Eibach springs (no headlight adjust) and abs/tc light on
Hey guys, I have two questions:
just lowered the Superb with Eibach springs somewhere between 3-4 cm and now I don’t have headlight adjustment when I start the car not when driving? Is this normal? Can some send me a pic how the sensor is mounted? Because it may be a mechanic bad mount when they mounted the springs. (Please see pic to check if it’a correctly mounted)
and
my abs/tc light is on. First I’m hearing a noise for a while ago (maybe 3 years) specially from 100kmh which I believed was from the bearing. Then o got the abs/tc light, connected vagcom and it was front left sensor.  Replaced the sensor because the stock one was scratched when i removed it. then I replaced a second time along with the bearing because the sensor was scratched again (please see pic). The roller noise keeps buzzing me, the abs/tc light sensor flashed again. My mechanic suspect the roller noise at high speed is from the tires (Toyo proxes t1r)  which I doubt because the noise is like the sound of a fidget spinner.069C974F-F58C-4628-84D7-64C2D852AD32.thumb.jpeg.f4c3cca899daed4113965307cd8b6846.jpeg
Edited by luis_palma
I have no clue what a "fidget spinner" is. Could you post the original Portuguese?
Here it is but it’s a global thing, not Portuguese.
Cheers; I still have no idea what one sounds like, never having seen or played with one.
Ok nevermind. The thing is I removed today the new sensor and it goes like this:
how can I adjust the gap between the sensor and the wheel?
