2 Bluetooth active in my fabia vrs
Hi all,
Apologies in advance if this has been covered somewhere in the forum :blush
I recently took ownership of my first Skoda Mk2 VRS and really enjoying it thus far! The one quipe I currently have with the car is that I have 2 bluetooth visible (one from the aftermarket RCD330 and another from the what I believe is the original OEM)...I'm keen to disable or remove the OEM bluetooth but can't figure out how to do this, I can't seem to disable it on the car's dashboard or find out where the OEM module is located (checked both under the driver and passenger seats with no luck). Any help/advice is much appreciated!
If you have TPMS this will be disabled if you remove the factory Bluetooth module, just tell your phone to forget it and try to ignore it, tricky with OCD I know, but try.
Mk2 vRS Fabia that do not have optional Bluetooth still have the TPMS.
My android phone keeps showing it up in status even though I've hit the forget...lol
The factory bluetooth module "should" be located under the front passenger seat,
if your happy with the bluetooth on the RCD whatever it is, then simply unplug the factory one.
