Superb Mk1 Door not opening, and heated seats project
Hi all its been a long time since ive owned a skoda (just over a year) and I recently bought 2 superbs. For tax reasons 2008 is cheaper to tax than any previous year so I found a low mileage 1.9tdi superb mk1 2008 and im transferring bits from my 2005 high spec superb into it. I have a few issues however. (Sorry for such a long post)
The rear right door on my 2008 will not open. The rest of the doors lock/ unlock just fine but this will not open either way - from outside or inside. Ive tried hitting and banging every part inside and out to no avail. Ive tried pulling up the lock silvery part still nothing. Is there any way of getting it open? Also the connectors were unplugged when I looked - so I plugged them in and got my windows working but still no lock. It does beg the question of why were they disconnected however I know it was working in September as it passed our national testing service and would have to have been working for that.
Another issue, more of a question really, I have mint condition half leather heated memory electric seats Im planning on putting in my cloth normal seated superb. Obviously the wires arent there so I have started taking the wires from the loom however Im wondering how far I have to go. Did Skoda make all fuse boxes the same or will I also have to do that part? If anyone knows about this it will probably save me a good few hours.
Hopefully I’ll be able to help some people in this forum some time soon as I now have stripped a superb to the shell almost (will be 100% by the time im done) so I should know a thing or two.
Thanks in advance
  • 4 months later...
Update? Currently working on this topic.."I have mint condition half leather heated memory electric seats Im planning on putting in my cloth normal seated superb. "
Edited by Dylan807
Messed up so put other one
@MilanM Yes thankfully I finished this a while back. It wasnt too hard once you do the first bit. Although the memory part, in my experience is impossible to get working but if you figure out how please tell.
Main issue is getting switched power as the heated seat switches stay on so would kill the battery. Due to the possible draw I made a separate source so I put a relay box under the drivers seat in the foam/ polystyrene box thats under there. I cut a whole in the middle and placed it in there.
Each seat basically needs a power, a ground, and then to have two wires connected to the switch. Also the switch needs power and ground.
Both the seat and switch will need “15” and “30” so i joined these as I was making them all ignition live and the 15 would only be to tell it to turn on/ off.
The switches also want a connection called 58b which is just connecting them to the dimmable lights in the cabin so the switches can light up and you can dim them the same as the lights on your dash. You can tap onto the closest one for these such as the one for the 12v socket in the back or the window heater switch at the front.
For movement of front seats you simply need a power and ground to each seat.
The app “CarminSTD” (weird name I know) has all the required wiring diagrams.
Definitely need to fuse everything properly and find out the correct ratings before you test anything.
Also all my door issues etc were due to rotten connections in those plastic sock-like connectors in the back left and front left footwells.
Feel free to ask any questions
