Very smooth DSG gears switching after VCDS Adaptation
No, you shouldn't hear noises, especially during engagement.
  • Replies 50
  • Views 119.1k
  • varaderoguy
    varaderoguy
    I would also add that if you also chuck in the Module 44 Driving Mode mod to make it direct drive acceleration instead of time based acceleration then it will be an even smoother drive....just my 5 pe
  • BTW There is something I have to add in the initial post in this thread - the car is not moving when you release the brake pedal(as it usually does) until the throttle pedal is pressed. It happens on
  • esoxecosse
    esoxecosse
    Yep I found that out to my expense, nearly cried for a couple of minutes, turned the car off and on and all was ok but good to know the throttle sorts it as well.lol   Cheers
