2023 280ps L&K replaced 2016 220ps Style
given u have the new 2Q0 A5 Camera - do u have Predictive ACC (pACC) enabled on ur car?
i hear good and bad things about how it works.
  • Replies 84
  • Views 22.6k
  • Yesterday i finished fantastic 3615 km round trip across Sweden and Norway         Thanks to the default speed limit 80 km/h, got numbers which i haven't ever seen be
  • +1 I did the same with mine - got the AliExpress rear boot spoiler.   So far so good and it's still holding strong and not fading.
4 hours ago, JR RS said:
Predictive ACC,
100% right, both :)
good:
 it can be useful for countries with zero speed exceed tolerance,
 crossing fingers Latvia won't be as fast as other countries. +10kmh still ok.
bad:
 i had feeling, like police man controls me all the time,
 not for my taste. currently switched it off.
On 12/03/2023 at 15:06, MartiniB said:
Start-Stop has got additionally to previously annoying
1. Cut Off Engine before full stop.
new, not less annoying, "feature"
2. Engine wakes up, when car in front moves even few cms
2. coded out
Start-Stop prevent Engine start when car in front move
13 Adaptive Cruise Control
            Adaptation
            -> Expanded restart function
                        On       ->         Off
Škoda's Simple Clever transformed to Save cents by add Drawbacks
+1 😞
Rear 12v Socket has been gone
MY23 Mk3.FL
MY16 Mk3
retrofitted Engine Cover 06Q-103-925-L for 2.0 TSI 280ps DNFE
from the factory came without -
Loving the updates on your new 280.
Did they not have to stop putting the engine covers on because they were coming loose and melting causing a fire risk, certainly they were on MkVIII Golf GTI and R - their part number is very slightly different, so perhaps the one with suffix "L" has solved the issue - I believe there was a recall where dealers were told to take the cover off - and bin it!
There's an article here - part number quoted as having the issue was 06Q-103-925-K
https://www.autoevolution.com/news/vw-recalls-golf-gti-and-golf-r-because-the-engine-cover-may-come-loose-and-melt-184792.html
I've actually invested in a Mk7 Golf R engine cover for my 280 - complete with "R" logo - will post a pic when I get a chance.
I really wish our 2016 had a couple of 5v outputs and a what seems to be an 230v inverter output?
^^^ @numskull
USB Type A also is 5v :)
230v is nice to have, but actually haven't use it ever.
for me, 12v + one USB-A is more flexible than two Type-C -
1. lot larger list of devices which can be feed from 12v socket.
2. all of my family's devices have been equipped by Gen10 magnetic connectors,
haven't met any cable with Type-C on the other end
3. haven't tested new Type-C sockets in MY23,
but previous Type-A in MY16 weren't able provide enough power for large phones / tablets,
the battery charged only when device were in standby
what i solved by similar 12v QC3 chargers
1305733470_Hbfc5cc3b5b784336aed24a4d90c69fe3X1.thumb.jpg.10399fc2dc4d5ee3490695cb8b2efa09.jpg
Thanks MartiniB 👍🏻👍🏻
The 230v inverter cannot be fitted to the UK cars as the outlet does not comply with our 3 pin socket specifications.  I assume it isn't worth Skoda's time and expense to fit an outlet that complies with UK regulations.
I've never seen anyone mention that they've retro fitted one to a UK car.
On 20/02/2023 at 21:53, MartiniB said:
Finally i have got feeling of new car, 2023. DCC suspension has zero parasitic sounds.
Honeymoon didn't last so long, less than two months -
looks like, rattle from front bottom comes as standard option 😞
dealer answered, they can't hear anything wrong
another cover has been add under bonnet
€9,38 Battery Cover
Covers r good
added  sound deadening
Wow......that's a lot happening to ur car!!!
How effective is the soft close door addition?
@JR RS
not tested for long, second picture is video
i'm not trailblazer, several other VAGs with same supplement
-> https://www.drive2.ru/l/548080159241011742/
-> https://www.drive2.ru/l/533914051428745659/
-> https://www.drive2.ru/l/625855763499200741/
-> https://www.drive2.ru/l/544268152427511986/
-> https://www.drive2.ru/l/597466648147920028/
-> https://www.drive2.ru/l/543462210404352055/
I forgot some minor details:
previously replaced OEM 8J0 947 409 B single LED Trunk Bulb
found it's new place behind panel above compartment under steering wheel
added Lock Seals 4M0 837 087
Edited by MartiniB
Wow, I have been hesitant to do chassis sound insulation, and now it seems to strengthen my resolve
Hey MartiniB,
I note they’re fitted to some Audi and the ghastly Bentaga (obviously they’re the same lock system as the Superb) but I’m mystified as to what they actually do?
Hi @numskull!
these Audi's / Bentley's parts make Superb drive faster :)
and add finished look
😂 Right, but what’s their real purpose?
BTW… that sound insulation you’ve added is insane
improvement aren't as huge as i waited for,
for unknown reason they ignored adding of ~3mm foam layer
example -> https://www.drive2.com/l/471766905447777004/
anyway sound comfort now are on higher level than A6, E-Class have got from the factory,
little bit behind 5 series
20190930_20190929_Door_Latch_01_before_2_25p.thumb.jpg.6f5305c78f8b9a89c3f5666e423f4e56.jpg  20190930_20190929_Door_Latch_02_afrer_1_25p.thumb.jpg.0b076e7ce816a54a49283cd5b38d50d7.jpg
Ahhhh, so do they reduce the locking sound? If not what’s the purpose?
