trip odometer
My trip odometer reset doesn't seem to be working I press the reset behind the steering wheel but nothing happens? its a normal dashboard and not the digital one
Manual says just a brief press of the button, but may be worth holding for a longer period (if you haven't tried that).
Based on mine, you may need to push it in to reset, and then pull it back out because it rubs on the panel transparency and sticks "in".
They may have changed slightly in the 21 years since your car was made Ken!
Romanian Gypsy, are you trying to reset the odometer while driving? If so it will not allow you to do so, you have to be at a standstill.
I thought you had to hold the button, pressed for a second.
I have a different problem with mine! I have the Virtual Cockpit, and so normally resetting the trip odometer needs a trip into the settings menu... but twice now, it has reset itself! Each time I have only driven around 300 miles since it was last reset, and I haven't noticed any other software updates causing it. But it's annoying as I use it to record my mileage each time I fill up with fuel (luckily I record the total mileage as well so my records are still correct.)
Chris
