Software Update available for Bolero?
1 hour ago, shved said:
Didn't work for me, something is wrong
@Rainesh Was getting TunerDB errors also, so for some no errors, but for others this message.
Fix currently unknown.
  • Replies 769
  • Views 208.5k
  • StripleRider03
    StripleRider03
    I just updated to 1800, I have a Skoda Slavia in India with the Bolero system. I can confirm that the issue with S23 Ultra is finally resolved! Attaching images.
  • radoszczak
    radoszczak
    Cześć, poniżej link do strony z opisem możliwych FW U Ciebie powinno pójść do wersji 742. https://www.drive2.ru/l/650934799095051499/
  • There are these updates, but not sure if the higher number will apply to your system.   MEN3_EU_SK370_P0113P_0469 MEN3_EU_SK370_P2135P_0742   MEN3_EU_SK370_P1185L_1760 ME
hello I have 2020 scala sometimes the screen does not turn on for days I have the bolero 0469 version which version should I update it please help I am writing from Turkey
@Asimozari Check this page, see if your Software Train matches this image.
Software Train
SW: 0469
thanks, I understand that I need to start from 0742 to try, if so, can you send me this update?
my multimedia sometimes doesn't open, the screen stays black, I wonder if I reinstall version 0469 first, will it fix it?
0741/0742...
I will send you some updates to try.
Hello,
I have a problem with my Skoda Kamiq's Bolero infotaintmend. I just bought a Samsung S23 Ultra and it fails to connect to my car. I tried multiple cables to no avail. I also tried multiple versions of Android auto - no dice.
My previous phone - a Samsung S20FE works flawlessly (even wirelessly).
Maybe the software of the infotainment needs an update? I am attaching images with all the versions as I'm not sure what is most important.
The SW Train is: MEN3_EU_SK370_P0113P (also seen in pictures, but I wanted to add it as text to help if someone needs to copy it).
@varooomIs it possible to update to a newer version to maybe solve the problem I have? Someone else posted about a similar issue, but I don't see a response if that worked.
Also,  I took a photo of the Logging section and there are 2 logs. Does that mean that the car's software was updated already at least once?
Thanks in advance.
30 minutes ago, mivanchev said:
Hello,
Thanks in advance.
MEN3_EU_SK370_P9494P = 0464
MEN3_EU_SK370_P0113P = 0469 (current)
I can send you some updates to try and load, won't know if it will make you S23 work, but worth a try.
Thanks, can you send me a couple versions?
I will try to install them and I will let you know if anything works.
Already done 🤝
Hi all,
I recommend this AA wireless adapter for those who can't connect their Samsung galaxy s23.
This actually works really good
This is the link to aliexpress .
I'm not getting any money from it its just a recommendation
Just found this amazing item on AliExpress. Check it out! ₪108.98 50%OFF | Car Wireless Android Auto Box Bluetooth 5.0 USB Charging Intelligent Module Wired To Wireless Android Auto Boxs Wireless Adapter
https://a.aliexpress.com/_EzvcAnn
hello all, could you tell me exactly the procedure to update the mib3 of a skoda fabia?
varooom gave me the firmware but I can't update, it can't find anything on the stick
For the attention of @Rainesh I think I have sent 1760, 1790 & 1798, for them to try.  But none will load (but I have not seen 1540 version before)
Make a folder on the stick. Name the folder for example the name of the 1790 update. Put data and Meta folders in it and then try to update
I’ll try 🤞
19 minutes ago, Tiry said:
I’ll try 🤞
If this helps, in case you lost names
MEN3_EU_SK370_P2345L_1790
MEN3_EU_SK370_P3225L_1798
Hi, please @varooom can you DM me software MEN3_EU_SK370_P3225L or newer if exist with manual? I cannot find update files anywhere
Yes I can send you this, no idea what Software Train you have though.
The only one I would suggest is 0742 to try (it won't load if it's not compatible)
If it doesn't load, then 0469 is your current version and the end of the line.
can anyone send me MEN3_EU_SK370_P2135P_0742
Sure if that is the version you want to load
I have the  0464 and i need to upgrade...
Hello.
 Dear varooom! I have a similar problem. Maybe I can update the software with your help?
15 minutes ago, FaceNot said:
Hello.
Best send an image of what you have installed now, so we can work out the update(s) to send
1 minute ago, FaceNot said:
Thank, I will PM you some files
