Software Update...?
Hi @varooom, thanks for your grate job, now it looks I understand what to do)
I have an issue that I can't become a primary user,  giving error all the time. I'm assuming that update will help. Can you help me with a files for update to latest version, please?
  • Replies 252
  • Views 66.9k
  • I have sent you a new link, they only live for 24hrs. Since you usually sell the firmwares, please don't ask for more... this is not why I send them.  I hope you understand my "spirit"
  • You should already have a private message.   The release is a 2 in 1 package, so it has 2 stages of update.  First takes you to 0308, after it has rebooted and settled, you will be able to l
  • Thank you so much Varooom, I'll update as soon as I can. You are really very kind and helpful, I am truly grateful to you.
A few weeks ago I had same issue, I update OCU from 88 to 143 and no solution.
My dealer, after one week, update the OCU again and It work now.
Hi @vegarz, is this OCU update helps with "primary user "? Then what is OCU, and how to update it? Sorry if I understand you wrong.
That is the Telematic unit, in my superb is the module 75.
SOS call is too in this module.
I read that somebody can login as principal user after do emergency call.
I don't check It.
Ok, I'm gonna try Emergency call (hope it will not a become a problem 😅)
But if doesn't work,  how can I update it?
You need to know what is SW version with OBD
I have OBD adapter. Can you advise how to check, if it's not the one on picture?17256348816252179316816284656028.thumb.jpg.516a223433f5a247dd0c4c1d7a8a9633.jpg
This photo is infotainment SW information. Module 5F
Obdeleven, Carscanner, Carista, Vcds, etc.
75. Emergency Call and Communication Module
VAG Part number: 5WA035284G
Software version: 0143
Just now, vegarz said:
Here there is two SW OCU 141 and 143  https://mega.nz/folder/bupmCaqA#dGb8Y30eDZ3rx95kts3E_A
Try to reinstall the 143.
I can't repair It but my dealer "do the same" (they said) and it work..... by the moment.
Thanks a lot for this info and your patience.
Good afternoon, can anyone share the mib3 0332 update? Thank you
Sorry I don't have the update (the Russian sites seem to be all over it) but if you have the changelog I'd be very glad to see it.
Hi, just been reading through and I have MST2_EU_SK_ZR_P0478T in my 2020 Karoq and i believe there is a P0480T available. Does anyone have the link to this software. Many Thanks Andy
@vegarz
Again I need your help please. I thought that I know how to update, but turned out that it's not true.
I'm extracting 143, then copying two folders in to USB. Connecting, going to developer mode, and then it's showing files inside, even start update, but all of them not active.
What I'm doing wrong?
You simply must select update and press ok.
So as I anderstand update not active becouse version (143) already installed.  Then I tried to update 5F block and it works properly. Only I have an error:  Check software version management.
@vegarz Is there any newer version,  or 143 is the latest?
Sorry  I don't know
Hi to everyone.
Any chance somebody knows if there is any update for block 75 (see attached photo)
Thanks for advance.
Hello,
A friend of mine has a MIB3 with SW 0270 (H22). Just to be sure: I need to update first to MOI3_EU_SKMQB_P30800P_0308 and then to MOI3_EU_SKMQB_P33000P, right? Can I expect any problems after the updates? I found two different version 0330: MOI3_EU_SKMQB_P33000P and MOI3_EU_SKMQB_P33000P_0330 - is there a difference between them or which one is the right one? Thank you.
Yes, the update procedure is correct.
There is only one 330 update.
They must be the same.
After update, the system must work moore fine.
Hello
Can somebody pleas help with OCU update?
I talk do dealer and they says that they must update OCU module. Problem is that i cannot become a primare user…and this update might solve the problem.
Can somebody write procedure for update Please?
Car is 2021 Superb.
Here is my firmware.
please.
Edited by Seba800
Sw 035, it's very old, now is available version 149. You can brick your OCU if you try by yourself.
I suggest going to dealer.
