High beam assist
Hi folks ... I have a 2020 edition karoq with road sign recognition,  rain sensors etc but don't appear to have high beam assist (although convinced we did!)
Anyone know if and how to check the coding for it? Based in Cornwall.
Many thanks
Mine was the same had it switched on via VCDS don't know what the coding was but had it done by a forum member in Kent
I need to find a local in cornwall :)
What is VCDS?
Thanks but I can't see the map...either that or noone in cornwall 😞
I will take a look..thanks
Had the same situation. Plugged the VCDS, follow the coding procedure and in 5 minutes everything was up and running. Will do the same with the Lane Assist which is currently missing
