Engine code and why it's useful to know
VW Codes Decoded
E0A = No special edition
1N2 = Power steering electro-hydraulic
4A0 = Without seat heater
7Q0 = Without navigation device
3L2 = Manual height adjustment for right frontseat
QG0 = Without service interval prolongation
1D0 = Without trailer hitch
1NH = Full wheel covers
8L3 = Roof antenna
8UE = Radio with CD drive
9P0 = Without seat belt reminder
0GG = Emission standard EU4
5SJ = Left exterior mirror: convex
H2Z = Tires 185/60 R14 T
J1P = Battery 220 A (44 Ah)
8QJ = Key for locking system with remote control
Q1A = Standard front seats
L03 = Suspension range 03 installation control only, no requirement forecast
5RV = Right exterior mirror: aspherical
4UE = Air bag for driver and front seat passenger
7AA = Electronic vehicle immobilization device
8X0 = Without headlight washer system
7X0 = Without park distance control
7P0 = Without lumbar support in seat backrests
1KM = Drum brakes, rear
4R2 = Power windows front, mechanical window regulators rear
8GD = Alternator 90A
4K3 = Radio remote controlled central locking operated from inside and safe securing
9W0 = W/o car phone preparation/installation
F0A = No special purpose vehicle, standard equipment
6FB = Body-colored exterior mirror housings
B09 = Type approval Great Britain and NorthernIreland
6Y0 = Without cruise control warning system
8WB = Front fog lights
1AN = Anti-lock brake system (ABS)
3QT = 3-point seat belts with tensioner and height adjustment, front
9AP = Climatic air-conditioning system (semi-automatic)
G01 = Front shock absorption
7A0 = Without CD changer/CD player
3S4 = Preparation for roof load rack
3FA = Without roof insert (standard roof)
4X0 = Without side air bag
8RM = 8 speakers (passive)
QN0 = Without drawers under front seats
VW Codes Decoder
http://igorweb.org/equidec.aspx
Front Springs G01, L03
(1) 6Q0411105AE coil spring
3 paint marks
2 paint marks
red
blue
Model data: PR-G01/L03
PR-G02/L03
Front Shock Absorbers G01
8 6Q0413031BH shock absorbers
Model data: PR-G01,G05
http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/FAB/year/2005/drive_standart/453/hg_ug/411/subcategory/411000/part_id/2561497/lang/e
Skoda Fabia MK1 Engines
Model Years Engine and code Displ. Power Torque
Petrol
1.0 8V 1999–2000 I4 AQV/ATY/ARV 997 cc 37 kW (50 PS; 50 hp) at 5000 rpm 84 N⋅m (62 lb⋅ft) at 2750 rpm
1.2 MPI 6V 2001–2003 I3 AWY/BMD 1198 cc 40 kW (54 PS; 54 hp) at 4750 rpm 108 N⋅m (80 lb⋅ft) at 3000 rpm
1.2 HTP 6V 2003–2007 I3 AWY/BMD 1198 cc 40 kW (54 PS; 54 hp) at 4750 rpm 108 N⋅m (80 lb⋅ft) at 3000 rpm
1.2 HTP 12V 2003–2007 I3 AZQ/BME 1198 cc 47 kW (64 PS; 63 hp) at 5400 rpm 112 N⋅m (83 lb⋅ft) at 3000 rpm
1.4 MPI 2000–2003 I4 AZE/AZF 1397 cc 44 kW (60 PS; 59 hp) at 5000 rpm 118 N⋅m (87 lb⋅ft) at 2600 rpm
1.4 MPI 1999–2003 I4 AME/AQW/ATZ 1397 cc 50 kW (68 PS; 67 hp) at 5000 rpm 120 N⋅m (89 lb⋅ft) at 2500 rpm
1.4 16V 2000–2007 I4 APE/AUA/BBY/BKY 1390 cc 55 kW (75 PS; 74 hp) at 5000 rpm 126 N⋅m (93 lb⋅ft) at 3800 rpm
1.4 16V 2006–2007 I4 BUD 1390 cc 59 kW (80 PS; 79 hp) at 5000 rpm 132 N⋅m (97 lb⋅ft) at 3800 rpm
1.4 16V 1999–2007 I4 AUB/BBZ 1390 cc 74 kW (101 PS; 99 hp) at 6000 rpm 126 N⋅m (93 lb⋅ft) at 4400 rpm
2.0 8V 1999–2000 I4 ATF 1984 cc 88 kW (120 PS; 118 hp) at 5600 rpm 174 N⋅m (128 lb⋅ft) at 2400 rpm
2.0 8V 2000–2007 I4 AZL/BBX 1984 cc 85 kW (116 PS; 114 hp) at 5200 rpm 170 N⋅m (130 lb⋅ft) at 2400 rpm
Diesel
1.4 TDI 6V 2005–2007 I3 BNM 1422 cc 51 kW (69 PS; 68 hp) at 4000 rpm 155 N⋅m (114 lb⋅ft) at 1600–2800 rpm
1.4 TDI 6V 2003–2005 I3 AMF 1422 cc 55 kW (75 PS; 74 hp) at 4000 rpm 195 N⋅m (144 lb⋅ft) at 2200 rpm
1.4 TDI 6V 2005–2008 I3 BNV 1422 cc 59 kW (80 PS; 79 hp) at 4000 rpm 195 N⋅m (144 lb⋅ft) at 2200 rpm
1.9 SDI 8V 1999–2006 I4 ASY 1896 cc 47 kW (64 PS; 63 hp) at 4000 rpm 125 N⋅m (92 lb⋅ft) at 1600–2800 rpm
1.9 TDI PD 8V 2000–2007 I4 ATD/AXR 1896 cc 74 kW (101 PS; 99 hp) at 4000 rpm 240 N⋅m (177 lb⋅ft) at 1800–2400 rpm
1.9 TDI PD 8V RS 2003–2007 I4 ASZ/BLT 1896 cc 96 kW (131 PS; 129 hp) at 4000 rpm 310 N⋅m (229 lbf⋅ft) at 1900 rpm
https://en.wikipedia.org/wiki/Å koda_Fabia#Engines
Edited by Carlston
I have the full car data pdf for that car thanks Carlston.
This thread was intended to be general, for all readers, not about my partners car, nor mk1 Fabias, both of which are well known to me.
Thanks for your efforts though.
The purpose was to add links to show where to find information, such as "vw codes decoder", "vw online parts catalogue", "wikipedia".
I simply used the AZQ engined Fabia MK1 as an example.
However, it's sounds like a great engine. I like the fact that maximum torque is produced from quite low revs, ie. 3,000rpm.
It's a shame VW/Skoda didn't increase the size of the 3 cylinder engine to 1,350cc, ie. 450cc per cylinder for 72PS@5,400rpm and 126Nm@3,000rpm which is a 12.5% increase in power and torque from the 1,200cc engine. The 126Nm of torque is similar to the 125Nm of torque that the old 1.9SDI engine produced in the Fabia MK1, although the 1.9SDI engine produced its maximum torque from a lower 1,600rpm to 2,800rpm. As you will see in the wikipedia engine chart above, the 1.9SDI engine had the engine code ASY.
Edited by Carlston
It is a fun thing to drive, suits the car well I think. I've no experience of driving diesels.  🙂
You can also ask at TPS to give a full printout of all PR codes installed for a given VIN - and this list is considerably larger than the limited selection of PR codes on the data sticker in the boot or service book
Some great info being posted, thanks it all helps use fix issues easier.
can some one please suggest a engine code reader I should look at using, I have a Octavia RS 2012 MK1
@Brissy, engine code is an identifier of the precise variety of engine in a given car. Not the same as fault code, which is what you seem to be asking about.
I would recommend asking in the more relevant section of the forum, here: Diagnostics & VCDS - BRISKODA
Edited by Breezy_Pete
On 15/10/2021 at 19:37, nige8021 said:
If the data sticker is missing from the boot/service book and there is no sticker on the cambelt cover, on UK cars the code can be found on the V5 vehicle logbook, the letters at the start of the engine serial number are the engine code.
My sticker in boot and service handbook says "CEGA", the V5 says "CEG".
  • 9 months later...
Who is/are TPS, I can't seem to find any reference when I google!
Thanks.
https://tps.trade/about-tps
Edited by Carlston
They used to be helpful with Joe Public in some of their locations. Good luck today.
OK, many thanks for the replies I'll check it out!
