Updating Swing radio software
Yes, I understand, I will also try the option you proposed. If it worked for others, I hope it works for me too.
  • Replies 407
  • Views 93k
  • Yes the update file can be sent to you
  • None 😞
  • Maybe my post do not complies with forum rules and I am so sorry if I'm doing something wrong, but this situation is really serious and against the warranty law: Skoda refuses to fix it, asks for mo
I did this just the other day with my own car, also the error has zero effect on the system.
So if you cannot clear this, then don't worry.
16 hours ago, varooom said:
That has been sent now via PM
Thanks so much. Worked perfectly. The Skoda service dept said no update was available.
Much obliged for your help!
Skoda service 😄 they are getting to be a laughing stock, glad I was able to help where they weren't.
Again, with the help of our colleague varooom, who showed me a very simple solution, I also eliminated this problem.
Many thanks, varooom!!!
Hi, i have problem with sound in apple carplay. Is any new SW firmware for this version Skoda Swing ?
Yes you need 8755 version to cure to noise.  I will send link by PM.
Hello dear colleagues,
could you send me the link to radio software update as well. Currently carplay is not working at all…
car doesn’t see my iphone (ios 16.5 onboard).
thanks in advance
thanks in advance
You can update to 8755 version, but won't know if it fixes error.
Hopefully it will.
Hi @varooom :)
wherr can I find it? Funny thing about carplay, in my wifes car (touran) carplay works correctly…
best regards
Michal
Oh, now I see private message.
tnx. I will inform you about the result.
@varooom thanks again for the update. Unfortunely it didn’t help. Currently carplay in my fabia 3 is dead. I will try to get in contact with apple. As I wrote before, with VW Touran (also usb connection) carplay works just fine…
Hi, do you know if there is any update available for sw train mst2_eu_sk_zr_p0241t?
Yes 0253 version
Buenas varooom me pasaste una actualizacion pero me pone esto
Creo que me pasaste la 0369 y es la 0359 no se si eso tiene algo que ver te paso la foto
Make sure that you are in this screen to make update
https://www.briskoda.net/forums/uploads/monthly_2023_05/IMG_20230518_083443.jpg.5596e6da12657643849150b80daec816.jpg
If that fails still, then make sure you have extracted the update to correct path (where M: = SD Card letter)
BAD!
M:\MST2_EU_SK_ZR_P0369T
GOOD!
M:\
Extraigo el archivo en la sd,pero No se como se hace que me dices de la ruta, no se donde se pone ni nada
Lo de la letra
Ciao a tutti è la orima volta che scrivo qui.
Voelvo capire/sapere se esistono aggiornamenti per il sistema infotainment Swing (su skoda fabia mk3 del 2017).
Chi mi sa aiutare?
Attualmente c'è installato questo:
Chi mi sa aiutare?
One, no update
Two, write in English on forum
Hi varoom, thanks for the reply and sorry for the mistake.
All good 🤝
Thanks for all your help on here Varoom.
Just got my Fabia Monte Carlo and same problem with crackling CarPlay sound.
Would really appreciate it if you could help with the software.
Thank you
Thank you
You will soon have silence, I will PM you link in a few moments.
Amazing.  Thank you!
