Does the 2009 1.4 TDI Roomster have a DPF fitted?
Thinking of buying one of these as a cheap runaround, but would rather avoid the headache of having a DPF. Does this car have one? Also what would a cam belt/pump replacement set me back?
According to the Wikipedia chart below, the 1.4TDI 69PS version doesn't have a DPF, but the 1.4TDI 80PS version does. However, the chart could be wrong.
Diesel engines
Engine designation Production Engine code (family) Displacement, configuration, valvetrain, fuel system, aspiration Motive power at rpm max. torque at rpm Gearbox (type), drive Top speed 0–100 km/h [s] (0–62 mph) Combined consumption [l/100 km / mpg imp / mpg US] CO2 [g/km]
1.2 TDI CR 55 kW 2010–2015 (EA189) 1199 ccm, I3, 12V, DOHC, common-rail, turbocharged 55 kW (75 PS; 74 hp) at 4200 rpm 180 Nm. (133 lb•ft) at 2000 rpm 5-speed manual (MQ250), FWD 162 km/h (101 mph) 15.5 4.5 / 62.8 / 52.3 119
1.2 TDI CR GL 55 kW 2010–2015 (EA189) 1199 ccm, I3, 12V, DOHC, common-rail, turbocharged 55 kW (75 PS; 74 hp) at 4200 rpm 180 Nm. (133 lb•ft) at 2000 rpm 5-speed manual (MQ250), FWD 165 km/h (103 mph) 15.4 4.2 / 67.3 / 56.0 109
1.4 TDI PD 51 kW 2006–2010 (EA188) 1422 ccm, I3, 6V, SOHC, Pumpe-Düse, turbocharged 51 kW (69 PS; 68 hp) at 4000 rpm 155 Nm. (114 lb•ft) at 1600–2800 rpm 5-speed manual (MQ250), FWD 163 km/h (101 mph) 14.8 4.8 / 58.9 / 49.0 127
1.4 TDI PD DPF 59 kW 2006–2010 (EA188) 1422 ccm, I3, 6V, SOHC, Pumpe-Düse, turbocharged 59 kW (80 PS; 79 hp) at 4000 rpm 195 Nm. (144 lb•ft) at 2200 rpm 5-speed manual (MQ250), FWD 172 km/h (107 mph) 13.3 4.8 / 58.9 / 49.0 127
1.6 TDI CR 66 kW 2010–2015 CAYB (EA189) 1598 ccm, I4, 16V, DOHC, common-rail, turbocharged 66 kW (90 PS; 89 hp) at 4200 rpm 230 Nm. (170 lb•ft) at 1500–2500 rpm 5-speed manual (MQ250), FWD 171 km/h (106 mph) 13.3 4.7 / 60.1 / 50.0 124
1.6 TDI CR 77 kW 2010–2015 CAYC (EA189) 1598 ccm, I4, 16V, DOHC, common-rail, turbocharged 77 kW (105 PS; 103 hp) at 4000 rpm 250 Nm. (184 lb•ft) at 1500–2500 rpm 5-speed manual (MQ250), FWD 181 km/h (112 mph) 11.5 4.7 / 60.1 / 50.0 124
1.9 TDI PD DPF 2006–2010 (EA188) 1896 ccm, I4, 8V SOHC, Pumpe-Düse, turbocharged 77 kW (105 PS; 103 hp) at 4000 rpm 240 Nm. (177 lb•ft) at 1900 rpm 5-speed manual (MQ250), FWD 182 km/h (113 mph) 10.8 5.0 / 56.5 / 47.0 130
https://en.wikipedia.org/wiki/Škoda_Roomster#Engines
I dont know about the 1.4 but my 2007 1.9 PD does not have a DPF so I have doubts about accuracy of these lists.
Happy to stand corrected but I believe only facelift Roomsters have DPFs. Pre-facelift, the only model in the Roomster/Fabia range to have a DPF was the Fabia Greenline.
I expect the build codes would tell you if a DPF was fitted.
If you can get the build codes that relate to the vehicle's VIN, you could use the "VW Codes Decoder" to check whether a DPF is present.
VW Codes Decoder
http://igorweb.org/equidec.aspx
  • Sponsor
As with so many other things in car world, engine code should tell you the answer. Go to the link in my signature if you don't know how/where to find this.
Scrutinising years 2008-2010 inclusive for Roomster, the only mention of particulate filters in the 'fuel, exhaust, cooling' area of ETKA is for engine codes BMS and BLS, of which the former is a 1.4l engine, the latter a 1.9.
e.g. for 2009 fuel, exhaust, cooling Roomster (RO) [EUROPA 2009 year] (7zap.com)
I don't see any mentions of any alternative exhausts for BMS engines without particulate filter on the same page either, which seems conclusive.
If the car has a BMS engine, it'll have a DPF, if not, it won't.
Skoda Fabia MK1
Diesel
1.4 TDI 6V 2005–2007 I3 BNM 1422 cc 51 kW (69 PS; 68 hp) at 4000 rpm 155 N⋅m (114 lb⋅ft) at 1600–2800 rpm
1.4 TDI 6V 2003–2005 I3 AMF 1422 cc 55 kW (75 PS; 74 hp) at 4000 rpm 195 N⋅m (144 lb⋅ft) at 2200 rpm
1.4 TDI 6V 2005–2008 I3 BNV 1422 cc 59 kW (80 PS; 79 hp) at 4000 rpm 195 N⋅m (144 lb⋅ft) at 2200 rpm
1.9 SDI 8V 1999–2006 I4 ASY 1896 cc 47 kW (64 PS; 63 hp) at 4000 rpm 125 N⋅m (92 lb⋅ft) at 1600–2800 rpm
1.9 TDI PD 8V 2000–2007 I4 ATD/AXR 1896 cc 74 kW (101 PS; 99 hp) at 4000 rpm 240 N⋅m (177 lb⋅ft) at 1800–2400 rpm
1.9 TDI PD 8V RS 2003–2007 I4 ASZ/BLT 1896 cc 96 kW (131 PS; 129 hp) at 4000 rpm 310 N⋅m (229 lbf⋅ft) at 1900 rpm
https://en.wikipedia.org/wiki/Škoda_Fabia#Engines
VW Polo MK4
Diesel engines
Engine Code Type Displacement Power (Max output) Torque (Max output) Years Top speed
1.4 TDI BNM / BWB I3 SOHC 6V, Pumpe Düse (PD) injectors; optional diesel particulate filter (DPF) 1422 cc 70 PS (51 kW; 69 hp) at 4000 rpm 155 N⋅m (114 lb⋅ft) at 1600–2800 rpm 2005–2009 164 km/h
1.4 TDI AMF / BAY I3 SOHC 6V, Pumpe Düse (PD) injectors 1422 cc 75 PS (55 kW; 74 hp) at 4000 rpm 195 N⋅m (144 lb⋅ft) at 2200 rpm 2001–2005 170 km/h
1.4 TDI BNV / BMS I3 SOHC 6V, Pumpe Düse (PD) injectors; optional diesel particulate filter (DPF) 1422 cc 80 PS (59 kW; 79 hp) at 4000 rpm 195 N⋅m (144 lb⋅ft) at 2200 rpm 2005–2009 174 km/h
1.9 SDI ASY I4 SOHC 8V, distributor-type injection pump 1896 cc 64 PS (47 kW; 63 hp) at 4000 rpm 125 N⋅m (92 lb⋅ft) at 1600–2800 rpm 2001–2005 160 km/h
1.9 TDI ATD / AXR / BMT I4 SOHC 8V, Pumpe Düse (PD) injectors; optional diesel particulate filter (DPF) 1896 cc 101 PS (74 kW; 100 hp) at 4000 rpm 240 N⋅m (180 lb⋅ft) at 1800–2400 rpm 2001–2009 188 km/h
1.9 TDI ASZ / BLT I4 SOHC 8V, Pumpe Düse (PD) injectors 1896 cc 130 PS (96 kW; 130 hp) at 4000 rpm 310 N⋅m (230 lb⋅ft) at 1900 rpm 2003–2009 206 km/h
https://en.wikipedia.org/wiki/Volkswagen_Polo_Mk4#Engines
The Skoda Roomster 1.4TDI 69PS engine has engine code BNM which doesn't have a DPF.
The Skoda Roomster 1.4TDI 80PS engines have either engine code BNV which doesn't have a DPF or BMS which does have a DPF.
Edited by Carlston
