Tyres any recommendations
2 hours ago, Kevgem said:
thanks for the advice guys much appreciated!
The Superb MK2 normally uses a 7Jx16 ET45 rim for its 205/55R16 tyre size.
However, compared to a 225/45R17 tyre the 205/55R16 option can look a bit sunken in the wheelarch.
Therefore, other rims that you might want to consider include the 6Jx16 ET40 rim from the Superb MK1 and the 6.5Jx16 ET41 rim from the Superb MK3.
6Jx16 ET40 5/112 57.1 steel rim (from the Superb MK1)
ALCAR 9490
https://www.mytyres.co.uk/rims/details?vehicleId=180495828815717488&rimCode=ALCAR9490
6.5Jx16 ET41 5/112 57.1 steel rim (from the Superb MK3)
ALCAR 8426
https://www.mytyres.co.uk/rims/details?vehicleId=1035468374024787056&rimCode=ALCAR8426
Superb MK2 16" alloy rims
1 3T0601025 Aluminium rim 7JX16 ET45 4 SPECTRUM -
  3T0601025 7ZS chrome coloured metallic
2 3T0601025N Aluminium rim 7JX16 ET45 4 MOON
  3T0601025N 7ZS chrome coloured metallic
https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/632/6/601/601060
Superb MK2 16" steel rims
1 3C0601027M Steel rim 7JX16H2 ET45
5/112
4 PR-CH3 -
  3C0601027M 03C rally black       -
1 3C0601027AQ Steel rim 7 JX16H2 ET45
5/112
4   -
  3C0601027AQ03C rally black
https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/632/6/601/601010
Superb MK2 17" alloy rims
1 3T0601025B Aluminium rim 7JX17 ET49 4 VENUS -
  3T0601025B 7ZS chrome coloured metallic
2 3T0601025C Aluminium rim
D >> - 29.05.2011
7,5JX17 ET49 4 CALLISTO
  3T0601025C 7ZS chrome coloured metallic
D >> - 29.05.2011
2 3T0601025CA Aluminium rim
D - 30.05.2011>>
PR-C4F
  3T0601025CAHA7 Anthracite metallic (grey)
D - 30.05.2011>>
3 3T0601025D Aluminium rim 7,5JX17 ET49 4 TRIFID
  3T0601025D 7ZS chrome coloured metallic
5 3T0601025G Aluminium rim 7,5JX17 ET49 4 LAUREL
  3T0601025G 7ZS chrome coloured metallic
https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/632/6/601/601070
Edited by Carlston
  • Replies 65
  • Views 11.9k
  • I'm pretty certain that those tyres are far too tall a profile for the Superb.   A 45 or 50 would be more similar to the original size.
  • Unless you live somewhere with very bad winter weather, you're probably better off getting a set of decent all-seasons. Michelin CrossClimate2 would be the best in that category right now.
  • i bite the bullet and had 4x Michelin cross climate tyres fitted best deal i could find was £110 each fitted balanced and disposal of my old tyres. i went for the same size that was on the car wh
ALCAR 9490
ALCAR 8426
5/112
4 PR-CH3 -
5/112
4   -
D >> - 29.05.2011
D >> - 29.05.2011
D - 30.05.2011>>
PR-C4F
D - 30.05.2011>>
thank you very much for the in depth advice !
cheers kev
I'm a fan of the Michelin Crossclimates on my Superb but after an MOT advisory re tyres(cracked etc) on Mrs BJ's Panda and discovering these weren't an option I've gone for a special offer on a full set of Goodyear Vector 4Seasons Gen-2 from Tyreshopper -- good value.  We shall see when fitted, but reviews look good.
Edited by bigjohn
I love this guy when it comes to cars….
would it be ok to fit pcd 5x112 - 6.5j - et38 - 17 inch wheels - centre bore 57.1mm - fitted with winter tyres 215/65/ r17 ?
cheers kev!
cheers kev!
Not really. Much too tall for one thing so your speedo/odometer will be wrong. Offset is also quite a bit different to what's recommended so the steering will be a bit weird.
ok thanks!
what about 225/40 /18- et51- j7.5?
cheers kev
Are you looking for tyres to go on your existing wheels, or a set of wheels with tyres?
a set of wheels with tyres,
i thought i would see if i can pick up some wheels with winter tyres on then get a full set of summer tyres on the original wheels as all 4x tyres on my original wheels have been given as a advisory on my very resent mot test
cheers kev
Edited by Kevgem
cheers kev
right ok i see your point
cheers kev
would it be ok for me to change the tyre size to (225/45/18) FROM (225/40/18 ) the reason being the roads where i live are getting steadily worse each year and when you get on the B roads some of the pot holes are like open manholes you know the ones, the ones that make you cringe thinking that will be my alloy cracked, so i thought as i will be looking for a full set of new tyres soon would it be a good time to get tyres with a slightly higher profile (225/45/18) do you think this would be ok to do ?
my car is ( 2013 mk2 face lift dsg 170bhp 4x4 )
cheers kev!
Edited by Kevgem
cheers kev!
Compared to 205/55R16, 225/45R18 will raise the gearing by 4.4%.
Compared to 225/45R17, 225/45R18 will raise the gearing by 4.0%.
Compared to 225/40R18, 225/45R18 will raise the gearing by 3.5%.
If you look at the below chart, 205/55R16 is the best value and 69dB is quiet.
However, out of 225/45R17 and 225/45R18, the 17" tyre is the better value and keeps the gearing standard.
Michelin CrossClimate 2
205/55R16 94V XL (Euro label B B 69dB) £70.24
https://www.blackcircles.com/tyres/205-55-16?seasonal=AllSeason&manufacturer=michelin&delivery=1&id=11377
225/45R17 94V XL (Euro label C B 71dB) £97.50
https://www.camskill.co.uk/m140b0s8017p208565/Michelin_Tyres_All_Season_Car_Michelin_Cross_Climate_2_-_225_45_R17_94V_XL_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_71dB
225/40R18 92Y XL (Euro label C B 71dB) £96.25
https://www.camskill.co.uk/m141b0s7954p208519/Michelin_Tyres_All_Season_Car_Michelin_Cross_Climate_2_-_225_40_R18_92Y_XL_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_71dB
225/45R18 95Y XL (Euro label C B 71dB) £157.60
https://www.camskill.co.uk/m141b0s8784p208577/Michelin_Tyres_All_Season_Car_Michelin_Cross_Climate_2_-_225_45_R18_95Y_XL_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_71dB
Edited by Carlston
thanks for your in-depth reply but i don't wont to have to change the 18s that are already fitted, a set of 18s trinity alloys in anthracite i think you would agree to buy a nice set of alloys that look as nice as mine do + a full set of new tyres would be far to expensive.
what would 3.5% raise in the gearing mean?
cheers kev
  3T0071498A Aluminium rim 7,5JX18 ET46 4 TRINITY
  3T0071498A HA7 Anthracite metallic (grey)
SKODA Alloy wheel TRINITY 18" for SUPERB II and OCTAVIA III SCOUT
https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/768/6/601/601080
I read somewhere that the 18" Trinity alloy rim weighs a shockingly heavy 14.6kg.
Maybe you could weigh one to check this. If you are going to change the tyres, perhaps weigh the wheel (rim and tyre) before the change. Then when the old tyre has been removed from the rim, weigh that and deduct that weight from the weight of the complete wheel before the old tyre was removed.
The below alloy rim weighs about 7.3kg, ie. half the weight of the above rim. The reason that it's so light is because it's made from forged aluminium, whereas most car alloy rims are made from much heavier sand cast aluminium.
7Jx16 ET45 5/112 forged alloy rim (from Audi A4/A6 cars around the year 2000)
9 8D0601025K Aluminium rim 7Jx16 ET45
5/112
  8D0601025K Z17 Avus silver
Rim set Aluminum 4 pc - Audi 100, S4, 91-94, 1994
https://www.lllparts.co.uk/catalogs/audi/RDW/A4/223/6/601/601060
Edited by Carlston
I would go for a set of 17" look on facebook marketplace
Loads of deals
Loads of deals
The 17" rims also come in the narrower 7J width. Fitted with a 225/45R17 tyre, you would get a more comfortable ride and better rim protection from kerbing damage.
Edited by Carlston
If your top gear was currently pulling 29mph/1,000rpm, then a 3.5% increase in gearing would mean that your top gear was now pulling 30mph/1,000rpm, ie. a 3.5% increase in gearing. Of course this increase in gearing applies to all the gears.
Edited by Carlston
i cant really see 3.5% increase in each gear making much difference to be honest, and i don't drive like loon and i only do 70mph on the motorways there are way to many cameras around now a days, i really don't want to change the wheels that i have already, they look really good and suit the car very well so i much prefer to stick with my 18s to be honest.
cheers kev
There is also a question of insurance it needs to be the correct size that has been approved to fit that vehicle at approval
But thats another minefield
The 17s  drive much smoother
Real world with the 170 TSI DSG 4x4 Superb Estate going along the road you will probably not be aware of any rpm difference.
As far as Insurance and tyres then there are many of us driving on tyres of a size not type approved for the vehicles and that includes emergency service vehicles with blue or green flashing lights.  We might have declared mods though and including oversized tyres.
But your insurance is for you to take responsibility for.
Many folks buy secondhand cars and won't be aware if their car has a non-standard tyre size.
Ultimately, UK insurance is governed by UK courts.
I suspect that any insurance company would have to show that the modification has made a material difference to the risk. This may explain why my insurance company once told me that they were happy for me to change my tyres by one size as long as it didn't increase the performance. Also, it's not uncommon for tyre fitters to fit the next nearest size if they don't have the correct size in stock, without even telling the customer.
I would have thought that it's far worse for a driver to be driving around with faulty brakes, than have one size difference in their tyres. Also, even the same size tyres vary hugely in performance. You can fit the cheapest, worst performing Chinese remoulds on your car and apparently your car is still fully insured.
It's strange how no one from the UK insurance industry clears up all this confusion. Although not long ago, they were encouraging drivers to drive in the snow on summer tyres...or they would increase their premiums if they fitted winter tyres.
Edited by Carlston
