Cruise control mk2 Octavia retrofit
Hi I'm wanting to fit cruise control In my car, I don't have the control module under the column, it has the stalks that come as one unit instead of having individual stalks that plug in.
Does anyone know what part I would need for this. It's allowing me to activate the cruise control with coding so I'm guessing it just needs the hardware. Any help will be greatful
Thanks Screenshot_20220527-193033.thumb.png.a77bc1aefe315504fe99bbf0f08dd4b1.pngScreenshot_20220527-184103.thumb.png.7cf7a26bfecbbd2da6243ba6c343536f.png
@Tech1e is the best person to advise on this as he does cruise control retrofts
Thanks Nige hopefully height be able to advise me. I've just seen this part that looks like a direct fit, I can do the coding but I'm not sure if it will need a new wire running threw to the module :s
There is a single wire from pin 5 of the 16 pin connector on the unit that goes to the engine ECU
Thanks, so am I right in thinking that on this set up the clock spring unit is also the steering column control module?
And is the 16pin connector the connector that is part of the clock spring unit?
I think I might actually take this on as a project :)
