Several error messages
I drove my front right (driver side) wheel through part of a puddle and after that my car made a high pitched noise and came up with error codes.
Once I switch my car on the following comes up
Stabilisation control (sec(
The Park pilot is currently not available
Tyre pressure loss indicator
I can then put the park pilot and speed setter on
Once I set off the ABS Error and ACC front and rear assist error shows up
Can someone please help
Sounds like the ABS sensor has problems
I will check that out and give it a clean
Had a similar thing happen when driving through a puddle leaving the Covid vaccination centre in Barnstaple, the right rear ABS sensor had failed - and as it is integrated into the rear wheel bearing meant we needed a new wheel bearing at a cost of over £500 (hope the front ABS sensor is a stand-alone item!).
The ABS sensor integrated into the wheel bearing? Not the case with my car 2013 1.4TSI Elegance
https://www.autodoc.co.uk/car-parts/abs-sensor-10138/skoda/octavia/octavia-5e3/126002-2-0-tsi-rs?criteria[100][0]=HA
Could be water has got into the ABS connector.
