My Starter motor is not disengaging - Fabia Mk1 1.9 tdi YG07DWA
Hi guys, I hope that someone can help me.
So, this is what happened -
I drove roughly 60 miles yesterday - mainly motorway and 10 miles of that A road. I made 1 stop and as i drove off - I heard loud (rattling sort of ) noise from the engine bay. I turned the car off to have a look and after that it will not switch on. There was no problem with fuel delivery, battery was fine i.e., when I turn the key to Acc, all the dash lights etc were coming on, but nothing when i turn the key to ignition.
I managed to bump start it - that made me think - it must be the starter motor. So, I changed the starter motor and old starter motor was cooked. I am able to start the car but starter motor is not disengaging by itself. I am having to turn the key back ever so slightly for it to disengage - I hope that makes sense.
So, what could it be? After browsing forums - I am thinking ignition switch. I have seen videos online on how to replace it. Would you say that is the right route to go down or am i supposed to take it to Skoda specialist garage?
Any help will be greatly appreciated. As I don't want to burn new starter motor as well.
Kind regards
Yogi
Ignition switch.
38 minutes ago, J.R. said:
Ignition switch.
Ok thanks J.R. I will try that
48 minutes ago, J.R. said:
Ignition switch.
Would anyone be kind enough to get me correct part number for ignition switch for my car.
Kind regards
Yogi
16 minutes ago, Arshwesh said:
Am I right to assume - replacing the switch is plug and play - i.e. no programming etc required.
Yes it's plug and play.
Lovely, thanks TMB
On 11/08/2021 at 16:34, Arshwesh said:
Lovely, thanks TMB
Hello guys,
It's me again.
I managed to get the part but I cannot undo the 2 torx screws underneath the steering wheel.
What I am finding is that I can't get my long torx screwdriver to go in their straight as it's at an angle. I hope you understand what I am saying.
I can't get it to any garage for at least another 2 weeks.
Is there anyone in Kent who is willing to help me? Of course I will pay.
Thank you in advance guys but I am very desperate.
Yogi
Do you mean the screws that hold the plastic shroud together?
Yes exactly that
5 minutes ago, Arshwesh said:
Yes exactly that
You have to rotate the white to the left and right to reveal them
Yes exactly that
Wheel
Anyone guys?
I am really stuck - I just can't get the screwdriver to grip on to the screw due to the angle.
Yogi
I have tools to take care of this type of problem, can you remove the steering wheel?
I can if I really have to but din't want to ideally.
On the video that I saw on you tube - the guy manages to take out those 2 torx screws with ease.
But I just cannot do it. Steering comes in the way.
Forgot to mention- I have bohemia model, so the steering wheel is chunky version.
I am in Kent.
I am in Sussex, it's too far, remove the wheel.
Hi Sepulchrave, I have sent you a pm.
Yogi
Yogi
Hi guys,
Just an update.
I feel stupid now but the reason I was not able to undo those 2 torx screws because someone had changed them to t10 and I was trying t20 screwdriver - hence why it was not gripping it.
Have a look.
4 minutes ago, Arshwesh said:
Hi guys,
Just an update.
Have a look.
I am going to try changing the switch itself tomorrow.
I saw on a video that switch and key has to be on position 1. Getting the key to position 1 is easily done lol 😆 but how do I make sure that ignition switch is on position 1.
Kind regards
Yogi
Hello everyone,
I managed to change the ignition switch today - now its doing what it is supposed to.
Thanks very much for all the help and suggestion.
Kind regards
Yogi
