MK3? Shocks same as MK2?
Hi all, I have just joined the forum after buying my first Skoda. It is a 2012 Superb estate DSG 4X4. It has done some miles (160k) but was the only one within budget and needs a few bits sorting...
I want to start by replacing the front shocks, someone has an OEM set for sale locally which I think are MK3 and I wonder if they will fit? I have searched the web but haven't got a definite answer using the part numbers in photos.
I look forward to being a member of the forum, looks a lot more sorted than some previous ones I have been a member of!
Thanks in advance.
Welcome.
Sorry no idea, but @Carlstonmight be along and know what is what, and what suits what.
So what engine / gearbox has your car?
That might help anyone looking at the scores on the doors as far as part numbers.
Thanks Toot and apologies. It is a 2.0 TDI elegance estate DSG 4x4. Just interested as they are OEM quality and local. There are so many different VAG part numbers for shocks out there!!
Superb MK3 shock absorbers won't be correct for the Superb MK2 because they use different OEM part numbers.
There are many different shock absorbers on the Superb MK2 depending on the car's build codes.
Have you got a photo of the build code label? This is a white label stuck under the carpet near the spare wheel well.
youtube video showing white label/build code label
skoda parts catalogue
https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/632/4
Edited by Carlston
Thanks in advance.
/cdn-cgi/mirage/782220f56ac0820981fbf9e56bd8af0cd22904a8750d34f8a52256b01f18ace3/1280/https://www.briskoda.net/forums/uploads/monthly_2022_12/Screenshot_20221209-205057.thumb.png.67e2fde80464fbd6581482f24fb40425.png
/cdn-cgi/mirage/782220f56ac0820981fbf9e56bd8af0cd22904a8750d34f8a52256b01f18ace3/1280/https://www.briskoda.net/forums/uploads/monthly_2022_12/Screenshot_20221209-205028.thumb.png.241d937d5952a754ed60d8c043ce9cd3.png
/cdn-cgi/mirage/782220f56ac0820981fbf9e56bd8af0cd22904a8750d34f8a52256b01f18ace3/1280/https://www.briskoda.net/forums/uploads/monthly_2022_12/Screenshot_20221209-205044.thumb.png.e6f329f6cd9ffc2750735bfdb1c0bc0c.png
I've summarised a bunch of information about the rear setup in the thread below which should answer some of your questions. Front end is simpler in terms of the array of options.
If you're doing shocks, it's a good idea to do springs too. Even new parts all around are not mad money, especially if you avoid dealer parts. Plenty of good aftermarket OEM options out there.
Thanks @chimaeravery helpful. I have just been through MOT history and seen that both front springs have failed in the past and one was replaced in 2021 and the other this year. Would have been good practice to replace shocks at the same time and I'm thinking this is why one shock has gone bad.
Thanks @CarlstonI have attached photo of build sticker. It's a bit battered so have taken 2 photos. I notice those shocks have a 2019 manufacture date so almost certainly MK3 OEM.
Thanks @Carlston, much appreciated.
I have a trade account with TPS, who stock / can obtain genuine VAG parts.
They will have access to the Skoda parts database for your specific car and will likely give you the part numbers for the shocks, specific to your particular car, if you ask nicely. Armed with the correct part number you are able to confidently select the correct part from the OEM manufacturer (I believe it is Sachs) either from TPS or via the usual channels.
The LLL parts catalogue link, kindly provided by Carlston above, is very useful but does not link to your specific car, just model range, so it is possible to select the incorrect part, as is the case with Euro Car Parts etc.
As has been said, there are so many variations on shock absorbers and springs for that matter, with different rebound rates depending on your model and all rigorously tested by Skoda before being released. Definitely worth sticking to the shocks and springs intended for your particular model and not using those intended for another model (unless they are the same), even if they fit!
Incidentally, a testament to the quality of Skodas in general is the high mileages they are capable of, as witnessed by many owners on this forum. The problem with shocks and springs is that they have a useful / effective life of about 50 to 60k miles and then start to work outside their original tolerances before failing (leaking or breaking). The knock on effect of this apart from changes to ride / handling is that the suspension geometry is no longer optimal, leading to increased / uneven tyre wear.
