"Service now ! " message on dash.
I have a 2012 Yeti with 2.0 tdi engine and with 126 000 km on it. I acquired it about two years ago but have only recently started using it regularly. The dash is displaying the message "Service now ! " The last documented oil change was at 100 000 km and in mid-2019.
Does anyone know how I can get rid of the "Service now !" message. ( I won't be taking the car to a dealer or garage as I have always done my own work. )
I am about to do an engine oil ( and oil filter ) change in the next few days.
Will that somehow remove the dash message or do I have to do something else specifically ?
Thanks.
Sounds like it is set on the Variable / Flexible service regime.  30,000 km / 24 months, so needs plugged in to reset.
If set on  Fixed Servicing at the last service, 9,400 miles / 15,000 km , 372 days you could reset from the drivers seat with the settings.
Think you need to [press the trip reset button and turn on ignition whilst pressing!
@FrenchtoneDoes that allow you to Reset the OIl / Service / Inspection Service when it is set for Variable Servicing?
Think so!
OK.
It should't though.
It may be the same as my Roomster but if you reset the 'inspection service' notification do the same as the 'service notification' but have the hazards on as well. It seems strange but it works for me
That's a coincidence ... mine started showing the same thing in the last week or so. First time i can remember it happing in 12 years
@oldstanWhen you reset does it go to 9,400 miles / 372 days because your car is on Fixed Servicing?
post-86161-0-09761700-1445351563.jpg.fa16706805b133d1331b3ff0fd157f44.jpg.90cac1856ad4c16e06044f160e186f7a.jpg
post-86161-0-36120700-1445351597.jpg.f735efbfd01a5d6c1719116e80fbf319.jpg.d7a34e205df99f9ae89d599abf87cdb0.jpg
post-86161-0-10501700-1445351632.jpg.6dc12665f201fc49b920f421eb106844.jpg.62fadfa95c88c832c140d626ae618ea0 (1).jpg
post-86161-0-63865800-1459249072.jpg.8b0d48b8ff75f575b9fd9402822977d1.jpg.80e5c0dbbca681c9198bebd1ab9eca09.jpg
Edited by Rooted
I haven't reset anything.
But I just checked and it's not doing it now.
Goodness knows what the latest electric cars are like now regards complicated settings.  I saw a Youtube of a Landrover Vogue something or other that had been stolen and the palava required to get the keys back working was amazing.     https://www.youtube.com/watch?v=u3LaWY8H860
Edited by oldstan
Thanks everyone. That gives me several things I can try. I will do an engine oil and filter change in the next few days and report back as to whether I have been able to reset the service message from the driver's seat.
Rooted - I think you are right about it being set for Variable servicing as I managed yesterday to speak with the previous owner ( from new ) and he said he always waited for the "Service now ! " message to tell him the service is due.  I looked back at the receipts of the garage that did the work hoping to see evidence that they used the correct "long life" oil ( VW  spec 507 00  I think ) and all I could see was a vague " 10W30 full synthetic " on the receipt. I hope they used the proper oil given that some of the oil change intervals were as much as 26 000 km !
Even for Australia i think you should be using VW504 00 / 507 00 For Fixed or Variable intervals with 5w 30 FS III
On an 11 year old engine i would not use 0w 30 FS III, and no idea why anyone would use 10w 30 FS with a 2.0 TDI.
You are absolutely correct. The invoices did in fact say "5W30". My apologies.
Just reporting back on my findings. A previous vehicle I owned had a "Service" reminder message pop up on the dash at a designated mileage and the only way to remove the message was by connecting to the car's ecu. Hence I imagined the same thing would be needed with the Yeti. But......I changed the oil yesterday and noticed after the first drive, the "Service Now ! " message has disappeared by itself !  I have no idea how the car monitors the service interval under "Variable/Flexible Servicing" but it almost seems like it can directly monitor the oil quality !
As I can't see how to edit my post above...
The "Service Now !"  message is back so it was  just a coincidence it disappeared shortly after the oil change. So it seems there is no oil quality sensor and in fact it makes sense that the Variable Servicing interval is monitored by just an algorithm that keeps track of driving conditions. Ill probably get hold of VCDS to reset the service message.
Hello @red2 To edit a post, click on the 3 dot symbol at the top RH side of your post - you get an option to report, edit or share the post.
Edited by Warrior193
added information
Thanks Warrior193. The strange thing is when I click on that 3 dot symbol, I only get "Report" or "Share" options. No sign of "Edit".
Editing of posts is a privilege of Freedom members.
Thanks @Lee. ( Was about to join anyway for greater access to tech help. )
Edited by red2
