Aftermarket headunit for VRS
Hi all,
I have 2015 Octavia Estate VRS. Are there any aftermarket head units available for this car, that will still retain all of the features of the car. I.e still using the multifunctional steering wheel, the multifunctional display/driver info system. With the ability to still change drive modes, with it still coming up on the head unit when changing from eco, normal, sport etc. and all car settings and car info, service status and parking cam and sensors oh and dab radio, assuming it would also work along side the unit in the glove box?
I believe it would fit using a T harness and plug onto OEM can bus if so?
Thank you.
Edited by TheJooooosh
The simple answer is sadly no.
Any aftermarket headunit will loose a lot of the OE functionality and fill your car with a variety of fault codes.
Out of interest, why are you looking to replace it as there may be OE alternatives that could work for you.
I was curious if any existed. I had heard of an alpine unit that worked as an OE would. Ease of being able to fit amp and sub. I have looked into plug and play sound set ups also.
I guess the alpin unit will work but it is as slow as hell...
