Cooling Fan Constantly Over Running - Help!!
No parts in erWin.
Hopefully you have a PDF printer available for all of the TPI documents.
If you haven't got this already, try and get a list of your PR codes downloaded, that can match the correct parts for your car.
Edited by varooom
Additional information
Thanks too @varooom
Took a 20 minute drive down the road today with some live data logging.  Coolant temperature at the radiator outlet was rising from the get-go.  Engine Oil temp maxed out at 84.  Coolant temp maxed out at 73.
I would say that the Stat is open all the time?????
Coolant Temp Trip to Stamford 6 Jan 2023.xlsx
On mobile phone, but took a little look.  It does look like it is, but hopefully a few more can chime in.
@varooom
Thanks for your reply.  Sorry to be a numpty but what are TPI documents and what are and where would I locate PR codes?
If you have erWin access, you can view a list of PR codes for your car, this will show you what it left the factory with.
And is very valuable in saying exactly which part to order if there's a choice of 3-4!
TPI documents are technical product information sheets about faults/issues with the vehicle, and the fix needed, very valuable information.
If you're at a PC I could assist you in finding the above (remotely) and then you can "fill" your boots with tech info.
on the laptop at the moment.  would a mobile number help?
I will PM you with some details in second
Last time I used erWin all the docs were available as PDFs already - has this changed?
Nope, just the TPI's are not PDF.
So will show how to download as PDF, then he can fill his boots.
7 hours ago, Junips99 said:
Thanks @DrCorbyLee.
Have purchased a days access to ERWIN.  Do you know if there is a parts listing anywhere on the system?  looking to download as much as possible.
Despite my recommendation never actually used ERWIN so not sure, sorry, but it's possible it does as I assume dealers use it or a similar related system to look up parts for specific cars.  Others have suggested it's possible to download everything in just 1 hour access so a day should give plenty of time to make sure you get every possible document. Best of luck
