Fabia mk1 1.9tdi minimum battery replacement?
Hi I’m trying to find details of the minimum battery replacements for my mk1 fabia 1.9tdi
as I was sold one by europarts , that I believe is not man enough even though there website part tool suggests it’s the one for my car
many thanks
many thanks
The Varta battery finder lists this one for the Fabia MK1 1.9TDI VRS. It has excellent capacity (77Ah) and cold cranking amps (780A).
Varta 577400078
https://www.varta-automotive.com/en-gb/products/varta-silver-dynamic/577-400-078
https://www.ebay.co.uk/itm/272917684700
https://www.tayna.co.uk/car-batteries/varta/e44/
Varta 577400078
Model: 577400078
Capacity: 77Ah
CCA: 780A
Width: 175mm
Length: 278mm
Height: 190mm
Short Code: E44
UK Code: 096
Edited by Carlston
Thanks for the info
europarts have agreed there on line tool was incorrect and have allowed me to buy the the  higher capacity vatara
cheers
  • Sponsor
Well done.
ECP's lookup by reg plate is usually very vague.
For our Fabia if you put the reg in and search brake discs, the suggestions include two different sizes of front disc and one of rear. The car has drums at the back, and only one size fits the front.
So more likely to be wrong than right.:crying:
