available
                Ceiling Light Module
                    Not available
                Roof Blind
                    Not available
                Relative Air Humidity Interior Sender
                    Not available
                Neck Heating Left
                    Not available
                Neck Heating Right
                    Not available
                Seat Backrest Fan 1 Front Left
                    Not available
                Seat Cushion Fan 1 Front Left
                    Not available
                Seat Backrest Fan 1 Front Right
                    Not available
                Seat Cushion Fan 1 Front Right
                    Not available
            RLS_wiper_position_parking
                    15 s
            RLS_close_glazing
                    2.0 s
            RLS_lights_for_autobahn
                p v autobahn on
                    140 km/h
                p v autobahn off
                    65 km/h
                p t autobahn delay on
                    10 s
                p t autobahn delay off
                    120 s
            RLS_Washer_Front
                    15 s
            RLS_LIN_Communication
                    4 s
            RLS_tunel_gateway_recognize
                    5 s
            RLS_Lights_on_at_Rain
                p n regenlichtschwelle high
                    12
                p n regenlichtschwelle low
                    6
                p lx regenlichtschwelle
                    6000 lx
                p t regenlicht
                    30 s
            RLS_Night_Sensitivity
                p lx rs day
                    500 lx
                p lx rs dawn
                    200 lx
            upper turn position
                    157.494348 °
            lower turn position
                    29.999970 °
            Position during interval mode
                    29.999970 °
            Alternating park position 1
                    19.999980 °
            Alternating park position 2
                    24.494481 °
            Service position
                    157.395447 °
            Wischgeschwindigkeiten
                Dauerwischen Stufe 1 Zyklen pro Minute
                    40
                Dauerwischen Stufe 2 Zyklen pro Minute
                    60
                Reduzierte Wischgeschwindigkeit Zyklen pro Minute
                    30
            Front_wash_function
                factor washing delay
                    17
            erase_error_table
                    0
            Wischer_Fehlermaske_Mitsuba_Entw
                error mask
                    0 bit
            Kopfraumheizung
                blower speed
                    1
                temperature
                    -2
            LIN Ambient light color list
                Rotwert Farbe 1 lin
                    255
                Gruenwert Farbe 1 lin
                    0
                Blauwert Farbe 1 lin
                    0
                Rotwert Farbe 2 lin
                    0
                Gruenwert Farbe 2 lin
                    0
                Blauwert Farbe 2 lin
                    0
                Rotwert Farbe 3 lin
                    0
                Gruenwert Farbe 3 lin
                    0
                Blauwert Farbe 3 lin
                    0
                Rotwert Farbe 4 lin
                    0
                Gruenwert Farbe 4 lin
                    0
                Blauwert Farbe 4 lin
                    0
                Rotwert Farbe 5 lin
                    0
                Gruenwert Farbe 5 lin
                    0
                Blauwert Farbe 5 lin
                    0
                Rotwert Farbe 6 lin
                    0
                Gruenwert Farbe 6 lin
                    0
                Blauwert Farbe 6 lin
                    0
                Rotwert Farbe 7 lin
                    0
                Gruenwert Farbe 7 lin
                    0
                Blauwert Farbe 7 lin
                    0
                Rotwert Farbe 8 lin
                    0
                Gruenwert Farbe 8 lin
                    0
                Blauwert Farbe 8 lin
                    0
                Rotwert Farbe 9 lin
                    0
                Gruenwert Farbe 9 lin
                    0
                Blauwert Farbe 9 lin
                    0
                Rotwert Farbe 10 lin
                    0
                Gruenwert Farbe 10 lin
                    0
                Blauwert Farbe 10 lin
                    0
        Advanced identification
            Diagnostic mode
                    VW - diagnostic mode
            ASAM/ODX file identification
                    EV BCMMQB
            ASAM/ODX file version
                    017001
            AUTOSAR Standard application software identification
                Standard software module
                    Component protection on ISO TP
                Software manufacturer ID
                    Elektrobit Automotive GmbH (3SOFT GmbH)
                Primary version number
                    2
                Secondary version number
                    0
                Revision number
                    1
                    BAP
                    Volkswagen AG
                    1
                    5
                Revision number
                    2
                    UDS - protocol
                    Volkswagen AG
                    2
                    0
                Revision number
                    6
                    Diagnostics - Event - Handler
                    IAV GmbH
                    2
                    2
                Revision number
                    2
                    ISO15765-2
                    Volkswagen AG
                    2
                    0
                Revision number
                    2
                    Operating system
                    NXP Semiconductors N.V. (Freescale Semiconductor Inc.)
                    2
                    1
                Revision number
                    0
                    High Speed - Network management
                    Vector Informatik GmbH
                    2
                    0
                Revision number
                    2
            Identification of bus master/sub bus master
                ECU ID
                    9
                ECU Name
                    Central Electrics
                LOGICAL-LINK SHORT-NAME
                    Central Electrics
            Consistency of EEPROM-data
                Error during last data record download
                    no error
                Data consistency
                    valid EEPROM data
                Data record modification
                    Data record not changed
                Parameterizability
                    Parameterizable
            Programmability status
                Programmability
                    programmable
                Program consistency
                    Program present
            Serial number
                    02001614101021
            Flash data security
                Hash value
                    Not available
                Key enable mechanism
                    Not available
                Key
                    No
                Key type
                    Series
                Project ID
                    00000433
                Hash value
            Workshop code and date of last update programming of SW module
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
            Number of possible access authorizations
                    2
            Software version for suppliers
                    45355F312E3F2030352E30342E31362046424C30342E303120505045352E3133204D4C46422D2D2D2D2D2D2D2D2D2048574D48333442205041526060
            Vehicle equipment code
                    00000000094D35C8E67B68B9
            Identification of parameterization
                Version number
                    00
            SoftwareVersion
                    0236
            Date of last adaptation
                Year
                    21
                Month
                    7
                Day
                    30
            Adaptation workshop code
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
            Date of last coding
                Year
                    21
                Month
                    7
                Day
                    24
            Coding workshop code
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
            Number of parameterization attempts
                Data record
                    1
            Number of successful parameterization attempts
                Data record
                    1
            Parameter set part number
                    V03935242KL
            Parameterization date
                Year
                    16
                Month
                    6
                Day
                    7
            Parameterization workshop code
                Device number
                    31
                Importer number
                    770
                Dealership number
                    73216
            Parameter set version
                    0001
            Hardware part number
                    5Q0937084CF
            HardwareVersion
                    H34
            FAZIT-identification
                Manufacture location index
                    SME-RBG
                Day of manufacture
                    24.05.16
                Manufacturer- test stand number
                    0011
                Running manufacturer number
                    1832
            Number of programming attempts
                Bootloader
                    0
                Application
                    0
                Data record
                    0
            Maximum number of possible update programming
                Bootloader
                    65535
                Application
                    65535
                Data record
                    65535
            Versions of software module
                Bootloader
                    0401
                Application
                    0236
                Data record
                    0236
            VW/Audi part number
                    5Q0937084CF
            System description
                    BCM MQBAB M+
            System abbreviation
                    J519
            Known subsystems
                Subsystem designation
                Subsystem number
                    1
                Subsystem number
                    2
                    Subsystem not coded
                Subsystem number
                    FFFF
                    Subsystem not coded
                Subsystem number
                    FFFF
                    Subsystem not coded
                Subsystem number
                    FFFF
                    Subsystem not coded
                Subsystem number
                    FFFF
                    Subsystem not coded
                Subsystem number
                    FFFF
                    Subsystem not coded
                Subsystem number
                    FFFF
                    Subsystem not coded
                Subsystem number
                    FFFF
                    Subsystem not coded
                Subsystem number
                    FFFF
                    Subsystem not coded
                Subsystem number
                    FFFF
                    Subsystem not coded
                Subsystem number
                    FFFF
                    Subsystem not coded
                Subsystem number
                    FFFF
                    Subsystem not coded
                Subsystem number
                    FFFF
                    Subsystem not coded
                Subsystem number
                    FFFF
                    Subsystem not coded
                Subsystem number
                    FFFF
                    Subsystem not coded
                Subsystem number
                    FFFF
                    Subsystem not coded
                Subsystem number
                    FFFF
                    Subsystem not coded
                Subsystem number
                    FFFF
            FAZIT identification test sum
                CRC32 Checksum of FAZIT Identification String par
                    81F0FBFB26
            Function Software Identification
                    Energiemanagment
                    AEV Audi Electronics Venture GmbH
                Version number
                    1101
        Mileage: 372624 km
        Date: 2021-08-01 19:31:57
    Backup
        13 Adaptive Cruise Control
        System description: ACC BOSCH MQB
        Software number: 3Q0907572B
        Software version: 0194
        Hardware number: 3Q0907572B
        Hardware version: H04
        Backup name: Adaptive Cruise Control
        Long coding
            3200600151FFC428949C8045
        Adaptations
                    Not activated
                    Deactivating
            Production mode
                    Deactivating
            Heated lens
                    On
                Development Message S100
                    Off
                Development Message S101
                    Off
                Development Message S102
                    Off
                Development Message ECU specific
                    Off
                XCP on FlexRay
                    Off
            Distance basic setting option
                    On
            Expanded restart function
                    Off
            Presentation mode
                    not active
            Distance change via speed adjustment
                    On
            Prioritized target object display
                    On
            Sail function
                    Deactivating
            Constant delay after transfer request
                    Yes
            Selection of release codes for a SWaP function
                    FFFFFFFF
            Transfer of release code for a SWaP function
                    00
                Bootloader
                    0
                Application
                    0
                Bootloader
                    10000
                Application
                    10000
            ISO TP block size in bootloader
                    F
            Identification of connected components
                ID number
                    13
                subsystem name
                Bus message/node address
                    57
                Year
                    0
                Month
                    1
                Day
                    1
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    1
                Day
                    1
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
            Date of last coding
                Year
                    21
                Month
                    7
                Day
                    29
                    RB8-658
                Day of manufacture
                    17.05.16
                    0439
                    0846
            Diagnostic mode
            VW/Audi part number
                    3Q0907572B
            SoftwareVersion
                    0194
                    3Q0907572B
            System description
                    ACC BOSCH MQB
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
                Year
                    21
                Month
                    2
                Day
                    2
                    EV ACCBOSCHVW48X
                    V03935242JJ
                    0001
                    001009
            HardwareVersion
                    H04
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
                Device number
                    31
                Importer number
                    770
                Dealership number
                    33281
                Year
                    16
                Month
                    6
                Day
                    7
            System abbreviation
                    J428
                Bootloader
                    0127
                Application
                    0194
                    E2E Library
                    TTTech Automotive GmbH
                    1
                    0
                Revision number
                    5
                    2
                    0
                Revision number
                    1
                    BAP
                    ICT Software Engineering GmbH
                    1
                    6
                Revision number
                    7
                    Software as Product (SWaP)
                    6
                    2
                Revision number
                    0
            Identification of data sets
                Data set ID
                    7200
                Data set version:
                    V001
                data set used by application
                    Yes
                data set plausible
                    Yes
                data set valid
                    Yes
            Flash data security
                Hash value
                    Not available
                    Not available
                Key
                    No
                Key type
                    Series
                Project ID
                    00000525
                Hash value
                    00
                    2500000000
                Programmability
                    programmable
                Program consistency
                    Program present
        Mileage: 372624 km
    Backup
        15 Airbag
        System description: AirbagVW21
        Software number: 5Q0959655AK
        Software version: 0130
        Hardware number: 5Q0959655AK
        Hardware version: 005
        Serial number: 003Q5R1TPBZX
        Backup name: Airbag
        Long coding
            98CCC0C0000000005C5400CF004800000065
        Adaptations
            Airbag adaptations
                Passenger airbag igniter
                    activated
                Driver airbag igniter
                    activated
                Front passenger side airbag igniter
                    activated
                Driver thorax airbag igniter
                    activated
                Front passenger rear thorax airbag igniter
                    not defined
                Driver side rear thorax airbag igniter
                    not defined
                Front passenger head curtain airbag igniter
                    activated
                Driver head curtain airbag igniter
                    activated
                Front passenger knee airbag igniter
                    not defined
                Driver knee airbag igniter
                    activated
                Reserved
                    not defined
                Reserved
                    activated
                Pedestrian protection igniter engine hood
                    not defined
                Front passenger side seat belt tension igniter
                    activated
                Driver side seat belt tension igniter
                    activated
                Passenger side rear safety belt tension igniter
                    activated
                Driver side rear safety belt tension igniter
                    activated
                Igniter for battery interrupt
                    not defined
                Rollover protection system
                    not defined
                Key switch
                    Airbag deactivation key switch installed
                Seat occupied recognition
                    activated
                Reserved
                    activated
                Reserved
                    not defined
                Reserved
                    activated
                Reserved
                    activated
                Reserved
                    activated
                Reserved
                    not defined
                Reserved
                    activated
                Reserved
                    not defined
                Reserved
                    activated
                Igniter for battery interrupt, high voltage battery
                    not defined
                Reserved
                    activated
            Calibration data, pre-crash
                Raw-Data
            Diagnostic mode
                    EV AirbaVW20SMEVW37X
                    002146
                    BAP
                    Volkswagen AG
                    1
                    5
                Revision number
                    0
                    UDS - protocol
                    Continental AG
                    1
                    7
                Revision number
                    0
                    CAN - driver
                    2
                    29
                Revision number
                    1
                    ISO15765-2
                    3
                    4
                Revision number
                    19
                    LIN 2.0
                    2
                    68
                Revision number
                    0
                    6
                    0
                Revision number
                    4
                ECU ID
                    15
                ECU Name
                    Airbag
                    Airbag
                    no error
                Data consistency
                    valid EEPROM data
                Parameterizability
                    Parameterizable
            Date of manufacture
                Year
                    16
                Month
                    6
                Day
                    2
            Manufacturer's test stand number
                    1568
                Programmability
                    programmable
                Program consistency
                    Program present
            Serial number
                    003Q5R1TPBZX
            Subassembly and series number
                    0814
                    11
                ID number
                    15
                subsystem name
                    Airbag
                    15
            Hardware version for suppliers
                    3036
                    000000000000000000009180
            Vehicle Identification Number (VIN)
                    TMBAH7NP2H7009796
                Version number
                    11
                Version number
                    12
                Version number
                    00
                Version number
                    11
                Version number
                    11
                Version number
                    21
                Version number
                    00
                Version number
                    11
                Version number
                    21
                Version number
                    11
                Version number
                    00
                Version number
                    12
                Version number
                    21
                Version number
                    12
                Version number
                    92
                Version number
                    22
                Version number
                    11
                Version number
                    11
            SoftwareVersion
                    0130
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
            Date of last coding
                Year
                    16
                Month
                    6
                Day
                    7
                Device number
                    31
                Importer number
                    770
                Dealership number
                    33281
                Data record
                    2
                Data record
                    2
                    3V0003t
                Year
                    16
                Month
                    6
                Day
                    7
                Device number
                    31
                Importer number
                    770
                Dealership number
                    33281
                    0041
                    5Q0959655AK
            HardwareVersion
                    005
                    TSR-TSR
                Day of manufacture
                    02.06.16
                    1568
                    0814
            VW/Audi part number
                    5Q0959655AK
            Manufacturer code
                    TSR
            System description
                    AirbagVW21
            System abbreviation
                    J234
            Known subsystems
                    Side Sensor Driver Front
                Subsystem number
                    A0
                    Side Sensor Passenger Front
                Subsystem number
                    A1
                    Side Sensor Driver Rear
                Subsystem number
                    A2
                    Side Sensor Passenger Rear
                Subsystem number
                    A3
                    Front Sensor Driver
                Subsystem number
                    A4
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
            Key switch
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
            Workshop code, pre-crash calibration data
                Device number
                    31
                Importer number
                    770
                Dealership number
                    33281
                Blocksize
                    F
            Coding
                Coding
                Coding
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Param to DOP 81118
                    0120E712EF
            Hardware part number for suppliers
                    94944300
                    V01.30
                Bootloader
                    0
                Application
                    0
                Data record
                    0
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                    Not available
                    Not available
                    Not available
                    Not available
                Bootloader
                    0103
                Application
                    0130
                Data record
                Bootloader
                    0
                Application
                    100
                Data record
                    0
        Mileage: 372624 km
    Backup
        16 Steering Column
        System description: Lenks.Modul
        Software number: 5Q0953569A
        Software version: 0235
        Hardware number: 5Q0953569A
        Hardware version: 075
        Serial number: 20210116400094
        Backup name: Steering Column
        Long coding
            1014
        Adaptations
            p_t_blinker_entprellen
                p t blinker entprellen
                    40 ms
            p_t_blinker_gra_entprellen
                p t blinker gra entprellen
                    40 ms
            p_t_fas_entprellen
                p t fas entprellen
                    40 ms
            p_t_wischer_entprellen
                p t wischer entprellen
                    40 ms
            p_t_wischer_intervall_entprellen
                p t wischer intervall entprellen
                    40 ms
            p_t_wischer_winterstellung
                p t wischer winterstellung
                    60 s
            p_t_grahebel_entprellen
                p t grahebel entprellen
                    40 ms
            p_t_hupe_entprellen
                p t hupe entprellen
                    40 ms
            p_s_NWDF_spg
                p s NWDF spg
                    0 ms
            p_t_hupe_indien_entprellen
                p t hupe indien entprellen
                    500 ms
            p_t_blinker_sperrzeit
                p t blinker sperrzeit
                    100 ms
            p_t_blinker_err_el_kurzschluss
                p t blinker err el kurzschluss
                    200 ms
            p_t_blinker_err_el_unterbrechung
                p t blinker err el unterbrechung
                    1000 ms
            p_t_blinker_err_unplausibel
                p t blinker err unplausibel
                    2000 ms
            p_t_blinker_err_lichthupe_haengt_ein
                p t blinker err lichthupe haengt ein
                    300 s
            p_t_blinker_err_lichthupe_haengt_aus
                p t blinker err lichthupe haengt aus
                    5000 ms
            p_t_blinker_err_fernlicht_haengt_ein
                p t blinker err fernlicht haengt ein
                    300 s
            p_t_blinker_err_fernlicht_haengt_aus
                p t blinker err fernlicht haengt aus
                    5000 ms
            p_t_blinker_err_gra_haengt_ein
                p t blinker err gra haengt ein
                    300 s
            p_t_blinker_err_gra_haengt_aus
                p t blinker err gra haengt aus
                    5000 ms
            p_t_wischer_err_el_kurzschluss
                p t wischer err el kurzschluss
                    200 ms
            p_t_wischer_err_el_unterbrechung
                p t wischer err el unterbrechung
                    1000 ms
            p_t_wischer_err_mfa_haengt_ein
                p t wischer err mfa haengt ein
                    300 s
            p_t_wischer_err_mfa_haengt_aus
                p t wischer err mfa haengt aus
                    5000 ms
            p_t_grahebel_err_el_kurzschluss
                p t grahebel err el kurzschluss
                    200 ms
            p_t_wischer_err_wischen_haengt_ein
                p t wischer err wischen haengt ein
                    300 s
            p_t_wischer_err_wischen_haengt_aus
                p t wischer err wischen haengt aus
                    5000 ms
            p_t_wischer_err_waschen_haengt_ein
                p t wischer err waschen haengt ein
                    300 s
            p_t_wischer_err_waschen_haengt_aus
                p t wischer err waschen haengt aus
                    5000 ms
            p_t_grahebel_err_el_unterbrechung
                p t grahebel err el unterbrechung
                    1000 ms
            p_t_grahebel_err_unplausibel
                p t grahebel err unplausibel
                    200 ms
            p_t_grahebel_err_gra_haengt_ein
                p t grahebel err gra haengt ein
                    300 s
            p_t_grahebel_err_gra_haengt_aus
                p t grahebel err gra haengt aus
                    5000 ms
            p_t_hupe_err_hupe_haengt_ein
                p t hupe err hupe haengt ein
                    60 s
            p_t_hupe_err_hupe_haengt_aus
                p t hupe err hupe haengt aus
                    5000 ms
            p_t_hupe_err_hinweis
                p t hupe err hinweis
                    2000 ms
            p_t_entprellzeit_unterspannung
                p t entprellzeit unterspannung
                    90000 ms
            p_t_entprellzeit_ueberspannung
                p t entprellzeit ueberspannung
                    90000 ms
            p_t_spannung_untere_schwelle
                p t spannung untere schwelle
                    6.5 V
            p_t_spannung_obere_schwelle
                p t spannung obere schwelle
                    18.0 V
            p_t_wischer_err_intervallpoti_haengt_ein
                p t wischer err intervallpoti haengt ein
                    300 s
            p_t_wischer_err_intervallpoti_haengt_aus
                p t wischer err intervallpoti haengt aus
                    5000 ms
            p_t_gra_ea_error
                p t gra ea error
                    2000 ms
            p_t_blinker_err_weckkontakthaengt_ein
                p t blinker err weckkontakthaengt ein
                    3000 ms
            p_t_blinker_err_weckkontakthaengt_aus
                p t blinker err weckkontakthaengt aus
                    5000 ms
            p_t_wischer_err_unplausibel
                p t wischer err unplausibel
                    200 ms
            p_t_spannung_obere_schwelle_funkt_einschr
                p t spannung obere schwelle funkt einschr
                    16.50 V
            p_t_spannung_untere_schwelle_funkt_einschr
                p t spannung untere schwelle funkt einschr
                    9.00 V
            p_t_entprellung_p_unplausibel
                p t entprellung p unplausibel
                    400 ms
            p_n_fehler_p_verriegelt
                p n fehler p verriegelt
                    50
                Bootloader
                    1
                Application
                    0
                Data record
                    0
                Data record
                    0
                Data record
                    0
                Bootloader
                    1
                Application
                    1000
                Data record
                    1000
                Year
                    13
                Month
                    1
                Day
                    25
                Device number
                    8192
                Importer number
                    258
                Dealership number
                    1280
                Programming status
                    Correct result
                Year
                    0
                Month
                    1
                Day
                    1
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    1
                Day
                    1
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                    0094
            Date of last coding
                Year
                    21
                Month
                    2
                Day
                    26
                    URB-001
                Day of manufacture
                    16.01.21
                    P4PQ
                    0094
                    P4PQ
            Manufacturer modification status
                Control module family
                Decoration variant
                Construction version
                Manufacture version
            Manufacturer code
                    URB
                Version number
                Version number
            Diagnostic mode
            VW/Audi part number
                    5Q0953569A
            SoftwareVersion
                    0235
            Supplier identification
                    VALEO BIETIGHEIM BISSINGEN, DE
            Date of manufacture
                Year
                    21
                Month
                    1
                Day
                    16
            Serial number
                    20210116400094
                    5Q0953569A
                    30373520202020202020
            Software version of suppliers
                    30323335
                    20160203142623
            System description
                    Lenks.Modul
                Device number
                    8192
                Importer number
                    258
                Dealership number
                    1280
                Year
                    12
                Month
                    10
                Day
                    16
                    EV SMLSVALEOMQB
                    001016
            HardwareVersion
                    075
                Device number
                    1048576
                Importer number
                    0
                Dealership number
                    44801
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Year
                    0
                Month
                    1
                Day
                    1
            System abbreviation
                    J524
                Bootloader
                    0095
                Application
                    0235
                Data record
                    0235
                    3
                    UDS - protocol
                    In2Soft GmbH
                    2
                    0
                Revision number
                    5
                    IAV GmbH
                    2
                    2
                Revision number
                    2
                    CAN - driver
                    1
                    9
                Revision number
                    0
                    ISO15765-2
                    In2Soft GmbH
                    2
                    0
                Revision number
                    2
                    OSEK - operating system
                    5
                    1
                Revision number
                    0
                    2
                    0
                Revision number
                    2
                    Standard diagnostic services for UDS
                    In2Soft GmbH
                    2
                    1
                Revision number
                    2
                    Bootloader/flasher (TP2.0/ISO TP)
                    3
                    3
                Revision number
                    8
                Programmability
                    programmable
                Program consistency
                    Program present
                    no error
                Data consistency
                    valid EEPROM data
                Parameterizability
                    Parameterizable
        Mileage: 372624 km
        Date: 2021-08-01 19:31:58
    Backup
        17 Dashboard
        System description: KOMBI
        Software number: 3V0920751A
        Software version: 8311
        Hardware number: 3V0920751A
        Hardware version: 304
        Backup name: Dashboard
        Long coding
            07A5011A2B80000801886A011000000000000000
        Adaptations
            Day
                    1 d
            dimming_characteristic_curve_adjustment_middle_display_main_field
                X1
                    0
                Y1
                    1
                X2
                    A
                Y2
                    1
                X3
                    46
                Y3
                    6
                X4
                    64
                Y4
                    C
                X5
                    DC
                Y5
                    46
                X6
                    FD
                Y6
                    64
            time_parameter_display
                tDDWUP
                    0.00
                tDD15 on
                    0.00
                tDD15 off
                    0.30
                hmi t Dreiter ms
                    2.0 s
                hmi t dummyMenuTimeout ms
                    5 s
                hmi t UhrTimeout ms
                    10 s
                hmi t MenuTimeout ms
                    255 s
                hmi t TWSAnz ms
                    3 s
                hmi t NextWarning ms
                    6 s
                hmi t NextServiceAnz ms
                    5 s
                hmi t P2Pause ms
                    900 s
                hmi t Quit ms
                    10 s
                hmi t FondGurt
                    35 s
                hmi t USZ
                    0.40 s
                hmi t FTuerAUF
                    300 ms
                hmi t P1Pause ms
                    20 s
                rollierblockgroesse
                    3
            Distance
                    372624 km
            Picture_Upload_Download
                Picture Upload Download
                    not active
            FIX: Distance covered since last mileage-dependent inspection
                    3400 km
            Fix: Max. distance until next mileage-related inspection
                    30000 km
            Offset for tank calibration values
                Offset sensor 1
                    -12.8 L
                Offset sensor 2
                    12.7 L
                Offset sensor 3
                    12.7 L
                Offset sensor 4
                    12.7 L
                Complete tank calibration
                    -12.8 L
            Service notification in days
                    30 d
            SIA: maximum value of time to service
                    365 d
            Source for synchronization of time
                    GPS
            Deactivate seat belt warning
                    No
            Hour
                    19 h
            WIV: Resetting ESI
                    no warning
            Oil temperature display
                    On
            dimming_characteristic_curve_adjustment_indicator_lights
                X1
                    0
                Y1
                    5
                X2
                    A
                Y2
                    5
                X3
                    32
                Y3
                    C
                X4
                    64
                Y4
                    17
                X5
                    96
                Y5
                    32
                X6
                    FD
                Y6
                    64
            FIX: Maximum time until next time-dependent inspection
                    365 d
            Day counter
                    1839 d
            FIX: Reset value for next mileage-dependent inspections
                    365 d
            MFA3-Reset
                MFI button RESET / OK
                    Manual reset, not possible
                Refuel detection gasoline / diesel
                    MFA3-Reset
                    MFA3-Reset
                Electrical refueling detection
                    MFA3-Reset
            SIA: maximum value of distance to service
                    15000 km
            Units adjusted
                Volume
                    Liter
                Temperature
                    Degrees Celsius
                Consumption gasoline / diesel - LPG (liquefied petroleum gas)
                    Liters per 100 km
                Pressure
                    Bar
                Distance
                    Kilometers
                Speed
                    Kilometers per hour
                Date
                    dd mm yy
                Time
                    24h
                Operating range consumption, CNG (compressed natural gas)
                    kg per 100 km
                Average consumption, electric drive
                    kWh per 100 km
                Trailer/support load ground
                    Kilogram (kg)
            SIE: minimum value km-driving distance/inspection
                    15000 km
                send messages
                    not active
            Year
                    2021 a
            Month
                    8 mon
            Speed warning
                    not active
                Unit
                    Kilometers per hour
                Speed
                    150
                    30000 km
            dimming_characteristic_curve_adjustment_gauge
                X1
                    0
                Y1
                    3
                X2
                    A
                Y2
                    3
                X3
                    46
                Y3
                    11
                X4
                    64
                Y4
                    1E
                X5
                    DC
                Y5
                    5A
                X6
                    FD
                Y6
                    64
            Display depiction
                    Version 1
            outside_temperature
                p time constant pt1
                    40 s
                p speed threshold
                    20 km/h
                p kmt at delta
                    25 °C
                p blocking time after v bigger 0
                    15 s
                p storage time engine off
                    180 min
                p mileage after v bigger 0
                    5.0 km
                p ice warning exit temperature
                    6 °C
                p ice warning entry temperature
                    4 °C
                p tendency threshold
                    1.0 °C
                p time constant slow damping
                    2.0
                p tendency damping
                    15 s
            Driving profiled for range remaining
                    7.7 l/100 km
            SIE: time from inspection
                    26 d
            FIX: Time since last time-dependent inspection
                    26 d
            SIE: maximum value km-driving distance/inspection
                    30000 km
            Service_Key_Clear_All_Counter
                clear all counter
                    Yes
            dimming_characteristic_curve_adjustment_clock_dial_day
                X1
                    0
                Y1
                    0
                X2
                    32
                Y2
                    0
                X3
                    66
                Y3
                    0
                X4
                    96
                Y4
                    A
                X5
                    DC
                Y5
                    32
                X6
                    FD
                Y6
                    64
            SIE: maximum value of time between inspections
                    730 d
            SIE: thermal load
                    2700 km
            SIE: distance driven from inspection
                    3477 km
            Service-key settings
                p write delay time
                    40 s
                p write delay speed
                    20 km/h
                p write distance
                    20 km
                p forcewrite qual time
                    10 s
                p main switch Keyless
                    On
                p main switch Basic
                    On
                p deactivate SK Function
                    On
            WIV: minimum value of time between inspections
                    365 d
            SIE: soot entry
                    8700 km
            Display correction of consumptions and operating range
                    100 %
            Configuration of Development CAN-Messages
                Block 1
                    off
                Block 12
                    off
                Block 2
                    off
                Block 3
                    off
                Block 4
                    off
                Block 5
                    off
                Block 6
                    off
                Block 7
                    off
                Block 8
                    off
                Block 9
                    off
                Block 10
                    off
                Block 11
                    off
                Block 13
                    off
                Block 14
                    off
                Block 15
                    off
                Block 16
                    off
                Block 17
                    off
                Block 18
                    off
                Block 19
                    off
                Block 20
                    off
                Block 21
                    off
                Block 22
                    off
                Block 23
                    off
                Block 24
                    off
                Block 25
                    off
                Block 26
                    off
                Block 27
                    off
                Block 28
                    off
                Block 29
                    off
                Block 30
                    off
                Block 31
                    off
                Block 32
                    off
                Block 33
                    off
                Block 34
                    off
                Block 35
                    off
                Block 36
                    off
                Block 37
                    off
                Block 38
                    off
                Block 39
                    off
            Minute
                    21 min
            dimming_characteristic_curve_adjustment_clock_dial_night
                X1
                    0
                Y1
                    3
                X2
                    A
                Y2
                    3
                X3
                    46
                Y3
                    11
                X4
                    64
                Y4
                    1F
                X5
                    DC
                Y5
                    5A
                X6
                    FD
                Y6
                    64
            Language version
                    English
            SIE: oil quality
                    Poor oil quality
            dimming_characteristic_curve_adjustment_internal_phototransistor
                X1
                    0
                Y1
                    0
                X2
                    32
                Y2
                    3C
                X3
                    64
                Y3
                    B4
                X4
                    C8
                Y4
                    DC
                X5
                    1F4
                Y5
                    FD
            Digital speedometer
                    Display
            BAP_Debug_Mode_Release
                Release
                    not released
            Vehicle positioning system interface control module
                    not installed
            Ignition active message, actuator
                    Driver door
            defuel_threshold
                defuel threshold
                    9 L
            init_fuel_algorithm
                initialisation
                    No
                    Not activated
            Gas_functionality
                Gas functionality
                    not active
            total_range_gas
                state
                    not active
                selection consumption factor
                    consumption factor CAN
                consumption profile
                    consumption profile calculation
                consumption factor
                    0.000
            No-voltage display
            Cylinder shut-off
                    Display
            Illumination_algorithm
                Pointer illumination algorithim
                    terminal 58xd log bus parkinglight
                Scale switching algorithm
                    parking light
                    30 d
            Statistic_phev_mileage
                    5 km
            Leaving_warning_delay
                Leaving warning delay
                    1.6 s
            Display of colour adjustment
                Red
                    0
                Green
                    0
                Blue
                    0
            Scale_switching_algorithm
                    lowbeam foglight
                Block 1
                    0
                Block 2
                    0
                Block 3
                    0
                Block 4
                    0
                Block 5
                    0
                Block 6
                    0
                Block 7
                    0
                Block 8
                    0
                Block 9
                    0
                Block 10
                    0
                Block 11
                    0
                Block 12
                    0
                Block 13
                    0
                Block 14
                    0
                Block 15
                    0
                Block 1
                    1000
                Block 2
                    1000
                Block 3
                    1000
                Block 4
                    1000
                Block 5
                    1000
                Block 6
                    1000
                Block 7
                    1000
                Block 8
                    1000
                Block 9
                    1000
                Block 10
                    65535
                Block 11
                    65535
                Block 12
                    65535
                Block 13
                    65535
                Block 14
                    65535
                Block 15
                    65535
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
            Date of last coding
                Year
                    21
                Month
                    7
                Day
                    29
                    VD1-048
                Day of manufacture
                    29.05.16
                    7396
                    3745
            Diagnostic mode
            VW/Audi part number
                    3V0920751A
            SoftwareVersion
                    8311
                    TMBAH7NP2H7009796
                    3V0920751A
            System description
                    KOMBI
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
                Year
                    21
                Month
                    7
                Day
                    28
                    EV DashBoardVDDMQBAB
                    009051
            HardwareVersion
                    304
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
            System abbreviation
                    J285
                Block 1
                    0086
                Block 2
                    0010
                Block 3
                    0005
                Block 4
                    0010
                Block 5
                    0007
                Block 6
                    0006
                Block 7
                    0006
                Block 8
                    0006
                Block 9
                    0007
                Block 10
                Block 11
                Block 12
                Block 13
                Block 14
                Block 15
                    1
                    Operating system
                    3
                    1
                Revision number
                    0
                    BAP
                    1
                    7
                Revision number
                    1
                    2
                    0
                Revision number
                    2
                    Leopold Kostal GmbH & Co. KG
                    6
                    2
                Revision number
                    3
            Flash data security
                Hash value
                    Not available
                    Not available
                Key
                    No
                Key type
                    Series
                Project ID
                    000004FC
                Hash value
                Programmability
                    programmable
                Program consistency
                    Program present
                Version number
                Version number
                Version number
                Version number
                Version number
                Version number
                Version number
                Version number
                Version number
                Version number
                Version number
                Version number
                Version number
                Counter Value Block 1
                    0
                Counter Value Block 2
                    0
                Counter Value Block 3
                    0
                Counter Value Block 4
                    0
                Counter Value Block 5
                    0
                Counter Value Block 6
                    0
                Counter Value Block 7
                    0
                Counter Value Block 8
                    0
                Counter Value Block 9
                    0
                Counter Value Block 10
                    0
                Counter Value Block 11
                    0
                Counter Value Block 12
                    0
                Counter Value Block 13
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Year
                    0
                Month
                    1
                Day
                    1
                    no error
                Data consistency
                    valid EEPROM data
                    Data record changed
                Parameterizability
                    Parameterizable
                    0
                    0
                    0
                    0
                    0
                    0
                    0
                    0
                    0
                    0
                    0
                    0
                    0
                    F
                ID number
                    17
                subsystem name
                    Dash Board
                    14
        Mileage: 372624 km
    Backup
        19 Gateway
        System description: GW MQB High
        Software number: 5Q0907530AM
        Software version: 2265
        Hardware number: 5Q0907530M
        Hardware version: 212
        Serial number: 30051610801229
        Backup name: Gateway
        Long coding
            0B0100045F087300EB0002481C0F00010001070000000000000000000000
        Adaptations
            Installation list, specified installations
                Gateway
                    coded
                Node 0x01
                    Not coded
                Node 0x02
                    Not coded
                Node 0x03
                    Not coded
                Node 0x04
                    Not coded
                Node 0x05
                    Not coded
                Node 0x06
                    Not coded
                Node 0x07
                    Not coded
                Node 0x08
                    Not coded
                Multifunction Module
                    Not coded
                Parking Assistance
                    coded
                Tire Pressure Monitoring 1
                    Not coded
                Steering Column Electronics
                    coded
                Node 0x0D
                    Not coded
                Central Electrics
                    coded
                All Wheel Control
                    Not coded
                Node 0x11
                    Not coded
                Steering Assistance
                    coded
                Brakes 1
                    coded
                Dash Board
                    coded
                Airbag
                    coded
                Node 0x16
                    Not coded
                Node 0x17
                    Not coded
                Radio
                    Not coded
                Air Conditioning Compressor
                    Not coded
                Node 0x1A
                    Not coded
                Head Up Display
                    Not coded
                Actuator For Structure-Borne Sound
                    Not coded
                Node 0x1D
                    Not coded
                Lock Electronics
                    Not coded
                Node 0x1F
                    Not coded
                Node 0x20
                    Not coded
                Node 0x21
                    Not coded
                Node 0x22
                    Not coded
                Deck Lid Control Unit
                    coded
                Node 0x24
                    Not coded
                Node 0x25
                    Not coded
                Node 0x26
                    Not coded
                Node 0x27
                    Not coded
                Node 0x28
                    Not coded
                Node 0x29
                    Not coded
                Node 0x2A
                    Not coded
                Special Function 2
                    Not coded
                Special Function
                    Not coded
                Electronic Roof Control
                    Not coded
                Node 0x2E
                    Not coded
                Node 0x2F
                    Not coded
                High Beam Assistance
                    Not coded
                Steering Column Locking
                    coded
                Access Startsystem Interface
                    coded
                Sliding Door Rear Left
                    Not coded
                Sliding Door Rear Right
                    Not coded
                Node 0x35
                    Not coded
                Node 0x36
                    Not coded
                Node 0x37
                    Not coded
                Node 0x38
                    Not coded
                Node 0x39
                    Not coded
                Node 0x3A
                    Not coded
                Brake Boost
                    Not coded
                Node 0x3C
                    Not coded
                Node 0x3D
                    Not coded
                Door Electronics Rear Driver Side
                    Not coded
                Door Electronics Rear Passenger Side
                    Not coded
                Node 0x40
                    Not coded
                Node 0x41
                    Not coded
                Thermal Management
                    Not coded
                Node 0x43
                    Not coded
                Battery Charger Control Module
                    Not coded
                Node 0x45
                    Not coded
                Air Conditioning
                    coded
                Trailer Function
                    Not coded
                Node 0x48
                    Not coded
                Node 0x49
                    Not coded
                Door Electronics Driver Side
                    coded
                Door Electronics Passenger Side
                    coded
                Seat Adjustment Driver Side
                    coded
                Seat Adjustment Passenger Side
                    Not coded
                Lane Change Assistant
                    Not coded
                Front Sensors Driver Assistance System
                    Not coded
                Vehicle Position Detection
                    Not coded
                Node 0x51
                    Not coded
                Node 0x52
                    Not coded
                Node 0x53
                    Not coded
                Headlight Regulation
                    coded
                Node 0x55
                    Not coded
                Node 0x56
                    Not coded
                    coded
                Node 0x58
                    Not coded
                Node 0x59
                    Not coded
                Node 0x5A
                    Not coded
                Node 0x5B
                    Not coded
                Node 0x5C
                    Not coded
                Node 0x5D
                    Not coded
                Node 0x5E
                    Not coded
                Node 0x5F
                    Not coded
                Node 0x60
                    Not coded
                Node 0x61
                    Not coded
                Node 0x62
                    Not coded
                Microphone Control Unit
                    Not coded
                Actuator For Exterior Noise
                    Not coded
                High Voltage Battery Charge Management
                    Not coded
                Node 0x66
                    Not coded
                Telematics Communication Unit
                    Not coded
                Node 0x68
                    Not coded
                Camera System Rear View
                    Not coded
                Auxiliary Parking Heater
                    Not coded
                Node 0x6B
                    Not coded
                Node 0x6C
                    Not coded
                TV Tuner
                    Not coded
                Node 0x6E
                    Not coded
                Sound System
                    Not coded
                Media Player Position 1
                    Not coded
                Tachograph
                    Not coded
                Wheel Dampening Electronics
                    Not coded
                Information Control Unit 1
                    coded
                Node 0x74
                    Not coded
                Node 0x75
                    Not coded
                Engine Control Module 1
                    coded
                Transmission Control Module
                    coded
                Node 0x78
                    Not coded
                Node 0x79
                    Not coded
                Node 0x7A
                    Not coded
                Battery Energy Control Module
                    Not coded
                Drive Motor Control Module
                    Not coded
                Node 0x7D
                    Not coded
                Node 0x7E
                    Not coded
                Node 0x7F
                    Not coded
                Node 0x80
                    Not coded
                Node 0x81
                    Not coded
                Node 0x82
                    Not coded
                Node 0x83
                    Not coded
                Control Module For Sunroof
                    Not coded
                Starter / Generator Control Module
                    Not coded
                Node 0x86
                    Not coded
                Node 0x87
                    Not coded
                Node 0x88
                    Not coded
                Node 0x89
                    Not coded
                Control Unit Lane Change Assistant 2
                    Not coded
                Node 0x8B
                    Not coded
                Node 0x8C
                    Not coded
                Node 0x8D
                    Not coded
                Node 0x8E
                    Not coded
                Node 0x8F
                    Not coded
                Node 0x90
                    Not coded
                Node 0x91
                    Not coded
                Node 0x92
                    Not coded
                Node 0x93
                    Not coded
                Node 0x94
                    Not coded
                Node 0x95
                    Not coded
                Node 0x96
                    Not coded
                Node 0x97
                    Not coded
                Node 0x98
                    Not coded
                Node 0x99
                    Not coded
                Node 0x9A
                    Not coded
                Node 0x9B
                    Not coded
                Battery Energy Control Module 2
                    Not coded
                Node 0x9D
                    Not coded
                Node 0x9E
                    Not coded
                Node 0x9F
                    Not coded
                Node 0xA0
                    Not coded
                Node 0xA1
                    Not coded
                Node 0xA2
                    Not coded
                Node 0xA3
                    Not coded
                Auxiliary Air Heater
                    Not coded
                Node 0xA5
                    Not coded
                Node 0xA6
                    Not coded
                Node 0xA7
                    Not coded
                Node 0xA8
                    Not coded
                    Not coded
                Node 0xAA
                    Not coded
                Node 0xAB
                    Not coded
                Node 0xAC
                    Not coded
                Node 0xAD
                    Not coded
                Battery Regulation Auxiliary Accumulator 1
                    Not coded
                Node 0xAF
                    Not coded
                Node 0xB0
                    Not coded
                Node 0xB1
                    Not coded
                Node 0xB2
                    Not coded
                Node 0xB3
                    Not coded
                Node 0xB4
                    Not coded
                Node 0xB5
                    Not coded
                Node 0xB6
                    Not coded
                Node 0xB7
                    Not coded
                Node 0xB8
                    Not coded
                Node 0xB9
                    Not coded
                Node 0xBA
                    Not coded
                Node 0xBB
                    Not coded
                Node 0xBC
                    Not coded
                Node 0xBD
                    Not coded
                Node 0xBE
                    Not coded
                Node 0xBF
                    Not coded
                Node 0xC0
                    Not coded
                Node 0xC1
                    Not coded
                Node 0xC2
                    Not coded
                Node 0xC3
                    Not coded
                Node 0xC4
                    Not coded
                Node 0xC5
                    Not coded
                Node 0xC6
                    Not coded
                Node 0xC7
                    Not coded
                Node 0xC8
                    Not coded
                Node 0xC9
                    Not coded
                Node 0xCA
                    Not coded
                Node 0xCB
                    Not coded
                Node 0xCC
                    Not coded
                Node 0xCD
                    Not coded
                Node 0xCE
                    Not coded
                Node 0xCF
                    Not coded
                Node 0xD0
                    Not coded
                Node 0xD1
                    Not coded
                Node 0xD2
                    Not coded
                Node 0xD3
                    Not coded
                Node 0xD4
                    Not coded
                Node 0xD5
                    Not coded
                Node 0xD6
                    Not coded
                Node 0xD7
                    Not coded
                Node 0xD8
                    Not coded
                Node 0xD9
                    Not coded
                Node 0xDA
                    Not coded
                Node 0xDB
                    Not coded
                Node 0xDC
                    Not coded
                Node 0xDD
                    Not coded
                Node 0xDE
                    Not coded
                Node 0xDF
                    Not coded
                Node 0xE0
                    Not coded
                Node 0xE1
                    Not coded
                Node 0xE2
                    Not coded
                Node 0xE3
                    Not coded
                Node 0xE4
                    Not coded
                Node 0xE5
                    Not coded
                Node 0xE6
                    Not coded
                Node 0xE7
                    Not coded
                Node 0xE8
                    Not coded
                Node 0xE9
                    Not coded
                Node 0xEA
                    Not coded
                Node 0xEB
                    Not coded
                Node 0xEC
                    Not coded
                Node 0xED
                    Not coded
                Node 0xEE
                    Not coded
                Node 0xEF
                    Not coded
                Node 0xF0
                    Not coded
                Node 0xF1
                    Not coded
                Node 0xF2
                    Not coded
                Node 0xF3
                    Not coded
                Node 0xF4
                    Not coded
                Node 0xF5
                    Not coded
                Node 0xF6
                    Not coded
                Node 0xF7
                    Not coded
                Node 0xF8
                    Not coded
                Node 0xF9
                    Not coded
                Node 0xFA
                    Not coded
                Node 0xFB
                    Not coded
                Node 0xFC
                    Not coded
                Node 0xFD
                    Not coded
                Node 0xFE
                    Not coded
                Node 0xFF
                    Not coded
            Battery adaptation
                Rated battery capacity
                    68 Ah
                Battery manufacturer
                    JCB
                Battery serial number
                    1111111111
                Battery technology
                    Fleece
            Static current measuring mode
                    Not activated
            Transport mode
                    not active
            Component protection showroom mode
                    not active
            GW_Enable_CAN_Timeout_DTC
                Gateway
                    enabled
                Gateway Component List Failure Mask Node 0x01
                    enabled
                Gateway Component List Failure Mask Node 0x02
                    enabled
                Gateway Component List Failure Mask Node 0x03
                    enabled
                Gateway Component List Failure Mask Node 0x04
                    enabled
                Gateway Component List Failure Mask Node 0x05
                    enabled
                Gateway Component List Failure Mask Node 0x06
                    enabled
                Gateway Component List Failure Mask Node 0x07
                    enabled
                Gateway Component List Failure Mask Node 0x08
                    enabled
                    enabled
                Parking Assistance
                    enabled
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x0D
                    enabled
                Central Electrics
                    enabled
                All Wheel Control
                    enabled
                Gateway Component List Failure Mask Node 0x11
                    enabled
                Steering Assistance
                    enabled
                Brakes 1
                    not enabled
                Dash Board
                    enabled
                Airbag
                    not enabled
                Gateway Component List Failure Mask Node 0x16
                    enabled
                Gateway Component List Failure Mask Node 0x17
                    enabled
                Radio
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x1A
                    enabled
                Head Up Display
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x1D
                    enabled
                Lock Electronics
                    enabled
                Gateway Component List Failure Mask Node 0x1F
                    enabled
                Gateway Component List Failure Mask Node 0x20
                    enabled
                Gateway Component List Failure Mask Node 0x21
                    enabled
                Gateway Component List Failure Mask Node 0x22
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x24
                    enabled
                Gateway Component List Failure Mask Node 0x25
                    enabled
                Gateway Component List Failure Mask Node 0x26
                    enabled
                Gateway Component List Failure Mask Node 0x27
                    enabled
                Gateway Component List Failure Mask Node 0x28
                    enabled
                Gateway Component List Failure Mask Node 0x29
                    enabled
                Gateway Component List Failure Mask Node 0x2A
                    enabled
                Special Function 2
                    enabled
                Special Function
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x2E
                    enabled
                Gateway Component List Failure Mask Node 0x2F
                    enabled
                    enabled
                    enabled
                    enabled
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x35
                    enabled
                Gateway Component List Failure Mask Node 0x36
                    enabled
                Gateway Component List Failure Mask Node 0x37
                    enabled
                Gateway Component List Failure Mask Node 0x38
                    enabled
                Gateway Component List Failure Mask Node 0x39
                    enabled
                Gateway Component List Failure Mask Node 0x3A
                    enabled
                Brake Boost
                    enabled
                Gateway Component List Failure Mask Node 0x3C
                    enabled
                Gateway Component List Failure Mask Node 0x3D
                    enabled
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x40
                    enabled
                Gateway Component List Failure Mask Node 0x41
                    enabled
                Thermal Management
                    enabled
                Gateway Component List Failure Mask Node 0x43
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x45
                    enabled
                Air Conditioning
                    enabled
                Trailer Function
                    enabled
                Gateway Component List Failure Mask Node 0x48
                    enabled
                Gateway Component List Failure Mask Node 0x49
                    enabled
                    enabled
                    enabled
                    enabled
                    enabled
                    enabled
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x51
                    enabled
                Gateway Component List Failure Mask Node 0x52
                    enabled
                Gateway Component List Failure Mask Node 0x53
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x55
                    enabled
                Gateway Component List Failure Mask Node 0x56
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x58
                    enabled
                Gateway Component List Failure Mask Node 0x59
                    enabled
                Gateway Component List Failure Mask Node 0x5A
                    enabled
                Gateway Component List Failure Mask Node 0x5B
                    enabled
                Gateway Component List Failure Mask Node 0x5C
                    enabled
                Gateway Component List Failure Mask Node 0x5D
                    enabled
                Gateway Component List Failure Mask Node 0x5E
                    enabled
                Gateway Component List Failure Mask Node 0x5F
                    enabled
                Gateway Component List Failure Mask Node 0x60
                    enabled
                Gateway Component List Failure Mask Node 0x61
                    enabled
                Gateway Component List Failure Mask Node 0x62
                    enabled
                    enabled
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x66
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x68
                    enabled
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x6B
                    enabled
                Gateway Component List Failure Mask Node 0x6C
                    enabled
                TV Tuner
                    enabled
                Gateway Component List Failure Mask Node 0x6E
                    enabled
                Sound System
                    enabled
                    enabled
                Tachograph
                    enabled
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x74
                    enabled
                Gateway Component List Failure Mask Node 0x75
                    enabled
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x78
                    enabled
                Gateway Component List Failure Mask Node 0x79
                    enabled
                Gateway Component List Failure Mask Node 0x7A
                    enabled
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x7D
                    enabled
                Gateway Component List Failure Mask Node 0x7E
                    enabled
                Gateway Component List Failure Mask Node 0x7F
                    enabled
                Gateway Component List Failure Mask Node 0x80
                    enabled
                Gateway Component List Failure Mask Node 0x81
                    enabled
                Gateway Component List Failure Mask Node 0x82
                    enabled
                Gateway Component List Failure Mask Node 0x83
                    enabled
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x86
                    enabled
                Gateway Component List Failure Mask Node 0x87
                    enabled
                Gateway Component List Failure Mask Node 0x88
                    enabled
                Gateway Component List Failure Mask Node 0x89
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x8B
                    enabled
                Gateway Component List Failure Mask Node 0x8C
                    enabled
                Gateway Component List Failure Mask Node 0x8D
                    enabled
                Gateway Component List Failure Mask Node 0x8E
                    enabled
                Gateway Component List Failure Mask Node 0x8F
                    enabled
                Gateway Component List Failure Mask Node 0x90
                    enabled
                Gateway Component List Failure Mask Node 0x91
                    enabled
                Gateway Component List Failure Mask Node 0x92
                    enabled
                Gateway Component List Failure Mask Node 0x93
                    enabled
                Gateway Component List Failure Mask Node 0x94
                    enabled
                Gateway Component List Failure Mask Node 0x95
                    enabled
                Gateway Component List Failure Mask Node 0x96
                    enabled
                Gateway Component List Failure Mask Node 0x97
                    enabled
                Gateway Component List Failure Mask Node 0x98
                    enabled
                Gateway Component List Failure Mask Node 0x99
                    enabled
                Gateway Component List Failure Mask Node 0x9A
                    enabled
                Gateway Component List Failure Mask Node 0x9B
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0x9D
                    enabled
                Gateway Component List Failure Mask Node 0x9E
                    enabled
                Gateway Component List Failure Mask Node 0x9F
                    enabled
                Gateway Component List Failure Mask Node 0xA0
                    enabled
                Gateway Component List Failure Mask Node 0xA1
                    enabled
                Gateway Component List Failure Mask Node 0xA2
                    enabled
                Gateway Component List Failure Mask Node 0xA3
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0xA5
                    enabled
                Gateway Component List Failure Mask Node 0xA6
                    enabled
                Gateway Component List Failure Mask Node 0xA7
                    enabled
                Gateway Component List Failure Mask Node 0xA8
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0xAA
                    enabled
                Gateway Component List Failure Mask Node 0xAB
                    enabled
                Gateway Component List Failure Mask Node 0xAC
                    enabled
                Gateway Component List Failure Mask Node 0xAD
                    enabled
                    enabled
                Gateway Component List Failure Mask Node 0xAF
                    enabled
                Gateway Component List Failure Mask Node 0xB0
                    enabled
                Gateway Component List Failure Mask Node 0xB1
                    enabled
                Gateway Component List Failure Mask Node 0xB2
                    enabled
                Gateway Component List Failure Mask Node 0xB3
                    enabled
                Gateway Component List Failure Mask Node 0xB4
                    enabled
                Gateway Component List Failure Mask Node 0xB5
                    enabled
                Gateway Component List Failure Mask Node 0xB6
                    enabled
                Gateway Component List Failure Mask Node 0xB7
                    enabled
                Gateway Component List Failure Mask Node 0xB8
                    enabled
                Gateway Component List Failure Mask Node 0xB9
                    enabled
                Gateway Component List Failure Mask Node 0xBA
                    enabled
                Gateway Component List Failure Mask Node 0xBB
                    enabled
                Gateway Component List Failure Mask Node 0xBC
                    enabled
                Gateway Component List Failure Mask Node 0xBD
                    enabled
                Gateway Component List Failure Mask Node 0xBE
                    enabled
                Gateway Component List Failure Mask Node 0xBF
                    enabled
                Gateway Component List Failure Mask Node 0xC0
                    enabled
                Gateway Component List Failure Mask Node 0xC1
                    enabled
                Gateway Component List Failure Mask Node 0xC2
                    enabled
                Gateway Component List Failure Mask Node 0xC3
                    enabled
                Gateway Component List Failure Mask Node 0xC4
                    enabled
                Gateway Component List Failure Mask Node 0xC5
                    enabled
                Gateway Component List Failure Mask Node 0xC6
                    enabled
                Gateway Component List Failure Mask Node 0xC7
                    enabled
                Gateway Component List Failure Mask Node 0xC8
                    enabled
                Gateway Component List Failure Mask Node 0xC9
                    enabled
                Gateway Component List Failure Mask Node 0xCA
                    enabled
                Gateway Component List Failure Mask Node 0xCB
                    enabled
                Gateway Component List Failure Mask Node 0xCC
                    enabled
                Gateway Component List Failure Mask Node 0xCD
                    enabled
                Gateway Component List Failure Mask Node 0xCE
                    enabled
                Gateway Component List Failure Mask Node 0xCF
                    enabled
                Gateway Component List Failure Mask Node 0xD0
                    enabled
                Gateway Component List Failure Mask Node 0xD1
                    enabled
                Gateway Component List Failure Mask Node 0xD2
                    enabled
                Gateway Component List Failure Mask Node 0xD3
                    enabled
                Gateway Component List Failure Mask Node 0xD4
                    enabled
                Gateway Component List Failure Mask Node 0xD5
                    enabled
                Gateway Component List Failure Mask Node 0xD6
                    enabled
                Gateway Component List Failure Mask Node 0xD7
                    enabled
                Gateway Component List Failure Mask Node 0xD8
                    enabled
                Gateway Component List Failure Mask Node 0xD9
                    enabled
                Gateway Component List Failure Mask Node 0xDA
                    enabled
                Gateway Component List Failure Mask Node 0xDB
                    enabled
                Gateway Component List Failure Mask Node 0xDC
                    enabled
                Gateway Component List Failure Mask Node 0xDD
                    enabled
                Gateway Component List Failure Mask Node 0xDE
                    enabled
                Gateway Component List Failure Mask Node 0xDF
                    enabled
                Gateway Component List Failure Mask Node 0xE0
                    enabled
                Gateway Component List Failure Mask Node 0xE1
                    enabled
                Gateway Component List Failure Mask Node 0xE2
                    enabled
                Gateway Component List Failure Mask Node 0xE3
                    enabled
                Gateway Component List Failure Mask Node 0xE4
                    enabled
                Gateway Component List Failure Mask Node 0xE5
                    enabled
                Gateway Component List Failure Mask Node 0xE6
                    enabled
                Gateway Component List Failure Mask Node 0xE7
                    enabled
                Gateway Component List Failure Mask Node 0xE8
                    enabled
                Gateway Component List Failure Mask Node 0xE9
                    enabled
                Gateway Component List Failure Mask Node 0xEA
                    enabled
                Gateway Component List Failure Mask Node 0xEB
                    enabled
                Gateway Component List Failure Mask Node 0xEC
                    enabled
                Gateway Component List Failure Mask Node 0xED
                    enabled
                Gateway Component List Failure Mask Node 0xEE
                    enabled
                Gateway Component List Failure Mask Node 0xEF
                    enabled
                Gateway Component List Failure Mask Node 0xF0
                    enabled
                Gateway Component List Failure Mask Node 0xF1
                    enabled
                Gateway Component List Failure Mask Node 0xF2
                    enabled
                Gateway Component List Failure Mask Node 0xF3
                    enabled
                Gateway Component List Failure Mask Node 0xF4
                    enabled
                Gateway Component List Failure Mask Node 0xF5
                    enabled
                Gateway Component List Failure Mask Node 0xF6
                    enabled
                Gateway Component List Failure Mask Node 0xF7
                    enabled
                Gateway Component List Failure Mask Node 0xF8
                    enabled
                Gateway Component List Failure Mask Node 0xF9
                    enabled
                Gateway Component List Failure Mask Node 0xFA
                    enabled
                Gateway Component List Failure Mask Node 0xFB
                    enabled
                Gateway Component List Failure Mask Node 0xFC
                    enabled
                Gateway Component List Failure Mask Node 0xFD
                    enabled
                Gateway Component List Failure Mask Node 0xFE
                    enabled
                Gateway Component List Failure Mask Node 0xFF
                    enabled
                Gateway Component List Failure Mask Node 0x00
                    enabled
            GW_mirror_mode
                mirror mode bus
                    Databus drivetrain
                mirror mode typ
                    not active
            MKE Check box
                    activated
            WakeUpMonitor_Configuration
                Sample Time Keeping Awake Events
                    12 s
                Max Num Keeping Awake Events
                    100
                WakeUpMonitor Start Delay
                    0 s
            WakeUpMonitor_Activation
                Activation
                    activated
                Open Filter Activate
                    Not activated
            Distance left for deactivation of static current measuring mode
                    2
            Distance left for deactivation of transport mode
                    50
                Activation stages
                    Not activated
                Malfunction states
                    no error
            Deactivation of start-stop function
                    Mode not active
            Auxiliary heater activation restriction request
                Switch on ban activation
                    Mode not active
                Set point target time
            Energy management deactivation stage
                    Mode not active
            EM_energy_management_warning_displays
                Generatormeldungen
                    Mode not active
                Batteriemeldungen
                    Mode not active
                MMI Vorwarnungen
                    Mode not active
                Ladezustand
                    Mode not active
            Energy management heat output control status
                    Mode not active
            Increase idle speed request
                    Mode not active
            Battery terminal recognition
                    connected
            Hysteresis voltage
                Voltage lowering
                    12.1 V
                Voltage elevation
                    12.1 V
            EM_nominal_voltage_limitation_low_beams
                    12.1 V
            Generator specified voltage value variable
                Set point voltage
                    10.6 V
            EM_start_stop_requirement_ambient_temperature
                Minimum temperature
                    -50.0 °C
                Maximum temperature
                    -50.0 °C
            EM_requirement_reduction_air_blowers
                    Mode not active
            EM_requirement_cyclic_time_voltage_measurement
                    0 s
            Production mode
                p mode deactivate recuperation
                    Deactivating
                p mode deactivate mfl keys
                    Deactivating
                Development messages
                    not active
            GW_routing_0
                    000000000000000000000000
            GW_routing_1
            GW_routing_2
            GW_routing_3
            GW_routing_4
            GW_routing_5
            GW_routing_6
            GW_routing_7
            GW_routing_8
            GW_routing_9
            Driving_Profile_Selection_Parameter
                Driving Profile Selection Toogle Time Adaptation
                    800 ms
                Driving Profile Selection Touch Contact Time Adaption
                    2500 ms
                Driving Profile Selection Indication Control Adaption
                    3000 ms
                Driving Profile Selection Kombi Offset Adaption
                    0 ms
                Driving Profile Selection Sync Time Adaptation
                    1500 ms
                Driving Profile Selection Request Repetition Time Adaptation
                    180000 ms
                Driving Profile Selection Fiddle Proofing Time Adaptation
                    10000 ms
                Driving Profile Selection Fiddle Proofing Limit Adaptation
                    100
                Driving Profile Selection Fiddle Proofing Lock Adaptation
                    60000 ms
                Driving Profile Selection Counter Master Reset
                    active
            Efficiency program display
                Live tip air resistance: close window/sunroof
                    activated
                Live tip engine brake: uncouple not until below 1300 RPM
                    activated
                Live tip do not operate gas pedal during engine start
                    activated
                Live tip adhere to switch display (only manual switch)
                    activated
                Live tip use start-stop-system
                    activated
                Live tip switch on start-stop-system
                    activated
                Live tip air conditioning: close window/sunroof
                    activated
                Live tip use gearshift position D
                    activated
                Live tip Do not press accelerator pedal at standstill
                    activated
                Live tip sunroof open: switch of A/C (AC button)
                    activated
                Live tip avoid engine warm-up at standstill
                    activated
                Comfort use A/C
                    activated
                Rear A/C System blower convenience consumption
                    activated
                Comfort use parking heater
                    activated
                Comfort use windshield heater
                    activated
                Comfort use rear window heater
                    activated
                Comfort use steering wheel heater
                    activated
                Comfort use rear heater
                    activated
                Comfort use mirror heater
                    activated
                Comfort use front seat heater
                    activated
                Comfort use rear seat heater
                    Not activated
                Comfort use front seat ventilation
                    activated
                Comfort use rear seat ventilation
                    activated
                Comfort use fog light
                    activated
                Comfort use rear fog light
                    Not activated
                Dependence of ECO tips on driver profile selection
                    ECO tips independent of driver profile selection
                Comfort use parking heater consumption emission
                    activated
                Convenience consumption outer mirror heater dependency
                    Until temperature threshold, with after-run, with switch
            Production process data 1
                    0
            Counter for inconsistent states
                    1099
            Start/stop start voltage limit
                    7.8 V
                    00
                    FFFFFFFF
            AGW_Calibration
                AGW Time Fade In
                    0 ms
                AGW Time Fade Out
                    0 ms
                AGW Time Fade In Start
                    0 ms
                AGW Time Fade Out Start
                    0 ms
                AGW Time Start Sequence
                    0 ms
                AGW Time Start Delay
                    0 ms
                AGW Brightness Start Sequence
                    100 %
                AGW fade in deactivation threshold
                    100
            AGW_Function_Releases
                AGW Enabling Brightness
                    active
                AGW Enabling Flash Frequency
                    active
                AGW Enabling Supression Symbol
                    active
            Range gain
                PTC(low voltage) consumption
                    Not activated
                Convenience consumption socket
                    activated
                Outer mirror heater consumption in rear window heating
                    Not activated
                Windshield heater consumption in AC system
                    Not activated
                List at engine still stand
                    activated
                List display absolute values with weighting
                    Not activated
                Catalogue range display
                    activated
                Loading condition catalogue range display
                    activated
                A/C System blower manual convenience consumption
                    Not activated
                Range gain AC system
                    activated
                Range gain auxiliary heater
                    activated
                Range gain window defogger
                    activated
                Range gain seat heater front
                    activated
                Range gain front set ventilation
                    activated
                Range gain rear heater
                    activated
                Range gain fog light
                    activated
                Range gain rear fog light
                    activated
                Range gain windshield heating
                    activated
                Range gain steering wheel heater
                    activated
                Range gain mirror heater
                    activated
                Range gain rear seat heater
                    activated
                    activated
                Windshield heater range gain in AC system
                    Not activated
                PTC(low voltage) range gain
                    Not activated
            Number requests autonomous recharging
                    3
            Cyclization limitation request battery service
                    0
            EM_heating_power_quota_adjustment
                    1000 W
                Bootloader
                    0
                Application
                    0
                Data record
                    0
                Data record
                    1
                Data record
                    1
                Bootloader
                    65535
                Application
                    65535
                Data record
                    0
                ECU ID
                    19
                ECU Name
                    Gateway
                    Gateway
                ID number
                    19
                subsystem name
                    Gateway
                    10
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                    Not available
                    Not available
                    Not available
                    Not available
            Date of last coding
                Year
                    0
                Month
                    1
                Day
                    1
                    SJ8-FST
                Day of manufacture
                    30.05.16
                    1080
                    1229
                Decoration variant
                Manufacture version
                Version number
                Version number
                    F4
                Version number
                Version number
                Version number
                Version number
                    36
                Version number
                Version number
                Version number
                Version number
                Version number
                Version number
                Version number
                    72
                Version number
                Version number
                Version number
            Diagnostic mode
            VW/Audi part number
                    5Q0907530AM
            SoftwareVersion
                    2265
            Serial number
                    30051610801229
                    TMBAH7NP2H7009796
                    5Q0907530M
                    333530303731333036323136303730362D2D2D2D2D2D2D2D
            System description
                    GW MQB High
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
                Year
                    0
                Month
                    0
                Day
                    0
                    EV GatewConti
                    V03935242BS
                    0001
                    013020
            HardwareVersion
                    212
                    00000000BA5EA3E9846A1D81
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
                Device number
                    18
                Importer number
                    770
                Dealership number
                    33281
                Year
                    16
                Month
                    6
                Day
                    7
            System abbreviation
                    J533
                Bootloader
                    2006
                Application
                    2265
                Data record
                    1
                    IAV GmbH
                    2
                    3
                Revision number
                    3
                    Unknown
                    In2Soft GmbH
                    1
                    0
                Revision number
                    3
                    ISO15765-2
                    In2Soft GmbH
                    2
                    0
                Revision number
                    5
                    In2Soft GmbH
                    2
                    2
                Revision number
                    6
                    UDS - protocol
                    In2Soft GmbH
                    2
                    1
                Revision number
                    16
                    OSEK - Network management
                    2
                    2
                Revision number
                    0
            Flash data security
                Hash value
                    Not available
                    Not available
                Key
                    No
                Key type
                    Series
                Project ID
                    0000041A
                Hash value
                Programmability
                    programmable
                Program consistency
                    Program present
                    no error
                Data consistency
                    valid EEPROM data
                Parameterizability
                    Parameterizable
        Mileage: 372624 km
    Backup
        2B Steering Column Lock
        System description: ELV-MQBB
        Software number: 3Q0905861
        Software version: 0032
        Hardware number: 3Q0905861
        Hardware version: H05
        Serial number: 16000112006001
        Backup name: Steering Column Lock
        Long coding
            0800000000000000
        Adaptations
                    not active
            Steering column lock unlocked
                    unlock
            functional_check_manufacturer
                functional check manufacturer
                    tested
            functional_check_steering_column_supplier
                functional check steering column supplier
                    tested
                Bootloader
                    0
                Application
                    0
                CoCo
                    0
                Bootloader
                    1000
                Application
                    1000
                CoCo
                    1000
                ID number
                    2B
                subsystem name
                    0
                Year
                    0
                Month
                    1
                Day
                    1
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    1
                Day
                    1
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    1
                Day
                    1
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                    0202
            Date of last coding
                Year
                    0
                Month
                    0
                Day
                    0
                    MD9-MSR
                Day of manufacture
                    14.05.16
                    0605
                    0202
            Manufacturer code
                    MD9
            Diagnostic mode
            VW/Audi part number
                    3Q0905861
            SoftwareVersion
                    0032
            Date of manufacture
                Year
                    16
                Month
                    5
                Day
                    14
            Serial number
                    16000112006001
                    TMBAH7NP2H7009796
                    3Q0905861
            System description
                    ELV-MQBB
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Year
                    0
                Month
                    1
                Day
                    1
                    EV ELVMarquMQBB
                    001007
            HardwareVersion
                    H05
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
            System abbreviation
                    J764
                Bootloader
                    0010
                Application
                    0032
                CoCo
                    0020
                    UDS - protocol
                    In2Soft GmbH
                    2
                    1
                Revision number
                    3
                    IAV GmbH
                    4
                    1
                Revision number
                    4
                    CAN - driver
                    1
                    26
                Revision number
                    2
                    ISO15765-2
                    In2Soft GmbH
                    2
                    0
                Revision number
                    4
                    3
                    21
                Revision number
                    0
                    2
                    2
                Revision number
                    0
                    In2Soft GmbH
                    2
                    2
                Revision number
                    3
            Flash data security
                Hash value
                    Not available
                    Not available
                Key
                    No
                Key type
                    Series
                Project ID
                    000004ED
                Hash value
                Programmability
                    programmable
                Program consistency
                    Program present
            Immobilizer - Challenge
                    C6684856
            State of Immobilizer
                    020103A3000000000000
            State of Immobilizer Slaves
                    04F80000000000000000
            State Blocking Time
                    000000000000
                    8234C49893
            Snapshot
                    FFFFFFFFFFFFFF000000
                    F
            MQ Serial Number
                    4016000112006001
            Platform coding value
                    MQBB
            Free_Releases_Numbers
                    255
                    0605
        Mileage: 372624 km
    Backup
        36 Driver Seat
        System description: Sitzmemory
        Software number: 5Q0959760B
        Software version: 0020
        Hardware number: 5Q0959760B
        Hardware version: H07
        Serial number: Y0006PES17037
        Backup name: Driver Seat
        Long coding
            0010000000000500018480808080000000008181000000D400
        Adaptations
            installation position
                    Memory seat driver side
            vehicle_velocity_monitoring
                    active
                Bootloader
                    0
                Application
                    0
                Data record
                    1
                Data record
                    1
                Bootloader
                    1
                Application
                    65534
                Year
                    0
                Month
                    1
                Day
                    1
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    1
                Day
                    1
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                    7037
            Date of last coding
                Year
                    21
                Month
                    3
                Day
                    26
                    KO1-ABY
                Day of manufacture
                    28.05.16
                    1019
                    7037
                    1019
            Manufacturer code
                    KO1
                Version number
                    03
                Version number
                    04
            Diagnostic mode
            VW/Audi part number
                    5Q0959760B
            SoftwareVersion
                    0020
                    Kostal
            Date of manufacture
                Year
                    16
                Month
                    5
                Day
                    28
            Serial number
                    Y0006PES17037
                    5Q0959760B
                    10121326
                    H07
                    10121326
                    APPL: 0020, FBL: 0010
            System description
                    Sitzmemory
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
                Year
                    21
                Month
                    3
                Day
                    26
                    EV SeatMemorDriveSide
                    002021
            HardwareVersion
                    H07
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
                Device number
                    1048576
                Importer number
                    0
                Dealership number
                    1536
                Year
                    95
                Month
                    11
                Day
                    1
            System abbreviation
                    J810
                    1
                Programmability
                    programmable
                Program consistency
                    Program present
                    no error
                Data consistency
                    valid EEPROM data
                Parameterizability
                    Parameterizable
                    15
                Bootloader
                    0010
                Application
                    0020
        Mileage: 372624 km
    Backup
        42 Driver Door
        System description: TSG FS
        Software number: 5Q4959593E
        Software version: 0031
        Hardware number: 5Q4959593B
        Hardware version: 010
        Serial number: 0000201590746
        Backup name: Driver Door
        Long coding
            001D0920DE00040000001100
        Adaptations
            Production mode
                Production mode
                    0
            Window_Regulator_Supplier_Settings_Driver_Side_Rear_1
                Parameter
                    000014832B14F0F0F0002000FC7C00140005066401F4320F0007800000073F8000B4000C000C00270050008900D10129017B04040301030703E80BB832050F2D507304049A3C091A36630083E0E7044E5370CA0003000C00AF016E5A01908507D010100014001403842710536D030010800C01FF9FFF0000000A010000009D42
            Window_Regulator_Supplier_Settings_Driver_Side_Rear_2
                Parameter
                    028A022614ECFF02020A0201000A053C0212190A0005F11E1E0F0005FB0A05FB120D00000000FF00000000FF002300191E201EFAD8C4F6FB281E320A1E00003203190C1210FAECD8F6FB1E1432000C00008202190E1614FAD8C4F6FB281E32080E000A280A0A2823050A281E00000000000000000000000000000000000010BD
            Patch_Code_Driver_Side_Rear
                Parameter
                    00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF22FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
            Window_Regulator_VW_Settings_Driver_Side_Rear
                Param to DOP 22811
                    F600F00010190F03F0080014C800000001A401C2096423C81E003232019000000000000000AF0000323CC8004E004D7964643260D36DCF641E320A0A5BD96DCF641432323214000037343031010000000000000000004C17
            Deactivate production mode
                    0
            Reversing_Threshold_Driver_Side_Front
                    90 %
            Reversing_Threshold_Driver_Side_Rear
                    90 %
                Bootloader
                    1
                Application
                    0
                Data record
                    1
                Data record
                    1
                Data record
                    1
                Bootloader
                    1
                Application
                    1000
                Data record
                    1000
                ECU ID
                    42
                ECU Name
                ID number
                    42
                subsystem name
                    4A
                Year
                    0
                Month
                    1
                Day
                    1
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    1
                Day
                    1
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    16
                Month
                    6
                Day
                    7
                Device number
                    31
                Importer number
                    770
                Dealership number
                    33281
                Programming status
                    Correct result
            Date of last coding
                Year
                    0
                Month
                    1
                Day
                    1
                    CU5-DCM
                Day of manufacture
                    25.05.16
                    0310
                    418B
                Version number
                    SK
                Version number
                    48
                Version number
                    11
                Version number
                    60
                Version number
                    42
                Version number
                    9D
                Version number
                    01
            Diagnostic mode
            VW/Audi part number
                    5Q4959593E
            SoftwareVersion
                    0031
            Serial number
                    0000201590746
                    5Q4959593B
            System description
                    TSG FS
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
                Year
                    21
                Month
                    1
                Day
                    31
                    EV DCUDriveSideEWMAXCONT
                    V03935241US
                    0001
                    006001
            HardwareVersion
                    010
                    0000000000000000000028AB
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
                Device number
                    31
                Importer number
                    770
                Dealership number
                    33281
                Year
                    16
                Month
                    6
                Day
                    7
            System abbreviation
                    J386
                Bootloader
                    0204
                Application
                    0031
                Data record
                    0001
                    2
                    Unknown
                    IAV GmbH
                    2
                    2
                Revision number
                    2
                    Flash EEPROM emulation
                    In2Soft GmbH
                    2
                    1
                Revision number
                    2
                    Unknown
                    In2Soft GmbH
                    2
                    0
                Revision number
                    5
                    Unknown
                    In2Soft GmbH
                    2
                    0
                Revision number
                    2
                    CAN - driver
                    1
                    26
                Revision number
                    2
                    2
                    0
                Revision number
                    2
                Programmability
                    programmable
                Program consistency
                    Program present
                    no error
                Data consistency
                    valid EEPROM data
                    Data record changed
                Parameterizability
                    Parameterizable
        Mileage: 372624 km
    Backup
        44 Steering Assistance
        System description: MQB_PP_APA
        Software number: 5Q0909143M
        Software version: 2041
        Hardware number: 5Q0909143E
        Hardware version: 204
        Serial number: 0000827022
        Backup name: Steering Assistance
        Long coding
            01000010005000
        Adaptations
            Activating and deactivating all development messages
                    not active
            Activation of pwr steering asst without engine running
                    not active
            Download without rest bus
                    not active
            XCP calibration protocol
                    not active
            Software end stop
                    active
            Straight line running
                    active
            Driving profile switchover
                    Incremental, controlled over time
            Support power
                    100%
            Characteristic curve of steering assistance
                    Not assigned
                Bootloader
                    1
                Application
                    1
                data block ASC
                    1
                data block system
                    2
                data block steering
                    3
                Data record
                    3
                Data record
                    2
                Bootloader
                    1
                Application
                    999
                data block ASC
                    999
                data block system
                    999
                data block steering
                    999
                ID number
                    44
                subsystem name
                    Steering Assistance
                    12
                Year
                    0
                Month
                    1
                Day
                    1
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    1
                Day
                    1
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    1
                Day
                    1
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    1
                Day
                    1
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    1
                Day
                    1
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                    0219
            Date of last coding
                Year
                    0
                Month
                    0
                Day
                    0
                    TT1-BUD
                Day of manufacture
                    24.05.16
                    0001
                    0219
                    0001
            Manufacturer code
                    TT1
                Number of data records
                    05
                Version of system parameters
                    22
                Vehicle type
                    UZ
                Index characteristic curve
                    06
                Version of characteristic curves
                    03
                Version of memory map
                    03
            Diagnostic mode
            VW/Audi part number
                    5Q0909143M
            SoftwareVersion
                    2041
            Date of manufacture
                Year
                    16
                Month
                    5
                Day
                    24
            Serial number
                    0000827022
                    5Q0909143E
            System description
                    MQB PP APA
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
                Year
                    32
                Month
                    31
                Day
                    30
                    EV SteerAssisVWBSMQBA
                    3V0074t
                    0016
                    008028
            HardwareVersion
                    204
                    FFFFFFFFFFFFFFFFFFFFFFFE
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
                Device number
                    2096927
                Importer number
                    771
                Dealership number
                    130817
                Year
                    21
                Month
                    2
                Day
                    17
            System abbreviation
                    J500
                Bootloader
                    U504
                Application
                    2041
                Data record
                    0934
                    2
            AUTOSAR Standard application software identification
                Standard software module
                    UDS - protocol
                Software manufacturer ID
                    In2Soft GmbH
                Primary version number
                    2
                Secondary version number
                    0
                Revision number
                    3
                    Diagnostics - Event - Handler
                    IAV GmbH
                    2
                    2
                Revision number
                    2
                    In2Soft GmbH
                    2
                    1
                Revision number
                    3
                    Bootloader/flasher
                    3
                    2
                Revision number
                    1
                    ISO15765-2
                    In2Soft GmbH
                    2
                    0
                Revision number
                    1
                    CAN - driver
                    2
                    18
                Revision number
                    2
                    High Speed - Network management
                    Vector Informatik GmbH
                    2
                    0
                Revision number
                    0
                    1
                    24
                Revision number
                    0
                    Unknown
                    In2Soft GmbH
                    1
                    0
                Revision number
                    1
                Programmability
                    programmable
                Program consistency
                    Program present
            Consistency of EEPROM-data
                Error during last data record download
                    no error
                Data consistency
                    valid EEPROM data
                Data record modification
                    Data record not changed
                Parameterizability
                    Parameterizable
                    0F
                    9796
        Mileage: 372624 km
        Date: 2021-08-01 19:31:59
    Backup
        52 Passenger Door
        System description: TSG BFS
        Software number: 5Q4959592E
        Hardware number: 5Q4959592B
        Serial number: 0000201904108
        Backup name: Passenger Door
        Long coding
            001D0320DE00040000001100
        Adaptations
            Production mode
                Production mode
                    0
            Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1
                Parameter
                    000014832B14F0F0F0002000FC7C00140005066401F4320F0007800000073F8000B4000C000C00270050008900D10129017B04040301030703E80BB832050F2D507304049A3C091A36630083E0E7044E5370CA0003000C000F016E5A01908507D010100014001403842710536D030010800C01FF9FFF0000000A01000000CECA
            Window_Regulator_Supplier_Settings_Passenger_Side_Rear_2
                Parameter
            Patch_Code_Passenger_Side_Rear
                Parameter
            Window_Regulator_VW_Settings_Passenger_Side_Rear
                Param to DOP 22811
                    F600F00010190F03F0080014C800000001A401C2096423C81E003232019000000000000000AF0000323CC8004E004D7900003260D36DCF641E320A0A5BD96DCF641432323214000037343031010000000000000000004191
                    0
            Reversing_Threshold_Passenger_Side_Front
                    90 %
            Reversing_Threshold_Passenger_Side_Rear
                    90 %
        Advanced identification
                Bootloader
                    1
                Application
                    0
                Data record
                    1
                Data record
                    1
                Data record
                    1
                Bootloader
                    1
                Application
                    1000
                Data record
                    1000
            Identification of bus master/sub bus master
                ECU ID
                    52
                ECU Name
                LOGICAL-LINK SHORT-NAME
                ID number
                    52
                subsystem name
                    4B
            Workshop code and date of last update programming of SW module
                Year
                    0
                Month
                    1
                Day
                    1
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    1
                Day
                    1
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    16
                Month
                    6
                Day
                    7
                Device number
                    31
                Importer number
                    770
                Dealership number
                    33281
                Programming status
                    Correct result
            Date of last coding
                Year
                    21
                Month
                    5
                Day
                    30
            FAZIT-identification
                Manufacture location index
                    CU5-DCM
                Day of manufacture
                    25.05.16
                Manufacturer- test stand number
                    0210
                Running manufacturer number
                    3220
            Identification of parameterization
                Version number
                    SK
                Version number
                    48
                Version number
                    11
                Version number
                    60
                Version number
                    42
                Version number
                    9D
                Version number
                    02
            Diagnostic mode
                    VW - diagnostic mode
            VW/Audi part number
                    5Q4959592E
            SoftwareVersion
                    0031
            Serial number
                    0000201904108
                    5Q4959592B
            System description
                    TSG BFS
            Adaptation workshop code
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
            Date of last adaptation
                Year
                    21
                Month
                    4
                Day
                    8
            ASAM/ODX file identification
                    EV DCUPasseSideEWMAXCONT
            Parameter set part number
                    V03935241UT
            Parameter set version
                    0001
            ASAM/ODX file version
                    006001
            HardwareVersion
                    010
            Vehicle equipment code
                    000000000000000000000D8B
            Coding workshop code
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
            Parameterization workshop code
                Device number
                    31
                Importer number
                    770
                Dealership number
                    33281
            Parameterization date
                Year
                    16
                Month
                    6
                Day
                    7
            System abbreviation
                    J387
            Versions of software module
                Bootloader
                    0204
                Application
                    0031
                Data record
                    0001
            Number of possible access authorizations
                    2
                    Unknown
                    IAV GmbH
                    2
                    2
                Revision number
                    2
                    In2Soft GmbH
                    2
                    1
                Revision number
                    2
                    Unknown
                    In2Soft GmbH
                    2
                    0
                Revision number
                    5
                    Unknown
                    In2Soft GmbH
                    2
                    0
                Revision number
                    2
                    CAN - driver
                    1
                    26
                Revision number
                    2
                    2
                    0
                Revision number
                    2
            Programmability status
                Programmability
                    programmable
                Program consistency
                    Program present
                    no error
                Data consistency
                    valid EEPROM data
                    Data record changed
                Parameterizability
                    Parameterizable
        Mileage: 372624 km
    Backup
        55 Headlight Regulation
        System description: AFS-ECU
        Software number: 7P6907357D
        Software version: 0090
        Hardware number: 7P6907357A
        Serial number: --------------
        Backup name: Headlight Regulation
        Long coding
            06DA00003F010000
        Adaptations
            Reference_Run_Start_Condition
                    Engine start
            PWM to Level Scaling Factor Front
                    3.47 mm/%
            PWM to Level Scaling Factor Rear
                    4.32 mm/%
            Presentation run dynamic AFS light
                    active
            Presentation mode
                    not active
            Adaptive light functions
                    active
            Activate left/right hand drive switch-over
                    not active
            Diagnostic mode
                    EV HeadlRegulVWAFSMQB
                    001120
                    Unknown
                    1
                    2
                Revision number
                    14
                    Unknown
                    IAV GmbH
                    1
                    2
                Revision number
                    5
                    Unknown
                    1
                    26
                Revision number
                    1
                    Unknown
                    1
                    2
                Revision number
                    15
                    1
                    1
                Revision number
                    0
                    no error
                Data consistency
                    valid EEPROM data
                Parameterizability
                    Parameterizable
                Decoration variant
                Manufacture version
                    0008
                Programmability
                    programmable
                Program consistency
                    Program present
            Serial number
                    2288
            Engine code
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                    1
            Identification of connected components
                ID number
                    55
                subsystem name
                Bus message/node address
                    54
                    00000000000000000000005C
                Version number
                    02
            SoftwareVersion
                    0090
                Year
                    21
                Month
                    7
                Day
                    11
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
            Date of last coding
                Year
                    21
                Month
                    7
                Day
                    28
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
            Number of parameterization attempts
                Data record
                    1
            Number of successful parameterization attempts
                Data record
                    1
                    V03935240PZ
                Year
                    16
                Month
                    6
                Day
                    7
                Device number
                    31
                Importer number
                    770
                Dealership number
                    73216
                    0001
                    7P6907357A
            HardwareVersion
                    H07
                    SME-RBG
                Day of manufacture
                    23.05.16
                    0008
                    2288
            Number of programming attempts
                Bootloader
                    0
                Application
                    0
            Maximum number of possible update programming
                Bootloader
                    0
                Application
                    0
                Bootloader
                    0112
                Application
                    0090
            VW/Audi part number
                    7P6907357D
            Manufacturer code
                    SME
            System description
                    AFS-ECU
            System abbreviation
                    J745
            Known subsystems
                Subsystem designation
                    Left Headlamp Power Output Stage
                Subsystem number
                    14
                    Right Headlamp Power Output Stage
                Subsystem number
                    15
        Mileage: 372624 km
    Backup
        5F Multimedia
        System description: MU-S-N-ER
        Software number: 5Q0035864B
        Software version: 0367
        Hardware number: 5Q0035864B
        Hardware version: H30
        Serial number: SKZAZ2S5070757
        Backup name: Multimedia
        Long coding
            03840101FF0000005111000100080A232F0100C401200100CE
        Adaptations
            Developer mode
                    Not activated
            Confirmation of installation change
                Key
                    B50C
            Check tone frequency
                High note frequency range
                    4000 Hz
                Medium note frequency range
                    1000 Hz
                Low note frequency range
                    100 Hz
            Electrical test of loudspeakers
                Mode
                    automatic
                Parameter AC-Diagnostics Channel 1 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 1 Test Volume
                    36
                Parameter AC-Diagnostics Channel 2 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 2 Test Volume
                    36
                Parameter AC-Diagnostics Channel 3 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 3 Test Volume
                    36
                Parameter AC-Diagnostics Channel 4 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 4 Test Volume
                    36
                Parameter AC-Diagnostics Channel 5 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 5 Test Volume
                    36
                Parameter AC-Diagnostics Channel 6 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 6 Test Volume
                    36
                Parameter AC-Diagnostics Channel 7 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 7 Test Volume
                    36
                Parameter AC-Diagnostics Channel 8 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 8 Test Volume
                    36
                Parameter AC-Diagnostics Channel 9 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 9 Test Volume
                    36
                Parameter AC-Diagnostics Channel 10 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 10 Test Volume
                    36
                Parameter AC-Diagnostics Channel 11 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 11 Test Volume
                    36
                Parameter AC-Diagnostics Channel 12 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 12 Test Volume
                    36
                Parameter AC-Diagnostics Channel 13 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 13 Test Volume
                    36
                Parameter AC-Diagnostics Channel 14 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 14 Test Volume
                    36
                Parameter AC-Diagnostics Channel 15 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 15 Test Volume
                    36
                Parameter AC-Diagnostics Channel 16 Test Frequency
                    19000 Hz
                Parameter AC-Diagnostics Channel 16 Test Volume
                    36
            Production mode
                    000000
            Number 1 for Info call
            Number 1 for roadside assistance
            Number 2 for roadside assistance
            Number 2 for Info call
            Base volume of speech output
                    50 %
            Base volume of telephone
                    50 %
            Microphone sensitivity
                    0 dB(A)
            Wheel pulse
                    0
            Wheel circ.
                    0 mm
            Bluetooth
                    On
            Bluetooth: Sniff mode
                    Off
            Automatic ring break diagnostic
                    No automatic start
            Sporadic ring break detection
                    Visual
            Awakening ability on optical databus
                    Off
            Selection of release codes for a SWaP function
                    FFFFFFFF
            Fee-based traffic information (TMC)
                    1023
            Infotainment recorder
                    activated
            Dimming_Ambient_Illumination_Information_Control_Unit
                X1
                    0
                Y1
                    0
                X2
                    50
                Y2
                    50
                X3
                    100
                Y3
                    100
            Dimming_Ambient_Illumination_Operating_and_Display_Unit
                X1
                    0
                Y1
                    0
                X2
                    50
                Y2
                    50
                X3
                    100
                Y3
                    100
            Dimming_Illumination_for_Display_Unit
                X1
                    0
                Y1
                    1 %
                X2
                    10
                Y2
                    1 %
                X3
                    100
                Y3
                    10 %
                X4
                    150
                Y4
                    20 %
                X5
                    220
                Y5
                    60 %
                X6
                    253
                Y6
                    100 %
            p_HMI_Display
                p HMI Display
                    13 %
            p_damping_Display
                p damping Display
                    5 ms
                Release
                    not released
            Startup_Screen_Sticker_HMI
                Startup Screen Sticker HMI
                    0
            Vehicle_configuration
                VZAPro
                    Off
                online POI
                    Off
                online POI voice
                    Off
                online portal browser services
                    Off
                online navigation
                    Off
                online street view
                    Off
                WIFI Hotspot
                    On
                my audi
                    Off
                picture navi
                    On
                online dictation
                    Off
                remote HMI
                    Off
                advanced range display
                    Off
                gracenote online coverarts
                    Off
                gracenote online other
                    Off
                gracenote local coverarts
                    On
                gracenote local other
                    On
                UPnP
                    On
                OPS display in dash board display unit
                    Off
                Joker button 1
                    Not present
                Joker button 2
                    Not present
                LTE modul
                    activated
                Support second phone
                    On
                Support of threeway calling
                    Off
                Dtmf without active call
                    Off
                Support for response and hold
                    Off
                Sim card mode switch
                    Not present
                Phone module operation mode
                    Data & language service active
                PSD Protocol Version
                    PSD 1.5
                RVC video input
                    FBAS
                Station Logo DB Mode
                    1
                TPEG availability
                    Off
                VZO
                    Off
                LGI
                    Off
                ProbeCar vzo
                    Off
                online media
                    Off
                ProbeCar lgi
                    Off
                Baidu Car Life
                    Off
                Google GAL
                    On
                Apple DIO
                    On
                SDS Region Flag
                    no region
                Privacy WithPINRequest
                    0
                Phone HMI Privacy
                    0
                Hybrid Radio additional online data
                    Not activated
                media control
                    Not activated
                UOTA
                    Off
                WiFi Client HMI
                    Off
                RSE software component
                    activated
                Mirror link
                    On
                Smartphone interface for rhmi
                    activated
                sd slot deactivation
                    no restriction
                map sms support
                    Off
                map email support
                    Off
                map instant messaging support
                    Off
                sim data only sms support
                    Off
                esim data only sms support
                    Off
                allow message editing
                    Off
                vehicle readiness sound
                    Not activated
                MirrorLink Country Code
                    MIB EU
                vehicle leaving sound
                    Not activated
                MirrorLink RGB Preference
                    RGB565
                conditioning variant
                    0
                Map Style
                    0
                Hybrid Radio Range Extender
                    deactivated
                scon telephony
                    Not activated
                voice over lte
                    Not activated
                show volte hmi switch
                    Not activated
                online radio
                    deactivated
                wlan 5ghz switch
                    Not activated
                unblock functions while piloted driving
                    blocked
                block hmi function p epb
                    blocked
                Popup if GPS services in use
                    Not activated
                Baidu Car Life ios
                    Off
                Tencent myCar canceling share location
                    Off
                UOTA 2
                    Off
                Pilot Parking
                    Not activated
                perso v threshold
                    0
                perso v threshold hysteresis
                    0
                FoD
                    SWaP
                Baidu Car Life Wireless
                    Off
                Baidu Car Life ios Wireless
                    Off
                Google GAL Wireless
                    Off
                Apple DIO Wireless
                    Off
                rvc low black screen velocity threshold
                    Not activated
                rvc low failsafe
                    Not activated
                rvc low black screen trunk open
                    Not activated
                AliBox
                    Off
                internet over WLAN default setting
                    Off
                correction e mileage
                    0
            Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation
                Proximity Sensor Basic Adaptation
                    04015204521052405232006400C8002C01FA00C8001400140014001400FFFFFFFFFFFFFFFF010037
            Radio_Level_Quality_Offsets
                Set AM Quality Level Offset
                    0
                Set FM Quality Level Offset
                    0
            Bluetooth_Phonebook_Access_Profile
                    PBAP
            Summertime-automatic
                    Manual
            Car_Function_Adaptations_Gen2
                menu display ACC
                    Not activated
                menu display ACC operation clamp 15 off
                    Not activated
                menu display ACC over threshold high
                    activated
                menu display ACC standstill
                    Not activated
                menu display ACC after disclaimer
                    Not activated
                menu display ambient illumination
                    activated
                menu display ambient illumination clamp 15 off
                    Not activated
                menu display ambient illumination over threshold high
                    activated
                menu display ambient illumination standstill
                    Not activated
                menu display ambient illumination after disclaimer
                    Not activated
                menu display pdc
                    activated
                menu display pdc clamp 15 off
                    Not activated
                menu display pdc over threshold high
                    activated
                menu display pdc standstill
                    Not activated
                menu display pdc after disclaimer
                    Not activated
                menu display awv
                    activated
                menu display awv clamp 15 off
                    Not activated
                menu display awv over threshold high
                    activated
                menu display awv standstill
                    Not activated
                menu display awv after disclaimer
                    Not activated
                menu display Lane Departure Warning
                    Not activated
                menu display Lane Departure Warning clamp 15 off
                    Not activated
                menu display Lane Departure Warning over threshold high
                    activated
                menu display Lane Departure Warning standstill
                    Not activated
                menu display Lane Departure Warning after disclaimer
                    Not activated
                menu display lane assistant
                    Not activated
                menu display lane assistant clamp 15 off
                    Not activated
                menu display lane assistant over threshold high
                    activated
                menu display lane assistant standstill
                    Not activated
                menu display lane assistant after disclaimer
                    Not activated
                menu display exterior illumination
                    activated
                menu display exterior illumination clamp 15 off
                    Not activated
                menu display exterior illumination over threshold high
                    activated
                menu display exterior illumination standstill
                    Not activated
                menu display exterior illumination after disclaimer
                    Not activated
                menu display windows
                    activated
                menu display windows clamp 15 off
                    Not activated
                menu display windows over threshold high
                    activated
                menu display windows standstill
                    Not activated
                menu display windows after disclaimer
                    Not activated
                menu display clima configuration
                    activated
                menu display clima configuration clamp 15 off
                    Not activated
                menu display clima configuration over threshold high
                    activated
                menu display clima configuration standstill
                    Not activated
                menu display clima configuration after disclaimer
                    Not activated
                menu display auxiliary heating
                    Not activated
                menu display auxiliary heating clamp 15 off
                    Not activated
                menu display auxiliary heating over threshold high
                    activated
                menu display auxiliary heating standstill
                    Not activated
                menu display auxiliary heating after disclaimer
                    Not activated
                menu display board computer
                    activated
                menu display board computer clamp 15 off
                    Not activated
                menu display board computer over threshold high
                    activated
                menu display board computer standstill
                    Not activated
                menu display board computer after disclaimer
                    Not activated
                menu display rdk
                    activated
                menu display rdk clamp 15 off
                    Not activated
                menu display rdk over threshold high
                    activated
                menu display rdk standstill
                    Not activated
                menu display rdk after disclaimer
                    Not activated
                menu display wiper
                    activated
                menu display wiper clamp 15 off
                    Not activated
                menu display wiper over threshold high
                    activated
                menu display wiper standstill
                    Not activated
                menu display wiper after disclaimer
                    Not activated
                menu display sia
                    activated
                menu display sia clamp 15 off
                    Not activated
                menu display sia over threshold high
                    activated
                menu display sia standstill
                    Not activated
                menu display sia after disclaimer
                    Not activated
                menu display seat configuration
                    activated
                menu display seat configuration clamp 15 off
                    Not activated
                menu display seat configuration over threshold high
                    activated
                menu display seat configuration standstill
                    Not activated
                menu display seat configuration after disclaimer
                    Not activated
                menu display central locking
                    activated
                menu display central locking clamp 15 off
                    Not activated
                menu display central locking over threshold high
                    activated
                menu display central locking standstill
                    Not activated
                menu display central locking after disclaimer
                    Not activated
                menu display compass
                    Not activated
                menu display compass clamp 15 off
                    Not activated
                menu display compass over threshold high
                    activated
                menu display compass standstill
                    Not activated
                menu display compass after disclaimer
                    Not activated
                menu display charisma
                    Not activated
                menu display charisma clamp 15 off
                    Not activated
                menu display charisma over threshold high
                    activated
                menu display charisma standstill
                    Not activated
                menu display charisma after disclaimer
                    Not activated
                menu display oil level
                    Not activated
                menu display oil level clamp 15 off
                    Not activated
                menu display oil level over threshold high
                    activated
                menu display oil level standstill
                    Not activated
                menu display oil level after disclaimer
                    Not activated
                menu display vin
                    activated
                menu display vin clamp 15 off
                    Not activated
                menu display vin over threshold high
                    activated
                menu display vin standstill
                    Not activated
                menu display vin after disclaimer
                    Not activated
                menu display clock
                    activated
                menu display clock clamp 15 off
                    Not activated
                menu display clock over threshold high
                    activated
                menu display clock standstill
                    Not activated
                menu display clock after disclaimer
                    Not activated
                menu display air damper
                    Not activated
                menu display air damper clamp 15 off
                    Not activated
                menu display air damper over threshold high
                    activated
                menu display air damper standstill
                    Not activated
                menu display air damper after disclaimer
                    Not activated
                menu display headup display
                    Not activated
                menu display headup display clamp 15 off
                    Not activated
                menu display headup display over threshold high
                    activated
                menu display headup display standstill
                    Not activated
                menu display headup display after disclaimer
                    Not activated
                menu display central unit master
                    activated
                menu display central unit master clamp 15 off
                    Not activated
                menu display central unit master over threshold high
                    activated
                menu display central unit master standstill
                    Not activated
                menu display central unit master after disclaimer
                    Not activated
                menu display hybrid
                    Not activated
                menu display hybrid clamp 15 off
                    Not activated
                menu display hybrid over threshold high
                    activated
                menu display hybrid standstill
                    Not activated
                menu display hybrid after disclaimer
                    Not activated
                menu display ugdo
                    Not activated
                menu display ugdo clamp 15 off
                    Not activated
                menu display ugdo over threshold high
                    activated
                menu display ugdo standstill
                    Not activated
                menu display ugdo after disclaimer
                    Not activated
                menu display night vision
                    Not activated
                menu display night vision clamp 15 off
                    Not activated
                menu display night vision over threshold high
                    activated
                menu display night vision standstill
                    Not activated
                menu display night vision after disclaimer
                    Not activated
                menu display side view
                    Not activated
                menu display side view clamp 15 off
                    Not activated
                menu display side view over threshold high
                    activated
                menu display side view standstill
                    Not activated
                menu display side view after disclaimer
                    Not activated
                menu display reversible belt pre load
                    Not activated
                menu display reversible belt pre load clamp 15 off
                    Not activated
                menu display reversible belt pre load over threshold high
                    activated
                menu display reversible belt pre load standstill
                    Not activated
                menu display reversible belt pre load after disclaimer
                    Not activated
                menu display MFL jocker
                    Not activated
                menu display MFL jocker clamp 15 off
                    Not activated
                menu display MFL jocker over threshold high
                    activated
                menu display MFL jocker standstill
                    Not activated
                menu display MFL jocker after disclaimer
                    Not activated
                menu display road sign identification
                    Not activated
                menu display road sign identification clamp 15 off
                    Not activated
                menu display road sign identification over threshold high
                    activated
                menu display road sign identification standstill
                    Not activated
                menu display road sign identification after disclaimer
                    Not activated
                menu display attention identification
                    Not activated
                menu display attention identification clamp 15 off
                    Not activated
                menu display attention identification over threshold high
                    activated
                menu display attention identification standstill
                    Not activated
                menu display attention identification after disclaimer
                    Not activated
                menu display adaptive key
                    Not activated
                menu display adaptive key clamp 15 off
                    Not activated
                menu display adaptive key over threshold high
                    activated
                menu display adaptive key standstill
                    Not activated
                menu display adaptive key after disclaimer
                    Not activated
                menu display car mirror
                    activated
                menu display car mirror clamp 15 off
                    Not activated
                menu display car mirror over threshold high
                    activated
                menu display car mirror standstill
                    Not activated
                menu display car mirror after disclaimer
                    Not activated
                menu display driving school
                    Not activated
                menu display driving school clamp 15 off
                    Not activated
                menu display driving school over threshold high
                    activated
                menu display driving school standstill
                    Not activated
                menu display driving school after disclaimer
                    Not activated
                menu display weariness recognition
                    Not activated
                menu display weariness recognition clamp 15 off
                    Not activated
                menu display weariness recognition over threshold high
                    activated
                menu display weariness recognition standstill
                    Not activated
                menu display weariness recognition after disclaimer
                    Not activated
                menu display BCmE
                    activated
                menu display BCmE clamp 15 off
                    Not activated
                menu display BCmE over threshold high
                    activated
                menu display BCmE standstill
                    Not activated
                menu display BCmE after disclaimer
                    Not activated
                menu display user eco rating
                    activated
                menu display user eco rating clamp 15 off
                    Not activated
                menu display user eco rating over threshold high
                    activated
                menu display user eco rating standstill
                    Not activated
                menu display user eco rating after disclaimer
                    Not activated
                menu display Brake Function
                    activated
                menu display Brake Function clamp 15 off
                    Not activated
                menu display Brake Function over threshold high
                    activated
                menu display Brake Function standstill
                    Not activated
                menu display Brake Function after disclaimer
                    Not activated
                menu display Start Stop reasons
                    activated
                menu display Start Stop reasons clamp 15 off
                    Not activated
                menu display Start Stop reasons over threshold high
                    activated
                menu display Start Stop reasons standstill
                    Not activated
                menu display Start Stop reasons after disclaimer
                    Not activated
                menu display angle of slope
                    Not activated
                menu display angle of slope clamp 15 off
                    Not activated
                menu display angle of slope over threshold high
                    activated
                menu display angle of slope standstill
                    Not activated
                menu display angle of slope after disclaimer
                    Not activated
                menu display battery management
                    Not activated
                menu display battery management clamp 15 off
                    Not activated
                menu display battery management over threshold high
                    activated
                menu display battery management standstill
                    Not activated
                menu display battery management after disclaimer
                    Not activated
                menu display RearSeatEntertainment
                    Not activated
                menu display RearSeatEntertainment clamp 15 off
                    Not activated
                menu display RearSeatEntertainment over threshold high
                    activated
                menu display RearSeatEntertainment standstill
                    Not activated
                menu display RearSeatEntertainment after disclaimer
                    Not activated
                menu display special functions
                    Not activated
                menu display special functions clamp 15 off
                    Not activated
                menu display special functions over threshold high
                    activated
                menu display special functions standstill
                    Not activated
                menu display special functions after disclaimer
                    Not activated
                menu display trailer assistant
                    Not activated
                menu display trailer assistant clamp 15 off
                    Not activated
                menu display trailer assistant over threshold high
                    activated
                menu display trailer assistant standstill
                    Not activated
                menu display trailer assistant after disclaimer
                    Not activated
                menu display TV Tuner
                    Not activated
                menu display TV Tuner clamp 15 off
                    Not activated
                menu display TV Tuner over threshold high
                    activated
                menu display TV Tuner standstill
                    Not activated
                menu display TV Tuner after disclaimer
                    Not activated
                menu auxiliary climatization
                    Not activated
                menu auxiliary climatization clamp 15 off
                    Not activated
                menu auxiliary climatization over threshold high
                    activated
                menu auxiliary climatization standstill
                    Not activated
                menu auxiliary climatization after disclaimer
                    Not activated
                menu display Pedestrian Assist
                    Not activated
                menu display Pedestrian Assist clamp 15 off
                    Not activated
                menu display Pedestrian Assist over threshold high
                    Not activated
                menu display Pedestrian Assist standstill
                    Not activated
                menu display Pedestrian Assist after disclaimer
                    Not activated
                menu display Seat Pneumatic
                    Not activated
                menu display Seat Pneumatic clamp 15 off
                    Not activated
                menu display Seat Pneumatic over threshold high
                    activated
                menu display Seat Pneumatic standstill
                    Not activated
                menu display Seat Pneumatic after disclaimer
                    Not activated
                menu display Curve Assist
                    Not activated
                menu display Curve Assist clamp 15 off
                    Not activated
                menu display Curve Assist over threshold high
                    activated
                menu display Curve Assist standstill
                    Not activated
                menu display Curve Assist after disclaimer
                    Not activated
                menu display eCall
                    Not activated
                menu display eCall clamp 15 off
                    Not activated
                menu display eCall over threshold high
                    Not activated
                menu display eCall standstill
                    Not activated
                menu display eCall after disclaimer
                    Not activated
                menu display ENI
                    Not activated
                menu display ENI clamp 15 off
                    Not activated
                menu display ENI over threshold high
                    Not activated
                menu display ENI standstill
                    Not activated
                menu display ENI after disclaimer
                    Not activated
                menu display SportHMI
                    Not activated
                menu display SportHMI clamp 15 off
                    Not activated
                menu display SportHMI over threshold high
                    Not activated
                menu display SportHMI standstill
                    Not activated
                menu display SportHMI after disclaimer
                    Not activated
                menu display Adblue
                    Not activated
                menu display Adblue clamp 15 off
                    Not activated
                menu display Adblue over threshold high
                    Not activated
                menu display Adblue standstill
                    Not activated
                menu display Adblue after disclaimer
                    Not activated
                menu display Spoiler
                    Not activated
                menu display Spoiler clamp 15 off
                    Not activated
                menu display Spoiler over threshold high
                    Not activated
                menu display Spoiler standstill
                    Not activated
                menu display Spoiler after disclaimer
                    Not activated
                menu display Efficiency Assist
                    Not activated
                menu display Efficiency Assist clamp 15 off
                    Not activated
                menu display Efficiency Assist over threshold high
                    Not activated
                menu display Efficiency Assist standstill
                    Not activated
                menu display Efficiency Assist after disclaimer
                    Not activated
                menu display Display Configuration
                    Not activated
                menu display Display Configuration clamp 15 off
                    Not activated
                menu display Display Configuration over threshold high
                    Not activated
                menu display Display Configuration standstill
                    Not activated
                menu display Display Configuration after disclaimer
                    Not activated
                menu soundcontrol
                    Not activated
                menu soundcontrol clamp 15 off
                    Not activated
                menu soundcontrol over threshold high
                    Not activated
                menu soundcontrol standstill
                    Not activated
                menu soundcontrol after disclaimer
                    Not activated
                menu auxiliary ventilation
                    Not activated
                menu auxiliary ventilation clamp 15 off
                    Not activated
                menu auxiliary ventilation over threshold high
                    Not activated
                menu auxiliary ventilation standstill
                    Not activated
                menu auxiliary ventilation after disclaimer
                    Not activated
                menu crossroad assistent
                    Not activated
                menu crossroad assistent clamp 15 off
                    Not activated
                menu crossroad assistent over threshold high
                    Not activated
                menu crossroad assistent standstill
                    Not activated
                menu crossroad assistent after disclaimer
                    Not activated
            Car_Function_List_CAN_Gen2
                MFL
                    available
                MFL msg bus
                    Databus Infotainment
                reserved
                    Not available
                reserved 1
                    Comfort data bus
                Oil level
                    Not available
                Oil level msg bus
                    Databus drivetrain
                PDC audio lowering
                    available
                PDC audio lowering msg bus
                    Terminal 15
                VIN
                    available
                VIN msg bus
                    Comfort data bus
                Driving school
                    Not available
                Driving school msg bus
                    Not available
                Adaptive key msg bus
                    Comfort data bus
                Adaptive key
                    Not available
                reserved 2
                    Comfort data bus
                reserved 3
                    Not available
            Car_Function_List_BAP_Gen2
                climatic master 0x01
                    activated
                climatic master 0x01 msg bus
                    Comfort data bus
                climatic slave 0x02
                    activated
                climatic slave 0x02 msg bus
                    Comfort data bus
                auxilary heating 0x03
                    Not activated
                auxilary heating 0x03 msg bus
                    Comfort data bus
                headup displ 0x04
                    Not activated
                headup displ 0x04 msg bus
                    Comfort data bus
                ACC 0x05
                    Not activated
                ACC 0x05 msg bus
                    Databus extended
                air suspension 0x06
                    Not activated
                air suspension 0x06 msg bus
                    Suspension data bus
                tire pressure system 0x07
                    activated
                tire pressure system 0x07 msg bus
                    Suspension data bus
                interieur light 0x08
                    activated
                interieur light 0x08 msg bus
                    Comfort data bus
                exterieur light 0x09
                    activated
                exterieur light 0x09 msg bus
                    Comfort data bus
                parking assist 0x0A
                    activated
                parking assist 0x0A msg bus
                    Terminal 15
                VPS 0x0B
                    Not activated
                VPS 0x0B msg bus
                wiper comfort 0x0C
                    activated
                wiper comfort 0x0C msg bus
                    Comfort data bus
                central locking 0x0D
                    activated
                central locking 0x0D msg bus
                    Comfort data bus
                mirror 0x0E
                    activated
                mirror 0x0E msg bus
                    Comfort data bus
                MFA 0x0F
                    activated
                MFA 0x0F msg bus
                    Comfort data bus
                driver seat 0x10
                    activated
                driver seat 0x10 msg bus
                    Comfort data bus
                clock 0x11
                    activated
                clock 0x11 msg bus
                    Comfort data bus
                service interval display 0x12
                    activated
                service interval display 0x12 msg bus
                    Comfort data bus
                unit master 0x13
                    activated
                unit master 0x13 msg bus
                    Comfort data bus
                UGDO 0x14
                    Not activated
                UGDO 0x14 msg bus
                    Terminal 15
                compass 0x15
                    Not activated
                compass 0x15 msg bus
                clima slave 2 0x16
                    Not activated
                clima slave 2 0x16 msg bus
                    Comfort data bus
                charisma 0x17
                    Not activated
                charisma 0x17 msg bus
                Night Vision 0x18
                    Not activated
                Night Vision 0x18 msg bus
                    CAB 9
                LDW HCA 0x19
                    Not activated
                LDW HCA 0x19 msg bus
                    Databus extended
                SWA 0x1A
                    Not activated
                SWA 0x1A msg bus
                    Databus extended
                AWV 0x1B
                    activated
                AWV 0x1B msg bus
                    Terminal 15
                Hybrid 0x1D
                    Not activated
                Hybrid 0x1D msg bus
                    Databus drivetrain
                SideView 0x1E
                    Not activated
                SideView 0x1E msg bus
                    CAB 9
                Reversible Seat Belt Tightener 0x1F
                    Not activated
                Reversible Seat Belt Tightener 0x1F msg bus
                    Databus drivetrain
                Passanger Seat 0x20
                    Not activated
                Passanger Seat 0x20 msg bus
                    Comfort data bus
                traffic sign recognition 0x21
                    Not activated
                traffic sign recognition 0x21 msg bus
                    Databus extended
                weariness rcognition 0x22
                    Not activated
                weariness rcognition 0x22 msg bus
                BCmE 0x23
                    activated
                BCmE 0x23 msg bus
                Brake 0x26
                    activated
                Brake 0x26 msg bus
                    Suspension data bus
                Start Stop reasons 0x27
                    activated
                Start Stop reasons 0x27 msg bus
                Amplifier 0x2D
                    Not activated
                Amplifier 0x2D msg bus
                    CAB 9
                TV tuner 0x2C
                    Not activated
                TV tuner 0x2C msg bus
                    Comfort data bus
                RearSeatEntertainment 0x2E
                    Not activated
                RearSeatEntertainment 0x2E msg bus
                    Comfort data bus
                MFL Jocker 0x34
                    Not activated
                MFL Jocker msg bus 0x34
                    CAB 9
                Special Functions 0x35
                    Not activated
                Special Functions msg bus 0x35
                Trailer Assistant 0x36
                    Not activated
                Trailer Assistant msg bus 0x36
                    Terminal 15
                ExBoxM2 0x38
                    Not activated
                Range Data 0x39
                    Not activated
                Range Data msg bus 0x39
                Angle Of Slope 0x24
                    Not activated
                Angle Of Slope 0x24 msg bus
                    Comfort data bus
                Battery Management 0x25
                    Not activated
                Battery Management 0x25 msg bus
                    Comfort data bus
                eCall 0x33
                    Not activated
                eCall 0x33 msg bus
                    Comfort data bus
                ENI 0x37
                    Not activated
                ENI 0x37 msg bus
                    Comfort data bus
                Pedestrian Assist 0x3A
                    Not activated
                Pedestrian Assist msg bus 0x3A
                    Databus extended
                Seat Pneumatic 0x3B
                    Not activated
                Seat Pneumatic msg bus 0x3B
                    Comfort data bus
                efficiency assist 0x3C
                    Not activated
                efficiency assis msg bus 0x3C
                    Databus extended
                Seatmemory driver rear 0x3E
                    Not activated
                Seatmemory driver rear msg bus 0x3E
                    Comfort data bus
                Seatmemory codriver rear 0x3F
                    Not activated
                Seatmemory codriver rear msg bus 0x3F
                    Comfort data bus
                ExBoxM2 0x38 msg bus
                    Comfort data bus
            Navigation receiver GNSS configuration
                Default
                    On
                GPS
                    Off
                Galileo
                    Off
                Glonass
                    Off
                Compass
                    Off
                external gps 1
                    Off
                external gps 2
                    Off
                    0000000000000000000000000000000000000000000000
            Number 1 (roaming) for roadside assistance
            WLAN
                    On
                Infotainment CAN Messages
                    Off
                MIB CAN Messages
                    Off
            Menu entries for mobile online services
                    Not activated
            Interface for external media, activation
                Connection 1
                    activated
                Connection 2
                    activated
                Connection 3
                    Not activated
                Connection 4
                    Not activated
            Audio Management Input Gain Generation 2
                TV tuner
                    -128
                Radio (FM)
                    -128
                Radio (AM)
                    -128
                Digital radio (DAB)
                    -128
                Satellite radio
                    -128
                Tuner TI
                    -128
                Media AUXIN
                    -128
                Media AUX Adapter
                    -128
                Media CDA
                    -128
                Media DVD
                    -128
                Media MFP
                    -128
                Media BTDevice
                    -128
                TA Tuner FM
                    -128
                Media Bluray
                    -128
                Media HDMI
                    -128
                Tuner Online
                    -128
                Media Airplay
                    -128
                Media UPNP
                    -128
                Media Cloud
                    -128
                Tuner Personal
                    -128
                Tone Beep
                    -128
                Tone Warning
                    -128
                Tone Touchscreen
                    -128
                Tone Messaging
                    -128
                Exbox DMB
                    -128
                Mirrorlink
                    -128
                TTS Nav
                    -128
                TTS SDS
                    -128
                Phone Voice
                    -128
                Phone Ringer MFP
                    -128
                Phone Ringer OB
                    -128
                HFP
                    -128
                TV AV IN
                    -128
            Installation list, specified installations
                Instrument cluster control module
                    No
                Information electronics control module 2
                    No
                DVD changer
                    No
                TV tuner
                    No
                Digital Sound System Control Module
                    No
                Radio
                    No
                Information electronics control module 1
                    Yes
                Smart Display Carrier 1
                    No
                Windshield projection head up display control module
                    No
                Multimedia Operating Unit
                    No
                Wireless Charger 2
                    No
                Wireless Charger 1
                    No
                Smart Control Carrier 2
                    No
                Smart Control Carrier 1
                    No
                Smart Display Carrier 2
                    No
                reserved 8
                    No
            Country identification, country of sale HMI
                    IS
            Locked menu contents
                FB TUNER 0
                    non blocked
                FB TUNER 1
                    non blocked
                FB TUNER 2
                    non blocked
                FB TUNER 3
                    non blocked
                FB TUNER 4
                    non blocked
                FB TUNER 5
                    non blocked
                FB TUNER 6
                    non blocked
                FB TUNER 7
                    non blocked
                FB TUNER 8
                    non blocked
                FB TUNER 9
                    non blocked
                FB TUNER 10
                    non blocked
                FB TUNER 11
                    non blocked
                FB TUNER 12
                    non blocked
                FB TUNER 13
                    non blocked
                FB TUNER 14
                    non blocked
                FB TUNER 15
                    non blocked
                FB MEDIA 0
                    non blocked
                FB MEDIA 1
                    non blocked
                FB MEDIA 2
                    non blocked
                FB MEDIA 3
                    non blocked
                FB MEDIA 4
                    non blocked
                FB MEDIA 5
                    non blocked
                FB MEDIA 6
                    non blocked
                FB MEDIA 7
                    non blocked
                FB MEDIA 8
                    non blocked
                FB MEDIA 9
                    non blocked
                FB MEDIA 10
                    non blocked
                FB MEDIA 11
                    non blocked
                FB MEDIA 12
                    non blocked
                FB MEDIA 13
                    non blocked
                FB MEDIA 14
                    non blocked
                FB MEDIA 15
                    non blocked
                FB MEDIA 16
                    non blocked
                FB MEDIA 17
                    non blocked
                FB MEDIA 18
                    non blocked
                FB MEDIA 19
                    non blocked
                FB MEDIA 20
                    non blocked
                FB MEDIA 21
                    non blocked
                FB MEDIA 22
                    non blocked
                FB MEDIA 23
                    non blocked
                FB PHONE 0
                    non blocked
                FB PHONE 1
                    non blocked
                FB PHONE 2
                    non blocked
                FB PHONE 3
                    non blocked
                FB PHONE 4
                    non blocked
                FB PHONE 5
                    non blocked
                FB PHONE 6
                    non blocked
                FB PHONE 7
                    non blocked
                FB PHONE 8
                    non blocked
                FB PHONE 9
                    non blocked
                FB PHONE 10
                    non blocked
                FB PHONE 11
                    non blocked
                FB PHONE 12
                    non blocked
                FB PHONE 13
                    non blocked
                FB PHONE 14
                    non blocked
                FB PHONE 15
                    non blocked
                FB NAV 0
                    non blocked
                FB NAV 1
                    non blocked
                FB NAV 2
                    non blocked
                FB NAV 3
                    non blocked
                FB NAV 4
                    non blocked
                FB NAV 5
                    non blocked
                FB NAV 6
                    non blocked
                FB NAV 7
                    non blocked
                FB NAV 8
                    non blocked
                FB NAV 9
                    non blocked
                FB NAV 10
                    non blocked
                FB NAV 11
                    non blocked
                FB NAV 12
                    non blocked
                FB NAV 13
                    non blocked
                FB NAV 14
                    non blocked
                FB NAV 15
                    non blocked
                FB NAV 16
                    non blocked
                FB NAV 17
                    non blocked
                FB NAV 18
                    non blocked
                FB NAV 19
                    non blocked
                FB NAV 20
                    non blocked
                FB NAV 21
                    non blocked
                FB NAV 22
                    non blocked
                FB NAV 23
                    non blocked
                FB NAV 24
                    non blocked
                FB NAV 25
                    non blocked
                FB NAV 26
                    non blocked
                FB NAV 27
                    non blocked
                FB NAV 28
                    non blocked
                FB NAV 29
                    non blocked
                FB NAV 30
                    non blocked
                FB NAV 31
                    non blocked
                FB NAV 32
                    non blocked
                FB NAV 33
                    non blocked
                FB NAV 34
                    non blocked
                FB NAV 35
                    non blocked
                FB NAV 36
                    non blocked
                FB NAV 37
                    non blocked
                FB NAV 38
                    non blocked
                FB NAV 39
                    non blocked
                FB CAR 0
                    non blocked
                FB CAR 1
                    non blocked
                FB CAR 2
                    non blocked
                FB CAR 3
                    non blocked
                FB CAR 4
                    non blocked
                FB CAR 5
                    non blocked
                FB CAR 6
                    non blocked
                FB CAR 7
                    non blocked
                FB CAR 8
                    non blocked
                FB CAR 9
                    non blocked
                FB CAR 10
                    non blocked
                FB CAR 11
                    non blocked
                FB CAR 12
                    non blocked
                FB CAR 13
                    non blocked
                FB CAR 14
                    non blocked
                FB CAR 15
                    non blocked
                FB CAR 16
                    non blocked
                FB CAR 17
                    non blocked
                FB CAR 18
                    non blocked
                FB CAR 19
                    non blocked
                FB CAR 20
                    non blocked
                FB CAR 21
                    non blocked
                FB CAR 22
                    non blocked
                FB CAR 23
                    non blocked
                FB MISC 0
                    non blocked
                FB MISC 1
                    non blocked
                FB MISC 2
                    non blocked
                FB MISC 3
                    non blocked
                FB MISC 4
                    non blocked
                FB MISC 5
                    non blocked
                FB MISC 6
                    non blocked
                FB MISC 7
                    non blocked
                FB MISC 8
                    non blocked
                FB MISC 9
                    non blocked
                FB MISC 10
                    non blocked
                FB MISC 11
                    non blocked
                FB MISC 12
                    non blocked
                FB MISC 13
                    non blocked
                FB MISC 14
                    non blocked
                FB MISC 15
                    non blocked
                FB MISC 16
                    non blocked
                FB MISC 17
                    non blocked
                FB MISC 18
                    non blocked
                FB MISC 19
                    non blocked
                FB MISC 20
                    non blocked
                FB MISC 21
                    non blocked
                FB MISC 22
                    non blocked
                FB MISC 23
                    non blocked
                FB MISC 24
                    non blocked
                FB MISC 25
                    non blocked
                FB MISC 26
                    non blocked
                FB MISC 27
                    non blocked
                FB MISC 28
                    non blocked
                FB MISC 29
                    non blocked
                FB MISC 30
                    non blocked
                FB MISC 31
                    non blocked
                FB MISC 32
                    non blocked
                FB MISC 33
                    non blocked
                FB MISC 34
                    non blocked
                FB MISC 35
                    non blocked
                FB MISC 36
                    non blocked
                FB MISC 37
                    non blocked
                FB MISC 38
                    non blocked
                FB MISC 39
                    non blocked
                FB MISC 40
                    non blocked
                FB MISC 41
                    non blocked
                FB MISC 42
                    non blocked
                FB MISC 43
                    non blocked
                FB MISC 44
                    non blocked
                FB MISC 45
                    non blocked
                FB MISC 46
                    non blocked
                FB MISC 47
                    non blocked
            Dashboard_Display_Configuration
                navigation map transmission mode
                    off
                navigation map compression mode
                    RLE
                navigation map resolution
                    resolution 1
                crossroad detail map transmission mode
                    off
                crossroad detail map compression mode
                    RLE
                coverart
                    Off
                stationart
                    Off
                call picture
                    Off
                crossroad detail map resolution
                    resolution 1
                fastlist most
                    Off
                ability switch nav maps
                    Off
                dynamic icon
                    0
            Roller test bench mode, functional
                    Not activated
            Diagnostic mode
                    EV MUStd4CTSAT
                    001022
                    ISO15765-2
                    In2Soft GmbH
                    2
                    0
                Revision number
                    2
                    Unknown
                    In2Soft GmbH
                    1
                    0
                Revision number
                    1
                    UDS - protocol
                    In2Soft GmbH
                    2
                    1
                Revision number
                    7
                    Component protection on ISO TP
                    Elektrobit Automotive GmbH (3SOFT GmbH)
                    6
                    2
                Revision number
                    4
                    BAP
                    ICT Software Engineering GmbH
                    1
                    7
                Revision number
                    1
                    MOST net services
                    0
                    0
                Revision number
                    0
                    INIC config string version
                    0
                    0
                Revision number
                    0
                    MOST firmware
                    0
                    0
                Revision number
                    0
                    2
                    0
                Revision number
                    0
                ECU ID
                    5F
                ECU Name
                    Information Control Unit 1
                    Error
                Data consistency
                    valid EEPROM data
                Parameterizability
                    Parameterizable
            Date of manufacture
                Year
                    16
                Month
                    5
                Day
                    23
            Manufacturer's test stand number
                    0310
                Programmability
                    programmable
                Program consistency
                    Program present
            Serial number
                    SKZAZ2S5070757
            Subassembly and series number
                    0007
            Flash data security
                Hash value
                    available
                Key enable mechanism
                    available
                Key
                    Yes
                Key type
                    Series
                Project ID
                    00000536
                Hash value
                    D9DED95CE1C2F03EF23BBB39E866E0E66E43E753
                Year
                    0
                Month
                    1
                Day
                    1
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    21
                Month
                    7
                Day
                    22
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
                Programming status
                    Correct result
                Year
                    0
                    Not available
                    Not available
                    Not available
                    Not available
                    1
                ID number
                    5F
                subsystem name
                    73
            Vehicle Identification Number (VIN)
                    TMBAH7NP2H7009796
                    50
                DTCP dataset
                ASAM ODX MUX dataset
                hmi control speed dataset
                    05
                language dataset
                    13
                visible MMI language dataset
                    15
                powermanagment timer dataset
                    20
                audio parameter sound dataset
                    23
                DAB frequency dataset
                audio parameter sound announcement dataset
                    M3
                audio managment mute hmi constant
                    11
                audio parameter telephone
                    MO
                audio parameter SDS
                audio parameter individual sound processing
                eco HMI dataset
                    00
                audio parameter sound cabrio dataset
                audio parameter sound configuration dataset
                    41
                speech signal enhancement dataset
                in car communication
                air quality
                reserved 20
                reserved 21
                reserved 22
                reserved 23
                reserved 24
                reserved 25
                reserved 26
                reserved 27
                reserved 28
                reserved 29
                reserved 30
                reserved 31
                reserved 32
                reserved 33
                reserved 34
                reserved 35
                reserved 36
                reserved 37
                reserved 38
                reserved 39
                reserved 40
                reserved 41
                reserved 42
                reserved 43
                reserved 44
                reserved 45
                reserved 46
                reserved 47
                reserved 48
                reserved 49
                reserved 50
            SoftwareVersion
                    0367
                Year
                    21
                Month
                    7
                Day
                    29
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
            Date of last coding
                Year
                    21
                Month
                    7
                Day
                    29
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
                DTCP dataset
                    65535
                    0
                    11
                language dataset
                    2
                    2
                    2
                    2
                    65535
                    2
                    2
                    2
                audio parameter SDS
                    65535
                    0
                eco HMI dataset
                    2
                    0
                    2
                    65535
                    0
                reserved 19
                    65535
                reserved 20
                    65535
                reserved 21
                    65535
                reserved 22
                    65535
                reserved 23
                    65535
                reserved 24
                    65535
                reserved 25
                    65535
                reserved 26
                    65535
                reserved 27
                    65535
                reserved 28
                    65535
                reserved 29
                    65535
                reserved 30
                    65535
                reserved 31
                    65535
                reserved 32
                    65535
                reserved 33
                    65535
                reserved 34
                    65535
                reserved 35
                    65535
                reserved 36
                    65535
                reserved 37
                    65535
                reserved 38
                    65535
                reserved 39
                    65535
                reserved 40
                    65535
                reserved 41
                    65535
                reserved 42
                    65535
                reserved 43
                    65535
                reserved 44
                    65535
                reserved 45
                    65535
                reserved 46
                    65535
                reserved 47
                    65535
                reserved 48
                    65535
                reserved 49
                    65535
                reserved 50
                    65535
                DTCP dataset
                    65535
                    0
                    3
                language dataset
                    2
                    2
                    2
                    2
                    65535
                    2
                    2
                    2
                audio parameter SDS
                    65535
                    0
                eco HMI dataset
                    2
                    0
                    2
                    65535
                    0
                reserved 19
                    65535
                reserved 20
                    65535
                reserved 21
                    65535
                reserved 22
                    65535
                reserved 23
                    65535
                reserved 24
                    65535
                reserved 25
                    65535
                reserved 26
                    65535
                reserved 27
                    65535
                reserved 28
                    65535
                reserved 29
                    65535
                reserved 30
                    65535
                reserved 31
                    65535
                reserved 32
                    65535
                reserved 33
                    65535
                reserved 34
                    65535
                reserved 35
                    65535
                reserved 36
                    65535
                reserved 37
                    65535
                reserved 38
                    65535
                reserved 39
                    65535
                reserved 40
                    65535
                reserved 41
                    65535
                reserved 42
                    65535
                reserved 43
                    65535
                reserved 44
                    65535
                reserved 45
                    65535
                reserved 46
                    65535
                reserved 47
                    65535
                reserved 48
                    65535
                reserved 49
                    65535
                reserved 50
                    65535
                    V03935296MG
                Year
                    21
                Month
                    7
                Day
                    26
                Device number
                    31
                Importer number
                    770
                Dealership number
                    73216
                    0001
            Hardware part number
                    5Q0035864B
            HardwareVersion
                    H30
                    YD7-002
                Day of manufacture
                    23.05.16
                    0310
                    0007
                Bootloader
                    0
                Application
                    1
                Data record
                    0
                Bootloader
                    0
                Application
                    0
                Data record
                    0
                Bootloader
                Application
                    0367
                Data record
            VW/Audi part number
                    5Q0035864B
            Manufacturer code
                    YD7
            System description
                    MU-S-N-ER
            System abbreviation
                    J794
            Known subsystems
                    Subsystem not coded
                Subsystem number
                    FFFF
                    Subsystem not coded
                Subsystem number
                    FFFF
                    Subsystem not coded
                Subsystem number
                    FFFF
                    Subsystem not coded
                Subsystem number
                    FFFF
                    Subsystem not coded
                Subsystem number
                    FFFF
                    Subsystem not coded
                Subsystem number
                    FFFF
                    Subsystem not coded
                Subsystem number
                    FFFF
                    Operating And Display Unit 1
                Subsystem number
                    E
                    Subsystem not coded
                Subsystem number
                    FFFF
                    Data Medium
                Subsystem number
                    11
                    Subsystem not coded
                Subsystem number
                    FFFF
            FAZIT identification test sum
                CRC32 parameter
                    10D75AB9
                Version dec
                    129
            Overall version of navigation database
                Card reader
                    5L0051236CD;1510;ECE AS 2021
                Card reader 2
                    nicht verfuegbar
                Optical drive
                    nicht verfuegbar
                internal accumulator
                    nicht verfuegbar
            Active source of navigation database
                    SD1
        Mileage: 372624 km
    Backup
        6D Deck Lid Control
        System description: HDSG-Modul
        Software number: 5Q0959107J
        Software version: 0253
        Hardware number: 5Q0959107J
        Hardware version: H13
        Serial number: 30712538900000
        Backup name: Deck Lid Control
        Long coding
            1008
        Adaptations
            Program opening stop
                    2014
            Offset for maximum programmable opening stop
                    20
            Minimum opening height of tailgate
                    600
            Offset for opening height after basic setting
                    0
            Detection area upper
                    10
            Opening height in production mode
                    60 %
                    not active
                    Deactivating
            Production mode
                Activation due to excessive pressure on rear lid
                    not active
                    not active
                Opening and closing rear lid
                    not active
                Tone sensor
                    not active
                Activation of rear lid with reduced speed
                    not active
                Calibration
                    not active
                Checking the rear lid button
                    not active
            Tailgate reverse path
                Reverse path when closing
                    7
                Reverse path when opening
                    4
            Deactivation of tailgate
                    active
            Dectivation of the luggage compartment cover
                    not active
            Deactivation of tailgate while in trailer operation
                Release button in rear lid handle
                    active
                Using button to close lock. mechanism in tailgate handle
                    active
                Button for opening rear lid in luggage compartment
                    active
                Rear lid lock button in luggage compartment
                    active
                Sensor for rear lid opening
                    active
                Remote ctrl, opening with button for tailgate unlock. mechan.
                    not active
                Remote ctrl, closing with button for tailgate unlock. mechan.
                    not active
                Opening with button for remote unlocking of tailgate
                    not active
                Closing with remote unl.button of tailgate when using a trailer
                    not active
                Using sensor to open tailgate
                    not active
                Using sensor to close tailgate
                    not active
                Opening with button 2 for remote unlocking of rear lid
                    not active
                Closing with remote unlock.butt.2 of rear lid when using trail.
                    not active
            Ausstattungen aktivieren
                Engine 2
                    active
                Motor 2, sensor system
                    active
                Tone sensor
                    active
                Clamping strip 1
                    not active
                Clamping strip 2
                    not active
                Clamping strip 3
                    not active
                Clamping strip 4
                    not active
                Temperature sensor 1
                    active
                Temperature sensor 2
                    active
                Closing assist motor
                    active
            Luggage compartment cover, tolerance of the block counter
                    0
            Luggage compartment cover, maximum no. of block drives
                    0
            Luggage compartment cover, reverse path after obstacle recogn.
                Open
                    0
                Close
                    0
            Luggage compartment cover, detection area
                Detection area lower
                    0
                    0
            Luggage compartment cover, adjust. track tolerance
                    0
            Luggage compartment cover, number bloom drives
                    0
            Luggage compartment cover, excess limitation in exclusion area
                    not active
                Bootloader
                    0
                Application
                    1
                Bootloader
                    1
                Application
                    65535
            ISO TP block size in bootloader
                    F
                ID number
                    6D
                subsystem name
                    Deck Lid Control Unit
                    23
                Year
                    0
                Month
                    1
                Day
                    1
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
            Date of last coding
                Year
                    0
                Month
                    0
                Day
                    0
                    TF7-MNL
                Day of manufacture
                    12.05.16
                    5007
                    0011
            Identification of data sets
                Data set ID
                    720A
                Data set version:
                    0142
                data set used by application
                    Yes
                data set plausible
                    Yes
                data set valid
                    Yes
                Data set ID
                    720D
                Data set version:
                    0142
                    Yes
                data set plausible
                    Yes
                data set valid
                    Yes
                Data set ID
                    720E
                Data set version:
                    0142
                    Yes
                data set plausible
                    Yes
                data set valid
                    Yes
                Data set ID
                    7210
                Data set version:
                    0142
                    Yes
                data set plausible
                    Yes
                data set valid
                    Yes
                Data set ID
                    7211
                Data set version:
                    0142
                    Yes
                data set plausible
                    Yes
                data set valid
                    Yes
                Data set ID
                    7215
                Data set version:
                    0142
                    Yes
                data set plausible
                    Yes
                data set valid
                    Yes
                Data set ID
                    7216
                Data set version:
                    0142
                    Yes
                data set plausible
                    Yes
                data set valid
                    Yes
                Data set ID
                    7217
                Data set version:
                    0142
                    Yes
                data set plausible
                    Yes
                data set valid
                    Yes
                Data set ID
                    7218
                Data set version:
                    0142
                    Yes
                data set plausible
                    Yes
                data set valid
                    Yes
                Data set ID
                    7219
                Data set version:
                    0142
                    Yes
                data set plausible
                    Yes
                data set valid
                    Yes
                Data set ID
                    721A
                Data set version:
                    0142
                    Yes
                data set plausible
                    Yes
                data set valid
                    Yes
                Data set ID
                    721B
                Data set version:
                    0142
                    Yes
                data set plausible
                    Yes
                data set valid
                    Yes
                Data set ID
                    721D
                Data set version:
                    0142
                    Yes
                data set plausible
                    Yes
                data set valid
                    Yes
                Data set ID
                    721E
                Data set version:
                    0142
                    Yes
                data set plausible
                    Yes
                data set valid
                    Yes
                Data set ID
                    721F
                Data set version:
                    0142
                    Yes
                data set plausible
                    Yes
                data set valid
                    Yes
                Data set ID
                    7220
                Data set version:
                    0142
                    Yes
                data set plausible
                    Yes
                data set valid
                    Yes
                Data set ID
                    7221
                Data set version:
                    0142
                    Yes
                data set plausible
                    Yes
                data set valid
                    Yes
                Data set ID
                    7222
                Data set version:
                    0142
                    Yes
                data set plausible
                    Yes
                data set valid
                    Yes
                Data set ID
                    7223
                Data set version:
                    0142
                    Yes
                data set plausible
                    Yes
                data set valid
                    Yes
                Data set ID
                    7224
                Data set version:
                    0142
                    Yes
                data set plausible
                    Yes
                data set valid
                    Yes
            Diagnostic mode
            VW/Audi part number
                    5Q0959107J
            SoftwareVersion
                    0253
                    5Q0959107J
            System description
                    HDSG-Modul
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
                Year
                    21
                Month
                    6
                Day
                    30
                    EV DeckLidCONTIAU736
                    V03935238KK
                    0001
                    001012
            HardwareVersion
                    H13
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
                Device number
                    31
                Importer number
                    770
                Dealership number
                    33281
                Year
                    16
                Month
                    6
                Day
                    7
            System abbreviation
                    J605
                Bootloader
                    0192
                Application
                    0253
                    UDS - protocol
                    In2Soft GmbH
                    2
                    1
                Revision number
                    3
                    Status management processor
                    7
                    3
                Revision number
                    2
                    Management communication
                    4
                    21
                Revision number
                    3
                    Development error tracer
                    5
                    1
                Revision number
                    0
                    Standard diagnostic services for UDS
                    In2Soft GmbH
                    2
                    2
                Revision number
                    3
                    Generic network management
                    2
                    21
                Revision number
                    2
                    CAN network management
                    4
                    20
                Revision number
                    2
                    CAN transport layer
                    1
                    24
                Revision number
                    0
                    Protocol data unit router
                    3
                    19
                Revision number
                    2
                    Diagnosis communication manager (DCM)
                    2
                    2
                Revision number
                    4
                    Diagnosis event manager (DEM)
                    2
                    2
                Revision number
                    2
                    CAN interface
                    4
                    19
                Revision number
                    4
                    BSW Mode Manager
                    1
                    5
                Revision number
                    2
                    Management CAN status
                    1
                    18
                Revision number
                    4
                    CAN driver
                    3
                    4
                Revision number
                    0
                    AUTOSAR COM
                    3
                    24
                Revision number
                    2
                    XCP Transport layer on CAN
                    1
                    7
                Revision number
                    1
                    1
                    31
                Revision number
                    2
                    IAV GmbH
                    4
                    1
                Revision number
                    6
                Programmability
                    programmable
                Program consistency
                    Program present
        Mileage: 372624 km
    Backup
        76 Parking Assistant
        System description: PARKHILFE 8K
        Software number: 5Q0919294L
        Software version: 0056
        Hardware number: 5Q0919294A
        Hardware version: H03
        Serial number: 39331614906693
        Backup name: Parking Assistant
        Long coding
            0071051051
        Adaptations
            Speaker volume for rear park assist
                    Stage 5
            Speaker frequency for rear park assist
                    Stage 3
            Speaker volume for front park assist
                    Stage 3
            Speaker frequency for front park assist
                    Stage 6
            Audio reduction request
                    On
            Park assist activation tone
                    On
            Switch-off speed for parking assist
                    15 km/h
            Deactivation of start-stop function
                    Start-stop function in control module active
            Production mode
                    Deactivating
                    Deactivating
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
            Serial number
                    39331614906693
                    5Q0919294A
                Bootloader
                    0107
                Application
                    0056
                Data record
                    0056
                Application
                    0056
                Application
                    0056
                Year
                    21
                Month
                    7
                Day
                    1
                Bootloader
                    1
                Application
                    0
                Data record
                    0
                Application
                    0
                Application
                    0
                Programmability
                    programmable
                Program consistency
                    Program present
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    0
                Day
                    0
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                    ATW-001
                Day of manufacture
                    29.05.16
                    EC03
                    0154
            System description
                    PARKHILFE 8K
                    EV EPHVA18AU3700000
            HardwareVersion
                    H03
                    002026
            VW/Audi part number
                    5Q0919294L
                    BAP
                    1
                    6
                Revision number
                    0
                    UDS - protocol
                    In2Soft GmbH
                    2
                    0
                Revision number
                    2
                    CAN - driver
                    2
                    4
                Revision number
                    6
                    ISO15765-2
                    In2Soft GmbH
                    2
                    0
                Revision number
                    1
            System abbreviation
                    J446
            Date of last coding
                Year
                    21
                Month
                    4
                Day
                    8
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
            Diagnostic mode
            Manufacturer modification status
                Control module family
                Decoration variant
                Construction version
                Manufacture version
            SoftwareVersion
                    0056
                Bootloader
                    1
                Application
                    10000
                Data record
                    10000
                Application
                    10000
                Application
                    10000
                    no error
                Data consistency
                    valid EEPROM data
                Parameterizability
                    Parameterizable
                Data record
                    1
                Version number
                    C2
                    000000000000000000003A2B
                    3V0039t
                    0001
                Data record
                    1
            VW Application Data Set Structure
                Version number
                    27
        Mileage: 372624 km
        Date: 2021-08-01 19:32:00
    Backup
        B7 Start System Interface
        System description: VWKESSYMQB
        Software number: 3Q0959435E
        Software version: 0811
        Hardware number: 3Q0959435E
        Hardware version: 036
        Serial number: 0403751108
        Backup name: Start System Interface
        Long coding
            032C0C0723
        Adaptations
            Control module switch-off, switch-off time
                Control module
                    20 min
                Data bus
                    30 min
                    Deactivating
            Production mode
                Deactivation of automatic shutdowns of terminal 15
                    not active
                Deactivation of automatic rear lid opening
                    not active
                Deactivation of terminal 50 request
                    not active
            rpm_threshold_engine_runnning
                    100 1/min
            Number_of_ZAT_activations_to_DTC
                    10
            Number_of_Multiple_ZAT_activations_to_emergency_shutoff
                    2
            Display_duration_please_engage_P
                    10 s
            time_to_drive_cycle_detection
                    1.00 s
            Display_duration_emergency_off
                    3000 ms
            Display_duration_error_mode_2_SPN
                    10 s
            min_time_for_Terminal_50_request
                    200 ms
            Terminal_S_Timeout
                    30 min
            time_to_ignore_ignition_trigger
                    35 s
            delay_time_Terminal_15_S_Shut_down_by_BEM
                    120.00 s
            delay_time_Terminal_15_S_Shut_down_after_leaving_vehicle
                    300 ms
            time_ZAT_actuation_detection
                    3000 ms
            duration_ZAT_debounce
                    50 ms
            time_to_ZAT_Short_circuit_fault_detection
                    60 s
            duration_to_ZAT_continuous_actuation_detection
                    1000 ms
            duration_to_ZAT_multi_actuation_detection
                    3000 ms
            time_ZAT_lock_after emergency_shutoff
                    1000 ms
            time_ZAT_lock_after_normal_shutoff
                    500 ms
            time_to_ZAT_Open_circuit_detection
                    1000 ms
            Speed_threshold_for_moving_vehicle_detection
                    1.0 km/h
            Speed_threshold_for_driving_cycle_detection
                    3.0 km/h
            Speed_threshold_for_terminal_15_emergency_shutoff
                    7.0 km/h
            CAN_signal_transmitting_duration_of_automatic_Terminal_15_shutoff
                    1.00 s
            Ignition_For_Immobilizer
                    Default
            Terminal_15_adaption_body_control_module
                    Default
            Debounce_time_driver_presence
                    200 ms
            Debounce_time_detection
                    500 ms
            Timeframe_request_immobilizer_terminal_approval
                    10000 ms
            CAN_signal_transmitting_duration_of_comfort_switch_off
                    10.00 s
            CAN_signal_transmitting_delay_of_car_roll _away_warning
                    1.00 s
            Byte13_vit_lf
                vit exit
                    Not activated
                vit evaluate inversbit
                    Not activated
                toggle active
                    Not activated
                toggle at  open door
                    Not activated
                lock via toggle by closed vehicle skin
                    Not activated
            min_receptiontime_vit
                    0 ms
            Timeout_trigger_terminal_deactivation_central_locking
                    1.00 s
            Diagnostic: wait time after power on
                    500 ms
            CAN-timeout service-key message
                    260 ms
            LED dimming curve first point 20 percent dimming
                    4.0 %
            Delta value LED dimming curve first point 40 percent dimming
                    11.0 %
            Delta value LED dimming curve second point 60 percent dimming
                    23.0 %
            Delta value LED dimming curve third point 80 percent dimming
                    28.0 %
            Delta value LED dimming curve forth point 100 percent dimming
                    34.0 %
            Standard dimming value ZAT
                    80.0 %
            Correction value LED dimming
                    1.0
            ZAT post-carridge during clamp 15 off
                    10 min
            ZAT nominal voltage
                    13.0 V
            ZAT init value
                    0.0 %
            Stop release for start-stop function
                    According to function requirements
            Proximity Sensor: duration of proximity Signal
                    10 s
            Internal
                    0 B
            Passive Entry Exit: T_ACT_OP_2
                    5000 ms
            Passive Entry Exit: minimum activity time locking sensor
                    140 ms
            Passive Entry Exit: PARA_T_TIMOUT_PROXIMITY_ENTRY
                    210 ms
            Passive Entry Exit: control by pulling the door handle during active DSL_timeout
                    2.00 s
            Passive Entry Exit: entry request e-sliding door active time
                    500 ms
            Initialization_diagnostics_switching_terminal
                    Not activated
            Reduced current for transponder-ID request
                    0 Step
            MCTX settling phase
                    7 B
            MCTX pause
                    1 B
            MCTX pause for Go / Key Minder
                    20 ms
            MCTX pause for Go authentification
                    7 B
            Scan Procedure: Timeout Authentification Result
                    150 ms
            Scan Procedure: p_keyless_eventsuche_retries_pause
                    1000 ms
            Scan Procedure: Timeout LF Repetition
                    100 ms
            Scan Procedure: Number of Repeats
                    1
            Scan Procedure: cycle convenience coverage limiting
                    65 ms
            Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Go
                    190 ms
            Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Kombi
                    700 ms
            Scan Procedure: current limiting on undervoltage at Go-protocol
                    5 Step
            ScanProcedure: Timeout Entry Response
                    260 ms
            ScanProcedure: Timeout Response
                    100 ms
            timeout_convenience_coverage_limiting
                    75 s
            internal_passive_entry_exit_byte1
                lf crc
                    Not activated
                Impairment Entry / Exit key on low battery
                    Not activated
                Passive Exit: access door not open
                    activated
                Passive Exit: all doors not open
                    Not activated
                passive exit door slam lock
                    Not activated
            internal_passive_entry_exit_byte2
                Passive Entry Exit: control by pulling door handle during active DSL
                    activated
                Passive Entry Exit
                    activated
                Passive Entry: second control concept
                    Not activated
                Passive Entry Exit: retry with antennastep 1
                    Not activated
                Passive Entry bei Tuer verriegelt/gesafed ODER ZV ist gesafed
                    activated
                lf shutdown
                    Not activated
                lf shutdown gotrigger
                    Not activated
            internal_keyminder_byte1
                Seat Memory: scan after driver door opening
                    Not activated
                Seat Memory: scan after driver door opening no KESSY unlocking
                    activated
                Softtouch mounted
                    installed
                Cyclic interior scan during active warning message "Key not found"
                    Not activated
                allowa remotestart to disable keys
                    Not activated
                aktivate function trigger access leaving elv
                    activated
            internal_keyminder_byte2
                No locking with ID-transmitter last used interior
                    activated
                Re-open after passive comfort closing
                    activated
                Re-open last handling
                    Not activated
                Re-open tailgate
                    activated
                Lock prevention tailgate
                    activated
                Inhibit ID-transmitter for passive go
                    activated
            DeveloperCoding: Search lights
                ZAT active during clamp 58t on
                    activated
                Standardisation of ZAT
                    activated
                ZAT detecting open load
                    Not activated
                ZAT illumination modus mybeat clamp58xt
                    Not activated
                ZAT illumination concept mybeat clamp58xt
                    Not activated
            DeveloperCoding: vehicle environment
                Steering wheel
                    Left-hand drive
                Convertible
                    Not activated
                Pre Catch for Trunk
                    Not activated
                reactivate all doorhandles
                    Not activated
            DeveloperCoding: Passiv Go
                Passive Go
                    activated
                GO only via antenna IN1 if tailgate open
                    Not activated
                GO only via antenna IN1 if sliding door open
                    Not activated
                Passive Go: tailgate authorized to start
                    activated
                Impairment go on a low key battery
                    Not activated
            Sonstiges_byte1
                Backdoor TSG
                    Not activated
                Response extension for scan procedure
                    Not activated
                Diagnostic: service 86 - response on event
                    Not activated
                Internal
                    Not activated
                Use default antenna data
                    Not activated
                Battery manager mounted
                    activated
                Scan Procedure: timeoutcontrol active
                    activated
            DeveloperCoding: Proximity Sensor
                AUDI doorknobs mounted
                    Not activated
                Proximity Sensor: sensor stays active after fault detection
                    Not activated
                Detection of an repeated failed doorknob actuation
                    activated
                Suppress fault manager entry "Falschverbau aktiv"
                    activated
                No turn off for driver doorknob while passive
                    activated
                energized doorhandles at stateKL15on when opening door
                    activated
            Byte9_VIP
                active vip
                    Not activated
                vip activation on clamp15
                    Not activated
                vip deactivation on running engine
                    Not activated
                Hitch trailer installation
                    Not activated
                Coding kick and close function
                    Not activated
                Coding easyclose locking
                    Not activated
                ECL Start ueber ViP
                    Not activated
            sonstiges_byte2
                interiorscan clamp15 reach trashhold
                    activated
                sad existing
                    Not activated
                trunk ecu existing
                    Not activated
            Byte12_diverse
                environment scan step1
                    Not activated
                environment scan step2
                    Not activated
                interior scan clamp 15 new concept
                    activated
                exeption drivers doors interior scan
                    Not activated
                suppression access detection for remotestart
                    Not activated
                open cabrio canopy interior scan
                    Not activated
            proximity Sensor: max. length of Diagnosticimpuls
                    71 ms
            proximity Sensor: max. length of Entryimpuls
                    10400 µs
            Proximity Sensor: max. length of Exitimpuls
                    40400 µs
            Proximity Sensor: max. Impulslength of proximity-Impuls
                    20400 µs
                    75 ms
            Proximity Sensor: max. intermission-length Diagnostic
                    14 ms
            Proximity Sensor: upper limit intermission-length
                    10 ms
            Proximity Sensor: max. signal-length
                    120 s
            Proximity Sensor: min. length of Diagnosticimpuls
                    42 ms
            Proximity Sensor: min. length of Entryimpuls
                    6200 µs
            Proximity Sensor: min. length of Exitimpuls
                    24200 µs
            Proximity Sensor: lower limit proximity-Impuls
                    12200 µs
            Proximity Sensor: lower limit Impuls
                    2000 µs
            Proximity Sensor: max. length of signal hall sensor
                    100 s
            Doorknob contact sensor disconnecting time
                    5400 min
            Time Sensor Power Off Group 2
                    3600 min
            Proximity Sensor: Time Power On
                    1960 ms
            Key Minder: delay reunlocking tailgate
                    500 ms
            Proximity Sensor: SP_X2
                    10 min
            Proximity Sensor: SP_X3
                    1
            Proximity Sensor: SP_X4
                    80
            Proximity Sensor: SP_X5
                    1
            Proximity Sensor: SP_X6
                    30 min
            Proximity Sensor: SP_X7
                    1
            Proximity Sensor: Timervalue for ExitReverseOption
                    0 ms
            Proximity Sensor: Comfort Exit-Enlargement
                    200 ms
            Proximity Sensor: turn-off limit from battery-manager
                    2
            Proximity Sensor: min. enginespeed for a running engine
                    300 1/min
            Proximity Sensor: min Vehiclespeed for a driving vehicle
                    20.0 km/h
            Proximity Sensor: max Vehiclespeed for a standing vehicle
                    10.0 km/h
            Proximity Sensor: min. tolerance data bit length
                    120 µs
            Proximity Sensor: max. tolerance data bit length
                    200 µs
            deactivation_time_vip_slidingdoor
                    15 s
            Time_frame_VIP_kick_forecast
                    5
            Voltage monitoring: undervoltage for Keyless Go
                    6000 mV
            Voltage monitoring: undervoltage Delta
                    500 mV
            Voltage monitoring: undervoltage Jumpstart 1 Delta
                    0 mV
            Voltage monitoring: undervoltage for KESSY ECU
                    9000 mV
            Voltage monitoring: overvoltage for KESSY ECU
                    16000 mV
            Voltage monitoring: overvoltage for Keyless Go
                    27000 mV
            Voltage monitoring: overvoltage Delta
                    500 mV
            Voltage monitoring: overvoltage Jumpstart 2 Delta
                    0 mV
            Cycletime for voltage monitoring during sleepmode
                    100 ms
            settime_trigger_exit_vehicle
                    500 ms
            settime_trigger_entry_vehicle
                    500 ms
            Key Minder: p_keyless_eventsearch_holding_time
                    10 s
            Interior scan: opening threshold window lifter
                    5.0 %
            Interior scan: opening threshold sliding roof
                    1.0 %
            Interior scan: Speed - threshold
                    20 km/h
            Interior scan: max. engine speed for standing engine
                    10 km/h
            Key Minder: p_keyless_eventsearch_retries
                    4
            Interior scan: deceleration after comfort closing
                    3200 ms
            Cyclic interior scan during clamp 15 on
                    10 s
            environment_scan_duration_step1
                    300 min
            environment_scan_cyclic_step1
                    700 ms
            environment_scan_duration_step2
                    24 h
            environment_scan_cyclic_step2
                    2000 ms
            environment_scan_responselevel_reduction
                    500
            environment_scan_level_bem
                    2
            environment_scan_startdelay_time
                    5 s
                    not active
            Control module rear lid opening, duration status query
                    4960 ms
            Control module rear lid opening, vehicle type
                    FE
            Easy_close_detection_areas
                Easy close antenna current step
                    E
                Easy close open door antenna current step
                    5
                Value area 4
                    70 V/m
                Value area leaving area
                    65 V/m
            Easy_close_alignment
                RSSI  sample rate
                    500 ms
                Timeframe scan active
                    20.00 s
                Min threashold trunk
                    70 %
                Max time IDGeber rear
                    2.00 s
                max threashold reopen EasyClose
                    30 %
                max time reentry EasyClose
                    5.00 s
                min rssi values hysteresis EasyClose
                    150
            Activating and deactivating all development messages
                Development messages
                    not active
            ZAT_motor_signal_timer_1
                Time
                    3000 ms
            ZAT_motor_signal_timer_2
                Time
                    3000 ms
            Interior_scans_clamp15_retry_at_active_message
                Interior scans clamp15 retry at active message
                    5
            Interior_scans_clamp15_break_at_active_message
                Time
                    5000 ms
            ZAT_first_rise_time_low_high_state
                Time
                    100 ms
            ZAT_first_fall_time_high_low_state
                Time
                    900 ms
            ZAT_second_fall_time_high_low_state
                Time
                    2000 ms
            ZAT_pwm_offset_1_lower_limit
                    5.0 %
            ZAT_pwm_offset_2_lower_limit
                    10.0 %
            ZAT_pwm_peak1_upper_limit
                    90.0 %
            ZAT_pwm_peak2_upper_limit
                    100.0 %
            ZAT_clamp58xt_signal_factor
                ZAT clamp58xt signal factor
                    0.200
            ZAT_clamp58xt_signal_offset
                ZAT clamp58xt signal offset
                    3.0
            duration_A-CAN_wake_up_for_Engine_ECU_wake_up
                Time
                    2000 ms
        Advanced identification
            Diagnostic mode
                    VW - diagnostic mode
            ASAM/ODX file identification
                    EV KessyHellaMQBAB
            ASAM/ODX file version
                    004039
            AUTOSAR Standard application software identification
                Standard software module
                    Diagnostics - Event - Handler
                Software manufacturer ID
                    IAV GmbH
                Primary version number
                    4
                Secondary version number
                    1
                Revision number
                    11
            Identification of bus master/sub bus master
                ECU ID
                    B7
                ECU Name
                    Access Startsystem Interface
                LOGICAL-LINK SHORT-NAME
            Consistency of EEPROM-data
                Error during last data record download
                    no error
                Data consistency
                    valid EEPROM data
                Data record modification
                    Data record changed
                Parameterizability
                    Parameterizable
            Date of manufacture
                Year
                    16
                Month
                    5
                Day
                    18
                    0
                Decoration variant
                    0
                    036
                Manufacture version
                    000
                    P001
            Programmability status
                Programmability
                    programmable
                Program consistency
                    Program present
            Serial number
                    0403751108
                    2201
            Workshop code and date of last update programming of SW module
                Year
                    12
                Month
                    1
                Day
                    27
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    0
                Month
                    1
                Day
                    1
                Device number
                    0
                Importer number
                    0
                Dealership number
                    0
                Programming status
                    Correct result
                Year
                    16
                Month
                    6
                Day
                    7
                Device number
                    31
                Importer number
                    770
                Dealership number
                    33281
                Programming status
                    Correct result
            Number of possible access authorizations
                Number Of Logins
                    1
                ID number
                    B7
                subsystem name
                    32
            Hardware part number for suppliers
                    355A413031313436302D3232
            Hardware version for suppliers
                    202020
            Software version of suppliers
                    4B594D5142
            Software version for suppliers
                    30383131
            Vehicle equipment code
                    000000000000000000001632
            Identification of parameterization
                Version number
                    01
            SoftwareVersion
                    0811
            Date of last adaptation
                Year
                    21
                Month
                    7
                Day
                    28
            Adaptation workshop code
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
            Date of last coding
                Year
                    21
                Month
                    7
                Day
                    29
            Coding workshop code
                Device number
                    60933
                Importer number
                    3
                Dealership number
                    12289
                Data record
                    1
                Data record
                    1
            Parameter set part number
                    V03935239ZY
            Parameterization date
                Year
                    16
                Month
                    6
                Day
                    7
            Parameterization workshop code
                Device number
                    31
                Importer number
                    770
                Dealership number
                    33281
            Parameter set version
                    0001
                    3Q0959435E
            HardwareVersion
                    036
            FAZIT-identification
                Manufacture location index
                    HLH-W42
                Day of manufacture
                    18.05.16
                Manufacturer- test stand number
                    P001
                Running manufacturer number
                    2201
                Bootloader
                    1
                Application
                    0
                Data record
                    1
                Bootloader
                    1
                Application
                    0
                Data record
                    0
            Versions of software module
                Bootloader
                    0009
                Application
                    0811
                Data record
                    0001
            VW/Audi part number
                    3Q0959435E
            Manufacturer code
                    HLH
            System description
                    VWKESSYMQB
            System abbreviation
                    J518
            Known subsystems
                    No subsystems
                segment number
                    1
                subsystem present
                    Yes
                subsystem coded
                    No
                reserved (VW 80127 3.0)
                    0
                Subsystem number
                    0
                    F
                    TMBAH7NP2H7009796
        Mileage: 372624 km
Rlhs:00084D
Leimo rechts:b20 00 00
same for leimo links
Few similar cars:
- https://forums.ross-tech.com/index.php?threads/25322/
- https://forums.ross-tech.com/index.php?threads/22380/
- https://www.briskoda.net/forums/topic/368574-vcds-options-on-superb-iii/?do=findComment&comment=4775818
Seems they all use different coding for 55 though :D
06DA00003F010000  Your coding
06EA00003F010000
06D202003F010000
06D202003F010000
That suggests you should check bytes 1, 2 and 3. No idea what those bytes control as I haven't got the same module in my car.
Have you found the OBDeleven history function yet? https://forum.obdeleven.com/thread/97/history
The weird thing is the a5 is that the camera and I don’t have that in the control units is that something I should have
And do you know central electric adaptions
If you have lane assist or traffic sign recognition, you should have the A5 camera.
I can't see it in the OBDeleven output...
Are you asking if I have a list of stock adaption values for your car? In which case no I don't...
The original values will depend on when the car was built and exactly which options were fitted. The only proper way to make sure you have the stock values, is to find someone with ODIS online access to get the original config from the Skoda/VAG servers.
Don’t have the camera and not the sla headlights but have bi-xenons
appears u have an MY16 Superb.
from MY17 onwards, 55-headlight range control module no longer exists and this function/control was moved to 4B Multifunction Module.
given ur model,  below is the coding i'm aware of, that was used in an MY15 Superb for its 55-headlight and its sub-modules.
ur output/scan dump above has too much crap/noise in it to properly see/find what is going on.
but from wat i could spot:-
reference coding (below) :- 06DA00003F010000
your coding:                          06D202003F010000
reference slave coding (left): B20000
your slave coding:                   unknown
reference slave coding (right): B20000
Address 55: Headlight Range (J745)       Labels: 7P6-907-357.clb
   Part No SW: 7P6 907 357 D    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0090
   Revision: --------    Serial number: --------------
   Coding: 06D202003F010000
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
   ROD: EV_HeadlRegulVWAFSMQB.rod
   VCID: 40888C4BDB872242FC-8014
   Left Headlamp Power Output Stage:
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0006
   Coding: B20000
   Right Headlamp Power Output Stage:
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0006
   Coding: B20000
I’ll try this tomorrow and let you know
Is my coding and adaptions for things like engine kessy central electronics and things like that correct
   Coding: B20000
   Coding: B20000
And how do I know if my car came with features that the previous owner disabled bought second hand an as far as I know he took out the centre speaker so I think he did more
i don't know wat codings and adaptations r "correct" for ur specific car.
it depends on wat was fitted/specc'ed.  i can't tell u that.  u need to use something like Skoda Erwin to get specifics.
u asked what the coding was for headlights, in ur case 55-headlight range control - i shared wat i know.
from MY17, 09-central electrics doesn't have any long coding anymore, just adaptations, and there is almost 2000 lines of adaptations just in that module.
codings/adaptations/blockmaps will change between RHD and LHD cars.  it will change based on equipment fitted.  so simply copying and pasting long codes and adaptations is not a wise move as u risk messing things up.
OBDeleven vehicle history log
Date: 2021-08-03 13:11:12
    VIN: TMBAH7NP2H7009796
    Car: nvm20
    Year: 2017
    Body type: Saloon
    Engine: CRLB  kW ( hp) l
    Mileage: 372899 km
09 Central Electrics
        System description: BCM MQBAB M+
        Software number: 5Q0937084CF
        Software version: 0236
        Hardware number: 5Q0937084CF
        Hardware version: H34
        Serial number: 02001614101021
        Faults:
                B11FF01 - Footwell lighting
            Electrical error
                static
I put everything back and do I have the wrong bulbs it’s set to 20-4/5w
Please put it in a [code] or quote tag so it’s not a million miles long 😂
did you save any backups from before you modified anything
and what’s the actual problem you’re having
Did not do that I’m having problems with headlights to dull
