2015 280 Low Coolant
Always happens ! Flying to Canaries tomorrow morning just popped out for a coffee and low coolant warning starting car …..
it’s about 8mil below minimum.
Im going to call into Halfrauds on way home for a bottle of coolant to top up anyone confirm what I need ?
All car parking booked so then have to decide if we should call and change reg then go in the Mrs’s i10 … Yuk !
Grrr !
Mmm according to halfrauds online checker it needs G40 !
Going to get the g40 looks like it’s G30 vw spec.
I recently topped mine up. Check the header tank. Mine says G13, so G13 is what I put in.
I was going to post about G12++ /G12 evo and G13, but I am now confused as online search advises different things.
Edited by coppertop
spelling
Thanks guys says G13 on the tank and apparently the Halfords stuff is G13 spec.
Would usually only use Skoda stuff but Sunday and flying in early hours beggars can’t be choosers….
Also notice a very slight white deposit around the header filler…. Could be nothing seems to be sealing ok..
If it's only a slight top up you need then distilled water should be fine, not likely to dilute it significantly. Buys you time to sort properly.
Got the coolant will stick it in and keep an eye on it.
Damn its a coolant leak ….. Not enough to drip onto the drive but the dark patches are coolant all right …. Not going to risk the airport run in it …
 Now at airport …. Taxi was an immaculate Superb L&K with 190k on the clock !
Likely thermostat/water pump housing leaking on front of engine - super common on these engines. Mine was a £700 job to fix inc. parts at my trusted local garage. Skoda quote was over 1K.
I second that @edwards, similar cost for me recently to get the water pump changed following a similar leak, although timing belt changed too whilst they were there.
I've topped my coolant up with a small amount a couple of times in the 6½ years I've owned the car.  I keep a small bottle mixed in the correct ratio in the boot in case I ever need some when I'm away from home.
Enjoy your holiday in the Canaries.  I'm in Tenerife and you've arrived just when the weather has turned a bit cooler and there's not much sun - it's only 22 degrees!
Thanks guys hopefully it’s a warranty job fingers crossed ! Just landed !
The EA888 Engine on the Skoda Superb 280 / 272 is a timing chain not belt. It doesn't need replaced.
The thermostat and water pump in this engine is guaranteed to failed🤣 Even you replace it now, it will still fail again.
Some aftermarket water pump has a better quality.
Edited by elfensin
You guys think this will be covered ?
Maybe if you can get them to admit it is the problem? I was told today after pressure testing and no fault found with a 1-2cm drop in water coolant bottle level after it was topped up 2500 miles ago,  that "these types of engines use water! " having owned petrol TSI since 2015, that is not my experience. I explained to the technician and he agreed it was a common fault. 'Customer to monitor' so I will monitor..... and then will probably have to go back again.
The yanks got a winning class action against VAG on this issue. Very unlikely one would win here and it’d be 2041 before it was settled. Ours went earlier this year and that was a £700 fix.
Ouch 😟
7 hours ago, Nick_H said:
Ouch 😟
Yep, it certainly did, but better than a wrecked engine.
True I’m booked in for Wed so fingers crossed !
Mmmm had to cancel Wed so booked in for next Wed.... Of course coolant level not changed since.... Hopefully its logged the warning somewhere ...
Indeed. Perhaps it was the belt drive to the water pump they were talking about?
