Octavia 3 rear wiper leak from the motor coupling (?)
Today, after a drive through town, I noticed that I had a little liquid in the trunk. Looking more closely, it was the protective cover of the tailgate that was wet. I managed to unscrew the whole cover and the liquid is gushing out next to the plug from the motor - not the white coupling, but the black one attached to the motor.That plug moves as if there is no grip between the 2 parts . Video here: https://imgur.com/B8vnBnT
Liquid flows normally from the wiper and the rear camera, but it also drips quite a lot here while functioning.
Will a new motor be needed?  or is there something that can be done.. Thanks
Common right across the VAG range where there is a rear wiper; Valeo the new Prince of darkness. It doesn’t happen on the Octavia 1U though as these have a sensible separate jet. The one fitted to the second generation A3 (type 8P) is an absolute joke, I am genuinely amazed if I notice one is working and think “it must be new”.
Ok, so the only remedy is a new motor/entire part?
Edited by SwatKat
Afraid so. The accountants overruled the engineers - who knew fine when they designed it the internals would corrode and then leak after 5/6 years.
On 27/11/2023 at 14:40, inspectorman said:
after 5/6 years.
That's optimistic on an A3 type 8P.
Thanks, this weekend did the motor replacement. Expensive like hell!
Disassembled the coupling and the gasket was a bit loose (the spring inside it was the clprit, I guess - so the gasket was not sealing anymore.
Hope for another 6 years :)
On the other hand, the garage had battery tester units, so I found out battery is around 60%. So next spring at the latest I need to replace also this!
Edited by SwatKat
