Front brakes | Rear shocks
Want to change front discs and pads. Looking on euro car parts there are 2 thicknesses of discs - 19mm & 22mm - thicker more expensive - will my calipers/ pads fit either? any tips? thank you. Prob going for the eicher as the cheapest.
Rear shock  absorbers - found Drexel G Force on ebay - £39.95 for 2 - that sound ok? or is there a better option for that price? Any particular tips? Watched a couple of yt vids. Should I  buy the rubber bushes for the top at £10 for 2? - Critical?
Thank you folks
ManufacturerSkodaModelRoomsterYear2008Engine1.9FuelDiesel
minimum thickness 22mm or 19mm?  104440719
Pads - 101440569
for SKODA ROOMSTER 1.4TDI ,1.9TDI 06> REAR SUSPENSION SHOCK ABSORBERS X2 £39.95 for 2
Drexler G Force -
Thank you folks
Pads - 101440569
Drexler G Force -
A 2008 Roomster 1.9TDI has 288x25mm front brake discs according to Jurid on autodoc. It's a TRW brake system. Later Roomsters from around 2011 used an ATE brake system when they were fitted with 288x25mm front brake discs.
Do you have front brake pads with or without a wear indicator? Both types are available.
You can check that you have 288mm front brake discs by measuring them. The only other Roomster size was 256mm, so it's easy to spot the difference.
Front brake discs 288x25mm (for 2008 Roomster 1.9TDI)
8 1J0615301R Brake disc (vented)
D >> - 24.05.2009
288X25 2
8 6R0615301A Brake disc (vented)
D - 25.05.2009>>
288X25 5/100 2
Front brake pads (for 2008 Roomster 1.9TDI)
12 6Q0698151A 1 set of brake pads for
disk brake
  1 PR-1LN+9U0
12 6Q0698151C 1 set: brake pads with
wear indicator for disc
brake
  1 PR-1LN+9U1
https://www.lllparts.co.uk/catalogs/skoda/CZ/RO/481/6/615/615025
D >> - 24.05.2009
288X25 2
D - 25.05.2009>>
288X25 5/100 2
disk brake
  1 PR-1LN+9U0
brake
  1 PR-1LN+9U1
Thank you very much for all this information. The link to the exploded parts looks great. Thank you.
I bought a set of pads for my 2008 TDI and was supplied with the type in the link above (providing the photo is correct) and they were incorrect. It is best to check if the pads fitted to the car have the spring slips on the back.
I am not sure if I would trust a £20 shock but that is up to you. If the shocks have never been touched, I would be tempted with new hardware and bushes, there is nothing worse than finding in the middle of the job that something is too far gone to reuse.
