ESP fault when using self-parking
Hi everyone!
Got a great 2009 Superb uthat has been, well, superb.
However when using the self-parking function the steering goes dead and heavy and an ESP fault warning flashes up. This has happened twice now out of three times used. I've used the self-parking loads of times (I'm disabled and can't turn my head round very far).
Has anyone come actoss this problem or experienced it? Any/all help gratefully received!
Hi Trenchman, have you had the battery tested recently? I'm guessing that the electro-assisted steering will be loading battery during this maneuver and battery voltage dropping too low - clue being the steering going 'dead'
Hi Warrior.
Thanks for the speedy reply. The battery is a Bosch unit with 4 year guarantee and fitted about 8 months ago so I expect it'll check out. Nevertheless, I'll get it checked anyway if only to rule it out.
Trenchman
Check the DTCs.
I would certainly check them if I knew what 'DTCs' are!
Diagnostic Trouble Codes.
Basically read out the car's controllers for faults. Basic code readers are petty cheap.
The dealer will charge £75 and upwards.
Thanks bud. I'll be in hospital over Xmas but it's on the New Year's list!
