Octavia 2010 diesel VRS auxilary water pump.
Merry Xmas everyone, so recently my trusty octavia stopped on the M5. At 230K miles I thought I'd had my luck with it. After recovery and some advice that the high pressure fuel pump had gone  I did some investigation myself. I found that fuse 24 kept blowing when I turned on the ignition. So I started disconnecting all sensors and actuators to determine the specific fault. Unfortunately one of the last to be disconnected was the auxilary water pump. I noticed that the connector had seen some heat, possibly a short. I could not remove this so had to cut the cable to the auxilary water pump. The car now starts and runs, obviously with the EML on. I have managed to obtain a new auxiliary water pump. However, I'm having some issues obtaining a new connector. Can anyone assist me with obtaining one. I have added some pictures of the connector and the socket.
I believe you're looking for 4H0 973 703; there are a number listed on fleabay.
To confirm you can see the original Skoda part HERE or an aftermarket part with attached leads HERE.
Mike, brilliant. Thanks for your help. I have a feeling there will be another question posted when I have to work out, which wires to go to which pins.
Job for the new year.
You mention the car is a VRS but not which model year. The engine code is also relevant.
Update: I see from the thread title it's a 2010, but the engine code is still relevant.
Edited by MikeTheThinker
Very good point and thanks for the advice.
The engine code is CEGA
So I have received the new water pump and connector that you kindly provided me the details for.
I'm now at the point of soldering in the new wiring. However, I can not determine what colour of the original wiring, goes to the each pin on the pump. (3 wires).
Does anyone have any advice, how I could determine this.
Many thanks.
Strip back and verify the existing wire colours.
Pin 1 = Negative (Brown)
Pin 2 = Positive (Blue & Red)
Pin 3 = Signal (Purple & Red)
AFAIK should be correct if coolant pump two
