Mib 2.5 retrofit
thank you !
i have a Superb 3V 2018 with MIB2 and the GPS is not working - on the Navi i'm somewhere in Poland, near the Baltic Sea, but I am actually in Romania :)
A scan with OBDEleven says "circuit open".
does anyone happen to know how many connections would be from the shark antenna to the main unit? if i check the roof and the back of the main unit, would i find *all* the connectors on the route from front to back? are there any others?
this is my first question, before i try to connect a new antenna and place it somewhere under the dashboard - i'm guessing this is the smallest hassle..
thanks!
3 hours ago, mihairosian said:
thanks!
The GPS is done with a single wire with fakra connectors which plugs from the MIB unit to the shark fin.
  • 5 months later...
@ApertureShey, does all shark fins has gps?
Have non navi superb 11/2018 and consider about retrofit. Atm got bolero ( i guess ) with DAB+ and cantona
Nope, shark fins came in different tech levels,
nothing, gps, gps+gsm and some others
if you want a gps one, I’ve actually just put one up for sale, £20 posted in the U.K. :)
It's nasty job to swap shark right? Can i check somehow which one I have without stripping interior?
If you send your vin i can check, swapping the shark fin involves dropping the back of the headliner, I can do these in about 3 hours but ive done a fair few :)
Sent you dm
  • 3 months later...
On 08/08/2023 at 14:40, Svenk said:
hello. sorry for my question. but from your photos you are running MIB2 columbus navigation unit with MIB2.5 larger glass display?
is this possible - or i need to swap both at same time?
thanks
