280 losing coolant
13 hours ago, SkudMissile21 said:
Well to add to my being unlucky it seems my local dealership isn’t helping with that - car dropped off in an unusable state (due to the leaking pump) on the 10th of June but isn’t scheduled to be repaired until the 12th of July! Has anyone else had a better experience of getting a breakdown scenario issue sorted or is it just my local dealer that is a shower of the brown stuff?!
That seems an awfully long wait. Did they tell you that before you dropped it off?
As for my car it only visited the dealer once & has been with a local indie VAG specialist ever since. Same with my previous Mk2 Superb & the Audi A6 before that. I only use main dealers when the cars are recalled or, still in warranty which, for us, ain't long because I normally buy them at 2-3 years old. Our 22 plate Hyundai will be with the dealer for a while longer due to it's 5 year warranty & then I'll be looking for an EV specialist to compare.
They didn’t quote me a date until last week, only said they would “look at it when we can”.
Im finally picking up a courtesy car from them today (after two weeks without) so at least I won’t be stranded while they carry on taking their time.
i just can’t believe it’s acceptable to not prioritise fixing broken down vehicles, I work in production maintenance and when something breaks we get it fixed asap regardless of what other planned stuff we have to do! It’s not like a minor annoyance I can live with until they’re free, if I carried on driving it there a risk it could completely fail and leave me stranded or worse
I bet the courtesy car isn't a 280!
Nope! 😭 it’s new though and seems nippy enough so fine for getting me and the kids around for the next 3 weeks
We’ll update to this, had an unexpected call to say the car was repaired so I have it back now.
guessing the combination of the Škoda uk complaint and the fact I had a courtesy car from them (after two weeks!) gave them incentive to get it done quicker.
if nothing else goes wrong before September I think this will be the last warranty year and last visit to a Škoda dealer, back to my trusted independent and take my chances that nothing else major messes the bed….
Thread revival time
My 280 2023 came up with a coolant light warning yesterday, i think it might be on the min as opposed to max. What do we use to top up these days I have something in the garage G12 or 13 of the proper VAG stuff from TPS. On this generation of EA888.4 do these water pump issues continue to plague the TSI. I am not sure if I should call out the breakdown to check this now as I have 2 years full RS and warranty cover on this used car and its better then being stranded if it gets worse all of a sudden. PS its just under 50k on the miles. I did about 240 miles yesterday it went off on the return leg from Enfield. Once the bonnet was opened it never returned, on the drive at home when still warm it was more low level biased. Advice welcomed
Edited by gav_is_con
submitted too early
1 hour ago, gav_is_con said:
Thread revival time
G13 should be ok for a top-up, and it may well be what's already in the engine - I believe the latest spec for coolant is G12evo.
Thanks it is in fact G13 as I went to check at lunch, at the same time half a litre may not impact the strength too much if use water instead?
My main concern is to understand if it could be the waterpump on the Gen 4 engines also
Ok for short-term emergencies - but better to keep the correct concentration to maintain corrosion protection.
